Dependency warning
Eckhard
Dependency warning
Post by Eckhard »
Hi all,
I very often get the message
Dependency not found for module: [DEP]::[MODUL] = BaseModule :: MQTT
What should I do to repair this? (The message is shown as written with the brackets.)
Regards, Eckhard
aivs
Re: Dependency warning
Post by aivs »
Hi, remove old MQTT module and install new MQTT Client if necessary.
Eckhard
Post by Eckhard »
Mmh, the new MQTT is not working for me - Error "something went wrong" - that is very helpful :-(
The logs says:
Notification: error (core): An error has occurred while the app was instantiated. Please reload or reinstall the app: MQTT
[2022-05-24 11:10:40.271] [core] (Mobile App Support) send notification: "An error has occurred while the app was instantiated. Please reload or reinstall the app: MQTT"
[2022-05-24 11:10:40.275] [core] (Mobile App Support) send notification: "An error has occurred while the app was instantiated. Please reload or reinstall the app: MQTT"
Does the new MQTT Client support SSL?
alexis92
Post by alexis92 »
SSL is supported as far as I'm aware.
Eckhard
Post by Eckhard »
My mosquitto runs on SSL Port 8883 and uses username and password. I copied the data from the old MQTT app but it is not working. How can I figure out what's wrong in the config?
1) Z-Way logs
2) tcpdump (wirehark)
