Latest OS Upgrade but port 8083 is not open / listening
Posted: 18 Jan 2023 20:44
by harveybabes
Hi
My topic "Upgrade Options without breaking Anything!" has the same question so I hope it does not contradict the forum's rules however I am now left with a system which is not working.
I have carefully migrated the files as suggested :
""The easiest would be to make a fresh install of Raspberry OS (Bullseye), copy the /opt/z-way-server folder, /etc/zbw and /etc/init.d/zbw_connect and then run the installation command as described on the site. It will upgrade Z-Way keeping your data""
So when the system upgrade was completed I have tried to go to the localIP:8083 without avail.
I have updated the interfaces as per another thread but it did not help:
"sudo nano /etc/network/interfaces"
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.x.x
gateway 192.168.x.x
netmask 255.255.255.0
All I see a white page with writing such as below with unselectable black icons:
{{_t('nav_apps')}}
{{_t('nav_devices')}}
{{_t('customize')}}
{{_t('nav_myaccess')}}
{{_t('management')}}
{{_t('news')}}
{{_t('my_hubs')}}
{{_t('nav_logout')}}
8084 works but without the correct webinf. The port scanners I use are not picking up 8083.
Please could you help me over the finish line ?(!) thanks
Re: Latest OS Upgrade but port 8083 is not open / listening
Posted: 18 Jan 2023 22:00
by Dan
Am I right, that you have no web interface in 4.0.2?
If yes, try to downdrade to 4.0.1
I have the same issue and that hepled
Posted: 18 Jan 2023 22:10
by Dan
Oh, seems to be no. Looks like you need to clear cache
In Chrome open Developers tools (Ctrl+Shift+I), right clict at page refresh button, "Clear caсhe and ~hard reload"
Posted: 19 Jan 2023 12:12
by harveybabes
Dan wrote: ↑
18 Jan 2023 22:10
Hey Dan
Thanks for your replay - I can't see that helping the port 8083 issue.
I will need to establish what version is within the package at https://z-wave.me/z-way/download-z-way/ once I have copied this troublesome img back onto an SD card.
I will try installing the 4.0.1 deb to see if it fixes the port issue also.
I'll update this thread.
i ran wget -qO - https://storage.z-wave.me/RaspbianInstall | sudo bash once again and clearedall caches from the browsers I use and all is well.
THANKS
Posted: 19 Jan 2023 17:09
by harveybabes
Hi All -
I spoke too soon. I have lost connection after thinking it's best to make an img of the setup and writing that img to the sd card to test it is rebust.
I have down a clean install and followed the same procedure i.e.:
1 - backed up said file and folders
2 - install Bullseye from https://z-wave.me/z-way/download-z-way/
3 - update interfaces config
4 - run wget -qO - https://storage.z-wave.me/RaspbianInstall | sudo bash
now on https://find.z-wave.me/ after clicking the IP address for 'Direct connect to Z-way" it is hanging on "waiting for find.z-wave.me..."
EDIT: I am unable to connect to the UI via the browser using th LAN or WAN IP addresses. Both ports 8083 and 8084 are open. I can connect via SSH
How can it work one moment and then this? If I need to send any log files I would be delighted to!
Any ideas?
TIA
Posted: 19 Jan 2023 23:55
If the port is open and you can't open it, check your firewall settings and that you are in the same network with the Pi.
Posted: 20 Jan 2023 18:01
by harveybabes
#### SOLVED ####
After having many failed attempts of trying the following method:
3 - update interfaces config & backed up files
5 - and trying 3 recent releases using sudo dpkg -i z-way-x.x.x_armhf.deb method
(I know a little about this but am in no way an expert so all was trial and error in the end). I was left with port 8083 closed and only some of my devices visible in the browser UI if it did work randomly. I was ready to give up...
SOLUTION:
1 - install Bullseye img
2 - copy backed up /opt/z-way-server folder, /etc/zbw folder and /etc/init.d/zbw_connect (chown & chgrp) to correct locations
3 - sudo nano /etc/network/interfaces
auto lo
auto eth0
address 192.168.x.x
gateway 192.168.x.x
4 - PKG=z-way-4.0.2_armhf.deb && wget -O /tmp/$PKG https://storage.z-wave.me/z-way-server/$PKG && sudo dpkg -i /tmp/$PKG
Posted: 20 Jan 2023 19:51
by harveybabes
19 Jan 2023 23:55
The firewall is set up correctly/working as intended with my previous img of z-way v2.3.7 and sporadically worked on the v4.0.1 update then port 8083 closed(!) - the ins and outs are beyond me but I have found a solution - the system has been running for 19 hours without any problems so I will take that as a win! Thanks for your advice
