Best way to change to Razberry 7?
otverber
Post by otverber »
Hello
I have a Razberry 2 - 5th gen chip ZM5202 running on 4.0.3. The new Razberry 7 is for sale and will give new oportunities.
What is the best sequence for changing controller with minimum hazle?
I intend to reuse the RPI, hence I will not run two rpi's during changeover of controller. I would need to re-include evry node, but maybe salvage automations.
in expert UI it looks like one should put together a new complete rpi + razberry 7 and have them running together before making a swap to the new controller?
Please indicate how the expert UI works, and if its possible to change razberry without changing rpi ?
piet66
Re: Best way to change to Razberry 7?
Post by piet66 »
otverber
Post by otverber »
Thanks a lot!
