sockets is not defined (sockets.tcp)
piet66
Post by piet66 »
Hi PoltoS,
there are increasing reports from users after changing the ZWay version, that MQTT Subscriber breaks with the message 'sockets is not defined'. I have also had this problem with version 4.1.0-27.
What could be the reason, did you remove the sockets function or is there a problem with the upgrade?
I upgraded to 4.1.0 via the UI and sockets was defined.
I upgraded to 4.1.0-27 via wget and sockets was not defined.
Re: sockets is not defined (sockets.tcp)
Please show the terminal output when you start it manually using LD_LIBRARY_PATH=libs ./z-way-server
And please show ls /opt/z-way-server/libs
Any news? Have you checked the z-way-4.1.1-lws16_armhf.deb build?
piet66
Post by piet66 »
I changed back to 4.1.0 and have not the time to temporarily install another version. Perhaps anybody else can do that, who is running one of the other versions?
