3-Speed Fan Switch
JW47
3-Speed Fan Switch
Post by JW47 »
I am using the three-speed Z-wave fan switch shown below.
When adding it to my Aeotec hub, it is recognized as a light dimmer switch, not a fan switch. I've tried all three methods of adding a new device to the hub (scan QR code, scan for new devices, select from list), but when detected it alwasys shows as a light dimmer. Besides being shown as a dimmer, it operates erratically with the fan speed changing as a light dimmer would change brightness. This switch is supposed to provide four distinct speeds (low, medium, high, off) with each press of the switch. I have used a similar switch from GE in the past and it worked correctly.
Can anyone help me to have the switch recognized correctly by my Aeotec hub? Thanks.
