How to manage a Scene
SolarFlor
Post by SolarFlor »
Dears,
May I treat a Scene like a Device?
I have just built a scene that is turning on simultaneous more devices (Switches and Plugs). I would like now to manage it as I device for example using a comand like
http://IP:8083/ZAutomation/OpenRemote/S ... aryOff/5/0
Thanks for your help
Re: How to manage a Scene
OpenRemote module uses Z-Way API and not Home Automotion API as basis.
But instead of OpenRemote module you can use irect API calls in the OpenRemote app. Like:
/ZAutomation/api/v1/devices/ZWayVDev_6:0:37/command/off
SolarFlor
Post by SolarFlor »
...but should I associate my Scene to a Device?
your call is working but only for devices but not for Scene
You can do same for Scene - just use Scene Id and command "on". There are also Group Devices module, that allows to group several devices together in one. It acts as ordinary device (switchBinary or switchMultilevel).
SolarFlor
Post by SolarFlor »
PoltoS wrote:You can do same for Scene - just use Scene Id and command "on".
Sorry PoltoS, but could you please edit the following call to work with a LightScene4?
Pipistrello77
Post by Pipistrello77 »
I guess is ...../devices/LightScene_4/....
n0ahg
Post by n0ahg »
/ZAutomation/api/v1/devices/LightScene_4/command/on
SolarFlor
Post by SolarFlor »
Many Thanks
I will try soon
