Hi, I can't find out how to upgrade my Raspberry Pi Razberry Zway package. Currently it's v3.2.3, and I notice we now have v4.
What I think I do is:
sudo apt update
sudo wget -q -O - https://storage.z-wave.me/RaspbianInstall | sudo bash
But this really is an initial install.
Is the above correct?
How to upgrade Raspberry Pi ZWAY (v3.23 to v4)
Re: How to upgrade Raspberry Pi ZWAY (v3.23 to v4)
Further to the above, the "update" operation produced the following errors, which are related to z-wave:
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repo.z-wave.me/z-way/raspbian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D5AA8FC24C6547A2
W: Failed to fetch https://repo.z-wave.me/z-way/raspbian/d ... /InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D5AA8FC24C6547A2
Any ideas?
Any ideas?
Further again to the above, after backing up the SD Card I ran the sudo wget command, and it installed "Firmware v4.0.2", according to the Info in Settings in the SmartHome UI. One thing Poltos should note is that I have to keep a copy of the .syscommands file (/opt/z-way-server/automation), because the instal puts a new copy in, and the old one contains 4 lines as:
/usr/bin/python3 /home/pi/Documents/Code_PIR_Action.py
which determine the action to take when a couple of Fibaro Motion/Temperature Detectors are activated (turns heating on, for one thing). I have to put these lines back in .syscommands manually.
So far, everything seems to be running OK, but early days.
One thing, while I have your attention. Where is the Neighbourhood Map gone? In an earlier version of zway, (probably v2), in the Expert UI, there was a Network Map connecting each node to the neighbours that it coulld communicate with. I found that very useful. This is still referred to in the Manual as the Poltorak-Chart, see https://z-wave.me/files/manual/z-way/Z_ ... 0000000000
But it's not shown in the Network menu now.
Looks like you have solved your own issues.
going forward, any outstanding problems, then ask again.
regards
Micky
regards
Micky
Raspi 4 - (Buster - 32 Bit) Zwave Version 4.1.1, Raz 7 Pro, Serial API Version: 07.38
Thanks, and yes, I seemed to have solved it, but only after making certain I could back-track!
I have asked about the Neighbourhood Map on a separate post. The answer was it is now under the Analytics tab, but I don't have that tab. I don't know why. Any suggestions?
You need to be Administrator to see the Analytics Tab.
Settings, User Management ! from the Smarthome login.
Then Expertui will show the tab.
