Heating Control - does not work
Posted: 22 Dec 2021 10:30
by JoLu
a created some schedules in the heating control application for my thermostats in the rooms but all of them have no effect means no action to the deviec are triggered although the active swith is set (see screenshot).
Can you give me some advice what may be wrong in general.
(if I use schedules instead of the heating control they a working but they a not so well-arranged of course)
POPP
Firmware version v3.2.0
UI version v1.13.2
Built date 24-08-2021 23:55:22
Re: Heating Control - does not work
Posted: 22 Dec 2021 11:14
Sure you have thermostats in that room?
Posted: 22 Dec 2021 20:24
by JoLu
Sure there is a thermostat named "Badezimmer" in that room. Also for all other room with thermostats I have the same issue. For none of the the "Heating control" works. So possible I made a general mistake or don't understand the functionality.
Posted: 14 Jan 2022 11:50
by J.nissen
i have the same efekt ( Problem )
Posted: 15 Jan 2022 02:26
Could you please provide access (admin login with temp password), so we can check it
Posted: 18 Jan 2022 09:12
by J.nissen
Heizung 2.png (125.73 KiB) Viewed 10228 times
No Event are Triggered
Thanks for your Help
