не работает UZB1 + razberry
Posted: 21 Dec 2014 02:18
UZB1 точно живой, проверял с Indigo6 - видит устройство без проблем.
Решил попробовать razberry, запустил на B+ модели ПО, но не работает с UZB1.
На raspberry USB порты опять-же точно рабочие, WiFi адаптер и клавиатура работают без проблем.
Linux raspberrypi 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l GNU/Linux
[2014-12-20 22:44:48.012] [D] [zway] Opened device: /dev/ttyAMA0
[2014-12-20 22:44:48.013] [D] [zway] Worker thread successfully created
[2014-12-20 22:44:48.015] [D] [zway] Worker thread entry point
[2014-12-20 22:44:48.025] [zway] Adding job: Get controller info and supported function classes
[2014-12-20 22:44:48.025] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-20 22:44:48.230] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-20 22:44:48.230] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-20 22:44:48.434] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-20 22:44:48.435] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-12-20 22:44:48.638] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-12-20 22:44:48.638] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2014-12-20 22:44:48.639] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2014-12-20 22:44:48.639] [C] [zway] Get Serial API Capabilities returned zero.
[2014-12-20 22:44:48.640] [zway] Removing job: Get controller info and supported function classes
[2014-12-20 22:44:48.650] [D] [zway] Worker thread exit point
[2014-12-20 22:44:48.650] [D] [zway] Worker thread successfully finished
[2014-12-20 22:44:48.670] [core] Notification: critical (z-wave): Can not start Z-Wave binding: Error: Bad data - communication failed
[2014-12-20 22:44:54.888] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
