Fibaro FGD-211 Sceneactivation
Tompa
Post by Tompa »
How can i get sceneactivation to work?
[2013-09-27 21:05:13.174] Got frame from device 5 to controller, but command class 0x2b for device is not registered - instantiating it as not supported
[2013-09-27 21:05:13.175] SETDATA devices.5.instances.0.commandClasses.43.data = Empty
[2013-09-27 21:05:13.176] SETDATA devices.5.instances.0.commandClasses.43.data.version = Empty
[2013-09-27 21:05:13.177] SETDATA devices.5.instances.0.commandClasses.43.data.version = 1 (0x00000001)
[2013-09-27 21:05:13.178] SETDATA devices.5.instances.0.commandClasses.43.data.security = Empty
[2013-09-27 21:05:13.179] SETDATA devices.5.instances.0.commandClasses.43.data.security = False
[2013-09-27 21:05:13.181] SETDATA devices.5.instances.0.commandClasses.43.data.interviewDone = Empty
[2013-09-27 21:05:13.182] SETDATA devices.5.instances.0.commandClasses.43.data.interviewCounter = Empty
[2013-09-27 21:05:13.183] SETDATA devices.5.instances.0.commandClasses.43.data.interviewDone = False
[2013-09-27 21:05:13.184] SETDATA devices.5.instances.0.commandClasses.43.data.interviewCounter = 10 (0x0000000a)
[2013-09-27 21:05:13.184] SETDATA devices.5.instances.0.commandClasses.43.data.currentScene = Empty
[2013-09-27 21:05:13.185] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2013-09-27 21:05:13.186] SETDATA devices.5.instances.0.commandClasses.43.data.currentScene = 24 (0x00000018)
The last line shows the sceneID. You just need to bind to that dataholder.
Tompa
The problem is the first line
Post by Tompa »
The problem is the first line in my log.
Got frame from device 5 to controller, but command class 0x2b for device is not registered - instantiating it as not supported.
After that when i press the switch nothing happens i get no more lines i my logfile.
This line just means that
This line just means that this command class is controller and is not supported.
Tompa
I have located the problem.
Post by Tompa »
using the following code in automation/main.js
zway.devices[5].instances[0].SceneActivation.data.currentScene.bind(function() {
if (this.value == 26) {
zway.devices[3].SwitchMultilevel.Set(0);
I get the this error in Z-Way.log:
result: Error: Uncaught TypeError: Cannot read property 'data' of undefined
this is because everytime i start Z-Way server executing the following url http://zpi:8083/ZWaveAPI/Run/devices[5] ... asses[0x2b] returns null.
After i press a button on the switch connected to the FGD-211 executing the same url returns
"supported": false,
"name": "SceneActivation",
"data": {
"name": "devices.5.instances.0.commandClasses.43.data",
"type": "NoneType",
"value": null,
"updateTime": 1380975824,
"invalidateTime": 1380975823,
"version": {
"name": "version",
"type": "int",
"value": 1,
"security": {
"name": "security",
"type": "bool",
"value": false,
"interviewDone": {
"name": "interviewDone",
"type": "bool",
"value": false,
"interviewCounter": {
"name": "interviewCounter",
"type": "int",
"value": 10,
"currentScene": {
"name": "currentScene",
"type": "int",
"value": 26,
"id": 43
On restart there is no zway.devices[5].instances[0].SceneActivation.data.currentScene to bind to.
Any ideas how to solve this?
You can use global bind
You can use global bind function to trap creation of new CCs (SceneActivation) and bind to it's data inthere.
