Programming JS Console.log doesn't work
micky1500
Post by micky1500 »
Since ver 4x it doesn't work anymore !
Loglevel is set to '0'
debugPrint has been tried also.
Restarted z-way, Rebooted Pi, Power Cycled. !!
This used to work.
console.log("Alexa M.B. Room=" + vDev.get("location") + " SwitchBinary " + vDev.get("metrics:title"));
Am I missing something ?
Re: Programming JS Console.log doesn't work
It should work. Do you see any lines in the log with [core]? If so, they are all printed with console.log (or debugPrint, which is same).
Maybe in your case one of the two values is null and nothing is printed then (since null + "anything" = null)?
micky1500
Post by micky1500 »
Yes I see 22,000 [core] events. in 48 hours.
I changed it to console.log("Alexa Check"); , so no null's
It still doesn't work, That's when I scan for new devices.
I also checked the Daylight App, It's supposed to log the event times, I have not altered that one, but it still doesn't log the console.log entries.
It all used to work before 4.0.1, not sure if 4.0.0 worked. Definitely worked before.
Are you sure your log-level in config.xml is 0?
micky1500
Post by micky1500 »
Right now with 4.0.2 timestamped 28/04/2020
<log-level>0</log-level>
Same as before 4.0.1 with timestamp of years ago.
I just wondered if it was only me with the issue.
I have a working system, I will do a total rebuild sometime soon.
Thanks for your advice.
It might be due to full SD card or logrotate log rotation
