z-way-server startet nicht
flo
Post by flo »
Hallo,
ich weiß gerade nicht mehr weiter.
Am 5. 12. habe ich apt Updates ausgeführt.
Start-Date: 2021-12-05  11:34:44
Commandline: /usr/bin/apt-get -y -o Dpkg::Options::=--force-confdef -o Dpkg::Options::=--force-confold upgrade --with-new-pkgs
Requested-By: flo (1001)
Upgrade: libraspberrypi-bin:armhf (1:1.20211029-1~buster, 1:1.20211118~buster-1), libraspberrypi-dev:armhf (1:1.20211029-1~buster, 1:1.20211118~buster-1), libraspberrypi-doc:armhf (1:1.20211029-1~buster, 1:1.20211118~buster-1), linux-libc-dev:armhf (1:1.20211029-1~buster, 1:1.20211118~buster-1), libicu63:armhf (63.1-6+deb10u1, 63.1-6+deb10u2), rpi-eeprom:armhf (12.15-1~buster, 13.1-1~buster), z-way-server:armhf (3.2.0, 3.2.2), raspberrypi-kernel:armhf (1:1.20211029-1~buster, 1:1.20211118~buster-1), raspberrypi-bootloader:armhf (1:1.20211029-1~buster, 1:1.20211118~buster-1), raspberrypi-kernel-headers:armhf (1:1.20211029-1~buster, 1:1.20211118~buster-1), libraspberrypi0:armhf (1:1.20211029-1~buster, 1:1.20211118~buster-1)
End-Date: 2021-12-05  11:54:53
Seitdem startet der z-way-server nicht mehr und Port 8083 ist nicht mehr erreichbar.
Ich habe danach noch Firmware-Updates machen können, aber das hat auch nicht geholfen.
Im Log steht nur das:
[2021-12-05 12:00:56.416] [I] [zway] Job 0x13 (Battery Get): Not delivered to recipient
[2021-12-05 12:00:56.417] [I] [zway] Job 0x13 (Battery Get): Removing job due to too much retransmitions
[2021-12-05 12:00:56.417] [D] [zway] SETDATA devices.22.data.failureCount = 5 (0x00000005)
[2021-12-05 12:00:56.417] [D] [zway] SETDATA devices.22.data.lastSendInternal = **********
[2021-12-05 12:00:56.417] [D] [zway] Job 0x13 (Battery Get): fail
[2021-12-05 12:00:56.417] [I] [zway] Removing job: Battery Get
[2021-12-05 12:01:04.972] [D] [zway] Job 0x13: deleted from queue
[2021-12-05 12:01:18.843] [D] [zway] Job 0x13: deleted from queue
[2021-12-05 12:05:34.915] [I] [core] Executing script: exit()
[2021-12-05 12:05:35.531] [D] [zway] Worker thread exit point
[2021-12-05 12:05:35.604] [D] [zway] Worker thread successfully finished
[2021-12-05 12:05:35.629] [I] [zway] Saving configuration data to config/zddx/e8a9b71e-DevicesData.xml
12:11 wurde der Pi neu gestartet und seitdem geht gar nichts mehr.
Ich habe schon versucht:
- Neustart
- vom Strom trennen und erneut versuchen
- Neuinstallation vom z-way-server ohne und mit Wiederherstellung der Konfigurationsdateien
Weiß da jemand weiter?
Grüße
Florian
neutrino
Re: z-way-server startet nicht
Post by neutrino »
Vermutlich ist dein Debian noch auf Stretch. Upgrade auf Buster dann gehts wieder
piet66
Post by piet66 »
Deine Art des Upgrades kenne ich gar nicht.
Unter 3.2.2 startet ZWay evtl nicht, wenn ein Workaround fehlt. Sieh mal hier:
https://forum.z-wave.me/viewtopic.php?p=93596#p93596
Z-Way version v3.2.3 from 2022-04-06 04:56:23 +0300
flo
Post by flo »
Das Update wurde automatisch durch Ansible durchgeführt, das hängt noch ein paar Parameter an, damit keine nervigen Rückfragen kommen.
Das System war schon länger auf Buster, daran lag es nicht. Mit dem Workaround zu libmosquitto.so funktioniert jetzt alles wieder. Danke.
