S2 timeout
harre
S2 timeout
Post by harre »
I get S2 timeout straight away when trying to add a new device.
Go here for logs:
https://www.dropbox.com/s/28nqfpes5mg0o ... r.log?dl=0
The new node has number 64
Edit: I got it associated with S2 now when I selected to use only S2 inclusion and not S0+S2
New log:
https://www.dropbox.com/s/w3ac3c4qkvyue ... .log2?dl=0
Edit2: It seems to be a intermittent error as I get timeout now again for node 69
Logs:
https://www.dropbox.com/s/dtpa0ji35wso5 ... .log3?dl=0
Re: S2 timeout
[2022-10-19 00:03:04.537] [I] [zway] Job 0x13 (Security S2 KEX Get to node 64): Not delivered to recipient
Only 1.5 s after the inclusion the device is already asleep? Or the connection is weak?
harre
Re: S2 timeout
Post by harre »
It was connected just a few centimetres apart from the station. Signal strength -45
It's a powered device so it shouldn't go to sleep.
Re: S2 timeout
Well, if it is not reachable anymore and it is a mains powered, then it forgot it's ID after reboot. This should be memory problem
