Advice on Upgrading
Posted: 26 Sep 2022 18:19
I've been controlling my central heating (and a few other things) with Z-Wave.me since 2015.
I have the RaZberry PI GPIO Daughter Card - Gen5, and I'm running Z-Way version 2.2.3.
I run a customized version of the Z-Way service, having adapted a couple of the core files to include my own REST interface (WebserverRequestRouter.js and ZAutomationAPIProvider.js) for use with my own Android App.
In addition I run some custom modules that I wrote.
This has worked great for the past 7 years, so I've been reluctant to change anything.
However, I miss the Alexa skill and the new one requires an upgrade of Z-Way version to at least v3.0.3. So, I would like to upgrade.
I have 2 choices:
Option 1. upgrade my existing raspberry pi setup to the latest Z-Way version OR
Option 2. buy a UZB1 and run Z-Way on my home server (Ubuntu based)
If I go with Option 1, is my existing hardware new enough to run the latest version of Z-Way? Are there likely to be any complications?
If I go with Option 2, can I transfer my existing Z-Way license to use with the UZB stick instead of the raspberry pi board? Or will I have to purchase a new license?
Will the UZB stick have better range / performance than my existing raspberry pi board?
For both cases, will I still have access and be able to adapt the files mentioned above? And can I include my custom module in the same way as before?
Any other advice?
Thanks.
I have 2 choices:
Any other advice?
Thanks.
