Probleme bei der Installation
TS-Tec
Post by TS-Tec »
Hallo,
ich versuche mit
den Z-Way-Server auf einem neuen Image basieren auf Raspbian Lite aufzusetzen.
Das Installations-Script endet mit:
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
[sudo] password for openhabian:
Do you accept Z-Wave.Me licence agreement?
Please read it on Z-Wave.Me web site: http://razberry.z-wave.me/docs/ZWAYEULA.pdf
yes/no: yes
z-way-server new installation
Installing additional libraries
Ign:1 http://repos.azulsystems.com/debian stable InRelease
Hit:2 http://repos.azulsystems.com/debian stable Release
Hit:3 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:4 http://archive.raspberrypi.org/debian stretch InRelease
Hit:6 https://deb.nodesource.com/node_7.x stretch InRelease
Ign:7 https://dl.bintray.com/openhab/apt-repo2 stable InRelease
Hit:8 https://dl.bintray.com/openhab/apt-repo2 stable Release
Reading package lists... Done
Building dependency tree
Reading state information... Done
tzdata is already the newest version (2017c-0+deb9u1).
Suggested packages:
  gawk-doc sharutils-doc bsd-mailx | mailx
The following NEW packages will be installed:
  gawk libc-ares2 libsigsegv2 sharutils
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 848 kB of archives.
After this operation, 3,598 kB of additional disk space will be used.
Get:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libsigsegv2 armhf 2.10-5 [28.4 kB]
Get:2 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf gawk armhf 1:4.1.4+dfsg-1 [508 kB]
Get:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf sharutils armhf 1:4.15.2-2 [236 kB]
Get:4 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian stretch/main armhf libc-ares2 armhf 1.12.0-1+deb9u1 [76.0 kB]
Fetched 848 kB in 0s (1,210 kB/s)
Selecting previously unselected package libsigsegv2:armhf.
(Reading database ... 45800 files and directories currently installed.)
Preparing to unpack .../libsigsegv2_2.10-5_armhf.deb ...
Unpacking libsigsegv2:armhf (2.10-5) ...
Setting up libsigsegv2:armhf (2.10-5) ...
Selecting previously unselected package gawk.
(Reading database ... 45810 files and directories currently installed.)
Preparing to unpack .../gawk_1%3a4.1.4+dfsg-1_armhf.deb ...
Unpacking gawk (1:4.1.4+dfsg-1) ...
Selecting previously unselected package sharutils.
Preparing to unpack .../sharutils_1%3a4.15.2-2_armhf.deb ...
Unpacking sharutils (1:4.15.2-2) ...
Selecting previously unselected package libc-ares2:armhf.
Preparing to unpack .../libc-ares2_1.12.0-1+deb9u1_armhf.deb ...
Unpacking libc-ares2:armhf (1.12.0-1+deb9u1) ...
Processing triggers for install-info (6.3.0.dfsg.1-1+b1) ...
Setting up sharutils (1:4.15.2-2) ...
Setting up gawk (1:4.1.4+dfsg-1) ...
Processing triggers for libc-bin (2.24-11+deb9u1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Setting up libc-ares2:armhf (1.12.0-1+deb9u1) ...
Updating FireMotD available updates count ...
Installing additional libraries for HomeKit
The following additional packages will be installed:
  libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd1 libdbus-1-dev
  libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libdbus-1-dev
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 422 kB of archives.
After this operation, 1,277 kB of additional disk space will be used.
Get:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libavahi-common-dev armhf 0.6.32-2 [62.6 kB]
Get:2 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libdbus-1-dev armhf 1.10.24-0+deb9u1 [200 kB]
Get:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libavahi-client-dev armhf 0.6.32-2 [56.5 kB]
Get:4 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libavahi-compat-libdnssd1 armhf 0.6.32-2 [44.0 kB]
Get:5 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libavahi-compat-libdnssd-dev armhf 0.6.32-2 [58.8 kB]
Fetched 422 kB in 0s (566 kB/s)
Selecting previously unselected package libavahi-common-dev:armhf.
(Reading database ... 46025 files and directories currently installed.)
Preparing to unpack .../libavahi-common-dev_0.6.32-2_armhf.deb ...
Unpacking libavahi-common-dev:armhf (0.6.32-2) ...
Selecting previously unselected package libdbus-1-dev:armhf.
Preparing to unpack .../libdbus-1-dev_1.10.24-0+deb9u1_armhf.deb ...
Unpacking libdbus-1-dev:armhf (1.10.24-0+deb9u1) ...
Selecting previously unselected package libavahi-client-dev:armhf.
Preparing to unpack .../libavahi-client-dev_0.6.32-2_armhf.deb ...
Unpacking libavahi-client-dev:armhf (0.6.32-2) ...
Selecting previously unselected package libavahi-compat-libdnssd1:armhf.
Preparing to unpack .../libavahi-compat-libdnssd1_0.6.32-2_armhf.deb ...
Unpacking libavahi-compat-libdnssd1:armhf (0.6.32-2) ...
Selecting previously unselected package libavahi-compat-libdnssd-dev:armhf.
Preparing to unpack .../libavahi-compat-libdnssd-dev_0.6.32-2_armhf.deb ...
Unpacking libavahi-compat-libdnssd-dev:armhf (0.6.32-2) ...
Setting up libdbus-1-dev:armhf (1.10.24-0+deb9u1) ...
Setting up libavahi-common-dev:armhf (0.6.32-2) ...
Setting up libavahi-client-dev:armhf (0.6.32-2) ...
Setting up libavahi-compat-libdnssd1:armhf (0.6.32-2) ...
Setting up libavahi-compat-libdnssd-dev:armhf (0.6.32-2) ...
Making symlinks to libssl.so
Making symlinks to libcrypto.so
Installing libarchive-dev
Building dependency tree...
  libarchive13 liblzo2-2
Suggested packages:
  lrzip
  libarchive-dev libarchive13 liblzo2-2
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 728 kB of archives.
After this operation, 2,043 kB of additional disk space will be used.
Get:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf liblzo2-2 armhf 2.08-1.2 [47.6 kB]
Get:2 http://mirror.de.leaseweb.net/raspbian/raspbian stretch/main armhf libarchive13 armhf 3.2.2-2 [254 kB]
Get:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian stretch/main armhf libarchive-dev armhf 3.2.2-2 [427 kB]
Fetched 728 kB in 0s (1,469 kB/s)
Selecting previously unselected package liblzo2-2:armhf.
(Reading database ... 46116 files and directories currently installed.)
Preparing to unpack .../liblzo2-2_2.08-1.2_armhf.deb ...
Unpacking liblzo2-2:armhf (2.08-1.2) ...
Selecting previously unselected package libarchive13:armhf.
Preparing to unpack .../libarchive13_3.2.2-2_armhf.deb ...
Unpacking libarchive13:armhf (3.2.2-2) ...
Selecting previously unselected package libarchive-dev:armhf.
Preparing to unpack .../libarchive-dev_3.2.2-2_armhf.deb ...
Unpacking libarchive-dev:armhf (3.2.2-2) ...
Setting up liblzo2-2:armhf (2.08-1.2) ...
Setting up libarchive13:armhf (3.2.2-2) ...
Setting up libarchive-dev:armhf (3.2.2-2) ...
Making link to libarchive.so.12
Getting Z-Way for Raspberry Pi and installing
--2018-02-15 17:06:05--  http://razberry.z-wave.me/z-way-server/z-way-server-RaspberryPiXTools-v2.3.6.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 19893339 (19M) [application/x-gzip]
Saving to: ‘/tmp/z-way-server-RaspberryPiXTools-v2.3.6.tgz’
z-way-server-RaspberryPiXTools-v2. 100%[================================================================>]  18.97M  2.47MB/s    in 11s
2018-02-15 17:06:16 (1.65 MB/s) - ‘/tmp/z-way-server-RaspberryPiXTools-v2.3.6.tgz’ saved [19893339/19893339]
Extracting new z-way-server
New version z-way-server installed
Creating Z-Way startup script
Adding z-way-server to autostart
Getting Webif for Raspberry Pi and installing
--2018-02-15 17:06:23--  http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 412185 (403K) [application/x-gzip]
Saving to: ‘STDOUT’
-                                  100%[================================================================>] 402.52K  1022KB/s    in 0.4s
2018-02-15 17:06:23 (1022 KB/s) - written to stdout [412185/412185]
First install, getting Remote ID
--2018-02-15 17:06:24--  http://find.zwave.me/zbw_new_user
Resolving find.zwave.me (find.zwave.me)... 46.20.244.72, 185.25.224.24, 78.46.43.211
Connecting to find.zwave.me (find.zwave.me)|46.20.244.72|:80... connected.
Length: unspecified [application/octet-stream]
Saving to: ‘/tmp/zbw_connect_setup.run’
/tmp/zbw_connect_setup.run             [ <=>                                                             ]   6.10K  --.-KB/s    in 0s
2018-02-15 17:06:24 (75.8 MB/s) - ‘/tmp/zbw_connect_setup.run’ saved [6244]
Do you want to enable the remote support(y/n)? Remote support NOT enabled
Now you can run zbw_connect with /etc/init.d/zbw_connect start
or simply reboot your system
Your user id: XXXX (geändert)
Your password: XXXX (geändert)
[ ok ] Starting zbw_connect (via systemctl): zbw_connect.service.
/tmp/zbw_autosetup: line 15: insserv: command not found
Getting webserver mongoose for Webif
--2018-02-15 17:06:35--  http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: ‘/tmp/mongoose.pkg.rPi.tgz’
mongoose.pkg.rPi.tgz               100%[================================================================>]  43.70K  --.-KB/s    in 0.05s
2018-02-15 17:06:35 (819 KB/s) - ‘/tmp/mongoose.pkg.rPi.tgz’ saved [44749/44749]
Adding mongoose to autostart
Start mongoose http server
[ ok ] Starting mongoose (via systemctl): mongoose.service.
Raspberry Pi 3 Detected. Disabling Bluetooth
Removed /etc/systemd/system/multi-user.target.wants/hciuart.service.
Adding 'dtoverlay=pi3-miniuart-bt' to /boot/config.txt
!!! Update Raspberry Pi 3 Firmware for stability work with commands:
sudo apt-get install rpi-update
sudo rpi-update
ls: cannot access 'config/zddx/*.xml': No such file or directory
Usage: ./z-cfg-update <filename>
diff: /etc/inittab: No such file or directory
diff: /tmp/zway_install_inittab: No such file or directory
Preparing AMA0 interface:
 removing 'console=ttyAMA0,115200' and 'kgdboc=ttyAMA0,115200 and 'console=serial0,115200' from kernel command line (/boot/cmdline.txt)
 removing '*:*:respawn:/sbin/getty ttyAMA0' from /etc/inittab
mv: cannot stat '/tmp/zway_install_inittab': No such file or directory
AMA0 interface reconfigured, please restart Raspberry
Do you want to receive emails with news about RaZberry project?
! Please subscribe again if you did it before 30.03.2013
yes/no: no
Thank you for using RaZberry!
Scheinbar können jedoch die Configurationsfiles nicht angelegt werden und ich sehe im Web Interface die im Anhang gezeigte Darstellung, wobei kein Link funktionsfähig ist...
Was kann ich tun?
Danke für den Support!!!
Ohne Titel.jpeg (140.44 KiB) Viewed 7258 times
Bastldd
Re: Probleme bei der Installation
Post by Bastldd »
Klingt als hättest die neue Version von Raspian genommen. Da musst du noch etwas nachinstallieren, damit es funktioniert.
Schau Mal hier:
viewtopic.php?f=3417&t=26138
Vg
ellen123
Post by ellen123 »
