Upgrade v2.3.8 to v3.2.2
zuperman
Re: Upgrade v2.3.8 to v3.2.2
Post by zuperman »
That's exactly what I was missing; step by step documentation in an easy to find place.
Perhaps instead of going from v2.3.8 to v3.2.2 I should have done intermittent upgrade steps, but they should be documented. Unless my search skills failed me :).
I only wanted to do the express UI backup import. I did not want to import the smarthome UI backup as my first attempt to upgrade made some quirks in the front end; I had a couple of mailgun scenes, only half of them were showing in the UI after my failed attempt to upgrade. Same for other automation parts. And this resulted in strange behavior ie. getting a movement mail for room A when PIR in room B was triggered. After the failed upgrade there was some mixup in all the components of the automation.
michael.seitz
Post by michael.seitz »
zuperman wrote:
14 Jan 2022 00:08
Now I wanted to SSH into the Pi for a simple reboot and can't login. User = pi, Password = raspberry doesn't seem to be correct?
I tried a couple of possible passwords and found "razberry" working. "z" insted of "sp".
