VS Plugin Issue
Posted: 06 Feb 2022 01:52
I am a Mac user. After initially installing the VS plugin I managed to compile code successfully and upload it to the Z-Uno Gen 2 and everything worked as expected. However, the next day when I restarted VS the plugin initialised ok, but when I try to run any of the plugin command (verify, set frequency, set board etc.) I get the following type of error:
Command 'Z-Uno: Verify' resulted in an error (Cannot read property 'core' of undefined)
Is there any way on the Mac to run the commands from the command line?
Thanks,
Johan
Thanks,
Johan
