RaZberry locks up including Cooper Aspire switch
scotts
Post by scotts »
I just bought a RaZberry and installed it with software version v1.4.1-rc1 on my pi. I included my first Z-Wave node, a Cooper Aspire RF (RF9518), and the RaZberry locked up during the interview process. The z-wave-server process is stuck at 99% CPU on the pi. The /var/log/Z-Way.log is filling rapidly with this message over and over:
Job 0x13 (Association Get): removing duplicate
I watched the interview process with a Zensys Ziffer (I did Z-Wave development for a company a few years ago) and the RaZberry locked up after the Association Groupings Get/Report exchange. The Cooper switch reported 255 groups supported (85 06 FF).
I then tried to include a lamp module, an Intermatic HA03, and its interview completed just fine. It looks like the RaZberry is having a problem handling the Association class (133) during the interview with the Cooper switch. I did not see an Association Groupings Get request with the Intermatic since the Node Info did not report support for the Association class.
I tried several times and the lock up is 100% reproducible with the Cooper Aspire.
The lines just before the flood of "removing duplicate" messages are shown below.
Thanks,
Scott
[2013-12-09 18:59:18.660] Adding job: Association Get
[2013-12-09 18:59:18.660] SETDATA devices.2.instances.0.commandClasses.133.data.255 = Empty
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.max = Empty
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.max = 0 (0x00000000)
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.nodes = Empty
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.nodes = byte[0]
( zero-length buffer )
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.nodesToFollow = Empty
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.nodesToFollow = byte[0]
[2013-12-09 18:59:18.662] Adding job: Association Get
[2013-12-09 18:59:18.662] SETDATA devices.2.instances.0.commandClasses.133.data.0 = Empty
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.max = Empty
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.max = 0 (0x00000000)
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.nodes = Empty
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.nodes = byte[0]
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.nodesToFollow = Empty
[2013-12-09 18:59:18.664] SETDATA devices.2.instances.0.commandClasses.133.data.0.nodesToFollow = byte[0]
[2013-12-09 18:59:18.664] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.665] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.666] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.667] Job 0x13 (Association Get): removing duplicate
scotts
Complete Log
Post by scotts »
Yes, it looks like a bounds checking bug during the iteration of the group associations. This also happens if I do a GroupingsGet from the Expert commands menu. The Razberry will always fall into this infinite loop with any Aspire switch.
Complete log of inclusion: http://pastebin.com/fFLCZatW
BTW - Nice work on Z-Way. It looks like a really well thought out architecture.
Thanks!
Scott
scotts
Complete log
Post by scotts »
Complete log of inclusion below.
Thanks!
Scott
[2013-12-09 18:59:02.129] Executing script: zway.controller.AddNodeToNetwork(1)
[2013-12-09 18:59:02.130] Adding job: Add/re-include node to network
[2013-12-09 18:59:02.135] SENDING (cb 0x05): ( 01 05 00 4A C1 05 74 )
[2013-12-09 18:59:02.146] RECEIVED ACK
[2013-12-09 18:59:02.156] RECEIVED: ( 01 07 00 4A 05 01 00 00 B6 )
[2013-12-09 18:59:02.156] SENT ACK
[2013-12-09 18:59:02.157] SETDATA controller.data.lastIncludedDevice = Empty
[2013-12-09 18:59:02.157] SETDATA controller.data.lastExcludedDevice = Empty
[2013-12-09 18:59:02.157] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2013-12-09 18:59:02.157] SETDATA controller.data.controllerState = 1 (0x00000001)
[2013-12-09 18:59:10.744] RECEIVED: ( 01 07 00 4A 05 02 00 00 B5 )
[2013-12-09 18:59:10.744] SENT ACK
[2013-12-09 18:59:10.744] Job 0x4a (Add/re-include node to network): Node found: #0
[2013-12-09 18:59:10.745] SETDATA controller.data.controllerState = 2 (0x00000002)
[2013-12-09 18:59:10.855] RECEIVED: ( 01 19 00 4A 05 03 02 12 04 10 01 25 27 28 75 86 70 71 85 77 2B 2C 72 73 82 87 86 )
[2013-12-09 18:59:10.856] SENT ACK
[2013-12-09 18:59:10.856] Job 0x4a (Add/re-include node to network): Adding slave: #2
[2013-12-09 18:59:10.856] SETDATA controller.data.controllerState = 3 (0x00000003)
[2013-12-09 18:59:10.856] SETDATA controller.data.lastIncludedDevice = 2 (0x00000002)
[2013-12-09 18:59:10.856] SETDATA devices.2.data = Empty
[2013-12-09 18:59:10.857] SETDATA devices.2.instances.0.data = Empty
[2013-12-09 18:59:10.857] SETDATA devices.2.instances.0.data.dynamic = Empty
[2013-12-09 18:59:10.857] SETDATA devices.2.instances.0.data.dynamic = False
[2013-12-09 18:59:10.857] SETDATA devices.2.instances.0.data.genericType = Empty
[2013-12-09 18:59:10.857] SETDATA devices.2.instances.0.data.genericType = 0 (0x00000000)
[2013-12-09 18:59:10.857] SETDATA devices.2.instances.0.data.specificType = Empty
[2013-12-09 18:59:10.858] SETDATA devices.2.instances.0.data.specificType = 0 (0x00000000)
[2013-12-09 18:59:10.858] SETDATA devices.2.data.basicType = Empty
[2013-12-09 18:59:10.858] SETDATA devices.2.data.genericType = Empty
[2013-12-09 18:59:10.858] SETDATA devices.2.data.specificType = Empty
[2013-12-09 18:59:10.858] SETDATA devices.2.data.infoProtocolSpecific = Empty
[2013-12-09 18:59:10.858] SETDATA devices.2.data.deviceTypeString = Empty
[2013-12-09 18:59:10.859] SETDATA devices.2.data.isVirtual = Empty
[2013-12-09 18:59:10.859] SETDATA devices.2.data.isListening = Empty
[2013-12-09 18:59:10.859] SETDATA devices.2.data.isRouting = Empty
[2013-12-09 18:59:10.859] SETDATA devices.2.data.isAwake = Empty
[2013-12-09 18:59:10.859] SETDATA devices.2.data.optional = Empty
[2013-12-09 18:59:10.860] SETDATA devices.2.data.isFailed = Empty
[2013-12-09 18:59:10.860] SETDATA devices.2.data.beam = Empty
[2013-12-09 18:59:10.860] SETDATA devices.2.data.sensor250 = Empty
[2013-12-09 18:59:10.860] SETDATA devices.2.data.sensor1000 = Empty
[2013-12-09 18:59:10.860] SETDATA devices.2.data.neighbours = Empty
[2013-12-09 18:59:10.860] SETDATA devices.2.data.manufacturerId = Empty
[2013-12-09 18:59:10.861] SETDATA devices.2.data.vendorString = Empty
[2013-12-09 18:59:10.861] SETDATA devices.2.data.manufacturerProductType = Empty
[2013-12-09 18:59:10.861] SETDATA devices.2.data.manufacturerProductId = Empty
[2013-12-09 18:59:10.861] SETDATA devices.2.data.ZWLib = Empty
[2013-12-09 18:59:10.861] SETDATA devices.2.data.ZWProtocolMajor = Empty
[2013-12-09 18:59:10.861] SETDATA devices.2.data.ZWProtocolMinor = Empty
[2013-12-09 18:59:10.861] SETDATA devices.2.data.SDK = Empty
[2013-12-09 18:59:10.862] SETDATA devices.2.data.applicationMajor = Empty
[2013-12-09 18:59:10.862] SETDATA devices.2.data.applicationMinor = Empty
[2013-12-09 18:59:10.862] SETDATA devices.2.data.nodeInfoFrame = Empty
[2013-12-09 18:59:10.862] SETDATA devices.2.data.ZDDXMLFile = Empty
[2013-12-09 18:59:10.862] SETDATA devices.2.data.lastSend = Empty
[2013-12-09 18:59:10.862] SETDATA devices.2.data.lastNonceGet = Empty
[2013-12-09 18:59:10.863] SETDATA devices.2.data.lastReceived = Empty
[2013-12-09 18:59:10.863] SETDATA devices.2.data.failureCount = Empty
[2013-12-09 18:59:10.863] SETDATA devices.2.data.keepAwake = Empty
[2013-12-09 18:59:10.863] SETDATA devices.2.data.countSuccess = Empty
[2013-12-09 18:59:10.863] SETDATA devices.2.data.countFailed = Empty
[2013-12-09 18:59:10.863] SETDATA devices.2.data.queueLength = Empty
[2013-12-09 18:59:10.863] SETDATA devices.2.data.lastPacketInfo = Empty
[2013-12-09 18:59:10.864] SETDATA devices.2.data.lastPacketInfo.deliveryTime = Empty
[2013-12-09 18:59:10.864] SETDATA devices.2.data.lastPacketInfo.delivered = Empty
[2013-12-09 18:59:10.864] SETDATA devices.2.data.lastPacketInfo.packetLength = Empty
[2013-12-09 18:59:10.864] SETDATA devices.2.data.basicType = 0 (0x00000000)
[2013-12-09 18:59:10.864] SETDATA devices.2.data.genericType = 0 (0x00000000)
[2013-12-09 18:59:10.864] SETDATA devices.2.data.specificType = 0 (0x00000000)
[2013-12-09 18:59:10.864] SETDATA devices.2.data.infoProtocolSpecific = 0 (0x00000000)
[2013-12-09 18:59:10.864] SETDATA devices.2.data.deviceTypeString = ""
[2013-12-09 18:59:10.865] SETDATA devices.2.data.isVirtual = False
[2013-12-09 18:59:10.865] SETDATA devices.2.data.isListening = True
[2013-12-09 18:59:10.865] SETDATA devices.2.data.isRouting = False
[2013-12-09 18:59:10.865] SETDATA devices.2.data.isAwake = False
[2013-12-09 18:59:10.865] SETDATA devices.2.data.optional = False
[2013-12-09 18:59:10.865] SETDATA devices.2.data.isFailed = False
[2013-12-09 18:59:10.865] SETDATA devices.2.data.beam = False
[2013-12-09 18:59:10.866] SETDATA devices.2.data.sensor250 = False
[2013-12-09 18:59:10.866] SETDATA devices.2.data.sensor1000 = False
[2013-12-09 18:59:10.866] SETDATA devices.2.data.neighbours = Empty
[2013-12-09 18:59:10.866] SETDATA devices.2.data.manufacturerId = 0 (0x00000000)
[2013-12-09 18:59:10.866] SETDATA devices.2.data.manufacturerProductType = 0 (0x00000000)
[2013-12-09 18:59:10.866] SETDATA devices.2.data.manufacturerProductId = 0 (0x00000000)
[2013-12-09 18:59:10.866] SETDATA devices.2.data.applicationMajor = 0 (0x00000000)
[2013-12-09 18:59:10.866] SETDATA devices.2.data.applicationMinor = 0 (0x00000000)
[2013-12-09 18:59:10.867] SETDATA devices.2.data.ZWProtocolMajor = 0 (0x00000000)
[2013-12-09 18:59:10.867] SETDATA devices.2.data.ZWProtocolMinor = 0 (0x00000000)
[2013-12-09 18:59:10.867] SETDATA devices.2.data.ZWLib = 0 (0x00000000)
[2013-12-09 18:59:10.867] SETDATA devices.2.data.SDK = ""
[2013-12-09 18:59:10.867] SETDATA devices.2.data.vendorString = ""
[2013-12-09 18:59:10.867] SETDATA devices.2.data.nodeInfoFrame = Empty
[2013-12-09 18:59:10.867] SETDATA devices.2.data.ZDDXMLFile = ""
[2013-12-09 18:59:10.867] SETDATA devices.2.data.keepAwake = False
[2013-12-09 18:59:10.868] SETDATA devices.2.data.countSuccess = 0 (0x00000000)
[2013-12-09 18:59:10.868] SETDATA devices.2.data.countFailed = 0 (0x00000000)
[2013-12-09 18:59:10.868] SETDATA devices.2.data.queueLength = 0 (0x00000000)
[2013-12-09 18:59:10.868] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:10.868] SETDATA devices.2.data.lastSend = 0 (0x00000000)
[2013-12-09 18:59:10.868] SETDATA devices.2.data.failureCount = 0 (0x00000000)
[2013-12-09 18:59:10.868] Adding job: Get node protocol information
[2013-12-09 18:59:10.868] Adding job: Get routing table line
[2013-12-09 18:59:10.869] Adding job: Check if node is failed
[2013-12-09 18:59:10.869] Adding job: Get routing table line
[2013-12-09 18:59:10.869] Job 0x80 (Get routing table line): removing duplicate
[2013-12-09 18:59:10.869] SETDATA devices.2.data.basicType = 4 (0x00000004)
[2013-12-09 18:59:10.869] SETDATA devices.2.data.genericType = 16 (0x00000010)
[2013-12-09 18:59:10.869] SETDATA devices.2.instances.0.data.genericType = 16 (0x00000010)
[2013-12-09 18:59:10.870] SETDATA devices.2.data.specificType = 1 (0x00000001)
[2013-12-09 18:59:10.870] SETDATA devices.2.instances.0.data.specificType = 1 (0x00000001)
[2013-12-09 18:59:10.872] SETDATA devices.2.data.deviceTypeString = "Binary Power Switch"
[2013-12-09 18:59:10.872] SETDATA devices.2.data.nodeInfoFrame = byte[15]
( 25 27 28 75 86 70 71 85 77 2B 2C 72 73 82 87 )
[2013-12-09 18:59:10.872] SENDING (cb 0x02): ( 01 04 00 62 02 9B )
[2013-12-09 18:59:10.883] RECEIVED ACK
[2013-12-09 18:59:10.893] RECEIVED: ( 01 04 01 62 00 98 )
[2013-12-09 18:59:10.894] SENT ACK
[2013-12-09 18:59:10.894] SETDATA devices.2.data.isFailed = False
[2013-12-09 18:59:10.894] Job 0x62 (Check if node is failed): Node 2 is operating
[2013-12-09 18:59:10.894] Job 0x62 (Check if node is failed): success
[2013-12-09 18:59:10.894] Removing job: Check if node is failed
[2013-12-09 18:59:11.130] RECEIVED: ( 01 07 00 4A 05 05 02 00 B0 )
[2013-12-09 18:59:11.130] SENT ACK
[2013-12-09 18:59:11.131] Job 0x4a (Add/re-include node to network): Protocol done
[2013-12-09 18:59:11.131] SETDATA controller.data.controllerState = 4 (0x00000004)
[2013-12-09 18:59:11.131] Adding job: Add/re-include node to network
[2013-12-09 18:59:11.131] Loading Command Classes for device 2
[2013-12-09 18:59:11.131] Node 2:0 supports CC SwitchBinary
[2013-12-09 18:59:11.131] SETDATA devices.2.instances.0.commandClasses.37.data = Empty
[2013-12-09 18:59:11.131] SETDATA devices.2.instances.0.commandClasses.37.data.version = Empty
[2013-12-09 18:59:11.132] SETDATA devices.2.instances.0.commandClasses.37.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.132] SETDATA devices.2.instances.0.commandClasses.37.data.security = Empty
[2013-12-09 18:59:11.132] SETDATA devices.2.instances.0.commandClasses.37.data.security = False
[2013-12-09 18:59:11.132] SETDATA devices.2.instances.0.commandClasses.37.data.interviewDone = Empty
[2013-12-09 18:59:11.132] SETDATA devices.2.instances.0.commandClasses.37.data.interviewCounter = Empty
[2013-12-09 18:59:11.132] SETDATA devices.2.instances.0.commandClasses.37.data.interviewDone = False
[2013-12-09 18:59:11.133] SETDATA devices.2.instances.0.commandClasses.37.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.133] SETDATA devices.2.instances.0.commandClasses.37.data.level = Empty
[2013-12-09 18:59:11.133] Node 2:0 supports CC SwitchAll
[2013-12-09 18:59:11.133] SETDATA devices.2.instances.0.commandClasses.39.data = Empty
[2013-12-09 18:59:11.133] SETDATA devices.2.instances.0.commandClasses.39.data.version = Empty
[2013-12-09 18:59:11.133] SETDATA devices.2.instances.0.commandClasses.39.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.133] SETDATA devices.2.instances.0.commandClasses.39.data.security = Empty
[2013-12-09 18:59:11.134] SETDATA devices.2.instances.0.commandClasses.39.data.security = False
[2013-12-09 18:59:11.134] SETDATA devices.2.instances.0.commandClasses.39.data.interviewDone = Empty
[2013-12-09 18:59:11.134] SETDATA devices.2.instances.0.commandClasses.39.data.interviewCounter = Empty
[2013-12-09 18:59:11.134] SETDATA devices.2.instances.0.commandClasses.39.data.interviewDone = False
[2013-12-09 18:59:11.134] SETDATA devices.2.instances.0.commandClasses.39.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.134] SETDATA devices.2.instances.0.commandClasses.39.data.mode = Empty
[2013-12-09 18:59:11.134] SETDATA devices.2.instances.0.commandClasses.39.data.onOff = Empty
[2013-12-09 18:59:11.135] Node 2:0 supports CC UNKNOWN 0x28
[2013-12-09 18:59:11.135] Node 2:0 supports CC SceneActivation
[2013-12-09 18:59:11.135] SETDATA devices.2.instances.0.commandClasses.43.data = Empty
[2013-12-09 18:59:11.135] SETDATA devices.2.instances.0.commandClasses.43.data.version = Empty
[2013-12-09 18:59:11.135] SETDATA devices.2.instances.0.commandClasses.43.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.135] SETDATA devices.2.instances.0.commandClasses.43.data.security = Empty
[2013-12-09 18:59:11.135] SETDATA devices.2.instances.0.commandClasses.43.data.security = False
[2013-12-09 18:59:11.136] SETDATA devices.2.instances.0.commandClasses.43.data.interviewDone = Empty
[2013-12-09 18:59:11.136] SETDATA devices.2.instances.0.commandClasses.43.data.interviewCounter = Empty
[2013-12-09 18:59:11.136] SETDATA devices.2.instances.0.commandClasses.43.data.interviewDone = False
[2013-12-09 18:59:11.136] SETDATA devices.2.instances.0.commandClasses.43.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.136] SETDATA devices.2.instances.0.commandClasses.43.data.currentScene = Empty
[2013-12-09 18:59:11.137] Node 2:0 supports CC SceneActuatorConf
[2013-12-09 18:59:11.137] SETDATA devices.2.instances.0.commandClasses.44.data = Empty
[2013-12-09 18:59:11.137] SETDATA devices.2.instances.0.commandClasses.44.data.version = Empty
[2013-12-09 18:59:11.137] SETDATA devices.2.instances.0.commandClasses.44.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.137] SETDATA devices.2.instances.0.commandClasses.44.data.security = Empty
[2013-12-09 18:59:11.137] SETDATA devices.2.instances.0.commandClasses.44.data.security = False
[2013-12-09 18:59:11.138] SETDATA devices.2.instances.0.commandClasses.44.data.interviewDone = Empty
[2013-12-09 18:59:11.138] SETDATA devices.2.instances.0.commandClasses.44.data.interviewCounter = Empty
[2013-12-09 18:59:11.138] SETDATA devices.2.instances.0.commandClasses.44.data.interviewDone = False
[2013-12-09 18:59:11.138] SETDATA devices.2.instances.0.commandClasses.44.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.138] SETDATA devices.2.instances.0.commandClasses.44.data.currentScene = Empty
[2013-12-09 18:59:11.138] SETDATA devices.2.instances.0.commandClasses.44.data.currentScene = 0 (0x00000000)
[2013-12-09 18:59:11.138] Node 2:0 supports CC Configuration
[2013-12-09 18:59:11.139] SETDATA devices.2.instances.0.commandClasses.112.data = Empty
[2013-12-09 18:59:11.139] SETDATA devices.2.instances.0.commandClasses.112.data.version = Empty
[2013-12-09 18:59:11.139] SETDATA devices.2.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.139] SETDATA devices.2.instances.0.commandClasses.112.data.security = Empty
[2013-12-09 18:59:11.139] SETDATA devices.2.instances.0.commandClasses.112.data.security = False
[2013-12-09 18:59:11.139] SETDATA devices.2.instances.0.commandClasses.112.data.interviewDone = Empty
[2013-12-09 18:59:11.139] SETDATA devices.2.instances.0.commandClasses.112.data.interviewCounter = Empty
[2013-12-09 18:59:11.139] SETDATA devices.2.instances.0.commandClasses.112.data.interviewDone = False
[2013-12-09 18:59:11.140] SETDATA devices.2.instances.0.commandClasses.112.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.140] Node 2:0 supports CC Alarm
[2013-12-09 18:59:11.140] SETDATA devices.2.instances.0.commandClasses.113.data = Empty
[2013-12-09 18:59:11.140] SETDATA devices.2.instances.0.commandClasses.113.data.version = Empty
[2013-12-09 18:59:11.140] SETDATA devices.2.instances.0.commandClasses.113.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.140] SETDATA devices.2.instances.0.commandClasses.113.data.security = Empty
[2013-12-09 18:59:11.140] SETDATA devices.2.instances.0.commandClasses.113.data.security = False
[2013-12-09 18:59:11.141] SETDATA devices.2.instances.0.commandClasses.113.data.interviewDone = Empty
[2013-12-09 18:59:11.141] SETDATA devices.2.instances.0.commandClasses.113.data.interviewCounter = Empty
[2013-12-09 18:59:11.141] SETDATA devices.2.instances.0.commandClasses.113.data.interviewDone = False
[2013-12-09 18:59:11.141] SETDATA devices.2.instances.0.commandClasses.113.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.141] SETDATA devices.2.instances.0.commandClasses.113.data.V1supported = Empty
[2013-12-09 18:59:11.141] SETDATA devices.2.instances.0.commandClasses.113.data.typeMask = Empty
[2013-12-09 18:59:11.141] SETDATA devices.2.instances.0.commandClasses.113.data.V1event = Empty
[2013-12-09 18:59:11.141] SETDATA devices.2.instances.0.commandClasses.113.data.V1event.type = Empty
[2013-12-09 18:59:11.142] SETDATA devices.2.instances.0.commandClasses.113.data.V1event.level = Empty
[2013-12-09 18:59:11.142] Node 2:0 supports CC ManufacturerSpecific
[2013-12-09 18:59:11.142] SETDATA devices.2.instances.0.commandClasses.114.data = Empty
[2013-12-09 18:59:11.142] SETDATA devices.2.instances.0.commandClasses.114.data.version = Empty
[2013-12-09 18:59:11.142] SETDATA devices.2.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.142] SETDATA devices.2.instances.0.commandClasses.114.data.security = Empty
[2013-12-09 18:59:11.143] SETDATA devices.2.instances.0.commandClasses.114.data.security = False
[2013-12-09 18:59:11.143] SETDATA devices.2.instances.0.commandClasses.114.data.interviewDone = Empty
[2013-12-09 18:59:11.143] SETDATA devices.2.instances.0.commandClasses.114.data.interviewCounter = Empty
[2013-12-09 18:59:11.143] SETDATA devices.2.instances.0.commandClasses.114.data.interviewDone = False
[2013-12-09 18:59:11.143] SETDATA devices.2.instances.0.commandClasses.114.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.143] SETDATA devices.2.instances.0.commandClasses.114.data.vendorId = Empty
[2013-12-09 18:59:11.144] SETDATA devices.2.instances.0.commandClasses.114.data.vendor = Empty
[2013-12-09 18:59:11.144] SETDATA devices.2.instances.0.commandClasses.114.data.productId = Empty
[2013-12-09 18:59:11.144] SETDATA devices.2.instances.0.commandClasses.114.data.productType = Empty
[2013-12-09 18:59:11.144] Node 2:0 supports CC UNKNOWN 0x73
[2013-12-09 18:59:11.144] Node 2:0 supports CC Protection
[2013-12-09 18:59:11.144] SETDATA devices.2.instances.0.commandClasses.117.data = Empty
[2013-12-09 18:59:11.144] SETDATA devices.2.instances.0.commandClasses.117.data.version = Empty
[2013-12-09 18:59:11.145] SETDATA devices.2.instances.0.commandClasses.117.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.145] SETDATA devices.2.instances.0.commandClasses.117.data.security = Empty
[2013-12-09 18:59:11.145] SETDATA devices.2.instances.0.commandClasses.117.data.security = False
[2013-12-09 18:59:11.145] SETDATA devices.2.instances.0.commandClasses.117.data.interviewDone = Empty
[2013-12-09 18:59:11.145] SETDATA devices.2.instances.0.commandClasses.117.data.interviewCounter = Empty
[2013-12-09 18:59:11.145] SETDATA devices.2.instances.0.commandClasses.117.data.interviewDone = False
[2013-12-09 18:59:11.145] SETDATA devices.2.instances.0.commandClasses.117.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.146] SETDATA devices.2.instances.0.commandClasses.117.data.state = Empty
[2013-12-09 18:59:11.146] SETDATA devices.2.instances.0.commandClasses.117.data.rfState = Empty
[2013-12-09 18:59:11.146] SETDATA devices.2.instances.0.commandClasses.117.data.exclusive = Empty
[2013-12-09 18:59:11.146] SETDATA devices.2.instances.0.commandClasses.117.data.timeout = Empty
[2013-12-09 18:59:11.146] SETDATA devices.2.instances.0.commandClasses.117.data.stateCap = Empty
[2013-12-09 18:59:11.147] SETDATA devices.2.instances.0.commandClasses.117.data.rfStateCap = Empty
[2013-12-09 18:59:11.147] SETDATA devices.2.instances.0.commandClasses.117.data.exclusiveCap = Empty
[2013-12-09 18:59:11.147] SETDATA devices.2.instances.0.commandClasses.117.data.timeoutCap = Empty
[2013-12-09 18:59:11.147] Node 2:0 supports CC NodeNaming
[2013-12-09 18:59:11.147] SETDATA devices.2.instances.0.commandClasses.119.data = Empty
[2013-12-09 18:59:11.147] SETDATA devices.2.instances.0.commandClasses.119.data.version = Empty
[2013-12-09 18:59:11.147] SETDATA devices.2.instances.0.commandClasses.119.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.148] SETDATA devices.2.instances.0.commandClasses.119.data.security = Empty
[2013-12-09 18:59:11.148] SETDATA devices.2.instances.0.commandClasses.119.data.security = False
[2013-12-09 18:59:11.148] SETDATA devices.2.instances.0.commandClasses.119.data.interviewDone = Empty
[2013-12-09 18:59:11.148] SETDATA devices.2.instances.0.commandClasses.119.data.interviewCounter = Empty
[2013-12-09 18:59:11.148] SETDATA devices.2.instances.0.commandClasses.119.data.interviewDone = False
[2013-12-09 18:59:11.148] SETDATA devices.2.instances.0.commandClasses.119.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.148] SETDATA devices.2.instances.0.commandClasses.119.data.nodename = Empty
[2013-12-09 18:59:11.149] SETDATA devices.2.instances.0.commandClasses.119.data.location = Empty
[2013-12-09 18:59:11.149] SETDATA devices.2.instances.0.commandClasses.119.data.myname = Empty
[2013-12-09 18:59:11.149] SETDATA devices.2.instances.0.commandClasses.119.data.mylocation = Empty
[2013-12-09 18:59:11.149] Node 2:0 supports CC UNKNOWN 0x82
[2013-12-09 18:59:11.149] Node 2:0 supports CC Association
[2013-12-09 18:59:11.149] SETDATA devices.2.instances.0.commandClasses.133.data = Empty
[2013-12-09 18:59:11.149] SETDATA devices.2.instances.0.commandClasses.133.data.version = Empty
[2013-12-09 18:59:11.150] SETDATA devices.2.instances.0.commandClasses.133.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.150] SETDATA devices.2.instances.0.commandClasses.133.data.security = Empty
[2013-12-09 18:59:11.150] SETDATA devices.2.instances.0.commandClasses.133.data.security = False
[2013-12-09 18:59:11.150] SETDATA devices.2.instances.0.commandClasses.133.data.interviewDone = Empty
[2013-12-09 18:59:11.150] SETDATA devices.2.instances.0.commandClasses.133.data.interviewCounter = Empty
[2013-12-09 18:59:11.150] SETDATA devices.2.instances.0.commandClasses.133.data.interviewDone = False
[2013-12-09 18:59:11.150] SETDATA devices.2.instances.0.commandClasses.133.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.151] SETDATA devices.2.instances.0.commandClasses.133.data.groups = Empty
[2013-12-09 18:59:11.151] Node 2:0 supports CC Version
[2013-12-09 18:59:11.151] SETDATA devices.2.instances.0.commandClasses.134.data = Empty
[2013-12-09 18:59:11.151] SETDATA devices.2.instances.0.commandClasses.134.data.version = Empty
[2013-12-09 18:59:11.151] SETDATA devices.2.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.151] SETDATA devices.2.instances.0.commandClasses.134.data.security = Empty
[2013-12-09 18:59:11.151] SETDATA devices.2.instances.0.commandClasses.134.data.security = False
[2013-12-09 18:59:11.151] SETDATA devices.2.instances.0.commandClasses.134.data.interviewDone = Empty
[2013-12-09 18:59:11.152] SETDATA devices.2.instances.0.commandClasses.134.data.interviewCounter = Empty
[2013-12-09 18:59:11.152] SETDATA devices.2.instances.0.commandClasses.134.data.interviewDone = False
[2013-12-09 18:59:11.152] SETDATA devices.2.instances.0.commandClasses.134.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.152] SETDATA devices.2.instances.0.commandClasses.134.data.ZWLib = Empty
[2013-12-09 18:59:11.152] SETDATA devices.2.instances.0.commandClasses.134.data.ZWProtocolMajor = Empty
[2013-12-09 18:59:11.152] SETDATA devices.2.instances.0.commandClasses.134.data.ZWProtocolMinor = Empty
[2013-12-09 18:59:11.153] SETDATA devices.2.instances.0.commandClasses.134.data.SDK = Empty
[2013-12-09 18:59:11.153] SETDATA devices.2.instances.0.commandClasses.134.data.applicationMajor = Empty
[2013-12-09 18:59:11.153] SETDATA devices.2.instances.0.commandClasses.134.data.applicationMinor = Empty
[2013-12-09 18:59:11.153] Node 2:0 supports CC Indicator
[2013-12-09 18:59:11.153] SETDATA devices.2.instances.0.commandClasses.135.data = Empty
[2013-12-09 18:59:11.153] SETDATA devices.2.instances.0.commandClasses.135.data.version = Empty
[2013-12-09 18:59:11.154] SETDATA devices.2.instances.0.commandClasses.135.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.154] SETDATA devices.2.instances.0.commandClasses.135.data.security = Empty
[2013-12-09 18:59:11.154] SETDATA devices.2.instances.0.commandClasses.135.data.security = False
[2013-12-09 18:59:11.154] SETDATA devices.2.instances.0.commandClasses.135.data.interviewDone = Empty
[2013-12-09 18:59:11.154] SETDATA devices.2.instances.0.commandClasses.135.data.interviewCounter = Empty
[2013-12-09 18:59:11.154] SETDATA devices.2.instances.0.commandClasses.135.data.interviewDone = False
[2013-12-09 18:59:11.154] SETDATA devices.2.instances.0.commandClasses.135.data.interviewCounter = 10 (0x0000000a)
[2013-12-09 18:59:11.155] SETDATA devices.2.instances.0.commandClasses.135.data.stat = Empty
[2013-12-09 18:59:11.155] SETDATA devices.2.data.lastSend = 119423 (0x0001d27f)
[2013-12-09 18:59:11.155] SETDATA devices.2.data.isAwake = True
[2013-12-09 18:59:11.155] SETDATA devices.2.data.lastSend = 119323 (0x0001d21b)
[2013-12-09 18:59:11.155] Interview step 1
[2013-12-09 18:59:11.156] SETDATA devices.2.instances.0.commandClasses.134.data.interviewDone = False
[2013-12-09 18:59:11.156] SETDATA devices.2.instances.0.commandClasses.134.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:11.156] Node 2:0 CC Version Interview started
[2013-12-09 18:59:11.156] Adding job: Version Get
[2013-12-09 18:59:11.157] Adding job: SwitchBinary Version Get
[2013-12-09 18:59:11.157] Adding job: SwitchAll Version Get
[2013-12-09 18:59:11.157] Adding job: SceneActivation Version Get
[2013-12-09 18:59:11.158] Adding job: SceneActuatorConf Version Get
[2013-12-09 18:59:11.158] Adding job: Configuration Version Get
[2013-12-09 18:59:11.158] Adding job: Alarm Version Get
[2013-12-09 18:59:11.158] Adding job: ManufacturerSpecific Version Get
[2013-12-09 18:59:11.158] Adding job: Protection Version Get
[2013-12-09 18:59:11.159] Adding job: NodeNaming Version Get
[2013-12-09 18:59:11.159] Adding job: Association Version Get
[2013-12-09 18:59:11.159] Adding job: Version Version Get
[2013-12-09 18:59:11.159] Adding job: Indicator Version Get
[2013-12-09 18:59:11.159] Running wakeup handler for node 2
[2013-12-09 18:59:11.171] SENDING (cb 0xc5): ( 01 04 00 4A C5 74 )
[2013-12-09 18:59:11.181] RECEIVED ACK
[2013-12-09 18:59:11.181] Removing job: Add/re-include node to network
[2013-12-09 18:59:11.226] RECEIVED: ( 01 07 00 4A 05 06 02 00 B3 )
[2013-12-09 18:59:11.226] SENT ACK
[2013-12-09 18:59:11.226] Job 0x4a (Add/re-include node to network): Done
[2013-12-09 18:59:11.226] SETDATA controller.data.controllerState = 0 (0x00000000)
[2013-12-09 18:59:11.226] Job 0x4a (Add/re-include node to network): success
[2013-12-09 18:59:11.227] Removing job: Add/re-include node to network
[2013-12-09 18:59:11.238] SENDING (cb 0x02): ( 01 04 00 41 02 B8 )
[2013-12-09 18:59:11.248] RECEIVED ACK
[2013-12-09 18:59:11.259] RECEIVED: ( 01 09 01 41 D1 8C 00 04 10 01 FE )
[2013-12-09 18:59:11.260] SENT ACK
[2013-12-09 18:59:11.260] SETDATA devices.2.data.basicType = 4 (0x00000004)
[2013-12-09 18:59:11.260] SETDATA devices.2.data.genericType = 16 (0x00000010)
[2013-12-09 18:59:11.260] SETDATA devices.2.data.specificType = 1 (0x00000001)
[2013-12-09 18:59:11.262] SETDATA devices.2.data.deviceTypeString = "Binary Power Switch"
[2013-12-09 18:59:11.262] SETDATA devices.2.data.isRouting = True
[2013-12-09 18:59:11.262] SETDATA devices.2.data.isListening = True
[2013-12-09 18:59:11.262] SETDATA devices.2.data.optional = True
[2013-12-09 18:59:11.262] SETDATA devices.2.data.sensor1000 = False
[2013-12-09 18:59:11.262] SETDATA devices.2.data.sensor250 = False
[2013-12-09 18:59:11.263] SETDATA devices.2.data.infoProtocolSpecific = 13732864 (0x00d18c00)
[2013-12-09 18:59:11.263] Job 0x41 (Get node protocol information): success
[2013-12-09 18:59:11.263] Removing job: Get node protocol information
[2013-12-09 18:59:11.274] SENDING (cb 0x00): ( 01 06 00 80 01 00 00 78 )
[2013-12-09 18:59:11.285] RECEIVED ACK
[2013-12-09 18:59:11.295] RECEIVED: ( 01 20 01 80 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5C )
[2013-12-09 18:59:11.296] SENT ACK
[2013-12-09 18:59:11.296] SETDATA devices.1.data.neighbours = byte[1]
( 02 )
[2013-12-09 18:59:11.296] Job 0x80 (Get routing table line): List of neighbours for node 1: [ 02 ]
[2013-12-09 18:59:11.296] Job 0x80 (Get routing table line): success
[2013-12-09 18:59:11.296] Removing job: Get routing table line
[2013-12-09 18:59:11.308] SENDING (cb 0x00): ( 01 06 00 80 02 00 00 7B )
[2013-12-09 18:59:11.318] RECEIVED ACK
[2013-12-09 18:59:11.329] RECEIVED: ( 01 20 01 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5F )
[2013-12-09 18:59:11.329] SENT ACK
[2013-12-09 18:59:11.329] SETDATA devices.2.data.neighbours = byte[1]
( 01 )
[2013-12-09 18:59:11.330] Job 0x80 (Get routing table line): List of neighbours for node 2: [ 01 ]
[2013-12-09 18:59:11.330] Job 0x80 (Get routing table line): success
[2013-12-09 18:59:11.330] Removing job: Get routing table line
[2013-12-09 18:59:11.341] SENDING (cb 0x06): ( 01 09 00 13 02 02 86 11 25 06 51 )
[2013-12-09 18:59:11.352] RECEIVED ACK
[2013-12-09 18:59:11.363] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:11.363] SENT ACK
[2013-12-09 18:59:11.363] Delivered to Z-Wave stack
[2013-12-09 18:59:11.373] RECEIVED: ( 01 05 00 13 06 00 EF )
[2013-12-09 18:59:11.374] SENT ACK
[2013-12-09 18:59:11.374] Job 0x13 (Version Get): Delivered
[2013-12-09 18:59:11.374] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:11.374] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2013-12-09 18:59:11.374] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:11.374] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:11.375] SendData Response with callback 0x06 received: received by recipient
[2013-12-09 18:59:11.375] SETDATA devices.2.data.lastSend = 119342 (0x0001d22e)
[2013-12-09 18:59:11.375] Job 0x13 (Version Get): success
[2013-12-09 18:59:11.375] Removing job: Version Get
[2013-12-09 18:59:11.385] RECEIVED: ( 01 0D 00 04 00 02 07 86 12 03 02 09 01 0B 65 )
[2013-12-09 18:59:11.386] SENT ACK
[2013-12-09 18:59:11.386] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:11.386] SETDATA devices.2.instances.0.commandClasses.134.data = Empty
[2013-12-09 18:59:11.386] SETDATA devices.2.instances.0.commandClasses.134.data.ZWLib = 3 (0x00000003)
[2013-12-09 18:59:11.387] SETDATA devices.2.instances.0.commandClasses.134.data.ZWProtocolMajor = 2 (0x00000002)
[2013-12-09 18:59:11.387] SETDATA devices.2.instances.0.commandClasses.134.data.ZWProtocolMinor = 9 (0x00000009)
[2013-12-09 18:59:11.388] SETDATA devices.2.instances.0.commandClasses.134.data.SDK = "4.22"
[2013-12-09 18:59:11.388] SETDATA devices.2.instances.0.commandClasses.134.data.applicationMajor = 1 (0x00000001)
[2013-12-09 18:59:11.389] SETDATA devices.2.instances.0.commandClasses.134.data.applicationMinor = 11 (0x0000000b)
[2013-12-09 18:59:11.389] SETDATA devices.2.data.ZWLib = 3 (0x00000003)
[2013-12-09 18:59:11.389] SETDATA devices.2.data.ZWProtocolMajor = 2 (0x00000002)
[2013-12-09 18:59:11.389] SETDATA devices.2.data.ZWProtocolMinor = 9 (0x00000009)
[2013-12-09 18:59:11.390] SETDATA devices.2.data.SDK = "4.22"
[2013-12-09 18:59:11.390] SETDATA devices.2.data.applicationMajor = 1 (0x00000001)
[2013-12-09 18:59:11.391] SETDATA devices.2.data.applicationMinor = 11 (0x0000000b)
[2013-12-09 18:59:11.448] SENDING (cb 0x07): ( 01 0A 00 13 02 03 86 13 25 25 07 75 )
[2013-12-09 18:59:11.458] RECEIVED ACK
[2013-12-09 18:59:11.469] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:11.469] SENT ACK
[2013-12-09 18:59:11.469] Delivered to Z-Wave stack
[2013-12-09 18:59:11.479] RECEIVED: ( 01 05 00 13 07 00 EE )
[2013-12-09 18:59:11.480] SENT ACK
[2013-12-09 18:59:11.480] Job 0x13 (SwitchBinary Version Get): Delivered
[2013-12-09 18:59:11.480] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:11.480] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:11.480] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:11.480] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:11.481] SendData Response with callback 0x07 received: received by recipient
[2013-12-09 18:59:11.481] SETDATA devices.2.data.lastSend = 119351 (0x0001d237)
[2013-12-09 18:59:11.481] Job 0x13 (SwitchBinary Version Get): success
[2013-12-09 18:59:11.481] Removing job: SwitchBinary Version Get
[2013-12-09 18:59:11.492] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 25 01 41 )
[2013-12-09 18:59:11.492] SENT ACK
[2013-12-09 18:59:11.492] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:11.492] Node 2:0 CC Version: SwitchBinary is v1
[2013-12-09 18:59:11.493] SETDATA devices.2.instances.0.commandClasses.37.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.550] SENDING (cb 0x08): ( 01 0A 00 13 02 03 86 13 27 25 08 78 )
[2013-12-09 18:59:11.560] RECEIVED ACK
[2013-12-09 18:59:11.571] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:11.571] SENT ACK
[2013-12-09 18:59:11.571] Delivered to Z-Wave stack
[2013-12-09 18:59:11.581] RECEIVED: ( 01 05 00 13 08 00 E1 )
[2013-12-09 18:59:11.582] SENT ACK
[2013-12-09 18:59:11.582] Job 0x13 (SwitchAll Version Get): Delivered
[2013-12-09 18:59:11.582] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:11.582] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:11.582] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:11.583] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:11.583] SendData Response with callback 0x08 received: received by recipient
[2013-12-09 18:59:11.583] SETDATA devices.2.data.lastSend = 119360 (0x0001d240)
[2013-12-09 18:59:11.583] Job 0x13 (SwitchAll Version Get): success
[2013-12-09 18:59:11.583] Removing job: SwitchAll Version Get
[2013-12-09 18:59:11.594] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 27 01 43 )
[2013-12-09 18:59:11.594] SENT ACK
[2013-12-09 18:59:11.594] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:11.594] Node 2:0 CC Version: SwitchAll is v1
[2013-12-09 18:59:11.594] SETDATA devices.2.instances.0.commandClasses.39.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.651] SENDING (cb 0x09): ( 01 0A 00 13 02 03 86 13 2B 25 09 75 )
[2013-12-09 18:59:11.662] RECEIVED ACK
[2013-12-09 18:59:11.672] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:11.673] SENT ACK
[2013-12-09 18:59:11.673] Delivered to Z-Wave stack
[2013-12-09 18:59:11.683] RECEIVED: ( 01 05 00 13 09 00 E0 )
[2013-12-09 18:59:11.683] SENT ACK
[2013-12-09 18:59:11.684] Job 0x13 (SceneActivation Version Get): Delivered
[2013-12-09 18:59:11.684] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:11.684] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:11.684] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:11.684] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:11.684] SendData Response with callback 0x09 received: received by recipient
[2013-12-09 18:59:11.685] SETDATA devices.2.data.lastSend = 119369 (0x0001d249)
[2013-12-09 18:59:11.685] Job 0x13 (SceneActivation Version Get): success
[2013-12-09 18:59:11.685] Removing job: SceneActivation Version Get
[2013-12-09 18:59:11.695] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 2B 01 4F )
[2013-12-09 18:59:11.696] SENT ACK
[2013-12-09 18:59:11.696] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:11.696] Node 2:0 CC Version: SceneActivation is v1
[2013-12-09 18:59:11.696] SETDATA devices.2.instances.0.commandClasses.43.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.753] SENDING (cb 0x0a): ( 01 0A 00 13 02 03 86 13 2C 25 0A 71 )
[2013-12-09 18:59:11.764] RECEIVED ACK
[2013-12-09 18:59:11.774] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:11.774] SENT ACK
[2013-12-09 18:59:11.775] Delivered to Z-Wave stack
[2013-12-09 18:59:11.785] RECEIVED: ( 01 05 00 13 0A 00 E3 )
[2013-12-09 18:59:11.785] SENT ACK
[2013-12-09 18:59:11.785] Job 0x13 (SceneActuatorConf Version Get): Delivered
[2013-12-09 18:59:11.786] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:11.786] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:11.786] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:11.786] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:11.786] SendData Response with callback 0x0a received: received by recipient
[2013-12-09 18:59:11.786] SETDATA devices.2.data.lastSend = 119378 (0x0001d252)
[2013-12-09 18:59:11.786] Job 0x13 (SceneActuatorConf Version Get): success
[2013-12-09 18:59:11.787] Removing job: SceneActuatorConf Version Get
[2013-12-09 18:59:11.797] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 2C 01 48 )
[2013-12-09 18:59:11.797] SENT ACK
[2013-12-09 18:59:11.798] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:11.798] Node 2:0 CC Version: SceneActuatorConf is v1
[2013-12-09 18:59:11.798] SETDATA devices.2.instances.0.commandClasses.44.data.version = 1 (0x00000001)
[2013-12-09 18:59:11.855] SENDING (cb 0x0b): ( 01 0A 00 13 02 03 86 13 70 25 0B 2C )
[2013-12-09 18:59:11.866] RECEIVED ACK
[2013-12-09 18:59:11.876] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:11.876] SENT ACK
[2013-12-09 18:59:11.876] Delivered to Z-Wave stack
[2013-12-09 18:59:11.887] RECEIVED: ( 01 05 00 13 0B 00 E2 )
[2013-12-09 18:59:11.887] SENT ACK
[2013-12-09 18:59:11.887] Job 0x13 (Configuration Version Get): Delivered
[2013-12-09 18:59:11.887] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:11.888] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:11.888] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:11.888] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:11.888] SendData Response with callback 0x0b received: received by recipient
[2013-12-09 18:59:11.888] SETDATA devices.2.data.lastSend = 119387 (0x0001d25b)
[2013-12-09 18:59:11.888] Job 0x13 (Configuration Version Get): success
[2013-12-09 18:59:11.888] Removing job: Configuration Version Get
[2013-12-09 18:59:11.975] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 70 01 14 )
[2013-12-09 18:59:11.975] SENT ACK
[2013-12-09 18:59:11.975] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:11.975] Node 2:0 CC Version: Configuration is v1
[2013-12-09 18:59:11.976] SETDATA devices.2.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2013-12-09 18:59:12.033] SENDING (cb 0x0c): ( 01 0A 00 13 02 03 86 13 71 25 0C 2A )
[2013-12-09 18:59:12.043] RECEIVED ACK
[2013-12-09 18:59:12.054] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:12.054] SENT ACK
[2013-12-09 18:59:12.054] Delivered to Z-Wave stack
[2013-12-09 18:59:12.065] RECEIVED: ( 01 05 00 13 0C 00 E5 )
[2013-12-09 18:59:12.065] SENT ACK
[2013-12-09 18:59:12.065] Job 0x13 (Alarm Version Get): Delivered
[2013-12-09 18:59:12.065] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:12.066] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:12.066] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:12.066] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:12.066] SendData Response with callback 0x0c received: received by recipient
[2013-12-09 18:59:12.066] SETDATA devices.2.data.lastSend = 119396 (0x0001d264)
[2013-12-09 18:59:12.066] Job 0x13 (Alarm Version Get): success
[2013-12-09 18:59:12.067] Removing job: Alarm Version Get
[2013-12-09 18:59:12.077] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 71 01 15 )
[2013-12-09 18:59:12.077] SENT ACK
[2013-12-09 18:59:12.077] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:12.078] Node 2:0 CC Version: Alarm is v1
[2013-12-09 18:59:12.078] SETDATA devices.2.instances.0.commandClasses.113.data.version = 1 (0x00000001)
[2013-12-09 18:59:12.135] SENDING (cb 0x0d): ( 01 0A 00 13 02 03 86 13 72 25 0D 28 )
[2013-12-09 18:59:12.145] RECEIVED ACK
[2013-12-09 18:59:12.156] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:12.156] SENT ACK
[2013-12-09 18:59:12.156] Delivered to Z-Wave stack
[2013-12-09 18:59:12.166] RECEIVED: ( 01 05 00 13 0D 00 E4 )
[2013-12-09 18:59:12.167] SENT ACK
[2013-12-09 18:59:12.167] Job 0x13 (ManufacturerSpecific Version Get): Delivered
[2013-12-09 18:59:12.167] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:12.167] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:12.167] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:12.168] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:12.168] SendData Response with callback 0x0d received: received by recipient
[2013-12-09 18:59:12.168] SETDATA devices.2.data.lastSend = 119405 (0x0001d26d)
[2013-12-09 18:59:12.168] Job 0x13 (ManufacturerSpecific Version Get): success
[2013-12-09 18:59:12.168] Removing job: ManufacturerSpecific Version Get
[2013-12-09 18:59:12.179] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 72 01 16 )
[2013-12-09 18:59:12.179] SENT ACK
[2013-12-09 18:59:12.179] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:12.179] Node 2:0 CC Version: ManufacturerSpecific is v1
[2013-12-09 18:59:12.180] SETDATA devices.2.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2013-12-09 18:59:12.236] SENDING (cb 0x0e): ( 01 0A 00 13 02 03 86 13 75 25 0E 2C )
[2013-12-09 18:59:12.247] RECEIVED ACK
[2013-12-09 18:59:12.257] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:12.258] SENT ACK
[2013-12-09 18:59:12.258] Delivered to Z-Wave stack
[2013-12-09 18:59:12.268] RECEIVED: ( 01 05 00 13 0E 00 E7 )
[2013-12-09 18:59:12.269] SENT ACK
[2013-12-09 18:59:12.269] Job 0x13 (Protection Version Get): Delivered
[2013-12-09 18:59:12.269] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:12.269] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:12.269] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:12.269] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:12.269] SendData Response with callback 0x0e received: received by recipient
[2013-12-09 18:59:12.270] SETDATA devices.2.data.lastSend = 119414 (0x0001d276)
[2013-12-09 18:59:12.270] Job 0x13 (Protection Version Get): success
[2013-12-09 18:59:12.270] Removing job: Protection Version Get
[2013-12-09 18:59:12.280] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 75 01 11 )
[2013-12-09 18:59:12.281] SENT ACK
[2013-12-09 18:59:12.281] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:12.281] Node 2:0 CC Version: Protection is v1
[2013-12-09 18:59:12.281] SETDATA devices.2.instances.0.commandClasses.117.data.version = 1 (0x00000001)
[2013-12-09 18:59:12.338] SENDING (cb 0x0f): ( 01 0A 00 13 02 03 86 13 77 25 0F 2F )
[2013-12-09 18:59:12.349] RECEIVED ACK
[2013-12-09 18:59:12.359] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:12.360] SENT ACK
[2013-12-09 18:59:12.360] Delivered to Z-Wave stack
[2013-12-09 18:59:12.404] RECEIVED: ( 01 05 00 13 0F 00 E6 )
[2013-12-09 18:59:12.404] SENT ACK
[2013-12-09 18:59:12.404] Job 0x13 (NodeNaming Version Get): Delivered
[2013-12-09 18:59:12.405] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:12.405] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:12.405] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 44 (0x0000002c)
[2013-12-09 18:59:12.405] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:12.405] SendData Response with callback 0x0f received: received by recipient
[2013-12-09 18:59:12.405] SETDATA devices.2.data.lastSend = 119426 (0x0001d282)
[2013-12-09 18:59:12.405] Job 0x13 (NodeNaming Version Get): success
[2013-12-09 18:59:12.405] Removing job: NodeNaming Version Get
[2013-12-09 18:59:12.416] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 77 01 13 )
[2013-12-09 18:59:12.416] SENT ACK
[2013-12-09 18:59:12.416] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:12.416] Node 2:0 CC Version: NodeNaming is v1
[2013-12-09 18:59:12.417] SETDATA devices.2.instances.0.commandClasses.119.data.version = 1 (0x00000001)
[2013-12-09 18:59:12.438] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 77 01 13 )
[2013-12-09 18:59:12.438] SENT ACK
[2013-12-09 18:59:12.438] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:12.438] Node 2:0 CC Version: NodeNaming is v1
[2013-12-09 18:59:12.438] SETDATA devices.2.instances.0.commandClasses.119.data.version = 1 (0x00000001)
[2013-12-09 18:59:12.473] SENDING (cb 0x10): ( 01 0A 00 13 02 03 86 13 85 25 10 C2 )
[2013-12-09 18:59:12.483] RECEIVED ACK
[2013-12-09 18:59:12.494] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:12.494] SENT ACK
[2013-12-09 18:59:12.494] Delivered to Z-Wave stack
[2013-12-09 18:59:12.504] RECEIVED: ( 01 05 00 13 10 00 F9 )
[2013-12-09 18:59:12.505] SENT ACK
[2013-12-09 18:59:12.505] Job 0x13 (Association Version Get): Delivered
[2013-12-09 18:59:12.505] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:12.505] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:12.505] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:12.505] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:12.506] SendData Response with callback 0x10 received: received by recipient
[2013-12-09 18:59:12.506] SETDATA devices.2.data.lastSend = 119435 (0x0001d28b)
[2013-12-09 18:59:12.506] Job 0x13 (Association Version Get): success
[2013-12-09 18:59:12.506] Removing job: Association Version Get
[2013-12-09 18:59:12.517] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 85 01 E1 )
[2013-12-09 18:59:12.517] SENT ACK
[2013-12-09 18:59:12.517] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:12.517] Node 2:0 CC Version: Association is v1
[2013-12-09 18:59:12.517] SETDATA devices.2.instances.0.commandClasses.133.data.version = 1 (0x00000001)
[2013-12-09 18:59:12.574] SENDING (cb 0x11): ( 01 0A 00 13 02 03 86 13 86 25 11 C0 )
[2013-12-09 18:59:12.585] RECEIVED ACK
[2013-12-09 18:59:12.595] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:12.596] SENT ACK
[2013-12-09 18:59:12.596] Delivered to Z-Wave stack
[2013-12-09 18:59:12.606] RECEIVED: ( 01 05 00 13 11 00 F8 )
[2013-12-09 18:59:12.607] SENT ACK
[2013-12-09 18:59:12.607] Job 0x13 (Version Version Get): Delivered
[2013-12-09 18:59:12.607] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:12.607] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:12.607] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:12.607] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:12.607] SendData Response with callback 0x11 received: received by recipient
[2013-12-09 18:59:12.608] SETDATA devices.2.data.lastSend = 119444 (0x0001d294)
[2013-12-09 18:59:12.608] Job 0x13 (Version Version Get): success
[2013-12-09 18:59:12.608] Removing job: Version Version Get
[2013-12-09 18:59:12.618] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 86 01 E2 )
[2013-12-09 18:59:12.619] SENT ACK
[2013-12-09 18:59:12.619] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:12.619] Node 2:0 CC Version: Version is v1
[2013-12-09 18:59:12.619] SETDATA devices.2.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2013-12-09 18:59:12.676] SENDING (cb 0x12): ( 01 0A 00 13 02 03 86 13 87 25 12 C2 )
[2013-12-09 18:59:12.686] RECEIVED ACK
[2013-12-09 18:59:12.697] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:12.697] SENT ACK
[2013-12-09 18:59:12.698] Delivered to Z-Wave stack
[2013-12-09 18:59:12.708] RECEIVED: ( 01 05 00 13 12 00 FB )
[2013-12-09 18:59:12.708] SENT ACK
[2013-12-09 18:59:12.708] Job 0x13 (Indicator Version Get): Delivered
[2013-12-09 18:59:12.709] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:12.709] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:12.709] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:12.709] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:12.709] SendData Response with callback 0x12 received: received by recipient
[2013-12-09 18:59:12.709] SETDATA devices.2.data.lastSend = 119453 (0x0001d29d)
[2013-12-09 18:59:12.710] Job 0x13 (Indicator Version Get): success
[2013-12-09 18:59:12.710] Removing job: Indicator Version Get
[2013-12-09 18:59:12.720] RECEIVED: ( 01 0A 00 04 00 02 04 86 14 87 01 E3 )
[2013-12-09 18:59:12.720] SENT ACK
[2013-12-09 18:59:12.720] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:12.721] Node 2:0 CC Version: Indicator is v1
[2013-12-09 18:59:12.721] SETDATA devices.2.instances.0.commandClasses.135.data.version = 1 (0x00000001)
[2013-12-09 18:59:12.721] SETDATA devices.2.instances.0.commandClasses.134.data.interviewDone = True
[2013-12-09 18:59:12.721] Node 2:0 CC Version Interview done
[2013-12-09 18:59:12.722] Saving configuration data to ./config/zddx/d8973ec9-DevicesData.xml
[2013-12-09 18:59:14.143] Interview step 2S skipped due to absence of Security CC
[2013-12-09 18:59:14.154] Interview step 2
[2013-12-09 18:59:14.154] SETDATA devices.2.instances.0.commandClasses.114.data.interviewDone = False
[2013-12-09 18:59:14.154] SETDATA devices.2.instances.0.commandClasses.114.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:14.154] Node 2:0 CC ManufacturerSpecific Interview started
[2013-12-09 18:59:14.154] Adding job: ManufacturerSpecific Get
[2013-12-09 18:59:14.219] SENDING (cb 0x13): ( 01 09 00 13 02 02 72 04 25 13 A5 )
[2013-12-09 18:59:14.229] RECEIVED ACK
[2013-12-09 18:59:14.240] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:14.240] SENT ACK
[2013-12-09 18:59:14.240] Delivered to Z-Wave stack
[2013-12-09 18:59:14.250] RECEIVED: ( 01 05 00 13 13 00 FA )
[2013-12-09 18:59:14.251] SENT ACK
[2013-12-09 18:59:14.251] Job 0x13 (ManufacturerSpecific Get): Delivered
[2013-12-09 18:59:14.251] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:14.251] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2013-12-09 18:59:14.251] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:14.251] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:14.252] SendData Response with callback 0x13 received: received by recipient
[2013-12-09 18:59:14.252] SETDATA devices.2.data.lastSend = 119462 (0x0001d2a6)
[2013-12-09 18:59:14.252] Job 0x13 (ManufacturerSpecific Get): success
[2013-12-09 18:59:14.252] Removing job: ManufacturerSpecific Get
[2013-12-09 18:59:14.263] RECEIVED: ( 01 0E 00 04 00 02 08 72 05 00 1A 53 4C 00 00 8D )
[2013-12-09 18:59:14.263] SENT ACK
[2013-12-09 18:59:14.263] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:14.263] SETDATA devices.2.instances.0.commandClasses.114.data.vendorId = 26 (0x0000001a)
[2013-12-09 18:59:14.267] SETDATA devices.2.instances.0.commandClasses.114.data.vendor = "Cooper"
[2013-12-09 18:59:14.267] SETDATA devices.2.instances.0.commandClasses.114.data.productType = 21324 (0x0000534c)
[2013-12-09 18:59:14.267] SETDATA devices.2.instances.0.commandClasses.114.data.productId = 0 (0x00000000)
[2013-12-09 18:59:14.267] SETDATA devices.2.data.manufacturerId = 26 (0x0000001a)
[2013-12-09 18:59:14.267] SETDATA devices.2.data.manufacturerProductType = 21324 (0x0000534c)
[2013-12-09 18:59:14.267] SETDATA devices.2.data.manufacturerProductId = 0 (0x00000000)
[2013-12-09 18:59:14.270] SETDATA devices.2.data.vendorString = "Cooper"
[2013-12-09 18:59:14.270] SETDATA devices.2.instances.0.commandClasses.114.data.interviewDone = True
[2013-12-09 18:59:14.270] Node 2:0 CC ManufacturerSpecific Interview done
[2013-12-09 18:59:14.271] Saving configuration data to ./config/zddx/d8973ec9-DevicesData.xml
[2013-12-09 18:59:17.291] Loading ZDDX index from ./ZDDX/ZDDX.indxml
[2013-12-09 18:59:17.397] Found multiple partial matches, choose manually
[2013-12-09 18:59:17.399] Interview step 3 skipped due to absence of MultiInstance CC
[2013-12-09 18:59:17.407] Interview step 4
[2013-12-09 18:59:17.408] SETDATA devices.2.instances.0.commandClasses.37.data.interviewDone = False
[2013-12-09 18:59:17.408] SETDATA devices.2.instances.0.commandClasses.37.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.408] Node 2:0 CC SwitchBinary Interview started
[2013-12-09 18:59:17.409] Adding job: SwitchBinary Get
[2013-12-09 18:59:17.409] SETDATA devices.2.instances.0.commandClasses.39.data.interviewDone = False
[2013-12-09 18:59:17.409] SETDATA devices.2.instances.0.commandClasses.39.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.409] Node 2:0 CC SwitchAll Interview started
[2013-12-09 18:59:17.410] Adding job: SwitchAll Get
[2013-12-09 18:59:17.411] Adding job: SwitchAll Set
[2013-12-09 18:59:17.411] Job 0x13 (SwitchAll Get): removing duplicate
[2013-12-09 18:59:17.412] Node 2:0 CC SwitchAll: Auto Configuration done
[2013-12-09 18:59:17.412] SETDATA devices.2.instances.0.commandClasses.43.data.interviewDone = False
[2013-12-09 18:59:17.412] SETDATA devices.2.instances.0.commandClasses.43.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.412] Node 2:0 CC SceneActivation Interview started
[2013-12-09 18:59:17.413] SETDATA devices.2.instances.0.commandClasses.43.data.interviewDone = True
[2013-12-09 18:59:17.413] Node 2:0 CC SceneActivation Interview done
[2013-12-09 18:59:17.413] SETDATA devices.2.instances.0.commandClasses.44.data.interviewDone = False
[2013-12-09 18:59:17.413] SETDATA devices.2.instances.0.commandClasses.44.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.413] Node 2:0 CC SceneActuatorConf Interview started
[2013-12-09 18:59:17.413] SETDATA devices.2.instances.0.commandClasses.44.data.interviewDone = True
[2013-12-09 18:59:17.413] Node 2:0 CC SceneActuatorConf Interview done
[2013-12-09 18:59:17.413] SETDATA devices.2.instances.0.commandClasses.112.data.interviewDone = False
[2013-12-09 18:59:17.414] SETDATA devices.2.instances.0.commandClasses.112.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.414] Node 2:0 CC Configuration Interview started
[2013-12-09 18:59:17.414] SETDATA devices.2.instances.0.commandClasses.112.data.interviewDone = True
[2013-12-09 18:59:17.414] Node 2:0 CC Configuration Interview done
[2013-12-09 18:59:17.414] SETDATA devices.2.instances.0.commandClasses.113.data.interviewDone = False
[2013-12-09 18:59:17.414] SETDATA devices.2.instances.0.commandClasses.113.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.415] Node 2:0 CC Alarm Interview started
[2013-12-09 18:59:17.415] SETDATA devices.2.instances.0.commandClasses.113.data.V1supported = True
[2013-12-09 18:59:17.415] SETDATA devices.2.instances.0.commandClasses.113.data.typeMask = Empty
[2013-12-09 18:59:17.415] SETDATA devices.2.instances.0.commandClasses.113.data.interviewDone = True
[2013-12-09 18:59:17.415] Node 2:0 CC Alarm Interview done
[2013-12-09 18:59:17.415] SETDATA devices.2.instances.0.commandClasses.117.data.interviewDone = False
[2013-12-09 18:59:17.415] SETDATA devices.2.instances.0.commandClasses.117.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.415] Node 2:0 CC Protection Interview started
[2013-12-09 18:59:17.417] Adding job: Protection Set (v1)
[2013-12-09 18:59:17.417] Adding job: Protection Get
[2013-12-09 18:59:17.417] Node 2:0 CC Protection: Auto Configuration done
[2013-12-09 18:59:17.418] Job 0x13 (Protection Get): removing duplicate
[2013-12-09 18:59:17.418] SETDATA devices.2.instances.0.commandClasses.119.data.interviewDone = False
[2013-12-09 18:59:17.418] SETDATA devices.2.instances.0.commandClasses.119.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.419] Node 2:0 CC NodeNaming Interview started
[2013-12-09 18:59:17.420] SETDATA devices.2.instances.0.commandClasses.119.data.myname = "Gateway"
[2013-12-09 18:59:17.420] SETDATA devices.2.instances.0.commandClasses.119.data.mylocation = ""
[2013-12-09 18:59:17.420] Adding job: NodeNaming GetName
[2013-12-09 18:59:17.420] Adding job: NodeNaming GetLocation
[2013-12-09 18:59:17.421] SETDATA devices.2.instances.0.commandClasses.133.data.interviewDone = False
[2013-12-09 18:59:17.421] SETDATA devices.2.instances.0.commandClasses.133.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.421] Node 2:0 CC Association Interview started
[2013-12-09 18:59:17.421] Adding job: Association Groupings Get
[2013-12-09 18:59:17.421] SETDATA devices.2.instances.0.commandClasses.135.data.interviewDone = False
[2013-12-09 18:59:17.422] SETDATA devices.2.instances.0.commandClasses.135.data.interviewCounter = 9 (0x00000009)
[2013-12-09 18:59:17.422] Node 2:0 CC Indicator Interview started
[2013-12-09 18:59:17.422] Adding job: Indicator Get
[2013-12-09 18:59:17.484] SENDING (cb 0x14): ( 01 09 00 13 02 02 25 02 25 14 F3 )
[2013-12-09 18:59:17.495] RECEIVED ACK
[2013-12-09 18:59:17.505] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:17.505] SENT ACK
[2013-12-09 18:59:17.506] Delivered to Z-Wave stack
[2013-12-09 18:59:17.516] RECEIVED: ( 01 05 00 13 14 00 FD )
[2013-12-09 18:59:17.516] SENT ACK
[2013-12-09 18:59:17.516] Job 0x13 (SwitchBinary Get): Delivered
[2013-12-09 18:59:17.517] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:17.517] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2013-12-09 18:59:17.517] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:17.517] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:17.517] SendData Response with callback 0x14 received: received by recipient
[2013-12-09 18:59:17.517] SETDATA devices.2.data.lastSend = 119471 (0x0001d2af)
[2013-12-09 18:59:17.518] Job 0x13 (SwitchBinary Get): success
[2013-12-09 18:59:17.518] Removing job: SwitchBinary Get
[2013-12-09 18:59:17.528] RECEIVED: ( 01 09 00 04 00 02 03 25 03 FF 2A )
[2013-12-09 18:59:17.529] SENT ACK
[2013-12-09 18:59:17.529] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:17.529] SETDATA devices.2.instances.0.commandClasses.37.data.level = 255 (0x000000ff)
[2013-12-09 18:59:17.529] SETDATA devices.2.instances.0.commandClasses.37.data.interviewDone = True
[2013-12-09 18:59:17.529] Node 2:0 CC SwitchBinary Interview done
[2013-12-09 18:59:17.586] SENDING (cb 0x15): ( 01 0A 00 13 02 03 27 01 00 25 15 F1 )
[2013-12-09 18:59:17.597] RECEIVED ACK
[2013-12-09 18:59:17.607] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:17.607] SENT ACK
[2013-12-09 18:59:17.608] Delivered to Z-Wave stack
[2013-12-09 18:59:17.618] RECEIVED: ( 01 05 00 13 15 00 FC )
[2013-12-09 18:59:17.618] SENT ACK
[2013-12-09 18:59:17.618] Job 0x13 (SwitchAll Set): Delivered
[2013-12-09 18:59:17.619] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:17.619] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:17.619] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:17.619] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:17.619] SendData Response with callback 0x15 received: received by recipient
[2013-12-09 18:59:17.619] SETDATA devices.2.data.lastSend = 119480 (0x0001d2b8)
[2013-12-09 18:59:17.619] Job 0x13 (SwitchAll Set): success
[2013-12-09 18:59:17.620] Removing job: SwitchAll Set
[2013-12-09 18:59:17.688] SENDING (cb 0x16): ( 01 09 00 13 02 02 27 02 25 16 F3 )
[2013-12-09 18:59:17.699] RECEIVED ACK
[2013-12-09 18:59:17.709] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:17.709] SENT ACK
[2013-12-09 18:59:17.709] Delivered to Z-Wave stack
[2013-12-09 18:59:17.720] RECEIVED: ( 01 05 00 13 16 00 FF )
[2013-12-09 18:59:17.720] SENT ACK
[2013-12-09 18:59:17.720] Job 0x13 (SwitchAll Get): Delivered
[2013-12-09 18:59:17.720] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:17.721] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2013-12-09 18:59:17.721] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:17.721] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:17.721] SendData Response with callback 0x16 received: received by recipient
[2013-12-09 18:59:17.721] SETDATA devices.2.data.lastSend = 119489 (0x0001d2c1)
[2013-12-09 18:59:17.722] Job 0x13 (SwitchAll Get): success
[2013-12-09 18:59:17.722] Removing job: SwitchAll Get
[2013-12-09 18:59:17.732] RECEIVED: ( 01 09 00 04 00 02 03 27 03 00 D7 )
[2013-12-09 18:59:17.732] SENT ACK
[2013-12-09 18:59:17.733] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:17.733] SETDATA devices.2.instances.0.commandClasses.39.data.mode = 0 (0x00000000)
[2013-12-09 18:59:17.733] SETDATA devices.2.instances.0.commandClasses.39.data.interviewDone = True
[2013-12-09 18:59:17.733] Node 2:0 CC SwitchAll Interview done
[2013-12-09 18:59:17.790] SENDING (cb 0x17): ( 01 0A 00 13 02 03 75 01 00 25 17 A1 )
[2013-12-09 18:59:17.801] RECEIVED ACK
[2013-12-09 18:59:17.811] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:17.811] SENT ACK
[2013-12-09 18:59:17.811] Delivered to Z-Wave stack
[2013-12-09 18:59:17.822] RECEIVED: ( 01 05 00 13 17 00 FE )
[2013-12-09 18:59:17.822] SENT ACK
[2013-12-09 18:59:17.822] Job 0x13 (Protection Set (v1)): Delivered
[2013-12-09 18:59:17.823] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:17.823] SETDATA devices.2.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2013-12-09 18:59:17.823] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:17.823] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:17.823] SendData Response with callback 0x17 received: received by recipient
[2013-12-09 18:59:17.823] SETDATA devices.2.data.lastSend = 119498 (0x0001d2ca)
[2013-12-09 18:59:17.823] Job 0x13 (Protection Set (v1)): success
[2013-12-09 18:59:17.823] Removing job: Protection Set (v1)
[2013-12-09 18:59:17.891] SENDING (cb 0x18): ( 01 09 00 13 02 02 75 02 25 18 AF )
[2013-12-09 18:59:17.902] RECEIVED ACK
[2013-12-09 18:59:17.913] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:17.913] SENT ACK
[2013-12-09 18:59:17.913] Delivered to Z-Wave stack
[2013-12-09 18:59:17.924] RECEIVED: ( 01 05 00 13 18 00 F1 )
[2013-12-09 18:59:17.924] SENT ACK
[2013-12-09 18:59:17.924] Job 0x13 (Protection Get): Delivered
[2013-12-09 18:59:17.924] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:17.924] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2013-12-09 18:59:17.924] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:17.925] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:17.925] SendData Response with callback 0x18 received: received by recipient
[2013-12-09 18:59:17.925] SETDATA devices.2.data.lastSend = 119507 (0x0001d2d3)
[2013-12-09 18:59:17.925] Job 0x13 (Protection Get): success
[2013-12-09 18:59:17.925] Removing job: Protection Get
[2013-12-09 18:59:17.936] RECEIVED: ( 01 09 00 04 00 02 03 75 03 00 85 )
[2013-12-09 18:59:17.936] SENT ACK
[2013-12-09 18:59:17.936] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:17.936] SETDATA devices.2.instances.0.commandClasses.117.data.state = 0 (0x00000000)
[2013-12-09 18:59:17.936] SETDATA devices.2.instances.0.commandClasses.117.data.interviewDone = True
[2013-12-09 18:59:17.937] Node 2:0 CC Protection Interview done
[2013-12-09 18:59:17.994] SENDING (cb 0x19): ( 01 09 00 13 02 02 77 02 25 19 AC )
[2013-12-09 18:59:18.004] RECEIVED ACK
[2013-12-09 18:59:18.015] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:18.015] SENT ACK
[2013-12-09 18:59:18.015] Delivered to Z-Wave stack
[2013-12-09 18:59:18.026] RECEIVED: ( 01 05 00 13 19 00 F0 )
[2013-12-09 18:59:18.026] SENT ACK
[2013-12-09 18:59:18.026] Job 0x13 (NodeNaming GetName): Delivered
[2013-12-09 18:59:18.026] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:18.026] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2013-12-09 18:59:18.026] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:18.027] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:18.027] SendData Response with callback 0x19 received: received by recipient
[2013-12-09 18:59:18.027] SETDATA devices.2.data.lastSend = 119516 (0x0001d2dc)
[2013-12-09 18:59:18.027] Job 0x13 (NodeNaming GetName): success
[2013-12-09 18:59:18.027] Removing job: NodeNaming GetName
[2013-12-09 18:59:18.038] RECEIVED: ( 01 0F 00 04 00 02 09 77 03 00 53 77 69 74 63 68 B9 )
[2013-12-09 18:59:18.038] SENT ACK
[2013-12-09 18:59:18.038] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:18.038] SETDATA devices.2.instances.0.commandClasses.119.data.nodename = "Switch"
[2013-12-09 18:59:18.038] SETDATA devices.2.instances.0.commandClasses.119.data.interviewDone = True
[2013-12-09 18:59:18.039] Node 2:0 CC NodeNaming Interview done
[2013-12-09 18:59:18.095] SENDING (cb 0x1a): ( 01 09 00 13 02 02 77 05 25 1A A8 )
[2013-12-09 18:59:18.106] RECEIVED ACK
[2013-12-09 18:59:18.116] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:18.117] SENT ACK
[2013-12-09 18:59:18.117] Delivered to Z-Wave stack
[2013-12-09 18:59:18.128] RECEIVED: ( 01 05 00 13 1A 00 F3 )
[2013-12-09 18:59:18.128] SENT ACK
[2013-12-09 18:59:18.128] Job 0x13 (NodeNaming GetLocation): Delivered
[2013-12-09 18:59:18.128] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:18.128] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2013-12-09 18:59:18.129] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2013-12-09 18:59:18.129] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:18.129] SendData Response with callback 0x1a received: received by recipient
[2013-12-09 18:59:18.129] SETDATA devices.2.data.lastSend = 119525 (0x0001d2e5)
[2013-12-09 18:59:18.129] Job 0x13 (NodeNaming GetLocation): success
[2013-12-09 18:59:18.129] Removing job: NodeNaming GetLocation
[2013-12-09 18:59:18.140] RECEIVED: ( 01 09 00 04 00 02 03 77 06 00 82 )
[2013-12-09 18:59:18.140] SENT ACK
[2013-12-09 18:59:18.140] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:18.140] SETDATA devices.2.instances.0.commandClasses.119.data.location = ""
[2013-12-09 18:59:18.197] SENDING (cb 0x1b): ( 01 09 00 13 02 02 85 05 25 1B 5B )
[2013-12-09 18:59:18.208] RECEIVED ACK
[2013-12-09 18:59:18.218] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-12-09 18:59:18.218] SENT ACK
[2013-12-09 18:59:18.219] Delivered to Z-Wave stack
[2013-12-09 18:59:18.229] RECEIVED: ( 01 05 00 13 1B 00 F2 )
[2013-12-09 18:59:18.229] SENT ACK
[2013-12-09 18:59:18.230] Job 0x13 (Association Groupings Get): Delivered
[2013-12-09 18:59:18.230] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2013-12-09 18:59:18.230] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2013-12-09 18:59:18.230] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 11 (0x0000000b)
[2013-12-09 18:59:18.231] SETDATA devices.2.data.lastPacketInfo = **********
[2013-12-09 18:59:18.231] SendData Response with callback 0x1b received: received by recipient
[2013-12-09 18:59:18.231] SETDATA devices.2.data.lastSend = 119534 (0x0001d2ee)
[2013-12-09 18:59:18.231] Job 0x13 (Association Groupings Get): success
[2013-12-09 18:59:18.231] Removing job: Association Groupings Get
[2013-12-09 18:59:18.242] RECEIVED: ( 01 09 00 04 00 02 03 85 06 FF 8F )
[2013-12-09 18:59:18.242] SENT ACK
[2013-12-09 18:59:18.242] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-12-09 18:59:18.242] SETDATA devices.2.instances.0.commandClasses.133.data.groups = 255 (0x000000ff)
[2013-12-09 18:59:18.242] SETDATA devices.2.instances.0.commandClasses.133.data.1 = Empty
[2013-12-09 18:59:18.243] SETDATA devices.2.instances.0.commandClasses.133.data.1.max = Empty
[2013-12-09 18:59:18.243] SETDATA devices.2.instances.0.commandClasses.133.data.1.max = 0 (0x00000000)
[2013-12-09 18:59:18.243] SETDATA devices.2.instances.0.commandClasses.133.data.1.nodes = Empty
[2013-12-09 18:59:18.243] SETDATA devices.2.instances.0.commandClasses.133.data.1.nodes = byte[0]
( zero-length buffer )
[2013-12-09 18:59:18.243] SETDATA devices.2.instances.0.commandClasses.133.data.1.nodesToFollow = Empty
[2013-12-09 18:59:18.243] SETDATA devices.2.instances.0.commandClasses.133.data.1.nodesToFollow = byte[0]
[2013-12-09 18:59:18.244] Adding job: Association Get
[2013-12-09 18:59:18.244] SETDATA devices.2.instances.0.commandClasses.133.data.2 = Empty
[2013-12-09 18:59:18.244] SETDATA devices.2.instances.0.commandClasses.133.data.2.max = Empty
[2013-12-09 18:59:18.244] SETDATA devices.2.instances.0.commandClasses.133.data.2.max = 0 (0x00000000)
[2013-12-09 18:59:18.244] SETDATA devices.2.instances.0.commandClasses.133.data.2.nodes = Empty
[2013-12-09 18:59:18.244] SETDATA devices.2.instances.0.commandClasses.133.data.2.nodes = byte[0]
[2013-12-09 18:59:18.244] SETDATA devices.2.instances.0.commandClasses.133.data.2.nodesToFollow = Empty
[2013-12-09 18:59:18.245] SETDATA devices.2.instances.0.commandClasses.133.data.2.nodesToFollow = byte[0]
[2013-12-09 18:59:18.245] Adding job: Association Get
[2013-12-09 18:59:18.245] SETDATA devices.2.instances.0.commandClasses.133.data.3 = Empty
[2013-12-09 18:59:18.245] SETDATA devices.2.instances.0.commandClasses.133.data.3.max = Empty
[2013-12-09 18:59:18.246] SETDATA devices.2.instances.0.commandClasses.133.data.3.max = 0 (0x00000000)
[2013-12-09 18:59:18.246] SETDATA devices.2.instances.0.commandClasses.133.data.3.nodes = Empty
[2013-12-09 18:59:18.246] SETDATA devices.2.instances.0.commandClasses.133.data.3.nodes = byte[0]
[2013-12-09 18:59:18.246] SETDATA devices.2.instances.0.commandClasses.133.data.3.nodesToFollow = Empty
[2013-12-09 18:59:18.246] SETDATA devices.2.instances.0.commandClasses.133.data.3.nodesToFollow = byte[0]
[2013-12-09 18:59:18.246] Adding job: Association Get
[2013-12-09 18:59:18.247] SETDATA devices.2.instances.0.commandClasses.133.data.4 = Empty
[2013-12-09 18:59:18.247] SETDATA devices.2.instances.0.commandClasses.133.data.4.max = Empty
[2013-12-09 18:59:18.247] SETDATA devices.2.instances.0.commandClasses.133.data.4.max = 0 (0x00000000)
[2013-12-09 18:59:18.247] SETDATA devices.2.instances.0.commandClasses.133.data.4.nodes = Empty
[2013-12-09 18:59:18.247] SETDATA devices.2.instances.0.commandClasses.133.data.4.nodes = byte[0]
[2013-12-09 18:59:18.247] SETDATA devices.2.instances.0.commandClasses.133.data.4.nodesToFollow = Empty
[2013-12-09 18:59:18.247] SETDATA devices.2.instances.0.commandClasses.133.data.4.nodesToFollow = byte[0]
[2013-12-09 18:59:18.248] Adding job: Association Get
[2013-12-09 18:59:18.248] SETDATA devices.2.instances.0.commandClasses.133.data.5 = Empty
[2013-12-09 18:59:18.248] SETDATA devices.2.instances.0.commandClasses.133.data.5.max = Empty
[2013-12-09 18:59:18.248] SETDATA devices.2.instances.0.commandClasses.133.data.5.max = 0 (0x00000000)
[2013-12-09 18:59:18.248] SETDATA devices.2.instances.0.commandClasses.133.data.5.nodes = Empty
[2013-12-09 18:59:18.248] SETDATA devices.2.instances.0.commandClasses.133.data.5.nodes = byte[0]
[2013-12-09 18:59:18.248] SETDATA devices.2.instances.0.commandClasses.133.data.5.nodesToFollow = Empty
[2013-12-09 18:59:18.249] SETDATA devices.2.instances.0.commandClasses.133.data.5.nodesToFollow = byte[0]
[2013-12-09 18:59:18.249] Adding job: Association Get
[2013-12-09 18:59:18.249] SETDATA devices.2.instances.0.commandClasses.133.data.6 = Empty
[2013-12-09 18:59:18.249] SETDATA devices.2.instances.0.commandClasses.133.data.6.max = Empty
[2013-12-09 18:59:18.249] SETDATA devices.2.instances.0.commandClasses.133.data.6.max = 0 (0x00000000)
[2013-12-09 18:59:18.249] SETDATA devices.2.instances.0.commandClasses.133.data.6.nodes = Empty
[2013-12-09 18:59:18.249] SETDATA devices.2.instances.0.commandClasses.133.data.6.nodes = byte[0]
[2013-12-09 18:59:18.250] SETDATA devices.2.instances.0.commandClasses.133.data.6.nodesToFollow = Empty
[2013-12-09 18:59:18.250] SETDATA devices.2.instances.0.commandClasses.133.data.6.nodesToFollow = byte[0]
[2013-12-09 18:59:18.250] Adding job: Association Get
[2013-12-09 18:59:18.251] SETDATA devices.2.instances.0.commandClasses.133.data.7 = Empty
[2013-12-09 18:59:18.251] SETDATA devices.2.instances.0.commandClasses.133.data.7.max = Empty
[2013-12-09 18:59:18.251] SETDATA devices.2.instances.0.commandClasses.133.data.7.max = 0 (0x00000000)
[2013-12-09 18:59:18.251] SETDATA devices.2.instances.0.commandClasses.133.data.7.nodes = Empty
[2013-12-09 18:59:18.251] SETDATA devices.2.instances.0.commandClasses.133.data.7.nodes = byte[0]
[2013-12-09 18:59:18.251] SETDATA devices.2.instances.0.commandClasses.133.data.7.nodesToFollow = Empty
[2013-12-09 18:59:18.252] SETDATA devices.2.instances.0.commandClasses.133.data.7.nodesToFollow = byte[0]
[2013-12-09 18:59:18.252] Adding job: Association Get
[2013-12-09 18:59:18.252] SETDATA devices.2.instances.0.commandClasses.133.data.8 = Empty
[2013-12-09 18:59:18.252] SETDATA devices.2.instances.0.commandClasses.133.data.8.max = Empty
[2013-12-09 18:59:18.252] SETDATA devices.2.instances.0.commandClasses.133.data.8.max = 0 (0x00000000)
[2013-12-09 18:59:18.253] SETDATA devices.2.instances.0.commandClasses.133.data.8.nodes = Empty
[2013-12-09 18:59:18.253] SETDATA devices.2.instances.0.commandClasses.133.data.8.nodes = byte[0]
[2013-12-09 18:59:18.253] SETDATA devices.2.instances.0.commandClasses.133.data.8.nodesToFollow = Empty
[2013-12-09 18:59:18.253] SETDATA devices.2.instances.0.commandClasses.133.data.8.nodesToFollow = byte[0]
[2013-12-09 18:59:18.253] Adding job: Association Get
[2013-12-09 18:59:18.253] SETDATA devices.2.instances.0.commandClasses.133.data.9 = Empty
[2013-12-09 18:59:18.254] SETDATA devices.2.instances.0.commandClasses.133.data.9.max = Empty
[2013-12-09 18:59:18.254] SETDATA devices.2.instances.0.commandClasses.133.data.9.max = 0 (0x00000000)
[2013-12-09 18:59:18.254] SETDATA devices.2.instances.0.commandClasses.133.data.9.nodes = Empty
[2013-12-09 18:59:18.254] SETDATA devices.2.instances.0.commandClasses.133.data.9.nodes = byte[0]
[2013-12-09 18:59:18.254] SETDATA devices.2.instances.0.commandClasses.133.data.9.nodesToFollow = Empty
[2013-12-09 18:59:18.254] SETDATA devices.2.instances.0.commandClasses.133.data.9.nodesToFollow = byte[0]
[2013-12-09 18:59:18.254] Adding job: Association Get
[2013-12-09 18:59:18.255] SETDATA devices.2.instances.0.commandClasses.133.data.10 = Empty
[2013-12-09 18:59:18.255] SETDATA devices.2.instances.0.commandClasses.133.data.10.max = Empty
[2013-12-09 18:59:18.255] SETDATA devices.2.instances.0.commandClasses.133.data.10.max = 0 (0x00000000)
[2013-12-09 18:59:18.255] SETDATA devices.2.instances.0.commandClasses.133.data.10.nodes = Empty
[2013-12-09 18:59:18.255] SETDATA devices.2.instances.0.commandClasses.133.data.10.nodes = byte[0]
[2013-12-09 18:59:18.255] SETDATA devices.2.instances.0.commandClasses.133.data.10.nodesToFollow = Empty
[2013-12-09 18:59:18.255] SETDATA devices.2.instances.0.commandClasses.133.data.10.nodesToFollow = byte[0]
[2013-12-09 18:59:18.256] Adding job: Association Get
[2013-12-09 18:59:18.256] SETDATA devices.2.instances.0.commandClasses.133.data.11 = Empty
[2013-12-09 18:59:18.256] SETDATA devices.2.instances.0.commandClasses.133.data.11.max = Empty
[2013-12-09 18:59:18.256] SETDATA devices.2.instances.0.commandClasses.133.data.11.max = 0 (0x00000000)
[2013-12-09 18:59:18.256] SETDATA devices.2.instances.0.commandClasses.133.data.11.nodes = Empty
[2013-12-09 18:59:18.256] SETDATA devices.2.instances.0.commandClasses.133.data.11.nodes = byte[0]
[2013-12-09 18:59:18.257] SETDATA devices.2.instances.0.commandClasses.133.data.11.nodesToFollow = Empty
[2013-12-09 18:59:18.257] SETDATA devices.2.instances.0.commandClasses.133.data.11.nodesToFollow = byte[0]
[2013-12-09 18:59:18.257] Adding job: Association Get
[2013-12-09 18:59:18.257] SETDATA devices.2.instances.0.commandClasses.133.data.12 = Empty
[2013-12-09 18:59:18.257] SETDATA devices.2.instances.0.commandClasses.133.data.12.max = Empty
[2013-12-09 18:59:18.257] SETDATA devices.2.instances.0.commandClasses.133.data.12.max = 0 (0x00000000)
[2013-12-09 18:59:18.257] SETDATA devices.2.instances.0.commandClasses.133.data.12.nodes = Empty
[2013-12-09 18:59:18.258] SETDATA devices.2.instances.0.commandClasses.133.data.12.nodes = byte[0]
[2013-12-09 18:59:18.258] SETDATA devices.2.instances.0.commandClasses.133.data.12.nodesToFollow = Empty
[2013-12-09 18:59:18.258] SETDATA devices.2.instances.0.commandClasses.133.data.12.nodesToFollow = byte[0]
[2013-12-09 18:59:18.258] Adding job: Association Get
[2013-12-09 18:59:18.258] SETDATA devices.2.instances.0.commandClasses.133.data.13 = Empty
[2013-12-09 18:59:18.259] SETDATA devices.2.instances.0.commandClasses.133.data.13.max = Empty
[2013-12-09 18:59:18.259] SETDATA devices.2.instances.0.commandClasses.133.data.13.max = 0 (0x00000000)
[2013-12-09 18:59:18.259] SETDATA devices.2.instances.0.commandClasses.133.data.13.nodes = Empty
[2013-12-09 18:59:18.259] SETDATA devices.2.instances.0.commandClasses.133.data.13.nodes = byte[0]
[2013-12-09 18:59:18.259] SETDATA devices.2.instances.0.commandClasses.133.data.13.nodesToFollow = Empty
[2013-12-09 18:59:18.259] SETDATA devices.2.instances.0.commandClasses.133.data.13.nodesToFollow = byte[0]
[2013-12-09 18:59:18.259] Adding job: Association Get
[2013-12-09 18:59:18.260] SETDATA devices.2.instances.0.commandClasses.133.data.14 = Empty
[2013-12-09 18:59:18.260] SETDATA devices.2.instances.0.commandClasses.133.data.14.max = Empty
[2013-12-09 18:59:18.260] SETDATA devices.2.instances.0.commandClasses.133.data.14.max = 0 (0x00000000)
[2013-12-09 18:59:18.260] SETDATA devices.2.instances.0.commandClasses.133.data.14.nodes = Empty
[2013-12-09 18:59:18.260] SETDATA devices.2.instances.0.commandClasses.133.data.14.nodes = byte[0]
[2013-12-09 18:59:18.261] SETDATA devices.2.instances.0.commandClasses.133.data.14.nodesToFollow = Empty
[2013-12-09 18:59:18.261] SETDATA devices.2.instances.0.commandClasses.133.data.14.nodesToFollow = byte[0]
[2013-12-09 18:59:18.261] Adding job: Association Get
[2013-12-09 18:59:18.261] SETDATA devices.2.instances.0.commandClasses.133.data.15 = Empty
[2013-12-09 18:59:18.262] SETDATA devices.2.instances.0.commandClasses.133.data.15.max = Empty
[2013-12-09 18:59:18.262] SETDATA devices.2.instances.0.commandClasses.133.data.15.max = 0 (0x00000000)
[2013-12-09 18:59:18.262] SETDATA devices.2.instances.0.commandClasses.133.data.15.nodes = Empty
[2013-12-09 18:59:18.262] SETDATA devices.2.instances.0.commandClasses.133.data.15.nodes = byte[0]
[2013-12-09 18:59:18.262] SETDATA devices.2.instances.0.commandClasses.133.data.15.nodesToFollow = Empty
[2013-12-09 18:59:18.262] SETDATA devices.2.instances.0.commandClasses.133.data.15.nodesToFollow = byte[0]
[2013-12-09 18:59:18.263] Adding job: Association Get
[2013-12-09 18:59:18.263] SETDATA devices.2.instances.0.commandClasses.133.data.16 = Empty
[2013-12-09 18:59:18.263] SETDATA devices.2.instances.0.commandClasses.133.data.16.max = Empty
[2013-12-09 18:59:18.263] SETDATA devices.2.instances.0.commandClasses.133.data.16.max = 0 (0x00000000)
[2013-12-09 18:59:18.263] SETDATA devices.2.instances.0.commandClasses.133.data.16.nodes = Empty
[2013-12-09 18:59:18.263] SETDATA devices.2.instances.0.commandClasses.133.data.16.nodes = byte[0]
[2013-12-09 18:59:18.263] SETDATA devices.2.instances.0.commandClasses.133.data.16.nodesToFollow = Empty
[2013-12-09 18:59:18.264] SETDATA devices.2.instances.0.commandClasses.133.data.16.nodesToFollow = byte[0]
[2013-12-09 18:59:18.264] Adding job: Association Get
[2013-12-09 18:59:18.264] SETDATA devices.2.instances.0.commandClasses.133.data.17 = Empty
[2013-12-09 18:59:18.264] SETDATA devices.2.instances.0.commandClasses.133.data.17.max = Empty
[2013-12-09 18:59:18.264] SETDATA devices.2.instances.0.commandClasses.133.data.17.max = 0 (0x00000000)
[2013-12-09 18:59:18.264] SETDATA devices.2.instances.0.commandClasses.133.data.17.nodes = Empty
[2013-12-09 18:59:18.265] SETDATA devices.2.instances.0.commandClasses.133.data.17.nodes = byte[0]
[2013-12-09 18:59:18.265] SETDATA devices.2.instances.0.commandClasses.133.data.17.nodesToFollow = Empty
[2013-12-09 18:59:18.265] SETDATA devices.2.instances.0.commandClasses.133.data.17.nodesToFollow = byte[0]
[2013-12-09 18:59:18.265] Adding job: Association Get
[2013-12-09 18:59:18.265] SETDATA devices.2.instances.0.commandClasses.133.data.18 = Empty
[2013-12-09 18:59:18.265] SETDATA devices.2.instances.0.commandClasses.133.data.18.max = Empty
[2013-12-09 18:59:18.266] SETDATA devices.2.instances.0.commandClasses.133.data.18.max = 0 (0x00000000)
[2013-12-09 18:59:18.266] SETDATA devices.2.instances.0.commandClasses.133.data.18.nodes = Empty
[2013-12-09 18:59:18.266] SETDATA devices.2.instances.0.commandClasses.133.data.18.nodes = byte[0]
[2013-12-09 18:59:18.266] SETDATA devices.2.instances.0.commandClasses.133.data.18.nodesToFollow = Empty
[2013-12-09 18:59:18.266] SETDATA devices.2.instances.0.commandClasses.133.data.18.nodesToFollow = byte[0]
[2013-12-09 18:59:18.267] Adding job: Association Get
[2013-12-09 18:59:18.267] SETDATA devices.2.instances.0.commandClasses.133.data.19 = Empty
[2013-12-09 18:59:18.267] SETDATA devices.2.instances.0.commandClasses.133.data.19.max = Empty
[2013-12-09 18:59:18.267] SETDATA devices.2.instances.0.commandClasses.133.data.19.max = 0 (0x00000000)
[2013-12-09 18:59:18.267] SETDATA devices.2.instances.0.commandClasses.133.data.19.nodes = Empty
[2013-12-09 18:59:18.267] SETDATA devices.2.instances.0.commandClasses.133.data.19.nodes = byte[0]
[2013-12-09 18:59:18.267] SETDATA devices.2.instances.0.commandClasses.133.data.19.nodesToFollow = Empty
[2013-12-09 18:59:18.268] SETDATA devices.2.instances.0.commandClasses.133.data.19.nodesToFollow = byte[0]
[2013-12-09 18:59:18.268] Adding job: Association Get
[2013-12-09 18:59:18.268] SETDATA devices.2.instances.0.commandClasses.133.data.20 = Empty
[2013-12-09 18:59:18.268] SETDATA devices.2.instances.0.commandClasses.133.data.20.max = Empty
[2013-12-09 18:59:18.268] SETDATA devices.2.instances.0.commandClasses.133.data.20.max = 0 (0x00000000)
[2013-12-09 18:59:18.268] SETDATA devices.2.instances.0.commandClasses.133.data.20.nodes = Empty
[2013-12-09 18:59:18.268] SETDATA devices.2.instances.0.commandClasses.133.data.20.nodes = byte[0]
[2013-12-09 18:59:18.269] SETDATA devices.2.instances.0.commandClasses.133.data.20.nodesToFollow = Empty
[2013-12-09 18:59:18.269] SETDATA devices.2.instances.0.commandClasses.133.data.20.nodesToFollow = byte[0]
[2013-12-09 18:59:18.269] Adding job: Association Get
[2013-12-09 18:59:18.269] SETDATA devices.2.instances.0.commandClasses.133.data.21 = Empty
[2013-12-09 18:59:18.269] SETDATA devices.2.instances.0.commandClasses.133.data.21.max = Empty
[2013-12-09 18:59:18.269] SETDATA devices.2.instances.0.commandClasses.133.data.21.max = 0 (0x00000000)
[2013-12-09 18:59:18.270] SETDATA devices.2.instances.0.commandClasses.133.data.21.nodes = Empty
[2013-12-09 18:59:18.270] SETDATA devices.2.instances.0.commandClasses.133.data.21.nodes = byte[0]
[2013-12-09 18:59:18.270] SETDATA devices.2.instances.0.commandClasses.133.data.21.nodesToFollow = Empty
[2013-12-09 18:59:18.270] SETDATA devices.2.instances.0.commandClasses.133.data.21.nodesToFollow = byte[0]
[2013-12-09 18:59:18.270] Adding job: Association Get
[2013-12-09 18:59:18.271] SETDATA devices.2.instances.0.commandClasses.133.data.22 = Empty
[2013-12-09 18:59:18.271] SETDATA devices.2.instances.0.commandClasses.133.data.22.max = Empty
[2013-12-09 18:59:18.271] SETDATA devices.2.instances.0.commandClasses.133.data.22.max = 0 (0x00000000)
[2013-12-09 18:59:18.271] SETDATA devices.2.instances.0.commandClasses.133.data.22.nodes = Empty
[2013-12-09 18:59:18.271] SETDATA devices.2.instances.0.commandClasses.133.data.22.nodes = byte[0]
[2013-12-09 18:59:18.272] SETDATA devices.2.instances.0.commandClasses.133.data.22.nodesToFollow = Empty
[2013-12-09 18:59:18.272] SETDATA devices.2.instances.0.commandClasses.133.data.22.nodesToFollow = byte[0]
[2013-12-09 18:59:18.272] Adding job: Association Get
[2013-12-09 18:59:18.272] SETDATA devices.2.instances.0.commandClasses.133.data.23 = Empty
[2013-12-09 18:59:18.272] SETDATA devices.2.instances.0.commandClasses.133.data.23.max = Empty
[2013-12-09 18:59:18.273] SETDATA devices.2.instances.0.commandClasses.133.data.23.max = 0 (0x00000000)
[2013-12-09 18:59:18.273] SETDATA devices.2.instances.0.commandClasses.133.data.23.nodes = Empty
[2013-12-09 18:59:18.273] SETDATA devices.2.instances.0.commandClasses.133.data.23.nodes = byte[0]
[2013-12-09 18:59:18.273] SETDATA devices.2.instances.0.commandClasses.133.data.23.nodesToFollow = Empty
[2013-12-09 18:59:18.273] SETDATA devices.2.instances.0.commandClasses.133.data.23.nodesToFollow = byte[0]
[2013-12-09 18:59:18.273] Adding job: Association Get
[2013-12-09 18:59:18.274] SETDATA devices.2.instances.0.commandClasses.133.data.24 = Empty
[2013-12-09 18:59:18.274] SETDATA devices.2.instances.0.commandClasses.133.data.24.max = Empty
[2013-12-09 18:59:18.274] SETDATA devices.2.instances.0.commandClasses.133.data.24.max = 0 (0x00000000)
[2013-12-09 18:59:18.274] SETDATA devices.2.instances.0.commandClasses.133.data.24.nodes = Empty
[2013-12-09 18:59:18.274] SETDATA devices.2.instances.0.commandClasses.133.data.24.nodes = byte[0]
[2013-12-09 18:59:18.274] SETDATA devices.2.instances.0.commandClasses.133.data.24.nodesToFollow = Empty
[2013-12-09 18:59:18.275] SETDATA devices.2.instances.0.commandClasses.133.data.24.nodesToFollow = byte[0]
[2013-12-09 18:59:18.275] Adding job: Association Get
[2013-12-09 18:59:18.275] SETDATA devices.2.instances.0.commandClasses.133.data.25 = Empty
[2013-12-09 18:59:18.275] SETDATA devices.2.instances.0.commandClasses.133.data.25.max = Empty
[2013-12-09 18:59:18.275] SETDATA devices.2.instances.0.commandClasses.133.data.25.max = 0 (0x00000000)
[2013-12-09 18:59:18.275] SETDATA devices.2.instances.0.commandClasses.133.data.25.nodes = Empty
[2013-12-09 18:59:18.276] SETDATA devices.2.instances.0.commandClasses.133.data.25.nodes = byte[0]
[2013-12-09 18:59:18.276] SETDATA devices.2.instances.0.commandClasses.133.data.25.nodesToFollow = Empty
[2013-12-09 18:59:18.276] SETDATA devices.2.instances.0.commandClasses.133.data.25.nodesToFollow = byte[0]
[2013-12-09 18:59:18.276] Adding job: Association Get
[2013-12-09 18:59:18.276] SETDATA devices.2.instances.0.commandClasses.133.data.26 = Empty
[2013-12-09 18:59:18.276] SETDATA devices.2.instances.0.commandClasses.133.data.26.max = Empty
[2013-12-09 18:59:18.277] SETDATA devices.2.instances.0.commandClasses.133.data.26.max = 0 (0x00000000)
[2013-12-09 18:59:18.277] SETDATA devices.2.instances.0.commandClasses.133.data.26.nodes = Empty
[2013-12-09 18:59:18.277] SETDATA devices.2.instances.0.commandClasses.133.data.26.nodes = byte[0]
[2013-12-09 18:59:18.277] SETDATA devices.2.instances.0.commandClasses.133.data.26.nodesToFollow = Empty
[2013-12-09 18:59:18.277] SETDATA devices.2.instances.0.commandClasses.133.data.26.nodesToFollow = byte[0]
[2013-12-09 18:59:18.277] Adding job: Association Get
[2013-12-09 18:59:18.277] SETDATA devices.2.instances.0.commandClasses.133.data.27 = Empty
[2013-12-09 18:59:18.278] SETDATA devices.2.instances.0.commandClasses.133.data.27.max = Empty
[2013-12-09 18:59:18.278] SETDATA devices.2.instances.0.commandClasses.133.data.27.max = 0 (0x00000000)
[2013-12-09 18:59:18.278] SETDATA devices.2.instances.0.commandClasses.133.data.27.nodes = Empty
[2013-12-09 18:59:18.278] SETDATA devices.2.instances.0.commandClasses.133.data.27.nodes = byte[0]
[2013-12-09 18:59:18.278] SETDATA devices.2.instances.0.commandClasses.133.data.27.nodesToFollow = Empty
[2013-12-09 18:59:18.278] SETDATA devices.2.instances.0.commandClasses.133.data.27.nodesToFollow = byte[0]
[2013-12-09 18:59:18.279] Adding job: Association Get
[2013-12-09 18:59:18.279] SETDATA devices.2.instances.0.commandClasses.133.data.28 = Empty
[2013-12-09 18:59:18.279] SETDATA devices.2.instances.0.commandClasses.133.data.28.max = Empty
[2013-12-09 18:59:18.279] SETDATA devices.2.instances.0.commandClasses.133.data.28.max = 0 (0x00000000)
[2013-12-09 18:59:18.279] SETDATA devices.2.instances.0.commandClasses.133.data.28.nodes = Empty
[2013-12-09 18:59:18.279] SETDATA devices.2.instances.0.commandClasses.133.data.28.nodes = byte[0]
[2013-12-09 18:59:18.279] SETDATA devices.2.instances.0.commandClasses.133.data.28.nodesToFollow = Empty
[2013-12-09 18:59:18.280] SETDATA devices.2.instances.0.commandClasses.133.data.28.nodesToFollow = byte[0]
[2013-12-09 18:59:18.280] Adding job: Association Get
[2013-12-09 18:59:18.280] SETDATA devices.2.instances.0.commandClasses.133.data.29 = Empty
[2013-12-09 18:59:18.280] SETDATA devices.2.instances.0.commandClasses.133.data.29.max = Empty
[2013-12-09 18:59:18.280] SETDATA devices.2.instances.0.commandClasses.133.data.29.max = 0 (0x00000000)
[2013-12-09 18:59:18.281] SETDATA devices.2.instances.0.commandClasses.133.data.29.nodes = Empty
[2013-12-09 18:59:18.281] SETDATA devices.2.instances.0.commandClasses.133.data.29.nodes = byte[0]
[2013-12-09 18:59:18.281] SETDATA devices.2.instances.0.commandClasses.133.data.29.nodesToFollow = Empty
[2013-12-09 18:59:18.281] SETDATA devices.2.instances.0.commandClasses.133.data.29.nodesToFollow = byte[0]
[2013-12-09 18:59:18.282] Adding job: Association Get
[2013-12-09 18:59:18.282] SETDATA devices.2.instances.0.commandClasses.133.data.30 = Empty
[2013-12-09 18:59:18.282] SETDATA devices.2.instances.0.commandClasses.133.data.30.max = Empty
[2013-12-09 18:59:18.282] SETDATA devices.2.instances.0.commandClasses.133.data.30.max = 0 (0x00000000)
[2013-12-09 18:59:18.283] SETDATA devices.2.instances.0.commandClasses.133.data.30.nodes = Empty
[2013-12-09 18:59:18.283] SETDATA devices.2.instances.0.commandClasses.133.data.30.nodes = byte[0]
[2013-12-09 18:59:18.283] SETDATA devices.2.instances.0.commandClasses.133.data.30.nodesToFollow = Empty
[2013-12-09 18:59:18.283] SETDATA devices.2.instances.0.commandClasses.133.data.30.nodesToFollow = byte[0]
[2013-12-09 18:59:18.283] Adding job: Association Get
[2013-12-09 18:59:18.283] SETDATA devices.2.instances.0.commandClasses.133.data.31 = Empty
[2013-12-09 18:59:18.284] SETDATA devices.2.instances.0.commandClasses.133.data.31.max = Empty
[2013-12-09 18:59:18.284] SETDATA devices.2.instances.0.commandClasses.133.data.31.max = 0 (0x00000000)
[2013-12-09 18:59:18.284] SETDATA devices.2.instances.0.commandClasses.133.data.31.nodes = Empty
[2013-12-09 18:59:18.284] SETDATA devices.2.instances.0.commandClasses.133.data.31.nodes = byte[0]
[2013-12-09 18:59:18.284] SETDATA devices.2.instances.0.commandClasses.133.data.31.nodesToFollow = Empty
[2013-12-09 18:59:18.284] SETDATA devices.2.instances.0.commandClasses.133.data.31.nodesToFollow = byte[0]
[2013-12-09 18:59:18.285] Adding job: Association Get
[2013-12-09 18:59:18.285] SETDATA devices.2.instances.0.commandClasses.133.data.32 = Empty
[2013-12-09 18:59:18.285] SETDATA devices.2.instances.0.commandClasses.133.data.32.max = Empty
[2013-12-09 18:59:18.285] SETDATA devices.2.instances.0.commandClasses.133.data.32.max = 0 (0x00000000)
[2013-12-09 18:59:18.285] SETDATA devices.2.instances.0.commandClasses.133.data.32.nodes = Empty
[2013-12-09 18:59:18.285] SETDATA devices.2.instances.0.commandClasses.133.data.32.nodes = byte[0]
[2013-12-09 18:59:18.285] SETDATA devices.2.instances.0.commandClasses.133.data.32.nodesToFollow = Empty
[2013-12-09 18:59:18.286] SETDATA devices.2.instances.0.commandClasses.133.data.32.nodesToFollow = byte[0]
[2013-12-09 18:59:18.286] Adding job: Association Get
[2013-12-09 18:59:18.286] SETDATA devices.2.instances.0.commandClasses.133.data.33 = Empty
[2013-12-09 18:59:18.286] SETDATA devices.2.instances.0.commandClasses.133.data.33.max = Empty
[2013-12-09 18:59:18.286] SETDATA devices.2.instances.0.commandClasses.133.data.33.max = 0 (0x00000000)
[2013-12-09 18:59:18.286] SETDATA devices.2.instances.0.commandClasses.133.data.33.nodes = Empty
[2013-12-09 18:59:18.287] SETDATA devices.2.instances.0.commandClasses.133.data.33.nodes = byte[0]
[2013-12-09 18:59:18.287] SETDATA devices.2.instances.0.commandClasses.133.data.33.nodesToFollow = Empty
[2013-12-09 18:59:18.287] SETDATA devices.2.instances.0.commandClasses.133.data.33.nodesToFollow = byte[0]
[2013-12-09 18:59:18.287] Adding job: Association Get
[2013-12-09 18:59:18.287] SETDATA devices.2.instances.0.commandClasses.133.data.34 = Empty
[2013-12-09 18:59:18.288] SETDATA devices.2.instances.0.commandClasses.133.data.34.max = Empty
[2013-12-09 18:59:18.288] SETDATA devices.2.instances.0.commandClasses.133.data.34.max = 0 (0x00000000)
[2013-12-09 18:59:18.288] SETDATA devices.2.instances.0.commandClasses.133.data.34.nodes = Empty
[2013-12-09 18:59:18.288] SETDATA devices.2.instances.0.commandClasses.133.data.34.nodes = byte[0]
[2013-12-09 18:59:18.288] SETDATA devices.2.instances.0.commandClasses.133.data.34.nodesToFollow = Empty
[2013-12-09 18:59:18.288] SETDATA devices.2.instances.0.commandClasses.133.data.34.nodesToFollow = byte[0]
[2013-12-09 18:59:18.288] Adding job: Association Get
[2013-12-09 18:59:18.289] SETDATA devices.2.instances.0.commandClasses.133.data.35 = Empty
[2013-12-09 18:59:18.289] SETDATA devices.2.instances.0.commandClasses.133.data.35.max = Empty
[2013-12-09 18:59:18.289] SETDATA devices.2.instances.0.commandClasses.133.data.35.max = 0 (0x00000000)
[2013-12-09 18:59:18.289] SETDATA devices.2.instances.0.commandClasses.133.data.35.nodes = Empty
[2013-12-09 18:59:18.289] SETDATA devices.2.instances.0.commandClasses.133.data.35.nodes = byte[0]
[2013-12-09 18:59:18.289] SETDATA devices.2.instances.0.commandClasses.133.data.35.nodesToFollow = Empty
[2013-12-09 18:59:18.289] SETDATA devices.2.instances.0.commandClasses.133.data.35.nodesToFollow = byte[0]
[2013-12-09 18:59:18.290] Adding job: Association Get
[2013-12-09 18:59:18.290] SETDATA devices.2.instances.0.commandClasses.133.data.36 = Empty
[2013-12-09 18:59:18.290] SETDATA devices.2.instances.0.commandClasses.133.data.36.max = Empty
[2013-12-09 18:59:18.290] SETDATA devices.2.instances.0.commandClasses.133.data.36.max = 0 (0x00000000)
[2013-12-09 18:59:18.291] SETDATA devices.2.instances.0.commandClasses.133.data.36.nodes = Empty
[2013-12-09 18:59:18.291] SETDATA devices.2.instances.0.commandClasses.133.data.36.nodes = byte[0]
[2013-12-09 18:59:18.291] SETDATA devices.2.instances.0.commandClasses.133.data.36.nodesToFollow = Empty
[2013-12-09 18:59:18.291] SETDATA devices.2.instances.0.commandClasses.133.data.36.nodesToFollow = byte[0]
[2013-12-09 18:59:18.291] Adding job: Association Get
[2013-12-09 18:59:18.292] SETDATA devices.2.instances.0.commandClasses.133.data.37 = Empty
[2013-12-09 18:59:18.292] SETDATA devices.2.instances.0.commandClasses.133.data.37.max = Empty
[2013-12-09 18:59:18.292] SETDATA devices.2.instances.0.commandClasses.133.data.37.max = 0 (0x00000000)
[2013-12-09 18:59:18.292] SETDATA devices.2.instances.0.commandClasses.133.data.37.nodes = Empty
[2013-12-09 18:59:18.292] SETDATA devices.2.instances.0.commandClasses.133.data.37.nodes = byte[0]
[2013-12-09 18:59:18.293] SETDATA devices.2.instances.0.commandClasses.133.data.37.nodesToFollow = Empty
[2013-12-09 18:59:18.293] SETDATA devices.2.instances.0.commandClasses.133.data.37.nodesToFollow = byte[0]
[2013-12-09 18:59:18.293] Adding job: Association Get
[2013-12-09 18:59:18.293] SETDATA devices.2.instances.0.commandClasses.133.data.38 = Empty
[2013-12-09 18:59:18.293] SETDATA devices.2.instances.0.commandClasses.133.data.38.max = Empty
[2013-12-09 18:59:18.293] SETDATA devices.2.instances.0.commandClasses.133.data.38.max = 0 (0x00000000)
[2013-12-09 18:59:18.294] SETDATA devices.2.instances.0.commandClasses.133.data.38.nodes = Empty
[2013-12-09 18:59:18.294] SETDATA devices.2.instances.0.commandClasses.133.data.38.nodes = byte[0]
[2013-12-09 18:59:18.294] SETDATA devices.2.instances.0.commandClasses.133.data.38.nodesToFollow = Empty
[2013-12-09 18:59:18.294] SETDATA devices.2.instances.0.commandClasses.133.data.38.nodesToFollow = byte[0]
[2013-12-09 18:59:18.294] Adding job: Association Get
[2013-12-09 18:59:18.295] SETDATA devices.2.instances.0.commandClasses.133.data.39 = Empty
[2013-12-09 18:59:18.295] SETDATA devices.2.instances.0.commandClasses.133.data.39.max = Empty
[2013-12-09 18:59:18.295] SETDATA devices.2.instances.0.commandClasses.133.data.39.max = 0 (0x00000000)
[2013-12-09 18:59:18.295] SETDATA devices.2.instances.0.commandClasses.133.data.39.nodes = Empty
[2013-12-09 18:59:18.295] SETDATA devices.2.instances.0.commandClasses.133.data.39.nodes = byte[0]
[2013-12-09 18:59:18.295] SETDATA devices.2.instances.0.commandClasses.133.data.39.nodesToFollow = Empty
[2013-12-09 18:59:18.295] SETDATA devices.2.instances.0.commandClasses.133.data.39.nodesToFollow = byte[0]
[2013-12-09 18:59:18.296] Adding job: Association Get
[2013-12-09 18:59:18.296] SETDATA devices.2.instances.0.commandClasses.133.data.40 = Empty
[2013-12-09 18:59:18.296] SETDATA devices.2.instances.0.commandClasses.133.data.40.max = Empty
[2013-12-09 18:59:18.296] SETDATA devices.2.instances.0.commandClasses.133.data.40.max = 0 (0x00000000)
[2013-12-09 18:59:18.296] SETDATA devices.2.instances.0.commandClasses.133.data.40.nodes = Empty
[2013-12-09 18:59:18.296] SETDATA devices.2.instances.0.commandClasses.133.data.40.nodes = byte[0]
[2013-12-09 18:59:18.297] SETDATA devices.2.instances.0.commandClasses.133.data.40.nodesToFollow = Empty
[2013-12-09 18:59:18.297] SETDATA devices.2.instances.0.commandClasses.133.data.40.nodesToFollow = byte[0]
[2013-12-09 18:59:18.297] Adding job: Association Get
[2013-12-09 18:59:18.297] SETDATA devices.2.instances.0.commandClasses.133.data.41 = Empty
[2013-12-09 18:59:18.297] SETDATA devices.2.instances.0.commandClasses.133.data.41.max = Empty
[2013-12-09 18:59:18.297] SETDATA devices.2.instances.0.commandClasses.133.data.41.max = 0 (0x00000000)
[2013-12-09 18:59:18.298] SETDATA devices.2.instances.0.commandClasses.133.data.41.nodes = Empty
[2013-12-09 18:59:18.298] SETDATA devices.2.instances.0.commandClasses.133.data.41.nodes = byte[0]
[2013-12-09 18:59:18.298] SETDATA devices.2.instances.0.commandClasses.133.data.41.nodesToFollow = Empty
[2013-12-09 18:59:18.298] SETDATA devices.2.instances.0.commandClasses.133.data.41.nodesToFollow = byte[0]
[2013-12-09 18:59:18.298] Adding job: Association Get
[2013-12-09 18:59:18.298] SETDATA devices.2.instances.0.commandClasses.133.data.42 = Empty
[2013-12-09 18:59:18.299] SETDATA devices.2.instances.0.commandClasses.133.data.42.max = Empty
[2013-12-09 18:59:18.299] SETDATA devices.2.instances.0.commandClasses.133.data.42.max = 0 (0x00000000)
[2013-12-09 18:59:18.299] SETDATA devices.2.instances.0.commandClasses.133.data.42.nodes = Empty
[2013-12-09 18:59:18.299] SETDATA devices.2.instances.0.commandClasses.133.data.42.nodes = byte[0]
[2013-12-09 18:59:18.299] SETDATA devices.2.instances.0.commandClasses.133.data.42.nodesToFollow = Empty
[2013-12-09 18:59:18.299] SETDATA devices.2.instances.0.commandClasses.133.data.42.nodesToFollow = byte[0]
[2013-12-09 18:59:18.300] Adding job: Association Get
[2013-12-09 18:59:18.300] SETDATA devices.2.instances.0.commandClasses.133.data.43 = Empty
[2013-12-09 18:59:18.300] SETDATA devices.2.instances.0.commandClasses.133.data.43.max = Empty
[2013-12-09 18:59:18.300] SETDATA devices.2.instances.0.commandClasses.133.data.43.max = 0 (0x00000000)
[2013-12-09 18:59:18.300] SETDATA devices.2.instances.0.commandClasses.133.data.43.nodes = Empty
[2013-12-09 18:59:18.300] SETDATA devices.2.instances.0.commandClasses.133.data.43.nodes = byte[0]
[2013-12-09 18:59:18.301] SETDATA devices.2.instances.0.commandClasses.133.data.43.nodesToFollow = Empty
[2013-12-09 18:59:18.301] SETDATA devices.2.instances.0.commandClasses.133.data.43.nodesToFollow = byte[0]
[2013-12-09 18:59:18.301] Adding job: Association Get
[2013-12-09 18:59:18.301] SETDATA devices.2.instances.0.commandClasses.133.data.44 = Empty
[2013-12-09 18:59:18.302] SETDATA devices.2.instances.0.commandClasses.133.data.44.max = Empty
[2013-12-09 18:59:18.302] SETDATA devices.2.instances.0.commandClasses.133.data.44.max = 0 (0x00000000)
[2013-12-09 18:59:18.302] SETDATA devices.2.instances.0.commandClasses.133.data.44.nodes = Empty
[2013-12-09 18:59:18.302] SETDATA devices.2.instances.0.commandClasses.133.data.44.nodes = byte[0]
[2013-12-09 18:59:18.303] SETDATA devices.2.instances.0.commandClasses.133.data.44.nodesToFollow = Empty
[2013-12-09 18:59:18.303] SETDATA devices.2.instances.0.commandClasses.133.data.44.nodesToFollow = byte[0]
[2013-12-09 18:59:18.303] Adding job: Association Get
[2013-12-09 18:59:18.303] SETDATA devices.2.instances.0.commandClasses.133.data.45 = Empty
[2013-12-09 18:59:18.303] SETDATA devices.2.instances.0.commandClasses.133.data.45.max = Empty
[2013-12-09 18:59:18.303] SETDATA devices.2.instances.0.commandClasses.133.data.45.max = 0 (0x00000000)
[2013-12-09 18:59:18.304] SETDATA devices.2.instances.0.commandClasses.133.data.45.nodes = Empty
[2013-12-09 18:59:18.304] SETDATA devices.2.instances.0.commandClasses.133.data.45.nodes = byte[0]
[2013-12-09 18:59:18.304] SETDATA devices.2.instances.0.commandClasses.133.data.45.nodesToFollow = Empty
[2013-12-09 18:59:18.304] SETDATA devices.2.instances.0.commandClasses.133.data.45.nodesToFollow = byte[0]
[2013-12-09 18:59:18.304] Adding job: Association Get
[2013-12-09 18:59:18.304] SETDATA devices.2.instances.0.commandClasses.133.data.46 = Empty
[2013-12-09 18:59:18.305] SETDATA devices.2.instances.0.commandClasses.133.data.46.max = Empty
[2013-12-09 18:59:18.305] SETDATA devices.2.instances.0.commandClasses.133.data.46.max = 0 (0x00000000)
[2013-12-09 18:59:18.305] SETDATA devices.2.instances.0.commandClasses.133.data.46.nodes = Empty
[2013-12-09 18:59:18.305] SETDATA devices.2.instances.0.commandClasses.133.data.46.nodes = byte[0]
[2013-12-09 18:59:18.305] SETDATA devices.2.instances.0.commandClasses.133.data.46.nodesToFollow = Empty
[2013-12-09 18:59:18.305] SETDATA devices.2.instances.0.commandClasses.133.data.46.nodesToFollow = byte[0]
[2013-12-09 18:59:18.306] Adding job: Association Get
[2013-12-09 18:59:18.306] SETDATA devices.2.instances.0.commandClasses.133.data.47 = Empty
[2013-12-09 18:59:18.306] SETDATA devices.2.instances.0.commandClasses.133.data.47.max = Empty
[2013-12-09 18:59:18.306] SETDATA devices.2.instances.0.commandClasses.133.data.47.max = 0 (0x00000000)
[2013-12-09 18:59:18.306] SETDATA devices.2.instances.0.commandClasses.133.data.47.nodes = Empty
[2013-12-09 18:59:18.306] SETDATA devices.2.instances.0.commandClasses.133.data.47.nodes = byte[0]
[2013-12-09 18:59:18.307] SETDATA devices.2.instances.0.commandClasses.133.data.47.nodesToFollow = Empty
[2013-12-09 18:59:18.307] SETDATA devices.2.instances.0.commandClasses.133.data.47.nodesToFollow = byte[0]
[2013-12-09 18:59:18.307] Adding job: Association Get
[2013-12-09 18:59:18.307] SETDATA devices.2.instances.0.commandClasses.133.data.48 = Empty
[2013-12-09 18:59:18.307] SETDATA devices.2.instances.0.commandClasses.133.data.48.max = Empty
[2013-12-09 18:59:18.307] SETDATA devices.2.instances.0.commandClasses.133.data.48.max = 0 (0x00000000)
[2013-12-09 18:59:18.308] SETDATA devices.2.instances.0.commandClasses.133.data.48.nodes = Empty
[2013-12-09 18:59:18.308] SETDATA devices.2.instances.0.commandClasses.133.data.48.nodes = byte[0]
[2013-12-09 18:59:18.308] SETDATA devices.2.instances.0.commandClasses.133.data.48.nodesToFollow = Empty
[2013-12-09 18:59:18.308] SETDATA devices.2.instances.0.commandClasses.133.data.48.nodesToFollow = byte[0]
[2013-12-09 18:59:18.308] Adding job: Association Get
[2013-12-09 18:59:18.309] SETDATA devices.2.instances.0.commandClasses.133.data.49 = Empty
[2013-12-09 18:59:18.309] SETDATA devices.2.instances.0.commandClasses.133.data.49.max = Empty
[2013-12-09 18:59:18.309] SETDATA devices.2.instances.0.commandClasses.133.data.49.max = 0 (0x00000000)
[2013-12-09 18:59:18.309] SETDATA devices.2.instances.0.commandClasses.133.data.49.nodes = Empty
[2013-12-09 18:59:18.309] SETDATA devices.2.instances.0.commandClasses.133.data.49.nodes = byte[0]
[2013-12-09 18:59:18.309] SETDATA devices.2.instances.0.commandClasses.133.data.49.nodesToFollow = Empty
[2013-12-09 18:59:18.309] SETDATA devices.2.instances.0.commandClasses.133.data.49.nodesToFollow = byte[0]
[2013-12-09 18:59:18.310] Adding job: Association Get
[2013-12-09 18:59:18.310] SETDATA devices.2.instances.0.commandClasses.133.data.50 = Empty
[2013-12-09 18:59:18.310] SETDATA devices.2.instances.0.commandClasses.133.data.50.max = Empty
[2013-12-09 18:59:18.310] SETDATA devices.2.instances.0.commandClasses.133.data.50.max = 0 (0x00000000)
[2013-12-09 18:59:18.310] SETDATA devices.2.instances.0.commandClasses.133.data.50.nodes = Empty
[2013-12-09 18:59:18.310] SETDATA devices.2.instances.0.commandClasses.133.data.50.nodes = byte[0]
[2013-12-09 18:59:18.311] SETDATA devices.2.instances.0.commandClasses.133.data.50.nodesToFollow = Empty
[2013-12-09 18:59:18.311] SETDATA devices.2.instances.0.commandClasses.133.data.50.nodesToFollow = byte[0]
[2013-12-09 18:59:18.311] Adding job: Association Get
[2013-12-09 18:59:18.311] SETDATA devices.2.instances.0.commandClasses.133.data.51 = Empty
[2013-12-09 18:59:18.311] SETDATA devices.2.instances.0.commandClasses.133.data.51.max = Empty
[2013-12-09 18:59:18.312] SETDATA devices.2.instances.0.commandClasses.133.data.51.max = 0 (0x00000000)
[2013-12-09 18:59:18.312] SETDATA devices.2.instances.0.commandClasses.133.data.51.nodes = Empty
[2013-12-09 18:59:18.312] SETDATA devices.2.instances.0.commandClasses.133.data.51.nodes = byte[0]
[2013-12-09 18:59:18.312] SETDATA devices.2.instances.0.commandClasses.133.data.51.nodesToFollow = Empty
[2013-12-09 18:59:18.313] SETDATA devices.2.instances.0.commandClasses.133.data.51.nodesToFollow = byte[0]
[2013-12-09 18:59:18.313] Adding job: Association Get
[2013-12-09 18:59:18.313] SETDATA devices.2.instances.0.commandClasses.133.data.52 = Empty
[2013-12-09 18:59:18.313] SETDATA devices.2.instances.0.commandClasses.133.data.52.max = Empty
[2013-12-09 18:59:18.313] SETDATA devices.2.instances.0.commandClasses.133.data.52.max = 0 (0x00000000)
[2013-12-09 18:59:18.314] SETDATA devices.2.instances.0.commandClasses.133.data.52.nodes = Empty
[2013-12-09 18:59:18.314] SETDATA devices.2.instances.0.commandClasses.133.data.52.nodes = byte[0]
[2013-12-09 18:59:18.314] SETDATA devices.2.instances.0.commandClasses.133.data.52.nodesToFollow = Empty
[2013-12-09 18:59:18.314] SETDATA devices.2.instances.0.commandClasses.133.data.52.nodesToFollow = byte[0]
[2013-12-09 18:59:18.314] Adding job: Association Get
[2013-12-09 18:59:18.315] SETDATA devices.2.instances.0.commandClasses.133.data.53 = Empty
[2013-12-09 18:59:18.315] SETDATA devices.2.instances.0.commandClasses.133.data.53.max = Empty
[2013-12-09 18:59:18.315] SETDATA devices.2.instances.0.commandClasses.133.data.53.max = 0 (0x00000000)
[2013-12-09 18:59:18.315] SETDATA devices.2.instances.0.commandClasses.133.data.53.nodes = Empty
[2013-12-09 18:59:18.315] SETDATA devices.2.instances.0.commandClasses.133.data.53.nodes = byte[0]
[2013-12-09 18:59:18.315] SETDATA devices.2.instances.0.commandClasses.133.data.53.nodesToFollow = Empty
[2013-12-09 18:59:18.315] SETDATA devices.2.instances.0.commandClasses.133.data.53.nodesToFollow = byte[0]
[2013-12-09 18:59:18.316] Adding job: Association Get
[2013-12-09 18:59:18.316] SETDATA devices.2.instances.0.commandClasses.133.data.54 = Empty
[2013-12-09 18:59:18.316] SETDATA devices.2.instances.0.commandClasses.133.data.54.max = Empty
[2013-12-09 18:59:18.316] SETDATA devices.2.instances.0.commandClasses.133.data.54.max = 0 (0x00000000)
[2013-12-09 18:59:18.316] SETDATA devices.2.instances.0.commandClasses.133.data.54.nodes = Empty
[2013-12-09 18:59:18.316] SETDATA devices.2.instances.0.commandClasses.133.data.54.nodes = byte[0]
[2013-12-09 18:59:18.317] SETDATA devices.2.instances.0.commandClasses.133.data.54.nodesToFollow = Empty
[2013-12-09 18:59:18.317] SETDATA devices.2.instances.0.commandClasses.133.data.54.nodesToFollow = byte[0]
[2013-12-09 18:59:18.317] Adding job: Association Get
[2013-12-09 18:59:18.317] SETDATA devices.2.instances.0.commandClasses.133.data.55 = Empty
[2013-12-09 18:59:18.317] SETDATA devices.2.instances.0.commandClasses.133.data.55.max = Empty
[2013-12-09 18:59:18.318] SETDATA devices.2.instances.0.commandClasses.133.data.55.max = 0 (0x00000000)
[2013-12-09 18:59:18.318] SETDATA devices.2.instances.0.commandClasses.133.data.55.nodes = Empty
[2013-12-09 18:59:18.318] SETDATA devices.2.instances.0.commandClasses.133.data.55.nodes = byte[0]
[2013-12-09 18:59:18.318] SETDATA devices.2.instances.0.commandClasses.133.data.55.nodesToFollow = Empty
[2013-12-09 18:59:18.318] SETDATA devices.2.instances.0.commandClasses.133.data.55.nodesToFollow = byte[0]
[2013-12-09 18:59:18.318] Adding job: Association Get
[2013-12-09 18:59:18.319] SETDATA devices.2.instances.0.commandClasses.133.data.56 = Empty
[2013-12-09 18:59:18.319] SETDATA devices.2.instances.0.commandClasses.133.data.56.max = Empty
[2013-12-09 18:59:18.319] SETDATA devices.2.instances.0.commandClasses.133.data.56.max = 0 (0x00000000)
[2013-12-09 18:59:18.319] SETDATA devices.2.instances.0.commandClasses.133.data.56.nodes = Empty
[2013-12-09 18:59:18.319] SETDATA devices.2.instances.0.commandClasses.133.data.56.nodes = byte[0]
[2013-12-09 18:59:18.319] SETDATA devices.2.instances.0.commandClasses.133.data.56.nodesToFollow = Empty
[2013-12-09 18:59:18.319] SETDATA devices.2.instances.0.commandClasses.133.data.56.nodesToFollow = byte[0]
[2013-12-09 18:59:18.320] Adding job: Association Get
[2013-12-09 18:59:18.320] SETDATA devices.2.instances.0.commandClasses.133.data.57 = Empty
[2013-12-09 18:59:18.320] SETDATA devices.2.instances.0.commandClasses.133.data.57.max = Empty
[2013-12-09 18:59:18.320] SETDATA devices.2.instances.0.commandClasses.133.data.57.max = 0 (0x00000000)
[2013-12-09 18:59:18.320] SETDATA devices.2.instances.0.commandClasses.133.data.57.nodes = Empty
[2013-12-09 18:59:18.320] SETDATA devices.2.instances.0.commandClasses.133.data.57.nodes = byte[0]
[2013-12-09 18:59:18.321] SETDATA devices.2.instances.0.commandClasses.133.data.57.nodesToFollow = Empty
[2013-12-09 18:59:18.321] SETDATA devices.2.instances.0.commandClasses.133.data.57.nodesToFollow = byte[0]
[2013-12-09 18:59:18.321] Adding job: Association Get
[2013-12-09 18:59:18.321] SETDATA devices.2.instances.0.commandClasses.133.data.58 = Empty
[2013-12-09 18:59:18.322] SETDATA devices.2.instances.0.commandClasses.133.data.58.max = Empty
[2013-12-09 18:59:18.322] SETDATA devices.2.instances.0.commandClasses.133.data.58.max = 0 (0x00000000)
[2013-12-09 18:59:18.322] SETDATA devices.2.instances.0.commandClasses.133.data.58.nodes = Empty
[2013-12-09 18:59:18.322] SETDATA devices.2.instances.0.commandClasses.133.data.58.nodes = byte[0]
[2013-12-09 18:59:18.322] SETDATA devices.2.instances.0.commandClasses.133.data.58.nodesToFollow = Empty
[2013-12-09 18:59:18.323] SETDATA devices.2.instances.0.commandClasses.133.data.58.nodesToFollow = byte[0]
[2013-12-09 18:59:18.323] Adding job: Association Get
[2013-12-09 18:59:18.323] SETDATA devices.2.instances.0.commandClasses.133.data.59 = Empty
[2013-12-09 18:59:18.324] SETDATA devices.2.instances.0.commandClasses.133.data.59.max = Empty
[2013-12-09 18:59:18.324] SETDATA devices.2.instances.0.commandClasses.133.data.59.max = 0 (0x00000000)
[2013-12-09 18:59:18.324] SETDATA devices.2.instances.0.commandClasses.133.data.59.nodes = Empty
[2013-12-09 18:59:18.324] SETDATA devices.2.instances.0.commandClasses.133.data.59.nodes = byte[0]
[2013-12-09 18:59:18.324] SETDATA devices.2.instances.0.commandClasses.133.data.59.nodesToFollow = Empty
[2013-12-09 18:59:18.324] SETDATA devices.2.instances.0.commandClasses.133.data.59.nodesToFollow = byte[0]
[2013-12-09 18:59:18.325] Adding job: Association Get
[2013-12-09 18:59:18.325] SETDATA devices.2.instances.0.commandClasses.133.data.60 = Empty
[2013-12-09 18:59:18.325] SETDATA devices.2.instances.0.commandClasses.133.data.60.max = Empty
[2013-12-09 18:59:18.325] SETDATA devices.2.instances.0.commandClasses.133.data.60.max = 0 (0x00000000)
[2013-12-09 18:59:18.325] SETDATA devices.2.instances.0.commandClasses.133.data.60.nodes = Empty
[2013-12-09 18:59:18.325] SETDATA devices.2.instances.0.commandClasses.133.data.60.nodes = byte[0]
[2013-12-09 18:59:18.325] SETDATA devices.2.instances.0.commandClasses.133.data.60.nodesToFollow = Empty
[2013-12-09 18:59:18.326] SETDATA devices.2.instances.0.commandClasses.133.data.60.nodesToFollow = byte[0]
[2013-12-09 18:59:18.326] Adding job: Association Get
[2013-12-09 18:59:18.326] SETDATA devices.2.instances.0.commandClasses.133.data.61 = Empty
[2013-12-09 18:59:18.326] SETDATA devices.2.instances.0.commandClasses.133.data.61.max = Empty
[2013-12-09 18:59:18.326] SETDATA devices.2.instances.0.commandClasses.133.data.61.max = 0 (0x00000000)
[2013-12-09 18:59:18.326] SETDATA devices.2.instances.0.commandClasses.133.data.61.nodes = Empty
[2013-12-09 18:59:18.327] SETDATA devices.2.instances.0.commandClasses.133.data.61.nodes = byte[0]
[2013-12-09 18:59:18.327] SETDATA devices.2.instances.0.commandClasses.133.data.61.nodesToFollow = Empty
[2013-12-09 18:59:18.327] SETDATA devices.2.instances.0.commandClasses.133.data.61.nodesToFollow = byte[0]
[2013-12-09 18:59:18.327] Adding job: Association Get
[2013-12-09 18:59:18.327] SETDATA devices.2.instances.0.commandClasses.133.data.62 = Empty
[2013-12-09 18:59:18.327] SETDATA devices.2.instances.0.commandClasses.133.data.62.max = Empty
[2013-12-09 18:59:18.328] SETDATA devices.2.instances.0.commandClasses.133.data.62.max = 0 (0x00000000)
[2013-12-09 18:59:18.328] SETDATA devices.2.instances.0.commandClasses.133.data.62.nodes = Empty
[2013-12-09 18:59:18.328] SETDATA devices.2.instances.0.commandClasses.133.data.62.nodes = byte[0]
[2013-12-09 18:59:18.328] SETDATA devices.2.instances.0.commandClasses.133.data.62.nodesToFollow = Empty
[2013-12-09 18:59:18.328] SETDATA devices.2.instances.0.commandClasses.133.data.62.nodesToFollow = byte[0]
[2013-12-09 18:59:18.328] Adding job: Association Get
[2013-12-09 18:59:18.329] SETDATA devices.2.instances.0.commandClasses.133.data.63 = Empty
[2013-12-09 18:59:18.329] SETDATA devices.2.instances.0.commandClasses.133.data.63.max = Empty
[2013-12-09 18:59:18.329] SETDATA devices.2.instances.0.commandClasses.133.data.63.max = 0 (0x00000000)
[2013-12-09 18:59:18.329] SETDATA devices.2.instances.0.commandClasses.133.data.63.nodes = Empty
[2013-12-09 18:59:18.329] SETDATA devices.2.instances.0.commandClasses.133.data.63.nodes = byte[0]
[2013-12-09 18:59:18.329] SETDATA devices.2.instances.0.commandClasses.133.data.63.nodesToFollow = Empty
[2013-12-09 18:59:18.329] SETDATA devices.2.instances.0.commandClasses.133.data.63.nodesToFollow = byte[0]
[2013-12-09 18:59:18.330] Adding job: Association Get
[2013-12-09 18:59:18.330] SETDATA devices.2.instances.0.commandClasses.133.data.64 = Empty
[2013-12-09 18:59:18.330] SETDATA devices.2.instances.0.commandClasses.133.data.64.max = Empty
[2013-12-09 18:59:18.330] SETDATA devices.2.instances.0.commandClasses.133.data.64.max = 0 (0x00000000)
[2013-12-09 18:59:18.331] SETDATA devices.2.instances.0.commandClasses.133.data.64.nodes = Empty
[2013-12-09 18:59:18.331] SETDATA devices.2.instances.0.commandClasses.133.data.64.nodes = byte[0]
[2013-12-09 18:59:18.331] SETDATA devices.2.instances.0.commandClasses.133.data.64.nodesToFollow = Empty
[2013-12-09 18:59:18.331] SETDATA devices.2.instances.0.commandClasses.133.data.64.nodesToFollow = byte[0]
[2013-12-09 18:59:18.331] Adding job: Association Get
[2013-12-09 18:59:18.332] SETDATA devices.2.instances.0.commandClasses.133.data.65 = Empty
[2013-12-09 18:59:18.332] SETDATA devices.2.instances.0.commandClasses.133.data.65.max = Empty
[2013-12-09 18:59:18.332] SETDATA devices.2.instances.0.commandClasses.133.data.65.max = 0 (0x00000000)
[2013-12-09 18:59:18.332] SETDATA devices.2.instances.0.commandClasses.133.data.65.nodes = Empty
[2013-12-09 18:59:18.332] SETDATA devices.2.instances.0.commandClasses.133.data.65.nodes = byte[0]
[2013-12-09 18:59:18.332] SETDATA devices.2.instances.0.commandClasses.133.data.65.nodesToFollow = Empty
[2013-12-09 18:59:18.333] SETDATA devices.2.instances.0.commandClasses.133.data.65.nodesToFollow = byte[0]
[2013-12-09 18:59:18.333] Adding job: Association Get
[2013-12-09 18:59:18.334] SETDATA devices.2.instances.0.commandClasses.133.data.66 = Empty
[2013-12-09 18:59:18.334] SETDATA devices.2.instances.0.commandClasses.133.data.66.max = Empty
[2013-12-09 18:59:18.334] SETDATA devices.2.instances.0.commandClasses.133.data.66.max = 0 (0x00000000)
[2013-12-09 18:59:18.334] SETDATA devices.2.instances.0.commandClasses.133.data.66.nodes = Empty
[2013-12-09 18:59:18.334] SETDATA devices.2.instances.0.commandClasses.133.data.66.nodes = byte[0]
[2013-12-09 18:59:18.334] SETDATA devices.2.instances.0.commandClasses.133.data.66.nodesToFollow = Empty
[2013-12-09 18:59:18.334] SETDATA devices.2.instances.0.commandClasses.133.data.66.nodesToFollow = byte[0]
[2013-12-09 18:59:18.335] Adding job: Association Get
[2013-12-09 18:59:18.335] SETDATA devices.2.instances.0.commandClasses.133.data.67 = Empty
[2013-12-09 18:59:18.335] SETDATA devices.2.instances.0.commandClasses.133.data.67.max = Empty
[2013-12-09 18:59:18.335] SETDATA devices.2.instances.0.commandClasses.133.data.67.max = 0 (0x00000000)
[2013-12-09 18:59:18.335] SETDATA devices.2.instances.0.commandClasses.133.data.67.nodes = Empty
[2013-12-09 18:59:18.335] SETDATA devices.2.instances.0.commandClasses.133.data.67.nodes = byte[0]
[2013-12-09 18:59:18.336] SETDATA devices.2.instances.0.commandClasses.133.data.67.nodesToFollow = Empty
[2013-12-09 18:59:18.336] SETDATA devices.2.instances.0.commandClasses.133.data.67.nodesToFollow = byte[0]
[2013-12-09 18:59:18.336] Adding job: Association Get
[2013-12-09 18:59:18.336] SETDATA devices.2.instances.0.commandClasses.133.data.68 = Empty
[2013-12-09 18:59:18.336] SETDATA devices.2.instances.0.commandClasses.133.data.68.max = Empty
[2013-12-09 18:59:18.336] SETDATA devices.2.instances.0.commandClasses.133.data.68.max = 0 (0x00000000)
[2013-12-09 18:59:18.337] SETDATA devices.2.instances.0.commandClasses.133.data.68.nodes = Empty
[2013-12-09 18:59:18.337] SETDATA devices.2.instances.0.commandClasses.133.data.68.nodes = byte[0]
[2013-12-09 18:59:18.337] SETDATA devices.2.instances.0.commandClasses.133.data.68.nodesToFollow = Empty
[2013-12-09 18:59:18.337] SETDATA devices.2.instances.0.commandClasses.133.data.68.nodesToFollow = byte[0]
[2013-12-09 18:59:18.337] Adding job: Association Get
[2013-12-09 18:59:18.338] SETDATA devices.2.instances.0.commandClasses.133.data.69 = Empty
[2013-12-09 18:59:18.338] SETDATA devices.2.instances.0.commandClasses.133.data.69.max = Empty
[2013-12-09 18:59:18.338] SETDATA devices.2.instances.0.commandClasses.133.data.69.max = 0 (0x00000000)
[2013-12-09 18:59:18.338] SETDATA devices.2.instances.0.commandClasses.133.data.69.nodes = Empty
[2013-12-09 18:59:18.338] SETDATA devices.2.instances.0.commandClasses.133.data.69.nodes = byte[0]
[2013-12-09 18:59:18.338] SETDATA devices.2.instances.0.commandClasses.133.data.69.nodesToFollow = Empty
[2013-12-09 18:59:18.339] SETDATA devices.2.instances.0.commandClasses.133.data.69.nodesToFollow = byte[0]
[2013-12-09 18:59:18.339] Adding job: Association Get
[2013-12-09 18:59:18.339] SETDATA devices.2.instances.0.commandClasses.133.data.70 = Empty
[2013-12-09 18:59:18.339] SETDATA devices.2.instances.0.commandClasses.133.data.70.max = Empty
[2013-12-09 18:59:18.339] SETDATA devices.2.instances.0.commandClasses.133.data.70.max = 0 (0x00000000)
[2013-12-09 18:59:18.339] SETDATA devices.2.instances.0.commandClasses.133.data.70.nodes = Empty
[2013-12-09 18:59:18.340] SETDATA devices.2.instances.0.commandClasses.133.data.70.nodes = byte[0]
[2013-12-09 18:59:18.340] SETDATA devices.2.instances.0.commandClasses.133.data.70.nodesToFollow = Empty
[2013-12-09 18:59:18.340] SETDATA devices.2.instances.0.commandClasses.133.data.70.nodesToFollow = byte[0]
[2013-12-09 18:59:18.340] Adding job: Association Get
[2013-12-09 18:59:18.340] SETDATA devices.2.instances.0.commandClasses.133.data.71 = Empty
[2013-12-09 18:59:18.341] SETDATA devices.2.instances.0.commandClasses.133.data.71.max = Empty
[2013-12-09 18:59:18.341] SETDATA devices.2.instances.0.commandClasses.133.data.71.max = 0 (0x00000000)
[2013-12-09 18:59:18.341] SETDATA devices.2.instances.0.commandClasses.133.data.71.nodes = Empty
[2013-12-09 18:59:18.341] SETDATA devices.2.instances.0.commandClasses.133.data.71.nodes = byte[0]
[2013-12-09 18:59:18.341] SETDATA devices.2.instances.0.commandClasses.133.data.71.nodesToFollow = Empty
[2013-12-09 18:59:18.341] SETDATA devices.2.instances.0.commandClasses.133.data.71.nodesToFollow = byte[0]
[2013-12-09 18:59:18.342] Adding job: Association Get
[2013-12-09 18:59:18.342] SETDATA devices.2.instances.0.commandClasses.133.data.72 = Empty
[2013-12-09 18:59:18.342] SETDATA devices.2.instances.0.commandClasses.133.data.72.max = Empty
[2013-12-09 18:59:18.342] SETDATA devices.2.instances.0.commandClasses.133.data.72.max = 0 (0x00000000)
[2013-12-09 18:59:18.342] SETDATA devices.2.instances.0.commandClasses.133.data.72.nodes = Empty
[2013-12-09 18:59:18.343] SETDATA devices.2.instances.0.commandClasses.133.data.72.nodes = byte[0]
[2013-12-09 18:59:18.343] SETDATA devices.2.instances.0.commandClasses.133.data.72.nodesToFollow = Empty
[2013-12-09 18:59:18.343] SETDATA devices.2.instances.0.commandClasses.133.data.72.nodesToFollow = byte[0]
[2013-12-09 18:59:18.344] Adding job: Association Get
[2013-12-09 18:59:18.344] SETDATA devices.2.instances.0.commandClasses.133.data.73 = Empty
[2013-12-09 18:59:18.344] SETDATA devices.2.instances.0.commandClasses.133.data.73.max = Empty
[2013-12-09 18:59:18.344] SETDATA devices.2.instances.0.commandClasses.133.data.73.max = 0 (0x00000000)
[2013-12-09 18:59:18.344] SETDATA devices.2.instances.0.commandClasses.133.data.73.nodes = Empty
[2013-12-09 18:59:18.344] SETDATA devices.2.instances.0.commandClasses.133.data.73.nodes = byte[0]
[2013-12-09 18:59:18.345] SETDATA devices.2.instances.0.commandClasses.133.data.73.nodesToFollow = Empty
[2013-12-09 18:59:18.345] SETDATA devices.2.instances.0.commandClasses.133.data.73.nodesToFollow = byte[0]
[2013-12-09 18:59:18.345] Adding job: Association Get
[2013-12-09 18:59:18.345] SETDATA devices.2.instances.0.commandClasses.133.data.74 = Empty
[2013-12-09 18:59:18.345] SETDATA devices.2.instances.0.commandClasses.133.data.74.max = Empty
[2013-12-09 18:59:18.346] SETDATA devices.2.instances.0.commandClasses.133.data.74.max = 0 (0x00000000)
[2013-12-09 18:59:18.346] SETDATA devices.2.instances.0.commandClasses.133.data.74.nodes = Empty
[2013-12-09 18:59:18.346] SETDATA devices.2.instances.0.commandClasses.133.data.74.nodes = byte[0]
[2013-12-09 18:59:18.346] SETDATA devices.2.instances.0.commandClasses.133.data.74.nodesToFollow = Empty
[2013-12-09 18:59:18.346] SETDATA devices.2.instances.0.commandClasses.133.data.74.nodesToFollow = byte[0]
[2013-12-09 18:59:18.347] Adding job: Association Get
[2013-12-09 18:59:18.347] SETDATA devices.2.instances.0.commandClasses.133.data.75 = Empty
[2013-12-09 18:59:18.347] SETDATA devices.2.instances.0.commandClasses.133.data.75.max = Empty
[2013-12-09 18:59:18.347] SETDATA devices.2.instances.0.commandClasses.133.data.75.max = 0 (0x00000000)
[2013-12-09 18:59:18.347] SETDATA devices.2.instances.0.commandClasses.133.data.75.nodes = Empty
[2013-12-09 18:59:18.347] SETDATA devices.2.instances.0.commandClasses.133.data.75.nodes = byte[0]
[2013-12-09 18:59:18.347] SETDATA devices.2.instances.0.commandClasses.133.data.75.nodesToFollow = Empty
[2013-12-09 18:59:18.348] SETDATA devices.2.instances.0.commandClasses.133.data.75.nodesToFollow = byte[0]
[2013-12-09 18:59:18.348] Adding job: Association Get
[2013-12-09 18:59:18.348] SETDATA devices.2.instances.0.commandClasses.133.data.76 = Empty
[2013-12-09 18:59:18.348] SETDATA devices.2.instances.0.commandClasses.133.data.76.max = Empty
[2013-12-09 18:59:18.348] SETDATA devices.2.instances.0.commandClasses.133.data.76.max = 0 (0x00000000)
[2013-12-09 18:59:18.348] SETDATA devices.2.instances.0.commandClasses.133.data.76.nodes = Empty
[2013-12-09 18:59:18.349] SETDATA devices.2.instances.0.commandClasses.133.data.76.nodes = byte[0]
[2013-12-09 18:59:18.349] SETDATA devices.2.instances.0.commandClasses.133.data.76.nodesToFollow = Empty
[2013-12-09 18:59:18.349] SETDATA devices.2.instances.0.commandClasses.133.data.76.nodesToFollow = byte[0]
[2013-12-09 18:59:18.349] Adding job: Association Get
[2013-12-09 18:59:18.349] SETDATA devices.2.instances.0.commandClasses.133.data.77 = Empty
[2013-12-09 18:59:18.350] SETDATA devices.2.instances.0.commandClasses.133.data.77.max = Empty
[2013-12-09 18:59:18.350] SETDATA devices.2.instances.0.commandClasses.133.data.77.max = 0 (0x00000000)
[2013-12-09 18:59:18.350] SETDATA devices.2.instances.0.commandClasses.133.data.77.nodes = Empty
[2013-12-09 18:59:18.350] SETDATA devices.2.instances.0.commandClasses.133.data.77.nodes = byte[0]
[2013-12-09 18:59:18.350] SETDATA devices.2.instances.0.commandClasses.133.data.77.nodesToFollow = Empty
[2013-12-09 18:59:18.350] SETDATA devices.2.instances.0.commandClasses.133.data.77.nodesToFollow = byte[0]
[2013-12-09 18:59:18.351] Adding job: Association Get
[2013-12-09 18:59:18.351] SETDATA devices.2.instances.0.commandClasses.133.data.78 = Empty
[2013-12-09 18:59:18.351] SETDATA devices.2.instances.0.commandClasses.133.data.78.max = Empty
[2013-12-09 18:59:18.351] SETDATA devices.2.instances.0.commandClasses.133.data.78.max = 0 (0x00000000)
[2013-12-09 18:59:18.352] SETDATA devices.2.instances.0.commandClasses.133.data.78.nodes = Empty
[2013-12-09 18:59:18.352] SETDATA devices.2.instances.0.commandClasses.133.data.78.nodes = byte[0]
[2013-12-09 18:59:18.352] SETDATA devices.2.instances.0.commandClasses.133.data.78.nodesToFollow = Empty
[2013-12-09 18:59:18.352] SETDATA devices.2.instances.0.commandClasses.133.data.78.nodesToFollow = byte[0]
[2013-12-09 18:59:18.352] Adding job: Association Get
[2013-12-09 18:59:18.353] SETDATA devices.2.instances.0.commandClasses.133.data.79 = Empty
[2013-12-09 18:59:18.353] SETDATA devices.2.instances.0.commandClasses.133.data.79.max = Empty
[2013-12-09 18:59:18.353] SETDATA devices.2.instances.0.commandClasses.133.data.79.max = 0 (0x00000000)
[2013-12-09 18:59:18.353] SETDATA devices.2.instances.0.commandClasses.133.data.79.nodes = Empty
[2013-12-09 18:59:18.353] SETDATA devices.2.instances.0.commandClasses.133.data.79.nodes = byte[0]
[2013-12-09 18:59:18.354] SETDATA devices.2.instances.0.commandClasses.133.data.79.nodesToFollow = Empty
[2013-12-09 18:59:18.354] SETDATA devices.2.instances.0.commandClasses.133.data.79.nodesToFollow = byte[0]
[2013-12-09 18:59:18.354] Adding job: Association Get
[2013-12-09 18:59:18.355] SETDATA devices.2.instances.0.commandClasses.133.data.80 = Empty
[2013-12-09 18:59:18.355] SETDATA devices.2.instances.0.commandClasses.133.data.80.max = Empty
[2013-12-09 18:59:18.355] SETDATA devices.2.instances.0.commandClasses.133.data.80.max = 0 (0x00000000)
[2013-12-09 18:59:18.355] SETDATA devices.2.instances.0.commandClasses.133.data.80.nodes = Empty
[2013-12-09 18:59:18.355] SETDATA devices.2.instances.0.commandClasses.133.data.80.nodes = byte[0]
[2013-12-09 18:59:18.355] SETDATA devices.2.instances.0.commandClasses.133.data.80.nodesToFollow = Empty
[2013-12-09 18:59:18.355] SETDATA devices.2.instances.0.commandClasses.133.data.80.nodesToFollow = byte[0]
[2013-12-09 18:59:18.356] Adding job: Association Get
[2013-12-09 18:59:18.356] SETDATA devices.2.instances.0.commandClasses.133.data.81 = Empty
[2013-12-09 18:59:18.356] SETDATA devices.2.instances.0.commandClasses.133.data.81.max = Empty
[2013-12-09 18:59:18.356] SETDATA devices.2.instances.0.commandClasses.133.data.81.max = 0 (0x00000000)
[2013-12-09 18:59:18.356] SETDATA devices.2.instances.0.commandClasses.133.data.81.nodes = Empty
[2013-12-09 18:59:18.357] SETDATA devices.2.instances.0.commandClasses.133.data.81.nodes = byte[0]
( zero-length buffer )
[2013-12-09 18:59:18.357] SETDATA devices.2.instances.0.commandClasses.133.data.81.nodesToFollow = Empty
[2013-12-09 18:59:18.357] SETDATA devices.2.instances.0.commandClasses.133.data.81.nodesToFollow = byte[0]
[2013-12-09 18:59:18.357] Adding job: Association Get
[2013-12-09 18:59:18.357] SETDATA devices.2.instances.0.commandClasses.133.data.82 = Empty
[2013-12-09 18:59:18.358] SETDATA devices.2.instances.0.commandClasses.133.data.82.max = Empty
[2013-12-09 18:59:18.358] SETDATA devices.2.instances.0.commandClasses.133.data.82.max = 0 (0x00000000)
[2013-12-09 18:59:18.358] SETDATA devices.2.instances.0.commandClasses.133.data.82.nodes = Empty
[2013-12-09 18:59:18.358] SETDATA devices.2.instances.0.commandClasses.133.data.82.nodes = byte[0]
[2013-12-09 18:59:18.358] SETDATA devices.2.instances.0.commandClasses.133.data.82.nodesToFollow = Empty
[2013-12-09 18:59:18.358] SETDATA devices.2.instances.0.commandClasses.133.data.82.nodesToFollow = byte[0]
[2013-12-09 18:59:18.359] Adding job: Association Get
[2013-12-09 18:59:18.359] SETDATA devices.2.instances.0.commandClasses.133.data.83 = Empty
[2013-12-09 18:59:18.359] SETDATA devices.2.instances.0.commandClasses.133.data.83.max = Empty
[2013-12-09 18:59:18.359] SETDATA devices.2.instances.0.commandClasses.133.data.83.max = 0 (0x00000000)
[2013-12-09 18:59:18.359] SETDATA devices.2.instances.0.commandClasses.133.data.83.nodes = Empty
[2013-12-09 18:59:18.359] SETDATA devices.2.instances.0.commandClasses.133.data.83.nodes = byte[0]
[2013-12-09 18:59:18.359] SETDATA devices.2.instances.0.commandClasses.133.data.83.nodesToFollow = Empty
[2013-12-09 18:59:18.360] SETDATA devices.2.instances.0.commandClasses.133.data.83.nodesToFollow = byte[0]
[2013-12-09 18:59:18.360] Adding job: Association Get
[2013-12-09 18:59:18.360] SETDATA devices.2.instances.0.commandClasses.133.data.84 = Empty
[2013-12-09 18:59:18.360] SETDATA devices.2.instances.0.commandClasses.133.data.84.max = Empty
[2013-12-09 18:59:18.360] SETDATA devices.2.instances.0.commandClasses.133.data.84.max = 0 (0x00000000)
[2013-12-09 18:59:18.361] SETDATA devices.2.instances.0.commandClasses.133.data.84.nodes = Empty
[2013-12-09 18:59:18.361] SETDATA devices.2.instances.0.commandClasses.133.data.84.nodes = byte[0]
[2013-12-09 18:59:18.361] SETDATA devices.2.instances.0.commandClasses.133.data.84.nodesToFollow = Empty
[2013-12-09 18:59:18.361] SETDATA devices.2.instances.0.commandClasses.133.data.84.nodesToFollow = byte[0]
[2013-12-09 18:59:18.361] Adding job: Association Get
[2013-12-09 18:59:18.362] SETDATA devices.2.instances.0.commandClasses.133.data.85 = Empty
[2013-12-09 18:59:18.362] SETDATA devices.2.instances.0.commandClasses.133.data.85.max = Empty
[2013-12-09 18:59:18.362] SETDATA devices.2.instances.0.commandClasses.133.data.85.max = 0 (0x00000000)
[2013-12-09 18:59:18.362] SETDATA devices.2.instances.0.commandClasses.133.data.85.nodes = Empty
[2013-12-09 18:59:18.362] SETDATA devices.2.instances.0.commandClasses.133.data.85.nodes = byte[0]
[2013-12-09 18:59:18.363] SETDATA devices.2.instances.0.commandClasses.133.data.85.nodesToFollow = Empty
[2013-12-09 18:59:18.363] SETDATA devices.2.instances.0.commandClasses.133.data.85.nodesToFollow = byte[0]
[2013-12-09 18:59:18.363] Adding job: Association Get
[2013-12-09 18:59:18.363] SETDATA devices.2.instances.0.commandClasses.133.data.86 = Empty
[2013-12-09 18:59:18.363] SETDATA devices.2.instances.0.commandClasses.133.data.86.max = Empty
[2013-12-09 18:59:18.364] SETDATA devices.2.instances.0.commandClasses.133.data.86.max = 0 (0x00000000)
[2013-12-09 18:59:18.364] SETDATA devices.2.instances.0.commandClasses.133.data.86.nodes = Empty
[2013-12-09 18:59:18.364] SETDATA devices.2.instances.0.commandClasses.133.data.86.nodes = byte[0]
[2013-12-09 18:59:18.364] SETDATA devices.2.instances.0.commandClasses.133.data.86.nodesToFollow = Empty
[2013-12-09 18:59:18.365] SETDATA devices.2.instances.0.commandClasses.133.data.86.nodesToFollow = byte[0]
[2013-12-09 18:59:18.365] Adding job: Association Get
[2013-12-09 18:59:18.365] SETDATA devices.2.instances.0.commandClasses.133.data.87 = Empty
[2013-12-09 18:59:18.365] SETDATA devices.2.instances.0.commandClasses.133.data.87.max = Empty
[2013-12-09 18:59:18.365] SETDATA devices.2.instances.0.commandClasses.133.data.87.max = 0 (0x00000000)
[2013-12-09 18:59:18.366] SETDATA devices.2.instances.0.commandClasses.133.data.87.nodes = Empty
[2013-12-09 18:59:18.366] SETDATA devices.2.instances.0.commandClasses.133.data.87.nodes = byte[0]
[2013-12-09 18:59:18.366] SETDATA devices.2.instances.0.commandClasses.133.data.87.nodesToFollow = Empty
[2013-12-09 18:59:18.366] SETDATA devices.2.instances.0.commandClasses.133.data.87.nodesToFollow = byte[0]
[2013-12-09 18:59:18.366] Adding job: Association Get
[2013-12-09 18:59:18.366] SETDATA devices.2.instances.0.commandClasses.133.data.88 = Empty
[2013-12-09 18:59:18.367] SETDATA devices.2.instances.0.commandClasses.133.data.88.max = Empty
[2013-12-09 18:59:18.367] SETDATA devices.2.instances.0.commandClasses.133.data.88.max = 0 (0x00000000)
[2013-12-09 18:59:18.367] SETDATA devices.2.instances.0.commandClasses.133.data.88.nodes = Empty
[2013-12-09 18:59:18.367] SETDATA devices.2.instances.0.commandClasses.133.data.88.nodes = byte[0]
[2013-12-09 18:59:18.367] SETDATA devices.2.instances.0.commandClasses.133.data.88.nodesToFollow = Empty
[2013-12-09 18:59:18.367] SETDATA devices.2.instances.0.commandClasses.133.data.88.nodesToFollow = byte[0]
[2013-12-09 18:59:18.368] Adding job: Association Get
[2013-12-09 18:59:18.368] SETDATA devices.2.instances.0.commandClasses.133.data.89 = Empty
[2013-12-09 18:59:18.368] SETDATA devices.2.instances.0.commandClasses.133.data.89.max = Empty
[2013-12-09 18:59:18.368] SETDATA devices.2.instances.0.commandClasses.133.data.89.max = 0 (0x00000000)
[2013-12-09 18:59:18.368] SETDATA devices.2.instances.0.commandClasses.133.data.89.nodes = Empty
[2013-12-09 18:59:18.368] SETDATA devices.2.instances.0.commandClasses.133.data.89.nodes = byte[0]
[2013-12-09 18:59:18.369] SETDATA devices.2.instances.0.commandClasses.133.data.89.nodesToFollow = Empty
[2013-12-09 18:59:18.369] SETDATA devices.2.instances.0.commandClasses.133.data.89.nodesToFollow = byte[0]
[2013-12-09 18:59:18.369] Adding job: Association Get
[2013-12-09 18:59:18.369] SETDATA devices.2.instances.0.commandClasses.133.data.90 = Empty
[2013-12-09 18:59:18.369] SETDATA devices.2.instances.0.commandClasses.133.data.90.max = Empty
[2013-12-09 18:59:18.370] SETDATA devices.2.instances.0.commandClasses.133.data.90.max = 0 (0x00000000)
[2013-12-09 18:59:18.370] SETDATA devices.2.instances.0.commandClasses.133.data.90.nodes = Empty
[2013-12-09 18:59:18.370] SETDATA devices.2.instances.0.commandClasses.133.data.90.nodes = byte[0]
[2013-12-09 18:59:18.370] SETDATA devices.2.instances.0.commandClasses.133.data.90.nodesToFollow = Empty
[2013-12-09 18:59:18.370] SETDATA devices.2.instances.0.commandClasses.133.data.90.nodesToFollow = byte[0]
[2013-12-09 18:59:18.371] Adding job: Association Get
[2013-12-09 18:59:18.371] SETDATA devices.2.instances.0.commandClasses.133.data.91 = Empty
[2013-12-09 18:59:18.371] SETDATA devices.2.instances.0.commandClasses.133.data.91.max = Empty
[2013-12-09 18:59:18.371] SETDATA devices.2.instances.0.commandClasses.133.data.91.max = 0 (0x00000000)
[2013-12-09 18:59:18.371] SETDATA devices.2.instances.0.commandClasses.133.data.91.nodes = Empty
[2013-12-09 18:59:18.372] SETDATA devices.2.instances.0.commandClasses.133.data.91.nodes = byte[0]
[2013-12-09 18:59:18.372] SETDATA devices.2.instances.0.commandClasses.133.data.91.nodesToFollow = Empty
[2013-12-09 18:59:18.372] SETDATA devices.2.instances.0.commandClasses.133.data.91.nodesToFollow = byte[0]
[2013-12-09 18:59:18.372] Adding job: Association Get
[2013-12-09 18:59:18.373] SETDATA devices.2.instances.0.commandClasses.133.data.92 = Empty
[2013-12-09 18:59:18.373] SETDATA devices.2.instances.0.commandClasses.133.data.92.max = Empty
[2013-12-09 18:59:18.373] SETDATA devices.2.instances.0.commandClasses.133.data.92.max = 0 (0x00000000)
[2013-12-09 18:59:18.373] SETDATA devices.2.instances.0.commandClasses.133.data.92.nodes = Empty
[2013-12-09 18:59:18.373] SETDATA devices.2.instances.0.commandClasses.133.data.92.nodes = byte[0]
[2013-12-09 18:59:18.373] SETDATA devices.2.instances.0.commandClasses.133.data.92.nodesToFollow = Empty
[2013-12-09 18:59:18.373] SETDATA devices.2.instances.0.commandClasses.133.data.92.nodesToFollow = byte[0]
[2013-12-09 18:59:18.374] Adding job: Association Get
[2013-12-09 18:59:18.374] SETDATA devices.2.instances.0.commandClasses.133.data.93 = Empty
[2013-12-09 18:59:18.374] SETDATA devices.2.instances.0.commandClasses.133.data.93.max = Empty
[2013-12-09 18:59:18.375] SETDATA devices.2.instances.0.commandClasses.133.data.93.max = 0 (0x00000000)
[2013-12-09 18:59:18.375] SETDATA devices.2.instances.0.commandClasses.133.data.93.nodes = Empty
[2013-12-09 18:59:18.375] SETDATA devices.2.instances.0.commandClasses.133.data.93.nodes = byte[0]
[2013-12-09 18:59:18.375] SETDATA devices.2.instances.0.commandClasses.133.data.93.nodesToFollow = Empty
[2013-12-09 18:59:18.375] SETDATA devices.2.instances.0.commandClasses.133.data.93.nodesToFollow = byte[0]
[2013-12-09 18:59:18.376] Adding job: Association Get
[2013-12-09 18:59:18.376] SETDATA devices.2.instances.0.commandClasses.133.data.94 = Empty
[2013-12-09 18:59:18.376] SETDATA devices.2.instances.0.commandClasses.133.data.94.max = Empty
[2013-12-09 18:59:18.376] SETDATA devices.2.instances.0.commandClasses.133.data.94.max = 0 (0x00000000)
[2013-12-09 18:59:18.376] SETDATA devices.2.instances.0.commandClasses.133.data.94.nodes = Empty
[2013-12-09 18:59:18.376] SETDATA devices.2.instances.0.commandClasses.133.data.94.nodes = byte[0]
[2013-12-09 18:59:18.376] SETDATA devices.2.instances.0.commandClasses.133.data.94.nodesToFollow = Empty
[2013-12-09 18:59:18.377] SETDATA devices.2.instances.0.commandClasses.133.data.94.nodesToFollow = byte[0]
[2013-12-09 18:59:18.377] Adding job: Association Get
[2013-12-09 18:59:18.377] SETDATA devices.2.instances.0.commandClasses.133.data.95 = Empty
[2013-12-09 18:59:18.377] SETDATA devices.2.instances.0.commandClasses.133.data.95.max = Empty
[2013-12-09 18:59:18.377] SETDATA devices.2.instances.0.commandClasses.133.data.95.max = 0 (0x00000000)
[2013-12-09 18:59:18.378] SETDATA devices.2.instances.0.commandClasses.133.data.95.nodes = Empty
[2013-12-09 18:59:18.378] SETDATA devices.2.instances.0.commandClasses.133.data.95.nodes = byte[0]
[2013-12-09 18:59:18.378] SETDATA devices.2.instances.0.commandClasses.133.data.95.nodesToFollow = Empty
[2013-12-09 18:59:18.378] SETDATA devices.2.instances.0.commandClasses.133.data.95.nodesToFollow = byte[0]
[2013-12-09 18:59:18.378] Adding job: Association Get
[2013-12-09 18:59:18.379] SETDATA devices.2.instances.0.commandClasses.133.data.96 = Empty
[2013-12-09 18:59:18.379] SETDATA devices.2.instances.0.commandClasses.133.data.96.max = Empty
[2013-12-09 18:59:18.379] SETDATA devices.2.instances.0.commandClasses.133.data.96.max = 0 (0x00000000)
[2013-12-09 18:59:18.379] SETDATA devices.2.instances.0.commandClasses.133.data.96.nodes = Empty
[2013-12-09 18:59:18.379] SETDATA devices.2.instances.0.commandClasses.133.data.96.nodes = byte[0]
[2013-12-09 18:59:18.379] SETDATA devices.2.instances.0.commandClasses.133.data.96.nodesToFollow = Empty
[2013-12-09 18:59:18.380] SETDATA devices.2.instances.0.commandClasses.133.data.96.nodesToFollow = byte[0]
[2013-12-09 18:59:18.380] Adding job: Association Get
[2013-12-09 18:59:18.380] SETDATA devices.2.instances.0.commandClasses.133.data.97 = Empty
[2013-12-09 18:59:18.380] SETDATA devices.2.instances.0.commandClasses.133.data.97.max = Empty
[2013-12-09 18:59:18.380] SETDATA devices.2.instances.0.commandClasses.133.data.97.max = 0 (0x00000000)
[2013-12-09 18:59:18.381] SETDATA devices.2.instances.0.commandClasses.133.data.97.nodes = Empty
[2013-12-09 18:59:18.381] SETDATA devices.2.instances.0.commandClasses.133.data.97.nodes = byte[0]
[2013-12-09 18:59:18.381] SETDATA devices.2.instances.0.commandClasses.133.data.97.nodesToFollow = Empty
[2013-12-09 18:59:18.381] SETDATA devices.2.instances.0.commandClasses.133.data.97.nodesToFollow = byte[0]
[2013-12-09 18:59:18.381] Adding job: Association Get
[2013-12-09 18:59:18.382] SETDATA devices.2.instances.0.commandClasses.133.data.98 = Empty
[2013-12-09 18:59:18.382] SETDATA devices.2.instances.0.commandClasses.133.data.98.max = Empty
[2013-12-09 18:59:18.382] SETDATA devices.2.instances.0.commandClasses.133.data.98.max = 0 (0x00000000)
[2013-12-09 18:59:18.382] SETDATA devices.2.instances.0.commandClasses.133.data.98.nodes = Empty
[2013-12-09 18:59:18.382] SETDATA devices.2.instances.0.commandClasses.133.data.98.nodes = byte[0]
[2013-12-09 18:59:18.383] SETDATA devices.2.instances.0.commandClasses.133.data.98.nodesToFollow = Empty
[2013-12-09 18:59:18.383] SETDATA devices.2.instances.0.commandClasses.133.data.98.nodesToFollow = byte[0]
[2013-12-09 18:59:18.383] Adding job: Association Get
[2013-12-09 18:59:18.383] SETDATA devices.2.instances.0.commandClasses.133.data.99 = Empty
[2013-12-09 18:59:18.383] SETDATA devices.2.instances.0.commandClasses.133.data.99.max = Empty
[2013-12-09 18:59:18.384] SETDATA devices.2.instances.0.commandClasses.133.data.99.max = 0 (0x00000000)
[2013-12-09 18:59:18.384] SETDATA devices.2.instances.0.commandClasses.133.data.99.nodes = Empty
[2013-12-09 18:59:18.384] SETDATA devices.2.instances.0.commandClasses.133.data.99.nodes = byte[0]
[2013-12-09 18:59:18.384] SETDATA devices.2.instances.0.commandClasses.133.data.99.nodesToFollow = Empty
[2013-12-09 18:59:18.384] SETDATA devices.2.instances.0.commandClasses.133.data.99.nodesToFollow = byte[0]
[2013-12-09 18:59:18.385] Adding job: Association Get
[2013-12-09 18:59:18.385] SETDATA devices.2.instances.0.commandClasses.133.data.100 = Empty
[2013-12-09 18:59:18.385] SETDATA devices.2.instances.0.commandClasses.133.data.100.max = Empty
[2013-12-09 18:59:18.386] SETDATA devices.2.instances.0.commandClasses.133.data.100.max = 0 (0x00000000)
[2013-12-09 18:59:18.386] SETDATA devices.2.instances.0.commandClasses.133.data.100.nodes = Empty
[2013-12-09 18:59:18.386] SETDATA devices.2.instances.0.commandClasses.133.data.100.nodes = byte[0]
[2013-12-09 18:59:18.386] SETDATA devices.2.instances.0.commandClasses.133.data.100.nodesToFollow = Empty
[2013-12-09 18:59:18.386] SETDATA devices.2.instances.0.commandClasses.133.data.100.nodesToFollow = byte[0]
[2013-12-09 18:59:18.387] Adding job: Association Get
[2013-12-09 18:59:18.387] SETDATA devices.2.instances.0.commandClasses.133.data.101 = Empty
[2013-12-09 18:59:18.387] SETDATA devices.2.instances.0.commandClasses.133.data.101.max = Empty
[2013-12-09 18:59:18.387] SETDATA devices.2.instances.0.commandClasses.133.data.101.max = 0 (0x00000000)
[2013-12-09 18:59:18.387] SETDATA devices.2.instances.0.commandClasses.133.data.101.nodes = Empty
[2013-12-09 18:59:18.387] SETDATA devices.2.instances.0.commandClasses.133.data.101.nodes = byte[0]
[2013-12-09 18:59:18.387] SETDATA devices.2.instances.0.commandClasses.133.data.101.nodesToFollow = Empty
[2013-12-09 18:59:18.388] SETDATA devices.2.instances.0.commandClasses.133.data.101.nodesToFollow = byte[0]
[2013-12-09 18:59:18.388] Adding job: Association Get
[2013-12-09 18:59:18.388] SETDATA devices.2.instances.0.commandClasses.133.data.102 = Empty
[2013-12-09 18:59:18.388] SETDATA devices.2.instances.0.commandClasses.133.data.102.max = Empty
[2013-12-09 18:59:18.388] SETDATA devices.2.instances.0.commandClasses.133.data.102.max = 0 (0x00000000)
[2013-12-09 18:59:18.389] SETDATA devices.2.instances.0.commandClasses.133.data.102.nodes = Empty
[2013-12-09 18:59:18.389] SETDATA devices.2.instances.0.commandClasses.133.data.102.nodes = byte[0]
[2013-12-09 18:59:18.389] SETDATA devices.2.instances.0.commandClasses.133.data.102.nodesToFollow = Empty
[2013-12-09 18:59:18.389] SETDATA devices.2.instances.0.commandClasses.133.data.102.nodesToFollow = byte[0]
[2013-12-09 18:59:18.389] Adding job: Association Get
[2013-12-09 18:59:18.390] SETDATA devices.2.instances.0.commandClasses.133.data.103 = Empty
[2013-12-09 18:59:18.390] SETDATA devices.2.instances.0.commandClasses.133.data.103.max = Empty
[2013-12-09 18:59:18.390] SETDATA devices.2.instances.0.commandClasses.133.data.103.max = 0 (0x00000000)
[2013-12-09 18:59:18.390] SETDATA devices.2.instances.0.commandClasses.133.data.103.nodes = Empty
[2013-12-09 18:59:18.390] SETDATA devices.2.instances.0.commandClasses.133.data.103.nodes = byte[0]
[2013-12-09 18:59:18.390] SETDATA devices.2.instances.0.commandClasses.133.data.103.nodesToFollow = Empty
[2013-12-09 18:59:18.390] SETDATA devices.2.instances.0.commandClasses.133.data.103.nodesToFollow = byte[0]
[2013-12-09 18:59:18.391] Adding job: Association Get
[2013-12-09 18:59:18.391] SETDATA devices.2.instances.0.commandClasses.133.data.104 = Empty
[2013-12-09 18:59:18.391] SETDATA devices.2.instances.0.commandClasses.133.data.104.max = Empty
[2013-12-09 18:59:18.391] SETDATA devices.2.instances.0.commandClasses.133.data.104.max = 0 (0x00000000)
[2013-12-09 18:59:18.391] SETDATA devices.2.instances.0.commandClasses.133.data.104.nodes = Empty
[2013-12-09 18:59:18.392] SETDATA devices.2.instances.0.commandClasses.133.data.104.nodes = byte[0]
[2013-12-09 18:59:18.392] SETDATA devices.2.instances.0.commandClasses.133.data.104.nodesToFollow = Empty
[2013-12-09 18:59:18.392] SETDATA devices.2.instances.0.commandClasses.133.data.104.nodesToFollow = byte[0]
[2013-12-09 18:59:18.393] Adding job: Association Get
[2013-12-09 18:59:18.393] SETDATA devices.2.instances.0.commandClasses.133.data.105 = Empty
[2013-12-09 18:59:18.393] SETDATA devices.2.instances.0.commandClasses.133.data.105.max = Empty
[2013-12-09 18:59:18.393] SETDATA devices.2.instances.0.commandClasses.133.data.105.max = 0 (0x00000000)
[2013-12-09 18:59:18.393] SETDATA devices.2.instances.0.commandClasses.133.data.105.nodes = Empty
[2013-12-09 18:59:18.393] SETDATA devices.2.instances.0.commandClasses.133.data.105.nodes = byte[0]
[2013-12-09 18:59:18.393] SETDATA devices.2.instances.0.commandClasses.133.data.105.nodesToFollow = Empty
[2013-12-09 18:59:18.394] SETDATA devices.2.instances.0.commandClasses.133.data.105.nodesToFollow = byte[0]
[2013-12-09 18:59:18.394] Adding job: Association Get
[2013-12-09 18:59:18.394] SETDATA devices.2.instances.0.commandClasses.133.data.106 = Empty
[2013-12-09 18:59:18.394] SETDATA devices.2.instances.0.commandClasses.133.data.106.max = Empty
[2013-12-09 18:59:18.395] SETDATA devices.2.instances.0.commandClasses.133.data.106.max = 0 (0x00000000)
[2013-12-09 18:59:18.395] SETDATA devices.2.instances.0.commandClasses.133.data.106.nodes = Empty
[2013-12-09 18:59:18.395] SETDATA devices.2.instances.0.commandClasses.133.data.106.nodes = byte[0]
[2013-12-09 18:59:18.395] SETDATA devices.2.instances.0.commandClasses.133.data.106.nodesToFollow = Empty
[2013-12-09 18:59:18.395] SETDATA devices.2.instances.0.commandClasses.133.data.106.nodesToFollow = byte[0]
[2013-12-09 18:59:18.396] Adding job: Association Get
[2013-12-09 18:59:18.396] SETDATA devices.2.instances.0.commandClasses.133.data.107 = Empty
[2013-12-09 18:59:18.396] SETDATA devices.2.instances.0.commandClasses.133.data.107.max = Empty
[2013-12-09 18:59:18.396] SETDATA devices.2.instances.0.commandClasses.133.data.107.max = 0 (0x00000000)
[2013-12-09 18:59:18.397] SETDATA devices.2.instances.0.commandClasses.133.data.107.nodes = Empty
[2013-12-09 18:59:18.397] SETDATA devices.2.instances.0.commandClasses.133.data.107.nodes = byte[0]
[2013-12-09 18:59:18.397] SETDATA devices.2.instances.0.commandClasses.133.data.107.nodesToFollow = Empty
[2013-12-09 18:59:18.397] SETDATA devices.2.instances.0.commandClasses.133.data.107.nodesToFollow = byte[0]
[2013-12-09 18:59:18.397] Adding job: Association Get
[2013-12-09 18:59:18.398] SETDATA devices.2.instances.0.commandClasses.133.data.108 = Empty
[2013-12-09 18:59:18.398] SETDATA devices.2.instances.0.commandClasses.133.data.108.max = Empty
[2013-12-09 18:59:18.398] SETDATA devices.2.instances.0.commandClasses.133.data.108.max = 0 (0x00000000)
[2013-12-09 18:59:18.398] SETDATA devices.2.instances.0.commandClasses.133.data.108.nodes = Empty
[2013-12-09 18:59:18.398] SETDATA devices.2.instances.0.commandClasses.133.data.108.nodes = byte[0]
[2013-12-09 18:59:18.398] SETDATA devices.2.instances.0.commandClasses.133.data.108.nodesToFollow = Empty
[2013-12-09 18:59:18.398] SETDATA devices.2.instances.0.commandClasses.133.data.108.nodesToFollow = byte[0]
[2013-12-09 18:59:18.399] Adding job: Association Get
[2013-12-09 18:59:18.399] SETDATA devices.2.instances.0.commandClasses.133.data.109 = Empty
[2013-12-09 18:59:18.399] SETDATA devices.2.instances.0.commandClasses.133.data.109.max = Empty
[2013-12-09 18:59:18.399] SETDATA devices.2.instances.0.commandClasses.133.data.109.max = 0 (0x00000000)
[2013-12-09 18:59:18.399] SETDATA devices.2.instances.0.commandClasses.133.data.109.nodes = Empty
[2013-12-09 18:59:18.400] SETDATA devices.2.instances.0.commandClasses.133.data.109.nodes = byte[0]
[2013-12-09 18:59:18.400] SETDATA devices.2.instances.0.commandClasses.133.data.109.nodesToFollow = Empty
[2013-12-09 18:59:18.400] SETDATA devices.2.instances.0.commandClasses.133.data.109.nodesToFollow = byte[0]
[2013-12-09 18:59:18.400] Adding job: Association Get
[2013-12-09 18:59:18.400] SETDATA devices.2.instances.0.commandClasses.133.data.110 = Empty
[2013-12-09 18:59:18.401] SETDATA devices.2.instances.0.commandClasses.133.data.110.max = Empty
[2013-12-09 18:59:18.401] SETDATA devices.2.instances.0.commandClasses.133.data.110.max = 0 (0x00000000)
[2013-12-09 18:59:18.401] SETDATA devices.2.instances.0.commandClasses.133.data.110.nodes = Empty
[2013-12-09 18:59:18.401] SETDATA devices.2.instances.0.commandClasses.133.data.110.nodes = byte[0]
[2013-12-09 18:59:18.401] SETDATA devices.2.instances.0.commandClasses.133.data.110.nodesToFollow = Empty
[2013-12-09 18:59:18.401] SETDATA devices.2.instances.0.commandClasses.133.data.110.nodesToFollow = byte[0]
[2013-12-09 18:59:18.402] Adding job: Association Get
[2013-12-09 18:59:18.402] SETDATA devices.2.instances.0.commandClasses.133.data.111 = Empty
[2013-12-09 18:59:18.402] SETDATA devices.2.instances.0.commandClasses.133.data.111.max = Empty
[2013-12-09 18:59:18.403] SETDATA devices.2.instances.0.commandClasses.133.data.111.max = 0 (0x00000000)
[2013-12-09 18:59:18.403] SETDATA devices.2.instances.0.commandClasses.133.data.111.nodes = Empty
[2013-12-09 18:59:18.403] SETDATA devices.2.instances.0.commandClasses.133.data.111.nodes = byte[0]
[2013-12-09 18:59:18.403] SETDATA devices.2.instances.0.commandClasses.133.data.111.nodesToFollow = Empty
[2013-12-09 18:59:18.403] SETDATA devices.2.instances.0.commandClasses.133.data.111.nodesToFollow = byte[0]
[2013-12-09 18:59:18.403] Adding job: Association Get
[2013-12-09 18:59:18.404] SETDATA devices.2.instances.0.commandClasses.133.data.112 = Empty
[2013-12-09 18:59:18.404] SETDATA devices.2.instances.0.commandClasses.133.data.112.max = Empty
[2013-12-09 18:59:18.404] SETDATA devices.2.instances.0.commandClasses.133.data.112.max = 0 (0x00000000)
[2013-12-09 18:59:18.404] SETDATA devices.2.instances.0.commandClasses.133.data.112.nodes = Empty
[2013-12-09 18:59:18.404] SETDATA devices.2.instances.0.commandClasses.133.data.112.nodes = byte[0]
[2013-12-09 18:59:18.404] SETDATA devices.2.instances.0.commandClasses.133.data.112.nodesToFollow = Empty
[2013-12-09 18:59:18.405] SETDATA devices.2.instances.0.commandClasses.133.data.112.nodesToFollow = byte[0]
[2013-12-09 18:59:18.405] Adding job: Association Get
[2013-12-09 18:59:18.406] SETDATA devices.2.instances.0.commandClasses.133.data.113 = Empty
[2013-12-09 18:59:18.406] SETDATA devices.2.instances.0.commandClasses.133.data.113.max = Empty
[2013-12-09 18:59:18.406] SETDATA devices.2.instances.0.commandClasses.133.data.113.max = 0 (0x00000000)
[2013-12-09 18:59:18.406] SETDATA devices.2.instances.0.commandClasses.133.data.113.nodes = Empty
[2013-12-09 18:59:18.406] SETDATA devices.2.instances.0.commandClasses.133.data.113.nodes = byte[0]
[2013-12-09 18:59:18.406] SETDATA devices.2.instances.0.commandClasses.133.data.113.nodesToFollow = Empty
[2013-12-09 18:59:18.406] SETDATA devices.2.instances.0.commandClasses.133.data.113.nodesToFollow = byte[0]
[2013-12-09 18:59:18.407] Adding job: Association Get
[2013-12-09 18:59:18.407] SETDATA devices.2.instances.0.commandClasses.133.data.114 = Empty
[2013-12-09 18:59:18.407] SETDATA devices.2.instances.0.commandClasses.133.data.114.max = Empty
[2013-12-09 18:59:18.407] SETDATA devices.2.instances.0.commandClasses.133.data.114.max = 0 (0x00000000)
[2013-12-09 18:59:18.407] SETDATA devices.2.instances.0.commandClasses.133.data.114.nodes = Empty
[2013-12-09 18:59:18.408] SETDATA devices.2.instances.0.commandClasses.133.data.114.nodes = byte[0]
[2013-12-09 18:59:18.408] SETDATA devices.2.instances.0.commandClasses.133.data.114.nodesToFollow = Empty
[2013-12-09 18:59:18.408] SETDATA devices.2.instances.0.commandClasses.133.data.114.nodesToFollow = byte[0]
[2013-12-09 18:59:18.408] Adding job: Association Get
[2013-12-09 18:59:18.409] SETDATA devices.2.instances.0.commandClasses.133.data.115 = Empty
[2013-12-09 18:59:18.409] SETDATA devices.2.instances.0.commandClasses.133.data.115.max = Empty
[2013-12-09 18:59:18.409] SETDATA devices.2.instances.0.commandClasses.133.data.115.max = 0 (0x00000000)
[2013-12-09 18:59:18.409] SETDATA devices.2.instances.0.commandClasses.133.data.115.nodes = Empty
[2013-12-09 18:59:18.409] SETDATA devices.2.instances.0.commandClasses.133.data.115.nodes = byte[0]
[2013-12-09 18:59:18.409] SETDATA devices.2.instances.0.commandClasses.133.data.115.nodesToFollow = Empty
[2013-12-09 18:59:18.409] SETDATA devices.2.instances.0.commandClasses.133.data.115.nodesToFollow = byte[0]
[2013-12-09 18:59:18.410] Adding job: Association Get
[2013-12-09 18:59:18.410] SETDATA devices.2.instances.0.commandClasses.133.data.116 = Empty
[2013-12-09 18:59:18.410] SETDATA devices.2.instances.0.commandClasses.133.data.116.max = Empty
[2013-12-09 18:59:18.410] SETDATA devices.2.instances.0.commandClasses.133.data.116.max = 0 (0x00000000)
[2013-12-09 18:59:18.410] SETDATA devices.2.instances.0.commandClasses.133.data.116.nodes = Empty
[2013-12-09 18:59:18.411] SETDATA devices.2.instances.0.commandClasses.133.data.116.nodes = byte[0]
[2013-12-09 18:59:18.411] SETDATA devices.2.instances.0.commandClasses.133.data.116.nodesToFollow = Empty
[2013-12-09 18:59:18.411] SETDATA devices.2.instances.0.commandClasses.133.data.116.nodesToFollow = byte[0]
[2013-12-09 18:59:18.411] Adding job: Association Get
[2013-12-09 18:59:18.412] SETDATA devices.2.instances.0.commandClasses.133.data.117 = Empty
[2013-12-09 18:59:18.412] SETDATA devices.2.instances.0.commandClasses.133.data.117.max = Empty
[2013-12-09 18:59:18.412] SETDATA devices.2.instances.0.commandClasses.133.data.117.max = 0 (0x00000000)
[2013-12-09 18:59:18.412] SETDATA devices.2.instances.0.commandClasses.133.data.117.nodes = Empty
[2013-12-09 18:59:18.412] SETDATA devices.2.instances.0.commandClasses.133.data.117.nodes = byte[0]
[2013-12-09 18:59:18.412] SETDATA devices.2.instances.0.commandClasses.133.data.117.nodesToFollow = Empty
[2013-12-09 18:59:18.413] SETDATA devices.2.instances.0.commandClasses.133.data.117.nodesToFollow = byte[0]
[2013-12-09 18:59:18.413] Adding job: Association Get
[2013-12-09 18:59:18.413] SETDATA devices.2.instances.0.commandClasses.133.data.118 = Empty
[2013-12-09 18:59:18.413] SETDATA devices.2.instances.0.commandClasses.133.data.118.max = Empty
[2013-12-09 18:59:18.414] SETDATA devices.2.instances.0.commandClasses.133.data.118.max = 0 (0x00000000)
[2013-12-09 18:59:18.414] SETDATA devices.2.instances.0.commandClasses.133.data.118.nodes = Empty
[2013-12-09 18:59:18.414] SETDATA devices.2.instances.0.commandClasses.133.data.118.nodes = byte[0]
[2013-12-09 18:59:18.414] SETDATA devices.2.instances.0.commandClasses.133.data.118.nodesToFollow = Empty
[2013-12-09 18:59:18.414] SETDATA devices.2.instances.0.commandClasses.133.data.118.nodesToFollow = byte[0]
[2013-12-09 18:59:18.415] Adding job: Association Get
[2013-12-09 18:59:18.415] SETDATA devices.2.instances.0.commandClasses.133.data.119 = Empty
[2013-12-09 18:59:18.415] SETDATA devices.2.instances.0.commandClasses.133.data.119.max = Empty
[2013-12-09 18:59:18.415] SETDATA devices.2.instances.0.commandClasses.133.data.119.max = 0 (0x00000000)
[2013-12-09 18:59:18.415] SETDATA devices.2.instances.0.commandClasses.133.data.119.nodes = Empty
[2013-12-09 18:59:18.416] SETDATA devices.2.instances.0.commandClasses.133.data.119.nodes = byte[0]
[2013-12-09 18:59:18.416] SETDATA devices.2.instances.0.commandClasses.133.data.119.nodesToFollow = Empty
[2013-12-09 18:59:18.416] SETDATA devices.2.instances.0.commandClasses.133.data.119.nodesToFollow = byte[0]
[2013-12-09 18:59:18.416] Adding job: Association Get
[2013-12-09 18:59:18.417] SETDATA devices.2.instances.0.commandClasses.133.data.120 = Empty
[2013-12-09 18:59:18.417] SETDATA devices.2.instances.0.commandClasses.133.data.120.max = Empty
[2013-12-09 18:59:18.417] SETDATA devices.2.instances.0.commandClasses.133.data.120.max = 0 (0x00000000)
[2013-12-09 18:59:18.417] SETDATA devices.2.instances.0.commandClasses.133.data.120.nodes = Empty
[2013-12-09 18:59:18.417] SETDATA devices.2.instances.0.commandClasses.133.data.120.nodes = byte[0]
[2013-12-09 18:59:18.417] SETDATA devices.2.instances.0.commandClasses.133.data.120.nodesToFollow = Empty
[2013-12-09 18:59:18.418] SETDATA devices.2.instances.0.commandClasses.133.data.120.nodesToFollow = byte[0]
[2013-12-09 18:59:18.418] Adding job: Association Get
[2013-12-09 18:59:18.418] SETDATA devices.2.instances.0.commandClasses.133.data.121 = Empty
[2013-12-09 18:59:18.418] SETDATA devices.2.instances.0.commandClasses.133.data.121.max = Empty
[2013-12-09 18:59:18.419] SETDATA devices.2.instances.0.commandClasses.133.data.121.max = 0 (0x00000000)
[2013-12-09 18:59:18.419] SETDATA devices.2.instances.0.commandClasses.133.data.121.nodes = Empty
[2013-12-09 18:59:18.419] SETDATA devices.2.instances.0.commandClasses.133.data.121.nodes = byte[0]
[2013-12-09 18:59:18.419] SETDATA devices.2.instances.0.commandClasses.133.data.121.nodesToFollow = Empty
[2013-12-09 18:59:18.419] SETDATA devices.2.instances.0.commandClasses.133.data.121.nodesToFollow = byte[0]
[2013-12-09 18:59:18.420] Adding job: Association Get
[2013-12-09 18:59:18.420] SETDATA devices.2.instances.0.commandClasses.133.data.122 = Empty
[2013-12-09 18:59:18.420] SETDATA devices.2.instances.0.commandClasses.133.data.122.max = Empty
[2013-12-09 18:59:18.420] SETDATA devices.2.instances.0.commandClasses.133.data.122.max = 0 (0x00000000)
[2013-12-09 18:59:18.420] SETDATA devices.2.instances.0.commandClasses.133.data.122.nodes = Empty
[2013-12-09 18:59:18.420] SETDATA devices.2.instances.0.commandClasses.133.data.122.nodes = byte[0]
[2013-12-09 18:59:18.420] SETDATA devices.2.instances.0.commandClasses.133.data.122.nodesToFollow = Empty
[2013-12-09 18:59:18.421] SETDATA devices.2.instances.0.commandClasses.133.data.122.nodesToFollow = byte[0]
[2013-12-09 18:59:18.421] Adding job: Association Get
[2013-12-09 18:59:18.421] SETDATA devices.2.instances.0.commandClasses.133.data.123 = Empty
[2013-12-09 18:59:18.421] SETDATA devices.2.instances.0.commandClasses.133.data.123.max = Empty
[2013-12-09 18:59:18.422] SETDATA devices.2.instances.0.commandClasses.133.data.123.max = 0 (0x00000000)
[2013-12-09 18:59:18.422] SETDATA devices.2.instances.0.commandClasses.133.data.123.nodes = Empty
[2013-12-09 18:59:18.422] SETDATA devices.2.instances.0.commandClasses.133.data.123.nodes = byte[0]
[2013-12-09 18:59:18.422] SETDATA devices.2.instances.0.commandClasses.133.data.123.nodesToFollow = Empty
[2013-12-09 18:59:18.422] SETDATA devices.2.instances.0.commandClasses.133.data.123.nodesToFollow = byte[0]
[2013-12-09 18:59:18.423] Adding job: Association Get
[2013-12-09 18:59:18.423] SETDATA devices.2.instances.0.commandClasses.133.data.124 = Empty
[2013-12-09 18:59:18.423] SETDATA devices.2.instances.0.commandClasses.133.data.124.max = Empty
[2013-12-09 18:59:18.423] SETDATA devices.2.instances.0.commandClasses.133.data.124.max = 0 (0x00000000)
[2013-12-09 18:59:18.423] SETDATA devices.2.instances.0.commandClasses.133.data.124.nodes = Empty
[2013-12-09 18:59:18.424] SETDATA devices.2.instances.0.commandClasses.133.data.124.nodes = byte[0]
[2013-12-09 18:59:18.424] SETDATA devices.2.instances.0.commandClasses.133.data.124.nodesToFollow = Empty
[2013-12-09 18:59:18.424] SETDATA devices.2.instances.0.commandClasses.133.data.124.nodesToFollow = byte[0]
[2013-12-09 18:59:18.424] Adding job: Association Get
[2013-12-09 18:59:18.424] SETDATA devices.2.instances.0.commandClasses.133.data.125 = Empty
[2013-12-09 18:59:18.425] SETDATA devices.2.instances.0.commandClasses.133.data.125.max = Empty
[2013-12-09 18:59:18.425] SETDATA devices.2.instances.0.commandClasses.133.data.125.max = 0 (0x00000000)
[2013-12-09 18:59:18.425] SETDATA devices.2.instances.0.commandClasses.133.data.125.nodes = Empty
[2013-12-09 18:59:18.425] SETDATA devices.2.instances.0.commandClasses.133.data.125.nodes = byte[0]
[2013-12-09 18:59:18.425] SETDATA devices.2.instances.0.commandClasses.133.data.125.nodesToFollow = Empty
[2013-12-09 18:59:18.425] SETDATA devices.2.instances.0.commandClasses.133.data.125.nodesToFollow = byte[0]
[2013-12-09 18:59:18.426] Adding job: Association Get
[2013-12-09 18:59:18.426] SETDATA devices.2.instances.0.commandClasses.133.data.126 = Empty
[2013-12-09 18:59:18.427] SETDATA devices.2.instances.0.commandClasses.133.data.126.max = Empty
[2013-12-09 18:59:18.427] SETDATA devices.2.instances.0.commandClasses.133.data.126.max = 0 (0x00000000)
[2013-12-09 18:59:18.427] SETDATA devices.2.instances.0.commandClasses.133.data.126.nodes = Empty
[2013-12-09 18:59:18.427] SETDATA devices.2.instances.0.commandClasses.133.data.126.nodes = byte[0]
[2013-12-09 18:59:18.427] SETDATA devices.2.instances.0.commandClasses.133.data.126.nodesToFollow = Empty
[2013-12-09 18:59:18.427] SETDATA devices.2.instances.0.commandClasses.133.data.126.nodesToFollow = byte[0]
[2013-12-09 18:59:18.428] Adding job: Association Get
[2013-12-09 18:59:18.428] SETDATA devices.2.instances.0.commandClasses.133.data.127 = Empty
[2013-12-09 18:59:18.428] SETDATA devices.2.instances.0.commandClasses.133.data.127.max = Empty
[2013-12-09 18:59:18.428] SETDATA devices.2.instances.0.commandClasses.133.data.127.max = 0 (0x00000000)
[2013-12-09 18:59:18.428] SETDATA devices.2.instances.0.commandClasses.133.data.127.nodes = Empty
[2013-12-09 18:59:18.428] SETDATA devices.2.instances.0.commandClasses.133.data.127.nodes = byte[0]
[2013-12-09 18:59:18.429] SETDATA devices.2.instances.0.commandClasses.133.data.127.nodesToFollow = Empty
[2013-12-09 18:59:18.429] SETDATA devices.2.instances.0.commandClasses.133.data.127.nodesToFollow = byte[0]
[2013-12-09 18:59:18.429] Adding job: Association Get
[2013-12-09 18:59:18.429] SETDATA devices.2.instances.0.commandClasses.133.data.128 = Empty
[2013-12-09 18:59:18.430] SETDATA devices.2.instances.0.commandClasses.133.data.128.max = Empty
[2013-12-09 18:59:18.430] SETDATA devices.2.instances.0.commandClasses.133.data.128.max = 0 (0x00000000)
[2013-12-09 18:59:18.430] SETDATA devices.2.instances.0.commandClasses.133.data.128.nodes = Empty
[2013-12-09 18:59:18.430] SETDATA devices.2.instances.0.commandClasses.133.data.128.nodes = byte[0]
[2013-12-09 18:59:18.430] SETDATA devices.2.instances.0.commandClasses.133.data.128.nodesToFollow = Empty
[2013-12-09 18:59:18.430] SETDATA devices.2.instances.0.commandClasses.133.data.128.nodesToFollow = byte[0]
[2013-12-09 18:59:18.431] Adding job: Association Get
[2013-12-09 18:59:18.431] SETDATA devices.2.instances.0.commandClasses.133.data.129 = Empty
[2013-12-09 18:59:18.431] SETDATA devices.2.instances.0.commandClasses.133.data.129.max = Empty
[2013-12-09 18:59:18.431] SETDATA devices.2.instances.0.commandClasses.133.data.129.max = 0 (0x00000000)
[2013-12-09 18:59:18.431] SETDATA devices.2.instances.0.commandClasses.133.data.129.nodes = Empty
[2013-12-09 18:59:18.431] SETDATA devices.2.instances.0.commandClasses.133.data.129.nodes = byte[0]
[2013-12-09 18:59:18.432] SETDATA devices.2.instances.0.commandClasses.133.data.129.nodesToFollow = Empty
[2013-12-09 18:59:18.432] SETDATA devices.2.instances.0.commandClasses.133.data.129.nodesToFollow = byte[0]
[2013-12-09 18:59:18.432] Adding job: Association Get
[2013-12-09 18:59:18.433] SETDATA devices.2.instances.0.commandClasses.133.data.130 = Empty
[2013-12-09 18:59:18.433] SETDATA devices.2.instances.0.commandClasses.133.data.130.max = Empty
[2013-12-09 18:59:18.433] SETDATA devices.2.instances.0.commandClasses.133.data.130.max = 0 (0x00000000)
[2013-12-09 18:59:18.433] SETDATA devices.2.instances.0.commandClasses.133.data.130.nodes = Empty
[2013-12-09 18:59:18.433] SETDATA devices.2.instances.0.commandClasses.133.data.130.nodes = byte[0]
[2013-12-09 18:59:18.433] SETDATA devices.2.instances.0.commandClasses.133.data.130.nodesToFollow = Empty
[2013-12-09 18:59:18.434] SETDATA devices.2.instances.0.commandClasses.133.data.130.nodesToFollow = byte[0]
[2013-12-09 18:59:18.434] Adding job: Association Get
[2013-12-09 18:59:18.434] SETDATA devices.2.instances.0.commandClasses.133.data.131 = Empty
[2013-12-09 18:59:18.435] SETDATA devices.2.instances.0.commandClasses.133.data.131.max = Empty
[2013-12-09 18:59:18.435] SETDATA devices.2.instances.0.commandClasses.133.data.131.max = 0 (0x00000000)
[2013-12-09 18:59:18.435] SETDATA devices.2.instances.0.commandClasses.133.data.131.nodes = Empty
[2013-12-09 18:59:18.435] SETDATA devices.2.instances.0.commandClasses.133.data.131.nodes = byte[0]
[2013-12-09 18:59:18.435] SETDATA devices.2.instances.0.commandClasses.133.data.131.nodesToFollow = Empty
[2013-12-09 18:59:18.435] SETDATA devices.2.instances.0.commandClasses.133.data.131.nodesToFollow = byte[0]
[2013-12-09 18:59:18.436] Adding job: Association Get
[2013-12-09 18:59:18.436] SETDATA devices.2.instances.0.commandClasses.133.data.132 = Empty
[2013-12-09 18:59:18.436] SETDATA devices.2.instances.0.commandClasses.133.data.132.max = Empty
[2013-12-09 18:59:18.437] SETDATA devices.2.instances.0.commandClasses.133.data.132.max = 0 (0x00000000)
[2013-12-09 18:59:18.437] SETDATA devices.2.instances.0.commandClasses.133.data.132.nodes = Empty
[2013-12-09 18:59:18.437] SETDATA devices.2.instances.0.commandClasses.133.data.132.nodes = byte[0]
[2013-12-09 18:59:18.437] SETDATA devices.2.instances.0.commandClasses.133.data.132.nodesToFollow = Empty
[2013-12-09 18:59:18.437] SETDATA devices.2.instances.0.commandClasses.133.data.132.nodesToFollow = byte[0]
[2013-12-09 18:59:18.438] Adding job: Association Get
[2013-12-09 18:59:18.438] SETDATA devices.2.instances.0.commandClasses.133.data.133 = Empty
[2013-12-09 18:59:18.438] SETDATA devices.2.instances.0.commandClasses.133.data.133.max = Empty
[2013-12-09 18:59:18.438] SETDATA devices.2.instances.0.commandClasses.133.data.133.max = 0 (0x00000000)
[2013-12-09 18:59:18.438] SETDATA devices.2.instances.0.commandClasses.133.data.133.nodes = Empty
[2013-12-09 18:59:18.438] SETDATA devices.2.instances.0.commandClasses.133.data.133.nodes = byte[0]
[2013-12-09 18:59:18.438] SETDATA devices.2.instances.0.commandClasses.133.data.133.nodesToFollow = Empty
[2013-12-09 18:59:18.439] SETDATA devices.2.instances.0.commandClasses.133.data.133.nodesToFollow = byte[0]
[2013-12-09 18:59:18.439] Adding job: Association Get
[2013-12-09 18:59:18.439] SETDATA devices.2.instances.0.commandClasses.133.data.134 = Empty
[2013-12-09 18:59:18.439] SETDATA devices.2.instances.0.commandClasses.133.data.134.max = Empty
[2013-12-09 18:59:18.440] SETDATA devices.2.instances.0.commandClasses.133.data.134.max = 0 (0x00000000)
[2013-12-09 18:59:18.440] SETDATA devices.2.instances.0.commandClasses.133.data.134.nodes = Empty
[2013-12-09 18:59:18.440] SETDATA devices.2.instances.0.commandClasses.133.data.134.nodes = byte[0]
[2013-12-09 18:59:18.440] SETDATA devices.2.instances.0.commandClasses.133.data.134.nodesToFollow = Empty
[2013-12-09 18:59:18.440] SETDATA devices.2.instances.0.commandClasses.133.data.134.nodesToFollow = byte[0]
[2013-12-09 18:59:18.441] Adding job: Association Get
[2013-12-09 18:59:18.441] SETDATA devices.2.instances.0.commandClasses.133.data.135 = Empty
[2013-12-09 18:59:18.441] SETDATA devices.2.instances.0.commandClasses.133.data.135.max = Empty
[2013-12-09 18:59:18.441] SETDATA devices.2.instances.0.commandClasses.133.data.135.max = 0 (0x00000000)
[2013-12-09 18:59:18.441] SETDATA devices.2.instances.0.commandClasses.133.data.135.nodes = Empty
[2013-12-09 18:59:18.441] SETDATA devices.2.instances.0.commandClasses.133.data.135.nodes = byte[0]
[2013-12-09 18:59:18.442] SETDATA devices.2.instances.0.commandClasses.133.data.135.nodesToFollow = Empty
[2013-12-09 18:59:18.442] SETDATA devices.2.instances.0.commandClasses.133.data.135.nodesToFollow = byte[0]
[2013-12-09 18:59:18.442] Adding job: Association Get
[2013-12-09 18:59:18.443] SETDATA devices.2.instances.0.commandClasses.133.data.136 = Empty
[2013-12-09 18:59:18.443] SETDATA devices.2.instances.0.commandClasses.133.data.136.max = Empty
[2013-12-09 18:59:18.443] SETDATA devices.2.instances.0.commandClasses.133.data.136.max = 0 (0x00000000)
[2013-12-09 18:59:18.443] SETDATA devices.2.instances.0.commandClasses.133.data.136.nodes = Empty
[2013-12-09 18:59:18.443] SETDATA devices.2.instances.0.commandClasses.133.data.136.nodes = byte[0]
[2013-12-09 18:59:18.443] SETDATA devices.2.instances.0.commandClasses.133.data.136.nodesToFollow = Empty
[2013-12-09 18:59:18.444] SETDATA devices.2.instances.0.commandClasses.133.data.136.nodesToFollow = byte[0]
[2013-12-09 18:59:18.444] Adding job: Association Get
[2013-12-09 18:59:18.444] SETDATA devices.2.instances.0.commandClasses.133.data.137 = Empty
[2013-12-09 18:59:18.444] SETDATA devices.2.instances.0.commandClasses.133.data.137.max = Empty
[2013-12-09 18:59:18.445] SETDATA devices.2.instances.0.commandClasses.133.data.137.max = 0 (0x00000000)
[2013-12-09 18:59:18.445] SETDATA devices.2.instances.0.commandClasses.133.data.137.nodes = Empty
[2013-12-09 18:59:18.445] SETDATA devices.2.instances.0.commandClasses.133.data.137.nodes = byte[0]
[2013-12-09 18:59:18.445] SETDATA devices.2.instances.0.commandClasses.133.data.137.nodesToFollow = Empty
[2013-12-09 18:59:18.445] SETDATA devices.2.instances.0.commandClasses.133.data.137.nodesToFollow = byte[0]
[2013-12-09 18:59:18.445] Adding job: Association Get
[2013-12-09 18:59:18.446] SETDATA devices.2.instances.0.commandClasses.133.data.138 = Empty
[2013-12-09 18:59:18.446] SETDATA devices.2.instances.0.commandClasses.133.data.138.max = Empty
[2013-12-09 18:59:18.446] SETDATA devices.2.instances.0.commandClasses.133.data.138.max = 0 (0x00000000)
[2013-12-09 18:59:18.446] SETDATA devices.2.instances.0.commandClasses.133.data.138.nodes = Empty
[2013-12-09 18:59:18.447] SETDATA devices.2.instances.0.commandClasses.133.data.138.nodes = byte[0]
[2013-12-09 18:59:18.447] SETDATA devices.2.instances.0.commandClasses.133.data.138.nodesToFollow = Empty
[2013-12-09 18:59:18.447] SETDATA devices.2.instances.0.commandClasses.133.data.138.nodesToFollow = byte[0]
[2013-12-09 18:59:18.447] Adding job: Association Get
[2013-12-09 18:59:18.448] SETDATA devices.2.instances.0.commandClasses.133.data.139 = Empty
[2013-12-09 18:59:18.448] SETDATA devices.2.instances.0.commandClasses.133.data.139.max = Empty
[2013-12-09 18:59:18.448] SETDATA devices.2.instances.0.commandClasses.133.data.139.max = 0 (0x00000000)
[2013-12-09 18:59:18.448] SETDATA devices.2.instances.0.commandClasses.133.data.139.nodes = Empty
[2013-12-09 18:59:18.448] SETDATA devices.2.instances.0.commandClasses.133.data.139.nodes = byte[0]
[2013-12-09 18:59:18.448] SETDATA devices.2.instances.0.commandClasses.133.data.139.nodesToFollow = Empty
[2013-12-09 18:59:18.448] SETDATA devices.2.instances.0.commandClasses.133.data.139.nodesToFollow = byte[0]
[2013-12-09 18:59:18.449] Adding job: Association Get
[2013-12-09 18:59:18.449] SETDATA devices.2.instances.0.commandClasses.133.data.140 = Empty
[2013-12-09 18:59:18.449] SETDATA devices.2.instances.0.commandClasses.133.data.140.max = Empty
[2013-12-09 18:59:18.449] SETDATA devices.2.instances.0.commandClasses.133.data.140.max = 0 (0x00000000)
[2013-12-09 18:59:18.450] SETDATA devices.2.instances.0.commandClasses.133.data.140.nodes = Empty
[2013-12-09 18:59:18.450] SETDATA devices.2.instances.0.commandClasses.133.data.140.nodes = byte[0]
[2013-12-09 18:59:18.450] SETDATA devices.2.instances.0.commandClasses.133.data.140.nodesToFollow = Empty
[2013-12-09 18:59:18.450] SETDATA devices.2.instances.0.commandClasses.133.data.140.nodesToFollow = byte[0]
[2013-12-09 18:59:18.451] Adding job: Association Get
[2013-12-09 18:59:18.451] SETDATA devices.2.instances.0.commandClasses.133.data.141 = Empty
[2013-12-09 18:59:18.451] SETDATA devices.2.instances.0.commandClasses.133.data.141.max = Empty
[2013-12-09 18:59:18.451] SETDATA devices.2.instances.0.commandClasses.133.data.141.max = 0 (0x00000000)
[2013-12-09 18:59:18.451] SETDATA devices.2.instances.0.commandClasses.133.data.141.nodes = Empty
[2013-12-09 18:59:18.451] SETDATA devices.2.instances.0.commandClasses.133.data.141.nodes = byte[0]
[2013-12-09 18:59:18.452] SETDATA devices.2.instances.0.commandClasses.133.data.141.nodesToFollow = Empty
[2013-12-09 18:59:18.452] SETDATA devices.2.instances.0.commandClasses.133.data.141.nodesToFollow = byte[0]
[2013-12-09 18:59:18.452] Adding job: Association Get
[2013-12-09 18:59:18.453] SETDATA devices.2.instances.0.commandClasses.133.data.142 = Empty
[2013-12-09 18:59:18.453] SETDATA devices.2.instances.0.commandClasses.133.data.142.max = Empty
[2013-12-09 18:59:18.453] SETDATA devices.2.instances.0.commandClasses.133.data.142.max = 0 (0x00000000)
[2013-12-09 18:59:18.453] SETDATA devices.2.instances.0.commandClasses.133.data.142.nodes = Empty
[2013-12-09 18:59:18.453] SETDATA devices.2.instances.0.commandClasses.133.data.142.nodes = byte[0]
[2013-12-09 18:59:18.453] SETDATA devices.2.instances.0.commandClasses.133.data.142.nodesToFollow = Empty
[2013-12-09 18:59:18.454] SETDATA devices.2.instances.0.commandClasses.133.data.142.nodesToFollow = byte[0]
[2013-12-09 18:59:18.454] Adding job: Association Get
[2013-12-09 18:59:18.454] SETDATA devices.2.instances.0.commandClasses.133.data.143 = Empty
[2013-12-09 18:59:18.454] SETDATA devices.2.instances.0.commandClasses.133.data.143.max = Empty
[2013-12-09 18:59:18.455] SETDATA devices.2.instances.0.commandClasses.133.data.143.max = 0 (0x00000000)
[2013-12-09 18:59:18.455] SETDATA devices.2.instances.0.commandClasses.133.data.143.nodes = Empty
[2013-12-09 18:59:18.455] SETDATA devices.2.instances.0.commandClasses.133.data.143.nodes = byte[0]
[2013-12-09 18:59:18.455] SETDATA devices.2.instances.0.commandClasses.133.data.143.nodesToFollow = Empty
[2013-12-09 18:59:18.455] SETDATA devices.2.instances.0.commandClasses.133.data.143.nodesToFollow = byte[0]
[2013-12-09 18:59:18.456] Adding job: Association Get
[2013-12-09 18:59:18.456] SETDATA devices.2.instances.0.commandClasses.133.data.144 = Empty
[2013-12-09 18:59:18.456] SETDATA devices.2.instances.0.commandClasses.133.data.144.max = Empty
[2013-12-09 18:59:18.456] SETDATA devices.2.instances.0.commandClasses.133.data.144.max = 0 (0x00000000)
[2013-12-09 18:59:18.456] SETDATA devices.2.instances.0.commandClasses.133.data.144.nodes = Empty
[2013-12-09 18:59:18.457] SETDATA devices.2.instances.0.commandClasses.133.data.144.nodes = byte[0]
[2013-12-09 18:59:18.457] SETDATA devices.2.instances.0.commandClasses.133.data.144.nodesToFollow = Empty
[2013-12-09 18:59:18.457] SETDATA devices.2.instances.0.commandClasses.133.data.144.nodesToFollow = byte[0]
[2013-12-09 18:59:18.458] Adding job: Association Get
[2013-12-09 18:59:18.458] SETDATA devices.2.instances.0.commandClasses.133.data.145 = Empty
[2013-12-09 18:59:18.458] SETDATA devices.2.instances.0.commandClasses.133.data.145.max = Empty
[2013-12-09 18:59:18.458] SETDATA devices.2.instances.0.commandClasses.133.data.145.max = 0 (0x00000000)
[2013-12-09 18:59:18.458] SETDATA devices.2.instances.0.commandClasses.133.data.145.nodes = Empty
[2013-12-09 18:59:18.459] SETDATA devices.2.instances.0.commandClasses.133.data.145.nodes = byte[0]
[2013-12-09 18:59:18.459] SETDATA devices.2.instances.0.commandClasses.133.data.145.nodesToFollow = Empty
[2013-12-09 18:59:18.459] SETDATA devices.2.instances.0.commandClasses.133.data.145.nodesToFollow = byte[0]
[2013-12-09 18:59:18.459] Adding job: Association Get
[2013-12-09 18:59:18.460] SETDATA devices.2.instances.0.commandClasses.133.data.146 = Empty
[2013-12-09 18:59:18.460] SETDATA devices.2.instances.0.commandClasses.133.data.146.max = Empty
[2013-12-09 18:59:18.460] SETDATA devices.2.instances.0.commandClasses.133.data.146.max = 0 (0x00000000)
[2013-12-09 18:59:18.460] SETDATA devices.2.instances.0.commandClasses.133.data.146.nodes = Empty
[2013-12-09 18:59:18.460] SETDATA devices.2.instances.0.commandClasses.133.data.146.nodes = byte[0]
[2013-12-09 18:59:18.460] SETDATA devices.2.instances.0.commandClasses.133.data.146.nodesToFollow = Empty
[2013-12-09 18:59:18.460] SETDATA devices.2.instances.0.commandClasses.133.data.146.nodesToFollow = byte[0]
[2013-12-09 18:59:18.461] Adding job: Association Get
[2013-12-09 18:59:18.461] SETDATA devices.2.instances.0.commandClasses.133.data.147 = Empty
[2013-12-09 18:59:18.461] SETDATA devices.2.instances.0.commandClasses.133.data.147.max = Empty
[2013-12-09 18:59:18.461] SETDATA devices.2.instances.0.commandClasses.133.data.147.max = 0 (0x00000000)
[2013-12-09 18:59:18.462] SETDATA devices.2.instances.0.commandClasses.133.data.147.nodes = Empty
[2013-12-09 18:59:18.462] SETDATA devices.2.instances.0.commandClasses.133.data.147.nodes = byte[0]
[2013-12-09 18:59:18.462] SETDATA devices.2.instances.0.commandClasses.133.data.147.nodesToFollow = Empty
[2013-12-09 18:59:18.462] SETDATA devices.2.instances.0.commandClasses.133.data.147.nodesToFollow = byte[0]
[2013-12-09 18:59:18.462] Adding job: Association Get
[2013-12-09 18:59:18.463] SETDATA devices.2.instances.0.commandClasses.133.data.148 = Empty
[2013-12-09 18:59:18.463] SETDATA devices.2.instances.0.commandClasses.133.data.148.max = Empty
[2013-12-09 18:59:18.463] SETDATA devices.2.instances.0.commandClasses.133.data.148.max = 0 (0x00000000)
[2013-12-09 18:59:18.463] SETDATA devices.2.instances.0.commandClasses.133.data.148.nodes = Empty
[2013-12-09 18:59:18.463] SETDATA devices.2.instances.0.commandClasses.133.data.148.nodes = byte[0]
[2013-12-09 18:59:18.464] SETDATA devices.2.instances.0.commandClasses.133.data.148.nodesToFollow = Empty
[2013-12-09 18:59:18.464] SETDATA devices.2.instances.0.commandClasses.133.data.148.nodesToFollow = byte[0]
[2013-12-09 18:59:18.464] Adding job: Association Get
[2013-12-09 18:59:18.464] SETDATA devices.2.instances.0.commandClasses.133.data.149 = Empty
[2013-12-09 18:59:18.465] SETDATA devices.2.instances.0.commandClasses.133.data.149.max = Empty
[2013-12-09 18:59:18.465] SETDATA devices.2.instances.0.commandClasses.133.data.149.max = 0 (0x00000000)
[2013-12-09 18:59:18.465] SETDATA devices.2.instances.0.commandClasses.133.data.149.nodes = Empty
[2013-12-09 18:59:18.465] SETDATA devices.2.instances.0.commandClasses.133.data.149.nodes = byte[0]
[2013-12-09 18:59:18.465] SETDATA devices.2.instances.0.commandClasses.133.data.149.nodesToFollow = Empty
[2013-12-09 18:59:18.465] SETDATA devices.2.instances.0.commandClasses.133.data.149.nodesToFollow = byte[0]
[2013-12-09 18:59:18.466] Adding job: Association Get
[2013-12-09 18:59:18.466] SETDATA devices.2.instances.0.commandClasses.133.data.150 = Empty
[2013-12-09 18:59:18.466] SETDATA devices.2.instances.0.commandClasses.133.data.150.max = Empty
[2013-12-09 18:59:18.466] SETDATA devices.2.instances.0.commandClasses.133.data.150.max = 0 (0x00000000)
[2013-12-09 18:59:18.467] SETDATA devices.2.instances.0.commandClasses.133.data.150.nodes = Empty
[2013-12-09 18:59:18.467] SETDATA devices.2.instances.0.commandClasses.133.data.150.nodes = byte[0]
[2013-12-09 18:59:18.467] SETDATA devices.2.instances.0.commandClasses.133.data.150.nodesToFollow = Empty
[2013-12-09 18:59:18.467] SETDATA devices.2.instances.0.commandClasses.133.data.150.nodesToFollow = byte[0]
[2013-12-09 18:59:18.468] Adding job: Association Get
[2013-12-09 18:59:18.468] SETDATA devices.2.instances.0.commandClasses.133.data.151 = Empty
[2013-12-09 18:59:18.468] SETDATA devices.2.instances.0.commandClasses.133.data.151.max = Empty
[2013-12-09 18:59:18.468] SETDATA devices.2.instances.0.commandClasses.133.data.151.max = 0 (0x00000000)
[2013-12-09 18:59:18.469] SETDATA devices.2.instances.0.commandClasses.133.data.151.nodes = Empty
[2013-12-09 18:59:18.469] SETDATA devices.2.instances.0.commandClasses.133.data.151.nodes = byte[0]
[2013-12-09 18:59:18.469] SETDATA devices.2.instances.0.commandClasses.133.data.151.nodesToFollow = Empty
[2013-12-09 18:59:18.469] SETDATA devices.2.instances.0.commandClasses.133.data.151.nodesToFollow = byte[0]
[2013-12-09 18:59:18.469] Adding job: Association Get
[2013-12-09 18:59:18.470] SETDATA devices.2.instances.0.commandClasses.133.data.152 = Empty
[2013-12-09 18:59:18.470] SETDATA devices.2.instances.0.commandClasses.133.data.152.max = Empty
[2013-12-09 18:59:18.470] SETDATA devices.2.instances.0.commandClasses.133.data.152.max = 0 (0x00000000)
[2013-12-09 18:59:18.470] SETDATA devices.2.instances.0.commandClasses.133.data.152.nodes = Empty
[2013-12-09 18:59:18.470] SETDATA devices.2.instances.0.commandClasses.133.data.152.nodes = byte[0]
[2013-12-09 18:59:18.470] SETDATA devices.2.instances.0.commandClasses.133.data.152.nodesToFollow = Empty
[2013-12-09 18:59:18.471] SETDATA devices.2.instances.0.commandClasses.133.data.152.nodesToFollow = byte[0]
[2013-12-09 18:59:18.471] Adding job: Association Get
[2013-12-09 18:59:18.471] SETDATA devices.2.instances.0.commandClasses.133.data.153 = Empty
[2013-12-09 18:59:18.471] SETDATA devices.2.instances.0.commandClasses.133.data.153.max = Empty
[2013-12-09 18:59:18.472] SETDATA devices.2.instances.0.commandClasses.133.data.153.max = 0 (0x00000000)
[2013-12-09 18:59:18.472] SETDATA devices.2.instances.0.commandClasses.133.data.153.nodes = Empty
[2013-12-09 18:59:18.472] SETDATA devices.2.instances.0.commandClasses.133.data.153.nodes = byte[0]
[2013-12-09 18:59:18.472] SETDATA devices.2.instances.0.commandClasses.133.data.153.nodesToFollow = Empty
[2013-12-09 18:59:18.472] SETDATA devices.2.instances.0.commandClasses.133.data.153.nodesToFollow = byte[0]
[2013-12-09 18:59:18.473] Adding job: Association Get
[2013-12-09 18:59:18.473] SETDATA devices.2.instances.0.commandClasses.133.data.154 = Empty
[2013-12-09 18:59:18.473] SETDATA devices.2.instances.0.commandClasses.133.data.154.max = Empty
[2013-12-09 18:59:18.473] SETDATA devices.2.instances.0.commandClasses.133.data.154.max = 0 (0x00000000)
[2013-12-09 18:59:18.474] SETDATA devices.2.instances.0.commandClasses.133.data.154.nodes = Empty
[2013-12-09 18:59:18.474] SETDATA devices.2.instances.0.commandClasses.133.data.154.nodes = byte[0]
[2013-12-09 18:59:18.474] SETDATA devices.2.instances.0.commandClasses.133.data.154.nodesToFollow = Empty
[2013-12-09 18:59:18.474] SETDATA devices.2.instances.0.commandClasses.133.data.154.nodesToFollow = byte[0]
[2013-12-09 18:59:18.475] Adding job: Association Get
[2013-12-09 18:59:18.475] SETDATA devices.2.instances.0.commandClasses.133.data.155 = Empty
[2013-12-09 18:59:18.475] SETDATA devices.2.instances.0.commandClasses.133.data.155.max = Empty
[2013-12-09 18:59:18.475] SETDATA devices.2.instances.0.commandClasses.133.data.155.max = 0 (0x00000000)
[2013-12-09 18:59:18.475] SETDATA devices.2.instances.0.commandClasses.133.data.155.nodes = Empty
[2013-12-09 18:59:18.475] SETDATA devices.2.instances.0.commandClasses.133.data.155.nodes = byte[0]
[2013-12-09 18:59:18.476] SETDATA devices.2.instances.0.commandClasses.133.data.155.nodesToFollow = Empty
[2013-12-09 18:59:18.476] SETDATA devices.2.instances.0.commandClasses.133.data.155.nodesToFollow = byte[0]
[2013-12-09 18:59:18.476] Adding job: Association Get
[2013-12-09 18:59:18.476] SETDATA devices.2.instances.0.commandClasses.133.data.156 = Empty
[2013-12-09 18:59:18.477] SETDATA devices.2.instances.0.commandClasses.133.data.156.max = Empty
[2013-12-09 18:59:18.477] SETDATA devices.2.instances.0.commandClasses.133.data.156.max = 0 (0x00000000)
[2013-12-09 18:59:18.477] SETDATA devices.2.instances.0.commandClasses.133.data.156.nodes = Empty
[2013-12-09 18:59:18.477] SETDATA devices.2.instances.0.commandClasses.133.data.156.nodes = byte[0]
[2013-12-09 18:59:18.477] SETDATA devices.2.instances.0.commandClasses.133.data.156.nodesToFollow = Empty
[2013-12-09 18:59:18.478] SETDATA devices.2.instances.0.commandClasses.133.data.156.nodesToFollow = byte[0]
[2013-12-09 18:59:18.478] Adding job: Association Get
[2013-12-09 18:59:18.478] SETDATA devices.2.instances.0.commandClasses.133.data.157 = Empty
[2013-12-09 18:59:18.478] SETDATA devices.2.instances.0.commandClasses.133.data.157.max = Empty
[2013-12-09 18:59:18.479] SETDATA devices.2.instances.0.commandClasses.133.data.157.max = 0 (0x00000000)
[2013-12-09 18:59:18.479] SETDATA devices.2.instances.0.commandClasses.133.data.157.nodes = Empty
[2013-12-09 18:59:18.479] SETDATA devices.2.instances.0.commandClasses.133.data.157.nodes = byte[0]
[2013-12-09 18:59:18.479] SETDATA devices.2.instances.0.commandClasses.133.data.157.nodesToFollow = Empty
[2013-12-09 18:59:18.479] SETDATA devices.2.instances.0.commandClasses.133.data.157.nodesToFollow = byte[0]
[2013-12-09 18:59:18.480] Adding job: Association Get
[2013-12-09 18:59:18.480] SETDATA devices.2.instances.0.commandClasses.133.data.158 = Empty
[2013-12-09 18:59:18.480] SETDATA devices.2.instances.0.commandClasses.133.data.158.max = Empty
[2013-12-09 18:59:18.480] SETDATA devices.2.instances.0.commandClasses.133.data.158.max = 0 (0x00000000)
[2013-12-09 18:59:18.480] SETDATA devices.2.instances.0.commandClasses.133.data.158.nodes = Empty
[2013-12-09 18:59:18.480] SETDATA devices.2.instances.0.commandClasses.133.data.158.nodes = byte[0]
[2013-12-09 18:59:18.481] SETDATA devices.2.instances.0.commandClasses.133.data.158.nodesToFollow = Empty
[2013-12-09 18:59:18.481] SETDATA devices.2.instances.0.commandClasses.133.data.158.nodesToFollow = byte[0]
[2013-12-09 18:59:18.481] Adding job: Association Get
[2013-12-09 18:59:18.481] SETDATA devices.2.instances.0.commandClasses.133.data.159 = Empty
[2013-12-09 18:59:18.482] SETDATA devices.2.instances.0.commandClasses.133.data.159.max = Empty
[2013-12-09 18:59:18.482] SETDATA devices.2.instances.0.commandClasses.133.data.159.max = 0 (0x00000000)
[2013-12-09 18:59:18.482] SETDATA devices.2.instances.0.commandClasses.133.data.159.nodes = Empty
[2013-12-09 18:59:18.482] SETDATA devices.2.instances.0.commandClasses.133.data.159.nodes = byte[0]
[2013-12-09 18:59:18.482] SETDATA devices.2.instances.0.commandClasses.133.data.159.nodesToFollow = Empty
[2013-12-09 18:59:18.482] SETDATA devices.2.instances.0.commandClasses.133.data.159.nodesToFollow = byte[0]
[2013-12-09 18:59:18.483] Adding job: Association Get
[2013-12-09 18:59:18.483] SETDATA devices.2.instances.0.commandClasses.133.data.160 = Empty
[2013-12-09 18:59:18.484] SETDATA devices.2.instances.0.commandClasses.133.data.160.max = Empty
[2013-12-09 18:59:18.484] SETDATA devices.2.instances.0.commandClasses.133.data.160.max = 0 (0x00000000)
[2013-12-09 18:59:18.484] SETDATA devices.2.instances.0.commandClasses.133.data.160.nodes = Empty
[2013-12-09 18:59:18.484] SETDATA devices.2.instances.0.commandClasses.133.data.160.nodes = byte[0]
[2013-12-09 18:59:18.484] SETDATA devices.2.instances.0.commandClasses.133.data.160.nodesToFollow = Empty
[2013-12-09 18:59:18.484] SETDATA devices.2.instances.0.commandClasses.133.data.160.nodesToFollow = byte[0]
( zero-length buffer )
[2013-12-09 18:59:18.485] Adding job: Association Get
[2013-12-09 18:59:18.485] SETDATA devices.2.instances.0.commandClasses.133.data.161 = Empty
[2013-12-09 18:59:18.485] SETDATA devices.2.instances.0.commandClasses.133.data.161.max = Empty
[2013-12-09 18:59:18.485] SETDATA devices.2.instances.0.commandClasses.133.data.161.max = 0 (0x00000000)
[2013-12-09 18:59:18.485] SETDATA devices.2.instances.0.commandClasses.133.data.161.nodes = Empty
[2013-12-09 18:59:18.486] SETDATA devices.2.instances.0.commandClasses.133.data.161.nodes = byte[0]
[2013-12-09 18:59:18.486] SETDATA devices.2.instances.0.commandClasses.133.data.161.nodesToFollow = Empty
[2013-12-09 18:59:18.486] SETDATA devices.2.instances.0.commandClasses.133.data.161.nodesToFollow = byte[0]
[2013-12-09 18:59:18.486] Adding job: Association Get
[2013-12-09 18:59:18.487] SETDATA devices.2.instances.0.commandClasses.133.data.162 = Empty
[2013-12-09 18:59:18.487] SETDATA devices.2.instances.0.commandClasses.133.data.162.max = Empty
[2013-12-09 18:59:18.487] SETDATA devices.2.instances.0.commandClasses.133.data.162.max = 0 (0x00000000)
[2013-12-09 18:59:18.487] SETDATA devices.2.instances.0.commandClasses.133.data.162.nodes = Empty
[2013-12-09 18:59:18.487] SETDATA devices.2.instances.0.commandClasses.133.data.162.nodes = byte[0]
[2013-12-09 18:59:18.487] SETDATA devices.2.instances.0.commandClasses.133.data.162.nodesToFollow = Empty
[2013-12-09 18:59:18.487] SETDATA devices.2.instances.0.commandClasses.133.data.162.nodesToFollow = byte[0]
[2013-12-09 18:59:18.488] Adding job: Association Get
[2013-12-09 18:59:18.489] SETDATA devices.2.instances.0.commandClasses.133.data.163 = Empty
[2013-12-09 18:59:18.489] SETDATA devices.2.instances.0.commandClasses.133.data.163.max = Empty
[2013-12-09 18:59:18.489] SETDATA devices.2.instances.0.commandClasses.133.data.163.max = 0 (0x00000000)
[2013-12-09 18:59:18.489] SETDATA devices.2.instances.0.commandClasses.133.data.163.nodes = Empty
[2013-12-09 18:59:18.489] SETDATA devices.2.instances.0.commandClasses.133.data.163.nodes = byte[0]
[2013-12-09 18:59:18.489] SETDATA devices.2.instances.0.commandClasses.133.data.163.nodesToFollow = Empty
[2013-12-09 18:59:18.489] SETDATA devices.2.instances.0.commandClasses.133.data.163.nodesToFollow = byte[0]
[2013-12-09 18:59:18.490] Adding job: Association Get
[2013-12-09 18:59:18.490] SETDATA devices.2.instances.0.commandClasses.133.data.164 = Empty
[2013-12-09 18:59:18.490] SETDATA devices.2.instances.0.commandClasses.133.data.164.max = Empty
[2013-12-09 18:59:18.491] SETDATA devices.2.instances.0.commandClasses.133.data.164.max = 0 (0x00000000)
[2013-12-09 18:59:18.491] SETDATA devices.2.instances.0.commandClasses.133.data.164.nodes = Empty
[2013-12-09 18:59:18.491] SETDATA devices.2.instances.0.commandClasses.133.data.164.nodes = byte[0]
[2013-12-09 18:59:18.491] SETDATA devices.2.instances.0.commandClasses.133.data.164.nodesToFollow = Empty
[2013-12-09 18:59:18.491] SETDATA devices.2.instances.0.commandClasses.133.data.164.nodesToFollow = byte[0]
[2013-12-09 18:59:18.492] Adding job: Association Get
[2013-12-09 18:59:18.492] SETDATA devices.2.instances.0.commandClasses.133.data.165 = Empty
[2013-12-09 18:59:18.492] SETDATA devices.2.instances.0.commandClasses.133.data.165.max = Empty
[2013-12-09 18:59:18.492] SETDATA devices.2.instances.0.commandClasses.133.data.165.max = 0 (0x00000000)
[2013-12-09 18:59:18.492] SETDATA devices.2.instances.0.commandClasses.133.data.165.nodes = Empty
[2013-12-09 18:59:18.492] SETDATA devices.2.instances.0.commandClasses.133.data.165.nodes = byte[0]
[2013-12-09 18:59:18.493] SETDATA devices.2.instances.0.commandClasses.133.data.165.nodesToFollow = Empty
[2013-12-09 18:59:18.493] SETDATA devices.2.instances.0.commandClasses.133.data.165.nodesToFollow = byte[0]
[2013-12-09 18:59:18.494] Adding job: Association Get
[2013-12-09 18:59:18.494] SETDATA devices.2.instances.0.commandClasses.133.data.166 = Empty
[2013-12-09 18:59:18.494] SETDATA devices.2.instances.0.commandClasses.133.data.166.max = Empty
[2013-12-09 18:59:18.494] SETDATA devices.2.instances.0.commandClasses.133.data.166.max = 0 (0x00000000)
[2013-12-09 18:59:18.494] SETDATA devices.2.instances.0.commandClasses.133.data.166.nodes = Empty
[2013-12-09 18:59:18.494] SETDATA devices.2.instances.0.commandClasses.133.data.166.nodes = byte[0]
[2013-12-09 18:59:18.495] SETDATA devices.2.instances.0.commandClasses.133.data.166.nodesToFollow = Empty
[2013-12-09 18:59:18.495] SETDATA devices.2.instances.0.commandClasses.133.data.166.nodesToFollow = byte[0]
[2013-12-09 18:59:18.495] Adding job: Association Get
[2013-12-09 18:59:18.495] SETDATA devices.2.instances.0.commandClasses.133.data.167 = Empty
[2013-12-09 18:59:18.496] SETDATA devices.2.instances.0.commandClasses.133.data.167.max = Empty
[2013-12-09 18:59:18.496] SETDATA devices.2.instances.0.commandClasses.133.data.167.max = 0 (0x00000000)
[2013-12-09 18:59:18.496] SETDATA devices.2.instances.0.commandClasses.133.data.167.nodes = Empty
[2013-12-09 18:59:18.496] SETDATA devices.2.instances.0.commandClasses.133.data.167.nodes = byte[0]
[2013-12-09 18:59:18.496] SETDATA devices.2.instances.0.commandClasses.133.data.167.nodesToFollow = Empty
[2013-12-09 18:59:18.496] SETDATA devices.2.instances.0.commandClasses.133.data.167.nodesToFollow = byte[0]
[2013-12-09 18:59:18.497] Adding job: Association Get
[2013-12-09 18:59:18.497] SETDATA devices.2.instances.0.commandClasses.133.data.168 = Empty
[2013-12-09 18:59:18.497] SETDATA devices.2.instances.0.commandClasses.133.data.168.max = Empty
[2013-12-09 18:59:18.497] SETDATA devices.2.instances.0.commandClasses.133.data.168.max = 0 (0x00000000)
[2013-12-09 18:59:18.497] SETDATA devices.2.instances.0.commandClasses.133.data.168.nodes = Empty
[2013-12-09 18:59:18.497] SETDATA devices.2.instances.0.commandClasses.133.data.168.nodes = byte[0]
[2013-12-09 18:59:18.498] SETDATA devices.2.instances.0.commandClasses.133.data.168.nodesToFollow = Empty
[2013-12-09 18:59:18.498] SETDATA devices.2.instances.0.commandClasses.133.data.168.nodesToFollow = byte[0]
[2013-12-09 18:59:18.499] Adding job: Association Get
[2013-12-09 18:59:18.499] SETDATA devices.2.instances.0.commandClasses.133.data.169 = Empty
[2013-12-09 18:59:18.499] SETDATA devices.2.instances.0.commandClasses.133.data.169.max = Empty
[2013-12-09 18:59:18.499] SETDATA devices.2.instances.0.commandClasses.133.data.169.max = 0 (0x00000000)
[2013-12-09 18:59:18.500] SETDATA devices.2.instances.0.commandClasses.133.data.169.nodes = Empty
[2013-12-09 18:59:18.500] SETDATA devices.2.instances.0.commandClasses.133.data.169.nodes = byte[0]
[2013-12-09 18:59:18.500] SETDATA devices.2.instances.0.commandClasses.133.data.169.nodesToFollow = Empty
[2013-12-09 18:59:18.500] SETDATA devices.2.instances.0.commandClasses.133.data.169.nodesToFollow = byte[0]
[2013-12-09 18:59:18.501] Adding job: Association Get
[2013-12-09 18:59:18.501] SETDATA devices.2.instances.0.commandClasses.133.data.170 = Empty
[2013-12-09 18:59:18.501] SETDATA devices.2.instances.0.commandClasses.133.data.170.max = Empty
[2013-12-09 18:59:18.501] SETDATA devices.2.instances.0.commandClasses.133.data.170.max = 0 (0x00000000)
[2013-12-09 18:59:18.501] SETDATA devices.2.instances.0.commandClasses.133.data.170.nodes = Empty
[2013-12-09 18:59:18.501] SETDATA devices.2.instances.0.commandClasses.133.data.170.nodes = byte[0]
[2013-12-09 18:59:18.501] SETDATA devices.2.instances.0.commandClasses.133.data.170.nodesToFollow = Empty
[2013-12-09 18:59:18.502] SETDATA devices.2.instances.0.commandClasses.133.data.170.nodesToFollow = byte[0]
[2013-12-09 18:59:18.502] Adding job: Association Get
[2013-12-09 18:59:18.503] SETDATA devices.2.instances.0.commandClasses.133.data.171 = Empty
[2013-12-09 18:59:18.503] SETDATA devices.2.instances.0.commandClasses.133.data.171.max = Empty
[2013-12-09 18:59:18.503] SETDATA devices.2.instances.0.commandClasses.133.data.171.max = 0 (0x00000000)
[2013-12-09 18:59:18.503] SETDATA devices.2.instances.0.commandClasses.133.data.171.nodes = Empty
[2013-12-09 18:59:18.503] SETDATA devices.2.instances.0.commandClasses.133.data.171.nodes = byte[0]
[2013-12-09 18:59:18.503] SETDATA devices.2.instances.0.commandClasses.133.data.171.nodesToFollow = Empty
[2013-12-09 18:59:18.504] SETDATA devices.2.instances.0.commandClasses.133.data.171.nodesToFollow = byte[0]
[2013-12-09 18:59:18.504] Adding job: Association Get
[2013-12-09 18:59:18.504] SETDATA devices.2.instances.0.commandClasses.133.data.172 = Empty
[2013-12-09 18:59:18.505] SETDATA devices.2.instances.0.commandClasses.133.data.172.max = Empty
[2013-12-09 18:59:18.505] SETDATA devices.2.instances.0.commandClasses.133.data.172.max = 0 (0x00000000)
[2013-12-09 18:59:18.505] SETDATA devices.2.instances.0.commandClasses.133.data.172.nodes = Empty
[2013-12-09 18:59:18.505] SETDATA devices.2.instances.0.commandClasses.133.data.172.nodes = byte[0]
[2013-12-09 18:59:18.505] SETDATA devices.2.instances.0.commandClasses.133.data.172.nodesToFollow = Empty
[2013-12-09 18:59:18.505] SETDATA devices.2.instances.0.commandClasses.133.data.172.nodesToFollow = byte[0]
[2013-12-09 18:59:18.506] Adding job: Association Get
[2013-12-09 18:59:18.506] SETDATA devices.2.instances.0.commandClasses.133.data.173 = Empty
[2013-12-09 18:59:18.506] SETDATA devices.2.instances.0.commandClasses.133.data.173.max = Empty
[2013-12-09 18:59:18.506] SETDATA devices.2.instances.0.commandClasses.133.data.173.max = 0 (0x00000000)
[2013-12-09 18:59:18.506] SETDATA devices.2.instances.0.commandClasses.133.data.173.nodes = Empty
[2013-12-09 18:59:18.507] SETDATA devices.2.instances.0.commandClasses.133.data.173.nodes = byte[0]
[2013-12-09 18:59:18.507] SETDATA devices.2.instances.0.commandClasses.133.data.173.nodesToFollow = Empty
[2013-12-09 18:59:18.507] SETDATA devices.2.instances.0.commandClasses.133.data.173.nodesToFollow = byte[0]
[2013-12-09 18:59:18.507] Adding job: Association Get
[2013-12-09 18:59:18.508] SETDATA devices.2.instances.0.commandClasses.133.data.174 = Empty
[2013-12-09 18:59:18.508] SETDATA devices.2.instances.0.commandClasses.133.data.174.max = Empty
[2013-12-09 18:59:18.508] SETDATA devices.2.instances.0.commandClasses.133.data.174.max = 0 (0x00000000)
[2013-12-09 18:59:18.508] SETDATA devices.2.instances.0.commandClasses.133.data.174.nodes = Empty
[2013-12-09 18:59:18.508] SETDATA devices.2.instances.0.commandClasses.133.data.174.nodes = byte[0]
[2013-12-09 18:59:18.509] SETDATA devices.2.instances.0.commandClasses.133.data.174.nodesToFollow = Empty
[2013-12-09 18:59:18.509] SETDATA devices.2.instances.0.commandClasses.133.data.174.nodesToFollow = byte[0]
[2013-12-09 18:59:18.509] Adding job: Association Get
[2013-12-09 18:59:18.510] SETDATA devices.2.instances.0.commandClasses.133.data.175 = Empty
[2013-12-09 18:59:18.510] SETDATA devices.2.instances.0.commandClasses.133.data.175.max = Empty
[2013-12-09 18:59:18.510] SETDATA devices.2.instances.0.commandClasses.133.data.175.max = 0 (0x00000000)
[2013-12-09 18:59:18.510] SETDATA devices.2.instances.0.commandClasses.133.data.175.nodes = Empty
[2013-12-09 18:59:18.510] SETDATA devices.2.instances.0.commandClasses.133.data.175.nodes = byte[0]
[2013-12-09 18:59:18.510] SETDATA devices.2.instances.0.commandClasses.133.data.175.nodesToFollow = Empty
[2013-12-09 18:59:18.511] SETDATA devices.2.instances.0.commandClasses.133.data.175.nodesToFollow = byte[0]
[2013-12-09 18:59:18.511] Adding job: Association Get
[2013-12-09 18:59:18.511] SETDATA devices.2.instances.0.commandClasses.133.data.176 = Empty
[2013-12-09 18:59:18.511] SETDATA devices.2.instances.0.commandClasses.133.data.176.max = Empty
[2013-12-09 18:59:18.512] SETDATA devices.2.instances.0.commandClasses.133.data.176.max = 0 (0x00000000)
[2013-12-09 18:59:18.512] SETDATA devices.2.instances.0.commandClasses.133.data.176.nodes = Empty
[2013-12-09 18:59:18.512] SETDATA devices.2.instances.0.commandClasses.133.data.176.nodes = byte[0]
[2013-12-09 18:59:18.512] SETDATA devices.2.instances.0.commandClasses.133.data.176.nodesToFollow = Empty
[2013-12-09 18:59:18.512] SETDATA devices.2.instances.0.commandClasses.133.data.176.nodesToFollow = byte[0]
[2013-12-09 18:59:18.513] Adding job: Association Get
[2013-12-09 18:59:18.513] SETDATA devices.2.instances.0.commandClasses.133.data.177 = Empty
[2013-12-09 18:59:18.513] SETDATA devices.2.instances.0.commandClasses.133.data.177.max = Empty
[2013-12-09 18:59:18.514] SETDATA devices.2.instances.0.commandClasses.133.data.177.max = 0 (0x00000000)
[2013-12-09 18:59:18.514] SETDATA devices.2.instances.0.commandClasses.133.data.177.nodes = Empty
[2013-12-09 18:59:18.514] SETDATA devices.2.instances.0.commandClasses.133.data.177.nodes = byte[0]
[2013-12-09 18:59:18.514] SETDATA devices.2.instances.0.commandClasses.133.data.177.nodesToFollow = Empty
[2013-12-09 18:59:18.514] SETDATA devices.2.instances.0.commandClasses.133.data.177.nodesToFollow = byte[0]
[2013-12-09 18:59:18.515] Adding job: Association Get
[2013-12-09 18:59:18.515] SETDATA devices.2.instances.0.commandClasses.133.data.178 = Empty
[2013-12-09 18:59:18.515] SETDATA devices.2.instances.0.commandClasses.133.data.178.max = Empty
[2013-12-09 18:59:18.515] SETDATA devices.2.instances.0.commandClasses.133.data.178.max = 0 (0x00000000)
[2013-12-09 18:59:18.516] SETDATA devices.2.instances.0.commandClasses.133.data.178.nodes = Empty
[2013-12-09 18:59:18.516] SETDATA devices.2.instances.0.commandClasses.133.data.178.nodes = byte[0]
[2013-12-09 18:59:18.516] SETDATA devices.2.instances.0.commandClasses.133.data.178.nodesToFollow = Empty
[2013-12-09 18:59:18.516] SETDATA devices.2.instances.0.commandClasses.133.data.178.nodesToFollow = byte[0]
[2013-12-09 18:59:18.517] Adding job: Association Get
[2013-12-09 18:59:18.517] SETDATA devices.2.instances.0.commandClasses.133.data.179 = Empty
[2013-12-09 18:59:18.517] SETDATA devices.2.instances.0.commandClasses.133.data.179.max = Empty
[2013-12-09 18:59:18.517] SETDATA devices.2.instances.0.commandClasses.133.data.179.max = 0 (0x00000000)
[2013-12-09 18:59:18.517] SETDATA devices.2.instances.0.commandClasses.133.data.179.nodes = Empty
[2013-12-09 18:59:18.517] SETDATA devices.2.instances.0.commandClasses.133.data.179.nodes = byte[0]
[2013-12-09 18:59:18.518] SETDATA devices.2.instances.0.commandClasses.133.data.179.nodesToFollow = Empty
[2013-12-09 18:59:18.518] SETDATA devices.2.instances.0.commandClasses.133.data.179.nodesToFollow = byte[0]
[2013-12-09 18:59:18.518] Adding job: Association Get
[2013-12-09 18:59:18.518] SETDATA devices.2.instances.0.commandClasses.133.data.180 = Empty
[2013-12-09 18:59:18.519] SETDATA devices.2.instances.0.commandClasses.133.data.180.max = Empty
[2013-12-09 18:59:18.519] SETDATA devices.2.instances.0.commandClasses.133.data.180.max = 0 (0x00000000)
[2013-12-09 18:59:18.519] SETDATA devices.2.instances.0.commandClasses.133.data.180.nodes = Empty
[2013-12-09 18:59:18.519] SETDATA devices.2.instances.0.commandClasses.133.data.180.nodes = byte[0]
[2013-12-09 18:59:18.519] SETDATA devices.2.instances.0.commandClasses.133.data.180.nodesToFollow = Empty
[2013-12-09 18:59:18.520] SETDATA devices.2.instances.0.commandClasses.133.data.180.nodesToFollow = byte[0]
[2013-12-09 18:59:18.520] Adding job: Association Get
[2013-12-09 18:59:18.521] SETDATA devices.2.instances.0.commandClasses.133.data.181 = Empty
[2013-12-09 18:59:18.521] SETDATA devices.2.instances.0.commandClasses.133.data.181.max = Empty
[2013-12-09 18:59:18.521] SETDATA devices.2.instances.0.commandClasses.133.data.181.max = 0 (0x00000000)
[2013-12-09 18:59:18.521] SETDATA devices.2.instances.0.commandClasses.133.data.181.nodes = Empty
[2013-12-09 18:59:18.521] SETDATA devices.2.instances.0.commandClasses.133.data.181.nodes = byte[0]
[2013-12-09 18:59:18.521] SETDATA devices.2.instances.0.commandClasses.133.data.181.nodesToFollow = Empty
[2013-12-09 18:59:18.521] SETDATA devices.2.instances.0.commandClasses.133.data.181.nodesToFollow = byte[0]
[2013-12-09 18:59:18.522] Adding job: Association Get
[2013-12-09 18:59:18.522] SETDATA devices.2.instances.0.commandClasses.133.data.182 = Empty
[2013-12-09 18:59:18.523] SETDATA devices.2.instances.0.commandClasses.133.data.182.max = Empty
[2013-12-09 18:59:18.523] SETDATA devices.2.instances.0.commandClasses.133.data.182.max = 0 (0x00000000)
[2013-12-09 18:59:18.523] SETDATA devices.2.instances.0.commandClasses.133.data.182.nodes = Empty
[2013-12-09 18:59:18.523] SETDATA devices.2.instances.0.commandClasses.133.data.182.nodes = byte[0]
[2013-12-09 18:59:18.523] SETDATA devices.2.instances.0.commandClasses.133.data.182.nodesToFollow = Empty
[2013-12-09 18:59:18.523] SETDATA devices.2.instances.0.commandClasses.133.data.182.nodesToFollow = byte[0]
[2013-12-09 18:59:18.524] Adding job: Association Get
[2013-12-09 18:59:18.524] SETDATA devices.2.instances.0.commandClasses.133.data.183 = Empty
[2013-12-09 18:59:18.524] SETDATA devices.2.instances.0.commandClasses.133.data.183.max = Empty
[2013-12-09 18:59:18.525] SETDATA devices.2.instances.0.commandClasses.133.data.183.max = 0 (0x00000000)
[2013-12-09 18:59:18.525] SETDATA devices.2.instances.0.commandClasses.133.data.183.nodes = Empty
[2013-12-09 18:59:18.525] SETDATA devices.2.instances.0.commandClasses.133.data.183.nodes = byte[0]
[2013-12-09 18:59:18.525] SETDATA devices.2.instances.0.commandClasses.133.data.183.nodesToFollow = Empty
[2013-12-09 18:59:18.525] SETDATA devices.2.instances.0.commandClasses.133.data.183.nodesToFollow = byte[0]
[2013-12-09 18:59:18.526] Adding job: Association Get
[2013-12-09 18:59:18.526] SETDATA devices.2.instances.0.commandClasses.133.data.184 = Empty
[2013-12-09 18:59:18.526] SETDATA devices.2.instances.0.commandClasses.133.data.184.max = Empty
[2013-12-09 18:59:18.526] SETDATA devices.2.instances.0.commandClasses.133.data.184.max = 0 (0x00000000)
[2013-12-09 18:59:18.526] SETDATA devices.2.instances.0.commandClasses.133.data.184.nodes = Empty
[2013-12-09 18:59:18.526] SETDATA devices.2.instances.0.commandClasses.133.data.184.nodes = byte[0]
[2013-12-09 18:59:18.527] SETDATA devices.2.instances.0.commandClasses.133.data.184.nodesToFollow = Empty
[2013-12-09 18:59:18.527] SETDATA devices.2.instances.0.commandClasses.133.data.184.nodesToFollow = byte[0]
[2013-12-09 18:59:18.527] Adding job: Association Get
[2013-12-09 18:59:18.527] SETDATA devices.2.instances.0.commandClasses.133.data.185 = Empty
[2013-12-09 18:59:18.528] SETDATA devices.2.instances.0.commandClasses.133.data.185.max = Empty
[2013-12-09 18:59:18.528] SETDATA devices.2.instances.0.commandClasses.133.data.185.max = 0 (0x00000000)
[2013-12-09 18:59:18.528] SETDATA devices.2.instances.0.commandClasses.133.data.185.nodes = Empty
[2013-12-09 18:59:18.528] SETDATA devices.2.instances.0.commandClasses.133.data.185.nodes = byte[0]
[2013-12-09 18:59:18.528] SETDATA devices.2.instances.0.commandClasses.133.data.185.nodesToFollow = Empty
[2013-12-09 18:59:18.528] SETDATA devices.2.instances.0.commandClasses.133.data.185.nodesToFollow = byte[0]
[2013-12-09 18:59:18.529] Adding job: Association Get
[2013-12-09 18:59:18.530] SETDATA devices.2.instances.0.commandClasses.133.data.186 = Empty
[2013-12-09 18:59:18.530] SETDATA devices.2.instances.0.commandClasses.133.data.186.max = Empty
[2013-12-09 18:59:18.530] SETDATA devices.2.instances.0.commandClasses.133.data.186.max = 0 (0x00000000)
[2013-12-09 18:59:18.530] SETDATA devices.2.instances.0.commandClasses.133.data.186.nodes = Empty
[2013-12-09 18:59:18.530] SETDATA devices.2.instances.0.commandClasses.133.data.186.nodes = byte[0]
[2013-12-09 18:59:18.530] SETDATA devices.2.instances.0.commandClasses.133.data.186.nodesToFollow = Empty
[2013-12-09 18:59:18.530] SETDATA devices.2.instances.0.commandClasses.133.data.186.nodesToFollow = byte[0]
[2013-12-09 18:59:18.531] Adding job: Association Get
[2013-12-09 18:59:18.531] SETDATA devices.2.instances.0.commandClasses.133.data.187 = Empty
[2013-12-09 18:59:18.531] SETDATA devices.2.instances.0.commandClasses.133.data.187.max = Empty
[2013-12-09 18:59:18.532] SETDATA devices.2.instances.0.commandClasses.133.data.187.max = 0 (0x00000000)
[2013-12-09 18:59:18.532] SETDATA devices.2.instances.0.commandClasses.133.data.187.nodes = Empty
[2013-12-09 18:59:18.532] SETDATA devices.2.instances.0.commandClasses.133.data.187.nodes = byte[0]
[2013-12-09 18:59:18.532] SETDATA devices.2.instances.0.commandClasses.133.data.187.nodesToFollow = Empty
[2013-12-09 18:59:18.532] SETDATA devices.2.instances.0.commandClasses.133.data.187.nodesToFollow = byte[0]
[2013-12-09 18:59:18.533] Adding job: Association Get
[2013-12-09 18:59:18.533] SETDATA devices.2.instances.0.commandClasses.133.data.188 = Empty
[2013-12-09 18:59:18.533] SETDATA devices.2.instances.0.commandClasses.133.data.188.max = Empty
[2013-12-09 18:59:18.533] SETDATA devices.2.instances.0.commandClasses.133.data.188.max = 0 (0x00000000)
[2013-12-09 18:59:18.534] SETDATA devices.2.instances.0.commandClasses.133.data.188.nodes = Empty
[2013-12-09 18:59:18.534] SETDATA devices.2.instances.0.commandClasses.133.data.188.nodes = byte[0]
[2013-12-09 18:59:18.534] SETDATA devices.2.instances.0.commandClasses.133.data.188.nodesToFollow = Empty
[2013-12-09 18:59:18.534] SETDATA devices.2.instances.0.commandClasses.133.data.188.nodesToFollow = byte[0]
[2013-12-09 18:59:18.535] Adding job: Association Get
[2013-12-09 18:59:18.535] SETDATA devices.2.instances.0.commandClasses.133.data.189 = Empty
[2013-12-09 18:59:18.535] SETDATA devices.2.instances.0.commandClasses.133.data.189.max = Empty
[2013-12-09 18:59:18.535] SETDATA devices.2.instances.0.commandClasses.133.data.189.max = 0 (0x00000000)
[2013-12-09 18:59:18.535] SETDATA devices.2.instances.0.commandClasses.133.data.189.nodes = Empty
[2013-12-09 18:59:18.535] SETDATA devices.2.instances.0.commandClasses.133.data.189.nodes = byte[0]
[2013-12-09 18:59:18.536] SETDATA devices.2.instances.0.commandClasses.133.data.189.nodesToFollow = Empty
[2013-12-09 18:59:18.536] SETDATA devices.2.instances.0.commandClasses.133.data.189.nodesToFollow = byte[0]
[2013-12-09 18:59:18.536] Adding job: Association Get
[2013-12-09 18:59:18.537] SETDATA devices.2.instances.0.commandClasses.133.data.190 = Empty
[2013-12-09 18:59:18.537] SETDATA devices.2.instances.0.commandClasses.133.data.190.max = Empty
[2013-12-09 18:59:18.537] SETDATA devices.2.instances.0.commandClasses.133.data.190.max = 0 (0x00000000)
[2013-12-09 18:59:18.537] SETDATA devices.2.instances.0.commandClasses.133.data.190.nodes = Empty
[2013-12-09 18:59:18.537] SETDATA devices.2.instances.0.commandClasses.133.data.190.nodes = byte[0]
[2013-12-09 18:59:18.537] SETDATA devices.2.instances.0.commandClasses.133.data.190.nodesToFollow = Empty
[2013-12-09 18:59:18.537] SETDATA devices.2.instances.0.commandClasses.133.data.190.nodesToFollow = byte[0]
[2013-12-09 18:59:18.538] Adding job: Association Get
[2013-12-09 18:59:18.538] SETDATA devices.2.instances.0.commandClasses.133.data.191 = Empty
[2013-12-09 18:59:18.539] SETDATA devices.2.instances.0.commandClasses.133.data.191.max = Empty
[2013-12-09 18:59:18.539] SETDATA devices.2.instances.0.commandClasses.133.data.191.max = 0 (0x00000000)
[2013-12-09 18:59:18.539] SETDATA devices.2.instances.0.commandClasses.133.data.191.nodes = Empty
[2013-12-09 18:59:18.539] SETDATA devices.2.instances.0.commandClasses.133.data.191.nodes = byte[0]
[2013-12-09 18:59:18.539] SETDATA devices.2.instances.0.commandClasses.133.data.191.nodesToFollow = Empty
[2013-12-09 18:59:18.540] SETDATA devices.2.instances.0.commandClasses.133.data.191.nodesToFollow = byte[0]
[2013-12-09 18:59:18.540] Adding job: Association Get
[2013-12-09 18:59:18.540] SETDATA devices.2.instances.0.commandClasses.133.data.192 = Empty
[2013-12-09 18:59:18.541] SETDATA devices.2.instances.0.commandClasses.133.data.192.max = Empty
[2013-12-09 18:59:18.541] SETDATA devices.2.instances.0.commandClasses.133.data.192.max = 0 (0x00000000)
[2013-12-09 18:59:18.541] SETDATA devices.2.instances.0.commandClasses.133.data.192.nodes = Empty
[2013-12-09 18:59:18.541] SETDATA devices.2.instances.0.commandClasses.133.data.192.nodes = byte[0]
[2013-12-09 18:59:18.541] SETDATA devices.2.instances.0.commandClasses.133.data.192.nodesToFollow = Empty
[2013-12-09 18:59:18.541] SETDATA devices.2.instances.0.commandClasses.133.data.192.nodesToFollow = byte[0]
[2013-12-09 18:59:18.542] Adding job: Association Get
[2013-12-09 18:59:18.542] SETDATA devices.2.instances.0.commandClasses.133.data.193 = Empty
[2013-12-09 18:59:18.542] SETDATA devices.2.instances.0.commandClasses.133.data.193.max = Empty
[2013-12-09 18:59:18.543] SETDATA devices.2.instances.0.commandClasses.133.data.193.max = 0 (0x00000000)
[2013-12-09 18:59:18.543] SETDATA devices.2.instances.0.commandClasses.133.data.193.nodes = Empty
[2013-12-09 18:59:18.543] SETDATA devices.2.instances.0.commandClasses.133.data.193.nodes = byte[0]
[2013-12-09 18:59:18.543] SETDATA devices.2.instances.0.commandClasses.133.data.193.nodesToFollow = Empty
[2013-12-09 18:59:18.543] SETDATA devices.2.instances.0.commandClasses.133.data.193.nodesToFollow = byte[0]
[2013-12-09 18:59:18.544] Adding job: Association Get
[2013-12-09 18:59:18.544] SETDATA devices.2.instances.0.commandClasses.133.data.194 = Empty
[2013-12-09 18:59:18.544] SETDATA devices.2.instances.0.commandClasses.133.data.194.max = Empty
[2013-12-09 18:59:18.544] SETDATA devices.2.instances.0.commandClasses.133.data.194.max = 0 (0x00000000)
[2013-12-09 18:59:18.544] SETDATA devices.2.instances.0.commandClasses.133.data.194.nodes = Empty
[2013-12-09 18:59:18.545] SETDATA devices.2.instances.0.commandClasses.133.data.194.nodes = byte[0]
[2013-12-09 18:59:18.545] SETDATA devices.2.instances.0.commandClasses.133.data.194.nodesToFollow = Empty
[2013-12-09 18:59:18.545] SETDATA devices.2.instances.0.commandClasses.133.data.194.nodesToFollow = byte[0]
[2013-12-09 18:59:18.545] Adding job: Association Get
[2013-12-09 18:59:18.546] SETDATA devices.2.instances.0.commandClasses.133.data.195 = Empty
[2013-12-09 18:59:18.546] SETDATA devices.2.instances.0.commandClasses.133.data.195.max = Empty
[2013-12-09 18:59:18.546] SETDATA devices.2.instances.0.commandClasses.133.data.195.max = 0 (0x00000000)
[2013-12-09 18:59:18.546] SETDATA devices.2.instances.0.commandClasses.133.data.195.nodes = Empty
[2013-12-09 18:59:18.546] SETDATA devices.2.instances.0.commandClasses.133.data.195.nodes = byte[0]
[2013-12-09 18:59:18.546] SETDATA devices.2.instances.0.commandClasses.133.data.195.nodesToFollow = Empty
[2013-12-09 18:59:18.547] SETDATA devices.2.instances.0.commandClasses.133.data.195.nodesToFollow = byte[0]
[2013-12-09 18:59:18.547] Adding job: Association Get
[2013-12-09 18:59:18.548] SETDATA devices.2.instances.0.commandClasses.133.data.196 = Empty
[2013-12-09 18:59:18.548] SETDATA devices.2.instances.0.commandClasses.133.data.196.max = Empty
[2013-12-09 18:59:18.548] SETDATA devices.2.instances.0.commandClasses.133.data.196.max = 0 (0x00000000)
[2013-12-09 18:59:18.548] SETDATA devices.2.instances.0.commandClasses.133.data.196.nodes = Empty
[2013-12-09 18:59:18.548] SETDATA devices.2.instances.0.commandClasses.133.data.196.nodes = byte[0]
[2013-12-09 18:59:18.548] SETDATA devices.2.instances.0.commandClasses.133.data.196.nodesToFollow = Empty
[2013-12-09 18:59:18.548] SETDATA devices.2.instances.0.commandClasses.133.data.196.nodesToFollow = byte[0]
[2013-12-09 18:59:18.549] Adding job: Association Get
[2013-12-09 18:59:18.549] SETDATA devices.2.instances.0.commandClasses.133.data.197 = Empty
[2013-12-09 18:59:18.549] SETDATA devices.2.instances.0.commandClasses.133.data.197.max = Empty
[2013-12-09 18:59:18.549] SETDATA devices.2.instances.0.commandClasses.133.data.197.max = 0 (0x00000000)
[2013-12-09 18:59:18.550] SETDATA devices.2.instances.0.commandClasses.133.data.197.nodes = Empty
[2013-12-09 18:59:18.550] SETDATA devices.2.instances.0.commandClasses.133.data.197.nodes = byte[0]
[2013-12-09 18:59:18.550] SETDATA devices.2.instances.0.commandClasses.133.data.197.nodesToFollow = Empty
[2013-12-09 18:59:18.551] SETDATA devices.2.instances.0.commandClasses.133.data.197.nodesToFollow = byte[0]
[2013-12-09 18:59:18.551] Adding job: Association Get
[2013-12-09 18:59:18.551] SETDATA devices.2.instances.0.commandClasses.133.data.198 = Empty
[2013-12-09 18:59:18.552] SETDATA devices.2.instances.0.commandClasses.133.data.198.max = Empty
[2013-12-09 18:59:18.552] SETDATA devices.2.instances.0.commandClasses.133.data.198.max = 0 (0x00000000)
[2013-12-09 18:59:18.552] SETDATA devices.2.instances.0.commandClasses.133.data.198.nodes = Empty
[2013-12-09 18:59:18.552] SETDATA devices.2.instances.0.commandClasses.133.data.198.nodes = byte[0]
[2013-12-09 18:59:18.552] SETDATA devices.2.instances.0.commandClasses.133.data.198.nodesToFollow = Empty
[2013-12-09 18:59:18.552] SETDATA devices.2.instances.0.commandClasses.133.data.198.nodesToFollow = byte[0]
[2013-12-09 18:59:18.553] Adding job: Association Get
[2013-12-09 18:59:18.553] SETDATA devices.2.instances.0.commandClasses.133.data.199 = Empty
[2013-12-09 18:59:18.553] SETDATA devices.2.instances.0.commandClasses.133.data.199.max = Empty
[2013-12-09 18:59:18.554] SETDATA devices.2.instances.0.commandClasses.133.data.199.max = 0 (0x00000000)
[2013-12-09 18:59:18.554] SETDATA devices.2.instances.0.commandClasses.133.data.199.nodes = Empty
[2013-12-09 18:59:18.554] SETDATA devices.2.instances.0.commandClasses.133.data.199.nodes = byte[0]
[2013-12-09 18:59:18.554] SETDATA devices.2.instances.0.commandClasses.133.data.199.nodesToFollow = Empty
[2013-12-09 18:59:18.554] SETDATA devices.2.instances.0.commandClasses.133.data.199.nodesToFollow = byte[0]
[2013-12-09 18:59:18.555] Adding job: Association Get
[2013-12-09 18:59:18.555] SETDATA devices.2.instances.0.commandClasses.133.data.200 = Empty
[2013-12-09 18:59:18.555] SETDATA devices.2.instances.0.commandClasses.133.data.200.max = Empty
[2013-12-09 18:59:18.556] SETDATA devices.2.instances.0.commandClasses.133.data.200.max = 0 (0x00000000)
[2013-12-09 18:59:18.556] SETDATA devices.2.instances.0.commandClasses.133.data.200.nodes = Empty
[2013-12-09 18:59:18.556] SETDATA devices.2.instances.0.commandClasses.133.data.200.nodes = byte[0]
[2013-12-09 18:59:18.556] SETDATA devices.2.instances.0.commandClasses.133.data.200.nodesToFollow = Empty
[2013-12-09 18:59:18.556] SETDATA devices.2.instances.0.commandClasses.133.data.200.nodesToFollow = byte[0]
[2013-12-09 18:59:18.557] Adding job: Association Get
[2013-12-09 18:59:18.557] SETDATA devices.2.instances.0.commandClasses.133.data.201 = Empty
[2013-12-09 18:59:18.557] SETDATA devices.2.instances.0.commandClasses.133.data.201.max = Empty
[2013-12-09 18:59:18.557] SETDATA devices.2.instances.0.commandClasses.133.data.201.max = 0 (0x00000000)
[2013-12-09 18:59:18.557] SETDATA devices.2.instances.0.commandClasses.133.data.201.nodes = Empty
[2013-12-09 18:59:18.558] SETDATA devices.2.instances.0.commandClasses.133.data.201.nodes = byte[0]
[2013-12-09 18:59:18.558] SETDATA devices.2.instances.0.commandClasses.133.data.201.nodesToFollow = Empty
[2013-12-09 18:59:18.558] SETDATA devices.2.instances.0.commandClasses.133.data.201.nodesToFollow = byte[0]
[2013-12-09 18:59:18.558] Adding job: Association Get
[2013-12-09 18:59:18.559] SETDATA devices.2.instances.0.commandClasses.133.data.202 = Empty
[2013-12-09 18:59:18.559] SETDATA devices.2.instances.0.commandClasses.133.data.202.max = Empty
[2013-12-09 18:59:18.559] SETDATA devices.2.instances.0.commandClasses.133.data.202.max = 0 (0x00000000)
[2013-12-09 18:59:18.559] SETDATA devices.2.instances.0.commandClasses.133.data.202.nodes = Empty
[2013-12-09 18:59:18.559] SETDATA devices.2.instances.0.commandClasses.133.data.202.nodes = byte[0]
[2013-12-09 18:59:18.559] SETDATA devices.2.instances.0.commandClasses.133.data.202.nodesToFollow = Empty
[2013-12-09 18:59:18.559] SETDATA devices.2.instances.0.commandClasses.133.data.202.nodesToFollow = byte[0]
[2013-12-09 18:59:18.561] Adding job: Association Get
[2013-12-09 18:59:18.561] SETDATA devices.2.instances.0.commandClasses.133.data.203 = Empty
[2013-12-09 18:59:18.561] SETDATA devices.2.instances.0.commandClasses.133.data.203.max = Empty
[2013-12-09 18:59:18.561] SETDATA devices.2.instances.0.commandClasses.133.data.203.max = 0 (0x00000000)
[2013-12-09 18:59:18.561] SETDATA devices.2.instances.0.commandClasses.133.data.203.nodes = Empty
[2013-12-09 18:59:18.561] SETDATA devices.2.instances.0.commandClasses.133.data.203.nodes = byte[0]
[2013-12-09 18:59:18.562] SETDATA devices.2.instances.0.commandClasses.133.data.203.nodesToFollow = Empty
[2013-12-09 18:59:18.562] SETDATA devices.2.instances.0.commandClasses.133.data.203.nodesToFollow = byte[0]
[2013-12-09 18:59:18.563] Adding job: Association Get
[2013-12-09 18:59:18.563] SETDATA devices.2.instances.0.commandClasses.133.data.204 = Empty
[2013-12-09 18:59:18.563] SETDATA devices.2.instances.0.commandClasses.133.data.204.max = Empty
[2013-12-09 18:59:18.563] SETDATA devices.2.instances.0.commandClasses.133.data.204.max = 0 (0x00000000)
[2013-12-09 18:59:18.563] SETDATA devices.2.instances.0.commandClasses.133.data.204.nodes = Empty
[2013-12-09 18:59:18.563] SETDATA devices.2.instances.0.commandClasses.133.data.204.nodes = byte[0]
[2013-12-09 18:59:18.564] SETDATA devices.2.instances.0.commandClasses.133.data.204.nodesToFollow = Empty
[2013-12-09 18:59:18.564] SETDATA devices.2.instances.0.commandClasses.133.data.204.nodesToFollow = byte[0]
[2013-12-09 18:59:18.564] Adding job: Association Get
[2013-12-09 18:59:18.565] SETDATA devices.2.instances.0.commandClasses.133.data.205 = Empty
[2013-12-09 18:59:18.565] SETDATA devices.2.instances.0.commandClasses.133.data.205.max = Empty
[2013-12-09 18:59:18.565] SETDATA devices.2.instances.0.commandClasses.133.data.205.max = 0 (0x00000000)
[2013-12-09 18:59:18.565] SETDATA devices.2.instances.0.commandClasses.133.data.205.nodes = Empty
[2013-12-09 18:59:18.565] SETDATA devices.2.instances.0.commandClasses.133.data.205.nodes = byte[0]
[2013-12-09 18:59:18.565] SETDATA devices.2.instances.0.commandClasses.133.data.205.nodesToFollow = Empty
[2013-12-09 18:59:18.566] SETDATA devices.2.instances.0.commandClasses.133.data.205.nodesToFollow = byte[0]
[2013-12-09 18:59:18.566] Adding job: Association Get
[2013-12-09 18:59:18.566] SETDATA devices.2.instances.0.commandClasses.133.data.206 = Empty
[2013-12-09 18:59:18.567] SETDATA devices.2.instances.0.commandClasses.133.data.206.max = Empty
[2013-12-09 18:59:18.567] SETDATA devices.2.instances.0.commandClasses.133.data.206.max = 0 (0x00000000)
[2013-12-09 18:59:18.567] SETDATA devices.2.instances.0.commandClasses.133.data.206.nodes = Empty
[2013-12-09 18:59:18.567] SETDATA devices.2.instances.0.commandClasses.133.data.206.nodes = byte[0]
[2013-12-09 18:59:18.567] SETDATA devices.2.instances.0.commandClasses.133.data.206.nodesToFollow = Empty
[2013-12-09 18:59:18.567] SETDATA devices.2.instances.0.commandClasses.133.data.206.nodesToFollow = byte[0]
[2013-12-09 18:59:18.568] Adding job: Association Get
[2013-12-09 18:59:18.568] SETDATA devices.2.instances.0.commandClasses.133.data.207 = Empty
[2013-12-09 18:59:18.568] SETDATA devices.2.instances.0.commandClasses.133.data.207.max = Empty
[2013-12-09 18:59:18.568] SETDATA devices.2.instances.0.commandClasses.133.data.207.max = 0 (0x00000000)
[2013-12-09 18:59:18.569] SETDATA devices.2.instances.0.commandClasses.133.data.207.nodes = Empty
[2013-12-09 18:59:18.569] SETDATA devices.2.instances.0.commandClasses.133.data.207.nodes = byte[0]
[2013-12-09 18:59:18.569] SETDATA devices.2.instances.0.commandClasses.133.data.207.nodesToFollow = Empty
[2013-12-09 18:59:18.569] SETDATA devices.2.instances.0.commandClasses.133.data.207.nodesToFollow = byte[0]
[2013-12-09 18:59:18.570] Adding job: Association Get
[2013-12-09 18:59:18.570] SETDATA devices.2.instances.0.commandClasses.133.data.208 = Empty
[2013-12-09 18:59:18.570] SETDATA devices.2.instances.0.commandClasses.133.data.208.max = Empty
[2013-12-09 18:59:18.570] SETDATA devices.2.instances.0.commandClasses.133.data.208.max = 0 (0x00000000)
[2013-12-09 18:59:18.571] SETDATA devices.2.instances.0.commandClasses.133.data.208.nodes = Empty
[2013-12-09 18:59:18.571] SETDATA devices.2.instances.0.commandClasses.133.data.208.nodes = byte[0]
[2013-12-09 18:59:18.571] SETDATA devices.2.instances.0.commandClasses.133.data.208.nodesToFollow = Empty
[2013-12-09 18:59:18.571] SETDATA devices.2.instances.0.commandClasses.133.data.208.nodesToFollow = byte[0]
[2013-12-09 18:59:18.572] Adding job: Association Get
[2013-12-09 18:59:18.572] SETDATA devices.2.instances.0.commandClasses.133.data.209 = Empty
[2013-12-09 18:59:18.572] SETDATA devices.2.instances.0.commandClasses.133.data.209.max = Empty
[2013-12-09 18:59:18.572] SETDATA devices.2.instances.0.commandClasses.133.data.209.max = 0 (0x00000000)
[2013-12-09 18:59:18.573] SETDATA devices.2.instances.0.commandClasses.133.data.209.nodes = Empty
[2013-12-09 18:59:18.573] SETDATA devices.2.instances.0.commandClasses.133.data.209.nodes = byte[0]
[2013-12-09 18:59:18.573] SETDATA devices.2.instances.0.commandClasses.133.data.209.nodesToFollow = Empty
[2013-12-09 18:59:18.573] SETDATA devices.2.instances.0.commandClasses.133.data.209.nodesToFollow = byte[0]
[2013-12-09 18:59:18.574] Adding job: Association Get
[2013-12-09 18:59:18.574] SETDATA devices.2.instances.0.commandClasses.133.data.210 = Empty
[2013-12-09 18:59:18.574] SETDATA devices.2.instances.0.commandClasses.133.data.210.max = Empty
[2013-12-09 18:59:18.574] SETDATA devices.2.instances.0.commandClasses.133.data.210.max = 0 (0x00000000)
[2013-12-09 18:59:18.574] SETDATA devices.2.instances.0.commandClasses.133.data.210.nodes = Empty
[2013-12-09 18:59:18.574] SETDATA devices.2.instances.0.commandClasses.133.data.210.nodes = byte[0]
[2013-12-09 18:59:18.575] SETDATA devices.2.instances.0.commandClasses.133.data.210.nodesToFollow = Empty
[2013-12-09 18:59:18.575] SETDATA devices.2.instances.0.commandClasses.133.data.210.nodesToFollow = byte[0]
[2013-12-09 18:59:18.576] Adding job: Association Get
[2013-12-09 18:59:18.576] SETDATA devices.2.instances.0.commandClasses.133.data.211 = Empty
[2013-12-09 18:59:18.576] SETDATA devices.2.instances.0.commandClasses.133.data.211.max = Empty
[2013-12-09 18:59:18.576] SETDATA devices.2.instances.0.commandClasses.133.data.211.max = 0 (0x00000000)
[2013-12-09 18:59:18.576] SETDATA devices.2.instances.0.commandClasses.133.data.211.nodes = Empty
[2013-12-09 18:59:18.576] SETDATA devices.2.instances.0.commandClasses.133.data.211.nodes = byte[0]
[2013-12-09 18:59:18.577] SETDATA devices.2.instances.0.commandClasses.133.data.211.nodesToFollow = Empty
[2013-12-09 18:59:18.577] SETDATA devices.2.instances.0.commandClasses.133.data.211.nodesToFollow = byte[0]
[2013-12-09 18:59:18.577] Adding job: Association Get
[2013-12-09 18:59:18.578] SETDATA devices.2.instances.0.commandClasses.133.data.212 = Empty
[2013-12-09 18:59:18.578] SETDATA devices.2.instances.0.commandClasses.133.data.212.max = Empty
[2013-12-09 18:59:18.578] SETDATA devices.2.instances.0.commandClasses.133.data.212.max = 0 (0x00000000)
[2013-12-09 18:59:18.578] SETDATA devices.2.instances.0.commandClasses.133.data.212.nodes = Empty
[2013-12-09 18:59:18.578] SETDATA devices.2.instances.0.commandClasses.133.data.212.nodes = byte[0]
[2013-12-09 18:59:18.578] SETDATA devices.2.instances.0.commandClasses.133.data.212.nodesToFollow = Empty
[2013-12-09 18:59:18.578] SETDATA devices.2.instances.0.commandClasses.133.data.212.nodesToFollow = byte[0]
[2013-12-09 18:59:18.579] Adding job: Association Get
[2013-12-09 18:59:18.579] SETDATA devices.2.instances.0.commandClasses.133.data.213 = Empty
[2013-12-09 18:59:18.579] SETDATA devices.2.instances.0.commandClasses.133.data.213.max = Empty
[2013-12-09 18:59:18.580] SETDATA devices.2.instances.0.commandClasses.133.data.213.max = 0 (0x00000000)
[2013-12-09 18:59:18.580] SETDATA devices.2.instances.0.commandClasses.133.data.213.nodes = Empty
[2013-12-09 18:59:18.580] SETDATA devices.2.instances.0.commandClasses.133.data.213.nodes = byte[0]
[2013-12-09 18:59:18.580] SETDATA devices.2.instances.0.commandClasses.133.data.213.nodesToFollow = Empty
[2013-12-09 18:59:18.580] SETDATA devices.2.instances.0.commandClasses.133.data.213.nodesToFollow = byte[0]
[2013-12-09 18:59:18.581] Adding job: Association Get
[2013-12-09 18:59:18.581] SETDATA devices.2.instances.0.commandClasses.133.data.214 = Empty
[2013-12-09 18:59:18.582] SETDATA devices.2.instances.0.commandClasses.133.data.214.max = Empty
[2013-12-09 18:59:18.582] SETDATA devices.2.instances.0.commandClasses.133.data.214.max = 0 (0x00000000)
[2013-12-09 18:59:18.582] SETDATA devices.2.instances.0.commandClasses.133.data.214.nodes = Empty
[2013-12-09 18:59:18.582] SETDATA devices.2.instances.0.commandClasses.133.data.214.nodes = byte[0]
[2013-12-09 18:59:18.582] SETDATA devices.2.instances.0.commandClasses.133.data.214.nodesToFollow = Empty
[2013-12-09 18:59:18.582] SETDATA devices.2.instances.0.commandClasses.133.data.214.nodesToFollow = byte[0]
[2013-12-09 18:59:18.583] Adding job: Association Get
[2013-12-09 18:59:18.583] SETDATA devices.2.instances.0.commandClasses.133.data.215 = Empty
[2013-12-09 18:59:18.583] SETDATA devices.2.instances.0.commandClasses.133.data.215.max = Empty
[2013-12-09 18:59:18.584] SETDATA devices.2.instances.0.commandClasses.133.data.215.max = 0 (0x00000000)
[2013-12-09 18:59:18.584] SETDATA devices.2.instances.0.commandClasses.133.data.215.nodes = Empty
[2013-12-09 18:59:18.584] SETDATA devices.2.instances.0.commandClasses.133.data.215.nodes = byte[0]
[2013-12-09 18:59:18.584] SETDATA devices.2.instances.0.commandClasses.133.data.215.nodesToFollow = Empty
[2013-12-09 18:59:18.584] SETDATA devices.2.instances.0.commandClasses.133.data.215.nodesToFollow = byte[0]
[2013-12-09 18:59:18.585] Adding job: Association Get
[2013-12-09 18:59:18.585] SETDATA devices.2.instances.0.commandClasses.133.data.216 = Empty
[2013-12-09 18:59:18.585] SETDATA devices.2.instances.0.commandClasses.133.data.216.max = Empty
[2013-12-09 18:59:18.586] SETDATA devices.2.instances.0.commandClasses.133.data.216.max = 0 (0x00000000)
[2013-12-09 18:59:18.586] SETDATA devices.2.instances.0.commandClasses.133.data.216.nodes = Empty
[2013-12-09 18:59:18.586] SETDATA devices.2.instances.0.commandClasses.133.data.216.nodes = byte[0]
[2013-12-09 18:59:18.586] SETDATA devices.2.instances.0.commandClasses.133.data.216.nodesToFollow = Empty
[2013-12-09 18:59:18.586] SETDATA devices.2.instances.0.commandClasses.133.data.216.nodesToFollow = byte[0]
[2013-12-09 18:59:18.587] Adding job: Association Get
[2013-12-09 18:59:18.587] SETDATA devices.2.instances.0.commandClasses.133.data.217 = Empty
[2013-12-09 18:59:18.587] SETDATA devices.2.instances.0.commandClasses.133.data.217.max = Empty
[2013-12-09 18:59:18.587] SETDATA devices.2.instances.0.commandClasses.133.data.217.max = 0 (0x00000000)
[2013-12-09 18:59:18.588] SETDATA devices.2.instances.0.commandClasses.133.data.217.nodes = Empty
[2013-12-09 18:59:18.588] SETDATA devices.2.instances.0.commandClasses.133.data.217.nodes = byte[0]
[2013-12-09 18:59:18.588] SETDATA devices.2.instances.0.commandClasses.133.data.217.nodesToFollow = Empty
[2013-12-09 18:59:18.588] SETDATA devices.2.instances.0.commandClasses.133.data.217.nodesToFollow = byte[0]
[2013-12-09 18:59:18.589] Adding job: Association Get
[2013-12-09 18:59:18.589] SETDATA devices.2.instances.0.commandClasses.133.data.218 = Empty
[2013-12-09 18:59:18.589] SETDATA devices.2.instances.0.commandClasses.133.data.218.max = Empty
[2013-12-09 18:59:18.589] SETDATA devices.2.instances.0.commandClasses.133.data.218.max = 0 (0x00000000)
[2013-12-09 18:59:18.589] SETDATA devices.2.instances.0.commandClasses.133.data.218.nodes = Empty
[2013-12-09 18:59:18.589] SETDATA devices.2.instances.0.commandClasses.133.data.218.nodes = byte[0]
[2013-12-09 18:59:18.589] SETDATA devices.2.instances.0.commandClasses.133.data.218.nodesToFollow = Empty
[2013-12-09 18:59:18.590] SETDATA devices.2.instances.0.commandClasses.133.data.218.nodesToFollow = byte[0]
[2013-12-09 18:59:18.590] Adding job: Association Get
[2013-12-09 18:59:18.590] SETDATA devices.2.instances.0.commandClasses.133.data.219 = Empty
[2013-12-09 18:59:18.591] SETDATA devices.2.instances.0.commandClasses.133.data.219.max = Empty
[2013-12-09 18:59:18.591] SETDATA devices.2.instances.0.commandClasses.133.data.219.max = 0 (0x00000000)
[2013-12-09 18:59:18.591] SETDATA devices.2.instances.0.commandClasses.133.data.219.nodes = Empty
[2013-12-09 18:59:18.591] SETDATA devices.2.instances.0.commandClasses.133.data.219.nodes = byte[0]
[2013-12-09 18:59:18.592] SETDATA devices.2.instances.0.commandClasses.133.data.219.nodesToFollow = Empty
[2013-12-09 18:59:18.592] SETDATA devices.2.instances.0.commandClasses.133.data.219.nodesToFollow = byte[0]
[2013-12-09 18:59:18.592] Adding job: Association Get
[2013-12-09 18:59:18.593] SETDATA devices.2.instances.0.commandClasses.133.data.220 = Empty
[2013-12-09 18:59:18.593] SETDATA devices.2.instances.0.commandClasses.133.data.220.max = Empty
[2013-12-09 18:59:18.593] SETDATA devices.2.instances.0.commandClasses.133.data.220.max = 0 (0x00000000)
[2013-12-09 18:59:18.593] SETDATA devices.2.instances.0.commandClasses.133.data.220.nodes = Empty
[2013-12-09 18:59:18.593] SETDATA devices.2.instances.0.commandClasses.133.data.220.nodes = byte[0]
[2013-12-09 18:59:18.593] SETDATA devices.2.instances.0.commandClasses.133.data.220.nodesToFollow = Empty
[2013-12-09 18:59:18.594] SETDATA devices.2.instances.0.commandClasses.133.data.220.nodesToFollow = byte[0]
[2013-12-09 18:59:18.594] Adding job: Association Get
[2013-12-09 18:59:18.595] SETDATA devices.2.instances.0.commandClasses.133.data.221 = Empty
[2013-12-09 18:59:18.595] SETDATA devices.2.instances.0.commandClasses.133.data.221.max = Empty
[2013-12-09 18:59:18.595] SETDATA devices.2.instances.0.commandClasses.133.data.221.max = 0 (0x00000000)
[2013-12-09 18:59:18.595] SETDATA devices.2.instances.0.commandClasses.133.data.221.nodes = Empty
[2013-12-09 18:59:18.595] SETDATA devices.2.instances.0.commandClasses.133.data.221.nodes = byte[0]
[2013-12-09 18:59:18.596] SETDATA devices.2.instances.0.commandClasses.133.data.221.nodesToFollow = Empty
[2013-12-09 18:59:18.596] SETDATA devices.2.instances.0.commandClasses.133.data.221.nodesToFollow = byte[0]
[2013-12-09 18:59:18.596] Adding job: Association Get
[2013-12-09 18:59:18.597] SETDATA devices.2.instances.0.commandClasses.133.data.222 = Empty
[2013-12-09 18:59:18.597] SETDATA devices.2.instances.0.commandClasses.133.data.222.max = Empty
[2013-12-09 18:59:18.597] SETDATA devices.2.instances.0.commandClasses.133.data.222.max = 0 (0x00000000)
[2013-12-09 18:59:18.597] SETDATA devices.2.instances.0.commandClasses.133.data.222.nodes = Empty
[2013-12-09 18:59:18.597] SETDATA devices.2.instances.0.commandClasses.133.data.222.nodes = byte[0]
[2013-12-09 18:59:18.597] SETDATA devices.2.instances.0.commandClasses.133.data.222.nodesToFollow = Empty
[2013-12-09 18:59:18.597] SETDATA devices.2.instances.0.commandClasses.133.data.222.nodesToFollow = byte[0]
[2013-12-09 18:59:18.598] Adding job: Association Get
[2013-12-09 18:59:18.598] SETDATA devices.2.instances.0.commandClasses.133.data.223 = Empty
[2013-12-09 18:59:18.598] SETDATA devices.2.instances.0.commandClasses.133.data.223.max = Empty
[2013-12-09 18:59:18.599] SETDATA devices.2.instances.0.commandClasses.133.data.223.max = 0 (0x00000000)
[2013-12-09 18:59:18.599] SETDATA devices.2.instances.0.commandClasses.133.data.223.nodes = Empty
[2013-12-09 18:59:18.599] SETDATA devices.2.instances.0.commandClasses.133.data.223.nodes = byte[0]
[2013-12-09 18:59:18.599] SETDATA devices.2.instances.0.commandClasses.133.data.223.nodesToFollow = Empty
[2013-12-09 18:59:18.599] SETDATA devices.2.instances.0.commandClasses.133.data.223.nodesToFollow = byte[0]
[2013-12-09 18:59:18.600] Adding job: Association Get
[2013-12-09 18:59:18.600] SETDATA devices.2.instances.0.commandClasses.133.data.224 = Empty
[2013-12-09 18:59:18.600] SETDATA devices.2.instances.0.commandClasses.133.data.224.max = Empty
[2013-12-09 18:59:18.600] SETDATA devices.2.instances.0.commandClasses.133.data.224.max = 0 (0x00000000)
[2013-12-09 18:59:18.600] SETDATA devices.2.instances.0.commandClasses.133.data.224.nodes = Empty
[2013-12-09 18:59:18.601] SETDATA devices.2.instances.0.commandClasses.133.data.224.nodes = byte[0]
[2013-12-09 18:59:18.601] SETDATA devices.2.instances.0.commandClasses.133.data.224.nodesToFollow = Empty
[2013-12-09 18:59:18.601] SETDATA devices.2.instances.0.commandClasses.133.data.224.nodesToFollow = byte[0]
[2013-12-09 18:59:18.602] Adding job: Association Get
[2013-12-09 18:59:18.602] SETDATA devices.2.instances.0.commandClasses.133.data.225 = Empty
[2013-12-09 18:59:18.602] SETDATA devices.2.instances.0.commandClasses.133.data.225.max = Empty
[2013-12-09 18:59:18.603] SETDATA devices.2.instances.0.commandClasses.133.data.225.max = 0 (0x00000000)
[2013-12-09 18:59:18.603] SETDATA devices.2.instances.0.commandClasses.133.data.225.nodes = Empty
[2013-12-09 18:59:18.603] SETDATA devices.2.instances.0.commandClasses.133.data.225.nodes = byte[0]
[2013-12-09 18:59:18.603] SETDATA devices.2.instances.0.commandClasses.133.data.225.nodesToFollow = Empty
[2013-12-09 18:59:18.603] SETDATA devices.2.instances.0.commandClasses.133.data.225.nodesToFollow = byte[0]
[2013-12-09 18:59:18.604] Adding job: Association Get
[2013-12-09 18:59:18.604] SETDATA devices.2.instances.0.commandClasses.133.data.226 = Empty
[2013-12-09 18:59:18.604] SETDATA devices.2.instances.0.commandClasses.133.data.226.max = Empty
[2013-12-09 18:59:18.604] SETDATA devices.2.instances.0.commandClasses.133.data.226.max = 0 (0x00000000)
[2013-12-09 18:59:18.605] SETDATA devices.2.instances.0.commandClasses.133.data.226.nodes = Empty
[2013-12-09 18:59:18.605] SETDATA devices.2.instances.0.commandClasses.133.data.226.nodes = byte[0]
[2013-12-09 18:59:18.605] SETDATA devices.2.instances.0.commandClasses.133.data.226.nodesToFollow = Empty
[2013-12-09 18:59:18.605] SETDATA devices.2.instances.0.commandClasses.133.data.226.nodesToFollow = byte[0]
[2013-12-09 18:59:18.606] Adding job: Association Get
[2013-12-09 18:59:18.606] SETDATA devices.2.instances.0.commandClasses.133.data.227 = Empty
[2013-12-09 18:59:18.606] SETDATA devices.2.instances.0.commandClasses.133.data.227.max = Empty
[2013-12-09 18:59:18.606] SETDATA devices.2.instances.0.commandClasses.133.data.227.max = 0 (0x00000000)
[2013-12-09 18:59:18.607] SETDATA devices.2.instances.0.commandClasses.133.data.227.nodes = Empty
[2013-12-09 18:59:18.607] SETDATA devices.2.instances.0.commandClasses.133.data.227.nodes = byte[0]
[2013-12-09 18:59:18.607] SETDATA devices.2.instances.0.commandClasses.133.data.227.nodesToFollow = Empty
[2013-12-09 18:59:18.607] SETDATA devices.2.instances.0.commandClasses.133.data.227.nodesToFollow = byte[0]
[2013-12-09 18:59:18.607] Adding job: Association Get
[2013-12-09 18:59:18.608] SETDATA devices.2.instances.0.commandClasses.133.data.228 = Empty
[2013-12-09 18:59:18.608] SETDATA devices.2.instances.0.commandClasses.133.data.228.max = Empty
[2013-12-09 18:59:18.608] SETDATA devices.2.instances.0.commandClasses.133.data.228.max = 0 (0x00000000)
[2013-12-09 18:59:18.608] SETDATA devices.2.instances.0.commandClasses.133.data.228.nodes = Empty
[2013-12-09 18:59:18.608] SETDATA devices.2.instances.0.commandClasses.133.data.228.nodes = byte[0]
[2013-12-09 18:59:18.608] SETDATA devices.2.instances.0.commandClasses.133.data.228.nodesToFollow = Empty
[2013-12-09 18:59:18.609] SETDATA devices.2.instances.0.commandClasses.133.data.228.nodesToFollow = byte[0]
[2013-12-09 18:59:18.609] Adding job: Association Get
[2013-12-09 18:59:18.609] SETDATA devices.2.instances.0.commandClasses.133.data.229 = Empty
[2013-12-09 18:59:18.610] SETDATA devices.2.instances.0.commandClasses.133.data.229.max = Empty
[2013-12-09 18:59:18.610] SETDATA devices.2.instances.0.commandClasses.133.data.229.max = 0 (0x00000000)
[2013-12-09 18:59:18.610] SETDATA devices.2.instances.0.commandClasses.133.data.229.nodes = Empty
[2013-12-09 18:59:18.610] SETDATA devices.2.instances.0.commandClasses.133.data.229.nodes = byte[0]
[2013-12-09 18:59:18.610] SETDATA devices.2.instances.0.commandClasses.133.data.229.nodesToFollow = Empty
[2013-12-09 18:59:18.610] SETDATA devices.2.instances.0.commandClasses.133.data.229.nodesToFollow = byte[0]
[2013-12-09 18:59:18.611] Adding job: Association Get
[2013-12-09 18:59:18.611] SETDATA devices.2.instances.0.commandClasses.133.data.230 = Empty
[2013-12-09 18:59:18.611] SETDATA devices.2.instances.0.commandClasses.133.data.230.max = Empty
[2013-12-09 18:59:18.612] SETDATA devices.2.instances.0.commandClasses.133.data.230.max = 0 (0x00000000)
[2013-12-09 18:59:18.612] SETDATA devices.2.instances.0.commandClasses.133.data.230.nodes = Empty
[2013-12-09 18:59:18.612] SETDATA devices.2.instances.0.commandClasses.133.data.230.nodes = byte[0]
[2013-12-09 18:59:18.612] SETDATA devices.2.instances.0.commandClasses.133.data.230.nodesToFollow = Empty
[2013-12-09 18:59:18.613] SETDATA devices.2.instances.0.commandClasses.133.data.230.nodesToFollow = byte[0]
[2013-12-09 18:59:18.613] Adding job: Association Get
[2013-12-09 18:59:18.614] SETDATA devices.2.instances.0.commandClasses.133.data.231 = Empty
[2013-12-09 18:59:18.614] SETDATA devices.2.instances.0.commandClasses.133.data.231.max = Empty
[2013-12-09 18:59:18.614] SETDATA devices.2.instances.0.commandClasses.133.data.231.max = 0 (0x00000000)
[2013-12-09 18:59:18.614] SETDATA devices.2.instances.0.commandClasses.133.data.231.nodes = Empty
[2013-12-09 18:59:18.614] SETDATA devices.2.instances.0.commandClasses.133.data.231.nodes = byte[0]
[2013-12-09 18:59:18.614] SETDATA devices.2.instances.0.commandClasses.133.data.231.nodesToFollow = Empty
[2013-12-09 18:59:18.614] SETDATA devices.2.instances.0.commandClasses.133.data.231.nodesToFollow = byte[0]
[2013-12-09 18:59:18.615] Adding job: Association Get
[2013-12-09 18:59:18.616] SETDATA devices.2.instances.0.commandClasses.133.data.232 = Empty
[2013-12-09 18:59:18.616] SETDATA devices.2.instances.0.commandClasses.133.data.232.max = Empty
[2013-12-09 18:59:18.616] SETDATA devices.2.instances.0.commandClasses.133.data.232.max = 0 (0x00000000)
[2013-12-09 18:59:18.616] SETDATA devices.2.instances.0.commandClasses.133.data.232.nodes = Empty
[2013-12-09 18:59:18.616] SETDATA devices.2.instances.0.commandClasses.133.data.232.nodes = byte[0]
[2013-12-09 18:59:18.616] SETDATA devices.2.instances.0.commandClasses.133.data.232.nodesToFollow = Empty
[2013-12-09 18:59:18.616] SETDATA devices.2.instances.0.commandClasses.133.data.232.nodesToFollow = byte[0]
[2013-12-09 18:59:18.617] Adding job: Association Get
[2013-12-09 18:59:18.617] SETDATA devices.2.instances.0.commandClasses.133.data.233 = Empty
[2013-12-09 18:59:18.617] SETDATA devices.2.instances.0.commandClasses.133.data.233.max = Empty
[2013-12-09 18:59:18.618] SETDATA devices.2.instances.0.commandClasses.133.data.233.max = 0 (0x00000000)
[2013-12-09 18:59:18.618] SETDATA devices.2.instances.0.commandClasses.133.data.233.nodes = Empty
[2013-12-09 18:59:18.618] SETDATA devices.2.instances.0.commandClasses.133.data.233.nodes = byte[0]
[2013-12-09 18:59:18.618] SETDATA devices.2.instances.0.commandClasses.133.data.233.nodesToFollow = Empty
[2013-12-09 18:59:18.618] SETDATA devices.2.instances.0.commandClasses.133.data.233.nodesToFollow = byte[0]
[2013-12-09 18:59:18.619] Adding job: Association Get
[2013-12-09 18:59:18.619] SETDATA devices.2.instances.0.commandClasses.133.data.234 = Empty
[2013-12-09 18:59:18.619] SETDATA devices.2.instances.0.commandClasses.133.data.234.max = Empty
[2013-12-09 18:59:18.619] SETDATA devices.2.instances.0.commandClasses.133.data.234.max = 0 (0x00000000)
[2013-12-09 18:59:18.620] SETDATA devices.2.instances.0.commandClasses.133.data.234.nodes = Empty
[2013-12-09 18:59:18.620] SETDATA devices.2.instances.0.commandClasses.133.data.234.nodes = byte[0]
[2013-12-09 18:59:18.620] SETDATA devices.2.instances.0.commandClasses.133.data.234.nodesToFollow = Empty
[2013-12-09 18:59:18.620] SETDATA devices.2.instances.0.commandClasses.133.data.234.nodesToFollow = byte[0]
[2013-12-09 18:59:18.621] Adding job: Association Get
[2013-12-09 18:59:18.621] SETDATA devices.2.instances.0.commandClasses.133.data.235 = Empty
[2013-12-09 18:59:18.621] SETDATA devices.2.instances.0.commandClasses.133.data.235.max = Empty
[2013-12-09 18:59:18.621] SETDATA devices.2.instances.0.commandClasses.133.data.235.max = 0 (0x00000000)
[2013-12-09 18:59:18.621] SETDATA devices.2.instances.0.commandClasses.133.data.235.nodes = Empty
[2013-12-09 18:59:18.622] SETDATA devices.2.instances.0.commandClasses.133.data.235.nodes = byte[0]
[2013-12-09 18:59:18.622] SETDATA devices.2.instances.0.commandClasses.133.data.235.nodesToFollow = Empty
[2013-12-09 18:59:18.622] SETDATA devices.2.instances.0.commandClasses.133.data.235.nodesToFollow = byte[0]
[2013-12-09 18:59:18.623] Adding job: Association Get
[2013-12-09 18:59:18.623] SETDATA devices.2.instances.0.commandClasses.133.data.236 = Empty
[2013-12-09 18:59:18.623] SETDATA devices.2.instances.0.commandClasses.133.data.236.max = Empty
[2013-12-09 18:59:18.624] SETDATA devices.2.instances.0.commandClasses.133.data.236.max = 0 (0x00000000)
[2013-12-09 18:59:18.624] SETDATA devices.2.instances.0.commandClasses.133.data.236.nodes = Empty
[2013-12-09 18:59:18.624] SETDATA devices.2.instances.0.commandClasses.133.data.236.nodes = byte[0]
[2013-12-09 18:59:18.624] SETDATA devices.2.instances.0.commandClasses.133.data.236.nodesToFollow = Empty
[2013-12-09 18:59:18.624] SETDATA devices.2.instances.0.commandClasses.133.data.236.nodesToFollow = byte[0]
[2013-12-09 18:59:18.625] Adding job: Association Get
[2013-12-09 18:59:18.625] SETDATA devices.2.instances.0.commandClasses.133.data.237 = Empty
[2013-12-09 18:59:18.625] SETDATA devices.2.instances.0.commandClasses.133.data.237.max = Empty
[2013-12-09 18:59:18.626] SETDATA devices.2.instances.0.commandClasses.133.data.237.max = 0 (0x00000000)
[2013-12-09 18:59:18.626] SETDATA devices.2.instances.0.commandClasses.133.data.237.nodes = Empty
[2013-12-09 18:59:18.626] SETDATA devices.2.instances.0.commandClasses.133.data.237.nodes = byte[0]
[2013-12-09 18:59:18.626] SETDATA devices.2.instances.0.commandClasses.133.data.237.nodesToFollow = Empty
[2013-12-09 18:59:18.626] SETDATA devices.2.instances.0.commandClasses.133.data.237.nodesToFollow = byte[0]
[2013-12-09 18:59:18.627] Adding job: Association Get
[2013-12-09 18:59:18.627] SETDATA devices.2.instances.0.commandClasses.133.data.238 = Empty
[2013-12-09 18:59:18.627] SETDATA devices.2.instances.0.commandClasses.133.data.238.max = Empty
[2013-12-09 18:59:18.627] SETDATA devices.2.instances.0.commandClasses.133.data.238.max = 0 (0x00000000)
[2013-12-09 18:59:18.628] SETDATA devices.2.instances.0.commandClasses.133.data.238.nodes = Empty
[2013-12-09 18:59:18.628] SETDATA devices.2.instances.0.commandClasses.133.data.238.nodes = byte[0]
[2013-12-09 18:59:18.628] SETDATA devices.2.instances.0.commandClasses.133.data.238.nodesToFollow = Empty
[2013-12-09 18:59:18.628] SETDATA devices.2.instances.0.commandClasses.133.data.238.nodesToFollow = byte[0]
[2013-12-09 18:59:18.629] Adding job: Association Get
[2013-12-09 18:59:18.629] SETDATA devices.2.instances.0.commandClasses.133.data.239 = Empty
[2013-12-09 18:59:18.629] SETDATA devices.2.instances.0.commandClasses.133.data.239.max = Empty
[2013-12-09 18:59:18.629] SETDATA devices.2.instances.0.commandClasses.133.data.239.max = 0 (0x00000000)
[2013-12-09 18:59:18.629] SETDATA devices.2.instances.0.commandClasses.133.data.239.nodes = Empty
[2013-12-09 18:59:18.629] SETDATA devices.2.instances.0.commandClasses.133.data.239.nodes = byte[0]
[2013-12-09 18:59:18.630] SETDATA devices.2.instances.0.commandClasses.133.data.239.nodesToFollow = Empty
[2013-12-09 18:59:18.630] SETDATA devices.2.instances.0.commandClasses.133.data.239.nodesToFollow = byte[0]
[2013-12-09 18:59:18.630] Adding job: Association Get
[2013-12-09 18:59:18.631] SETDATA devices.2.instances.0.commandClasses.133.data.240 = Empty
[2013-12-09 18:59:18.631] SETDATA devices.2.instances.0.commandClasses.133.data.240.max = Empty
[2013-12-09 18:59:18.631] SETDATA devices.2.instances.0.commandClasses.133.data.240.max = 0 (0x00000000)
[2013-12-09 18:59:18.631] SETDATA devices.2.instances.0.commandClasses.133.data.240.nodes = Empty
[2013-12-09 18:59:18.631] SETDATA devices.2.instances.0.commandClasses.133.data.240.nodes = byte[0]
( zero-length buffer )
[2013-12-09 18:59:18.631] SETDATA devices.2.instances.0.commandClasses.133.data.240.nodesToFollow = Empty
[2013-12-09 18:59:18.631] SETDATA devices.2.instances.0.commandClasses.133.data.240.nodesToFollow = byte[0]
[2013-12-09 18:59:18.632] Adding job: Association Get
[2013-12-09 18:59:18.633] SETDATA devices.2.instances.0.commandClasses.133.data.241 = Empty
[2013-12-09 18:59:18.633] SETDATA devices.2.instances.0.commandClasses.133.data.241.max = Empty
[2013-12-09 18:59:18.633] SETDATA devices.2.instances.0.commandClasses.133.data.241.max = 0 (0x00000000)
[2013-12-09 18:59:18.633] SETDATA devices.2.instances.0.commandClasses.133.data.241.nodes = Empty
[2013-12-09 18:59:18.633] SETDATA devices.2.instances.0.commandClasses.133.data.241.nodes = byte[0]
[2013-12-09 18:59:18.634] SETDATA devices.2.instances.0.commandClasses.133.data.241.nodesToFollow = Empty
[2013-12-09 18:59:18.634] SETDATA devices.2.instances.0.commandClasses.133.data.241.nodesToFollow = byte[0]
[2013-12-09 18:59:18.635] Adding job: Association Get
[2013-12-09 18:59:18.635] SETDATA devices.2.instances.0.commandClasses.133.data.242 = Empty
[2013-12-09 18:59:18.635] SETDATA devices.2.instances.0.commandClasses.133.data.242.max = Empty
[2013-12-09 18:59:18.635] SETDATA devices.2.instances.0.commandClasses.133.data.242.max = 0 (0x00000000)
[2013-12-09 18:59:18.636] SETDATA devices.2.instances.0.commandClasses.133.data.242.nodes = Empty
[2013-12-09 18:59:18.636] SETDATA devices.2.instances.0.commandClasses.133.data.242.nodes = byte[0]
[2013-12-09 18:59:18.636] SETDATA devices.2.instances.0.commandClasses.133.data.242.nodesToFollow = Empty
[2013-12-09 18:59:18.636] SETDATA devices.2.instances.0.commandClasses.133.data.242.nodesToFollow = byte[0]
[2013-12-09 18:59:18.637] Adding job: Association Get
[2013-12-09 18:59:18.637] SETDATA devices.2.instances.0.commandClasses.133.data.243 = Empty
[2013-12-09 18:59:18.637] SETDATA devices.2.instances.0.commandClasses.133.data.243.max = Empty
[2013-12-09 18:59:18.637] SETDATA devices.2.instances.0.commandClasses.133.data.243.max = 0 (0x00000000)
[2013-12-09 18:59:18.637] SETDATA devices.2.instances.0.commandClasses.133.data.243.nodes = Empty
[2013-12-09 18:59:18.638] SETDATA devices.2.instances.0.commandClasses.133.data.243.nodes = byte[0]
[2013-12-09 18:59:18.638] SETDATA devices.2.instances.0.commandClasses.133.data.243.nodesToFollow = Empty
[2013-12-09 18:59:18.638] SETDATA devices.2.instances.0.commandClasses.133.data.243.nodesToFollow = byte[0]
[2013-12-09 18:59:18.638] Adding job: Association Get
[2013-12-09 18:59:18.639] SETDATA devices.2.instances.0.commandClasses.133.data.244 = Empty
[2013-12-09 18:59:18.639] SETDATA devices.2.instances.0.commandClasses.133.data.244.max = Empty
[2013-12-09 18:59:18.639] SETDATA devices.2.instances.0.commandClasses.133.data.244.max = 0 (0x00000000)
[2013-12-09 18:59:18.639] SETDATA devices.2.instances.0.commandClasses.133.data.244.nodes = Empty
[2013-12-09 18:59:18.639] SETDATA devices.2.instances.0.commandClasses.133.data.244.nodes = byte[0]
[2013-12-09 18:59:18.639] SETDATA devices.2.instances.0.commandClasses.133.data.244.nodesToFollow = Empty
[2013-12-09 18:59:18.640] SETDATA devices.2.instances.0.commandClasses.133.data.244.nodesToFollow = byte[0]
[2013-12-09 18:59:18.640] Adding job: Association Get
[2013-12-09 18:59:18.641] SETDATA devices.2.instances.0.commandClasses.133.data.245 = Empty
[2013-12-09 18:59:18.641] SETDATA devices.2.instances.0.commandClasses.133.data.245.max = Empty
[2013-12-09 18:59:18.641] SETDATA devices.2.instances.0.commandClasses.133.data.245.max = 0 (0x00000000)
[2013-12-09 18:59:18.641] SETDATA devices.2.instances.0.commandClasses.133.data.245.nodes = Empty
[2013-12-09 18:59:18.641] SETDATA devices.2.instances.0.commandClasses.133.data.245.nodes = byte[0]
[2013-12-09 18:59:18.641] SETDATA devices.2.instances.0.commandClasses.133.data.245.nodesToFollow = Empty
[2013-12-09 18:59:18.641] SETDATA devices.2.instances.0.commandClasses.133.data.245.nodesToFollow = byte[0]
[2013-12-09 18:59:18.642] Adding job: Association Get
[2013-12-09 18:59:18.643] SETDATA devices.2.instances.0.commandClasses.133.data.246 = Empty
[2013-12-09 18:59:18.643] SETDATA devices.2.instances.0.commandClasses.133.data.246.max = Empty
[2013-12-09 18:59:18.643] SETDATA devices.2.instances.0.commandClasses.133.data.246.max = 0 (0x00000000)
[2013-12-09 18:59:18.643] SETDATA devices.2.instances.0.commandClasses.133.data.246.nodes = Empty
[2013-12-09 18:59:18.643] SETDATA devices.2.instances.0.commandClasses.133.data.246.nodes = byte[0]
[2013-12-09 18:59:18.644] SETDATA devices.2.instances.0.commandClasses.133.data.246.nodesToFollow = Empty
[2013-12-09 18:59:18.644] SETDATA devices.2.instances.0.commandClasses.133.data.246.nodesToFollow = byte[0]
[2013-12-09 18:59:18.645] Adding job: Association Get
[2013-12-09 18:59:18.645] SETDATA devices.2.instances.0.commandClasses.133.data.247 = Empty
[2013-12-09 18:59:18.645] SETDATA devices.2.instances.0.commandClasses.133.data.247.max = Empty
[2013-12-09 18:59:18.645] SETDATA devices.2.instances.0.commandClasses.133.data.247.max = 0 (0x00000000)
[2013-12-09 18:59:18.645] SETDATA devices.2.instances.0.commandClasses.133.data.247.nodes = Empty
[2013-12-09 18:59:18.645] SETDATA devices.2.instances.0.commandClasses.133.data.247.nodes = byte[0]
[2013-12-09 18:59:18.646] SETDATA devices.2.instances.0.commandClasses.133.data.247.nodesToFollow = Empty
[2013-12-09 18:59:18.646] SETDATA devices.2.instances.0.commandClasses.133.data.247.nodesToFollow = byte[0]
[2013-12-09 18:59:18.647] Adding job: Association Get
[2013-12-09 18:59:18.647] SETDATA devices.2.instances.0.commandClasses.133.data.248 = Empty
[2013-12-09 18:59:18.647] SETDATA devices.2.instances.0.commandClasses.133.data.248.max = Empty
[2013-12-09 18:59:18.647] SETDATA devices.2.instances.0.commandClasses.133.data.248.max = 0 (0x00000000)
[2013-12-09 18:59:18.647] SETDATA devices.2.instances.0.commandClasses.133.data.248.nodes = Empty
[2013-12-09 18:59:18.647] SETDATA devices.2.instances.0.commandClasses.133.data.248.nodes = byte[0]
[2013-12-09 18:59:18.648] SETDATA devices.2.instances.0.commandClasses.133.data.248.nodesToFollow = Empty
[2013-12-09 18:59:18.648] SETDATA devices.2.instances.0.commandClasses.133.data.248.nodesToFollow = byte[0]
[2013-12-09 18:59:18.648] Adding job: Association Get
[2013-12-09 18:59:18.649] SETDATA devices.2.instances.0.commandClasses.133.data.249 = Empty
[2013-12-09 18:59:18.649] SETDATA devices.2.instances.0.commandClasses.133.data.249.max = Empty
[2013-12-09 18:59:18.649] SETDATA devices.2.instances.0.commandClasses.133.data.249.max = 0 (0x00000000)
[2013-12-09 18:59:18.649] SETDATA devices.2.instances.0.commandClasses.133.data.249.nodes = Empty
[2013-12-09 18:59:18.649] SETDATA devices.2.instances.0.commandClasses.133.data.249.nodes = byte[0]
[2013-12-09 18:59:18.649] SETDATA devices.2.instances.0.commandClasses.133.data.249.nodesToFollow = Empty
[2013-12-09 18:59:18.649] SETDATA devices.2.instances.0.commandClasses.133.data.249.nodesToFollow = byte[0]
[2013-12-09 18:59:18.650] Adding job: Association Get
[2013-12-09 18:59:18.650] SETDATA devices.2.instances.0.commandClasses.133.data.250 = Empty
[2013-12-09 18:59:18.651] SETDATA devices.2.instances.0.commandClasses.133.data.250.max = Empty
[2013-12-09 18:59:18.651] SETDATA devices.2.instances.0.commandClasses.133.data.250.max = 0 (0x00000000)
[2013-12-09 18:59:18.651] SETDATA devices.2.instances.0.commandClasses.133.data.250.nodes = Empty
[2013-12-09 18:59:18.651] SETDATA devices.2.instances.0.commandClasses.133.data.250.nodes = byte[0]
[2013-12-09 18:59:18.651] SETDATA devices.2.instances.0.commandClasses.133.data.250.nodesToFollow = Empty
[2013-12-09 18:59:18.651] SETDATA devices.2.instances.0.commandClasses.133.data.250.nodesToFollow = byte[0]
[2013-12-09 18:59:18.652] Adding job: Association Get
[2013-12-09 18:59:18.652] SETDATA devices.2.instances.0.commandClasses.133.data.251 = Empty
[2013-12-09 18:59:18.653] SETDATA devices.2.instances.0.commandClasses.133.data.251.max = Empty
[2013-12-09 18:59:18.653] SETDATA devices.2.instances.0.commandClasses.133.data.251.max = 0 (0x00000000)
[2013-12-09 18:59:18.653] SETDATA devices.2.instances.0.commandClasses.133.data.251.nodes = Empty
[2013-12-09 18:59:18.653] SETDATA devices.2.instances.0.commandClasses.133.data.251.nodes = byte[0]
[2013-12-09 18:59:18.654] SETDATA devices.2.instances.0.commandClasses.133.data.251.nodesToFollow = Empty
[2013-12-09 18:59:18.654] SETDATA devices.2.instances.0.commandClasses.133.data.251.nodesToFollow = byte[0]
[2013-12-09 18:59:18.654] Adding job: Association Get
[2013-12-09 18:59:18.655] SETDATA devices.2.instances.0.commandClasses.133.data.252 = Empty
[2013-12-09 18:59:18.655] SETDATA devices.2.instances.0.commandClasses.133.data.252.max = Empty
[2013-12-09 18:59:18.655] SETDATA devices.2.instances.0.commandClasses.133.data.252.max = 0 (0x00000000)
[2013-12-09 18:59:18.655] SETDATA devices.2.instances.0.commandClasses.133.data.252.nodes = Empty
[2013-12-09 18:59:18.655] SETDATA devices.2.instances.0.commandClasses.133.data.252.nodes = byte[0]
[2013-12-09 18:59:18.655] SETDATA devices.2.instances.0.commandClasses.133.data.252.nodesToFollow = Empty
[2013-12-09 18:59:18.656] SETDATA devices.2.instances.0.commandClasses.133.data.252.nodesToFollow = byte[0]
[2013-12-09 18:59:18.656] Adding job: Association Get
[2013-12-09 18:59:18.657] SETDATA devices.2.instances.0.commandClasses.133.data.253 = Empty
[2013-12-09 18:59:18.657] SETDATA devices.2.instances.0.commandClasses.133.data.253.max = Empty
[2013-12-09 18:59:18.657] SETDATA devices.2.instances.0.commandClasses.133.data.253.max = 0 (0x00000000)
[2013-12-09 18:59:18.657] SETDATA devices.2.instances.0.commandClasses.133.data.253.nodes = Empty
[2013-12-09 18:59:18.657] SETDATA devices.2.instances.0.commandClasses.133.data.253.nodes = byte[0]
[2013-12-09 18:59:18.657] SETDATA devices.2.instances.0.commandClasses.133.data.253.nodesToFollow = Empty
[2013-12-09 18:59:18.658] SETDATA devices.2.instances.0.commandClasses.133.data.253.nodesToFollow = byte[0]
[2013-12-09 18:59:18.658] Adding job: Association Get
[2013-12-09 18:59:18.659] SETDATA devices.2.instances.0.commandClasses.133.data.254 = Empty
[2013-12-09 18:59:18.659] SETDATA devices.2.instances.0.commandClasses.133.data.254.max = Empty
[2013-12-09 18:59:18.659] SETDATA devices.2.instances.0.commandClasses.133.data.254.max = 0 (0x00000000)
[2013-12-09 18:59:18.659] SETDATA devices.2.instances.0.commandClasses.133.data.254.nodes = Empty
[2013-12-09 18:59:18.659] SETDATA devices.2.instances.0.commandClasses.133.data.254.nodes = byte[0]
[2013-12-09 18:59:18.659] SETDATA devices.2.instances.0.commandClasses.133.data.254.nodesToFollow = Empty
[2013-12-09 18:59:18.660] SETDATA devices.2.instances.0.commandClasses.133.data.254.nodesToFollow = byte[0]
[2013-12-09 18:59:18.660] Adding job: Association Get
[2013-12-09 18:59:18.660] SETDATA devices.2.instances.0.commandClasses.133.data.255 = Empty
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.max = Empty
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.max = 0 (0x00000000)
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.nodes = Empty
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.nodes = byte[0]
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.nodesToFollow = Empty
[2013-12-09 18:59:18.661] SETDATA devices.2.instances.0.commandClasses.133.data.255.nodesToFollow = byte[0]
[2013-12-09 18:59:18.662] Adding job: Association Get
[2013-12-09 18:59:18.662] SETDATA devices.2.instances.0.commandClasses.133.data.0 = Empty
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.max = Empty
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.max = 0 (0x00000000)
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.nodes = Empty
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.nodes = byte[0]
[2013-12-09 18:59:18.663] SETDATA devices.2.instances.0.commandClasses.133.data.0.nodesToFollow = Empty
[2013-12-09 18:59:18.664] SETDATA devices.2.instances.0.commandClasses.133.data.0.nodesToFollow = byte[0]
[2013-12-09 18:59:18.664] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.665] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.666] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.667] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.668] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.669] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.670] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.671] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.672] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.673] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.674] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.675] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.676] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.677] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.678] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.679] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.680] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.681] Job 0x13 (Association Get): removing duplicate
[2013-12-09 18:59:18.682] Job 0x13 (Association Get): removing duplicate
Please provide me a bit more
Please provide me a bit more log from above. I see group 0 created - this is a bug - it should not exist (it is (0xff+1) % 0xff).
boomhauser
Re: RaZberry locks up including Cooper Aspire switch
Post by boomhauser »
This is definitely a problem also with Z-Way 1.4 as well. I have 3 Cooper Aspire switches and all of them locked up during inclusion in a similar way. My quick and dirty solution is:
1. Include Aspire switch
2. Wait for the infinite loop problem to occur (60 seconds)
3. ssh to Raspberry and: 'sudo shutdown -r now'
4. when system returns, open old blue interface and navigate to 'devices status'
5. Using the big blue question mark, manually complete all interview items EXCEPT Associations
Now you can mostly use the switch like any other. Obviously associations won't work though.
Is it still in 1.5-rc3? I thought we have fixed this issue.
