Repository key change
hubert
Post by hubert »
Can you post some official confirmation that this new key for your raspbian package repository is legit please?
The key is available from keyserver.ubuntu.com but without any mention on your site I can't tell if it's legit or your repo got hacked
Err:5 https://repo.z-wave.me/z-way/raspbian buster InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D5AA8FC24C6547A2
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repo.z-wave.me/z-way/raspbian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D5AA8FC24C6547A2
W: Failed to fetch https://repo.z-wave.me/z-way/raspbian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D5AA8FC24C6547A2
Re: Repository key change
Hello!
Yes, the old key has expired and the new one is available from the key server. You can use the following script to update it:
https://storage.z-wave.me/RaspbianInstall (this is the script you used to download Z-Way)
hubert
Post by hubert »
# apt-key adv --keyserver keyserver.ubuntu.com --recv-keys D5AA8FC24C6547A2
also works
xurg
Post by xurg »
PoltoS wrote:
25 Jul 2022 16:24
Is there a reason why https://repo.z-wave.me/z-way/raspbian/p ... _armhf.deb apparently got at least touched along the way? It has a timestamp of July 20th but it has been released for quite a while longer now. (I do not have saved the old .deb so I can cmp its contents.) A simple key exchange should not have affected the pool contents. Sorry for being paranoid, and I know no serious hacker would leave a silly timestamp like this, but I really think you should be extra transparent with all of your activities these days.
RaZberry ZW0500 1024/2 SDK: 6.82.01 API: 05.39
Z-Way version v4.1.0
We have re-uploaded all .deb packages with fixed dependencies. The code was not re-compiled, just .deb dependency altered. All this to allow arm 64 installations. Soon we will release the new script that will allow both arm 32 and 64 bits installations.
judge
Post by judge »
The key seems to have expired on 16/07/2025. See https://keyserver.ubuntu.com/pks/lookup ... n&op=index. Will it be updated soon?
Atomic
Post by Atomic »
judge wrote:
02 Aug 2025 13:11
Don't expect it. As I read in the announcement, Z-Wave.me will be closing down soon...
NorthLuc
Post by NorthLuc »
Repository still not work properly. I was forced to install version 5.0.2 from trident ((
I think create an complete image of razberry based on actual version of debian (bookworm) is good idea, this will most likely be the last image.
i wann't use trident's version of zway until they hard works on it.
PoltoS, are you working with the Trident team on the further development of zway?
harre
Post by harre »
The key should be updated so the last 4.1.4 version could be verified.
I have just disabled the source on my raspberry pi as no newer versions will come out anyway.
NorthLuc
Post by NorthLuc »
The repository key is working normally!
