Z wave linux issue
OmarBr
Z wave linux issue
Post by OmarBr »
So my raspberry is using linux 10 buster and I wnat the jessie to run the system so i can hold up with the process of z wave , any suggestions?
lanbrown
Re: Z wave linux issue
Post by lanbrown »
You don't actually say what software you are running. Linux is an OS. Z-Wave is a protocol. In the middle is an application like Z-Way.
If you are using Z-Way and if you want to run a current version of Z-Way, Jessie is not supported:
https://z-wave.me/z-way/download-z-way/
Raspberry OS Buster and Bullseye are supported. Older versions (Weezy, Jessie and Stretch) should be upgraded first.
OmarBr
Post by OmarBr »
thank you for your help
