Network Map
Posted: 17 Feb 2023 19:05
by ScotsDon
There used to be a Network Map available in earlier versions of Zway using the Expert UI on the Raspberry Pi/Razberry setup. Certainly it was there in v2. Where has it gone? The Manual refers to it as a Poltorak-Chart, and it is still mentioned. My Razberry is a few years old now, with:
SDK Version: 6.51.06
Serial API Version: 05.04
Zway is now at version 4.0.2
Re: Network Map
Posted: 17 Feb 2023 20:27
by micky1500
Some stuff has been moved around.
Route Map is now under the Analytics Tab.
Re: Network Map
Posted: 28 Feb 2023 16:15
by ScotsDon
I don't seem to have an Analytics tab. In the Expert UI, I have Home, Control, Device, Configuratuion, Network, Settings, Jobs. I can't see Analytics in any of those either. I have a feeling I looked at this some while back and Analytics is a special tab?
Re: Network Map
Posted: 28 Feb 2023 18:44
by enbemokel
I never had such a problem, maybe its not the admin user?
Re: Network Map
Posted: 28 Feb 2023 23:59
by micky1500
You need to be Administrator to see the Analytics Tab.
Settings, User Management ! from the Smarthome login.
Then Expertui will show the tab.
