Installation Problem
pofs
Re: Installation Problem
Post by pofs »
I think you need to replace your RaZberry card. It seems to have wrong firmware loaded.
It seems you have one of the deffective boards manufactured last year 2013. We thought we have revoked all of them. Please ask for RMA with your supplier to exchange it.
marih
Post by marih »
I've similar problems on an existing installation after update to 1.7.0 (and following downgrade 1.5.0.rc3)
I've a Razberry board which worked fine for several months. When I updated to version 1.7.0. z-way-server wouldn't start anymore and the logging is reporting the "Device is not compatible. Terminating…" issue.
Reboot wouldn't fix the issue, so I decided to rollback to version 1.5.0.rc3. But this version which has run stable for several weeks now, has become unstable as well.
After a successful start, with the 'expected correct values" in the logging:
[2014-06-05 21:17:21.112] SETDATA controller.data.APIVersion = "04.02"
[2014-06-05 21:17:21.112] SETDATA controller.data.manufacturerId = 327 (0x00000147)
[2014-06-05 21:17:21.112] SETDATA controller.data.manufacturerProductType = 2 (0x00000002)
[2014-06-05 21:17:21.113] SETDATA controller.data.manufacturerProductId = 3 (0x00000003)
[2014-06-05 21:17:21.128] SETDATA controller.data.vendor = "RaZberry by Z-Wave.Me"
[2014-06-05 21:17:21.128] Supported Function Classes:
[2014-06-05 21:17:21.128] ---------------------------
[2014-06-05 21:17:21.128] 0x02 SerialAPIGetInitData
[2014-06-05 21:17:21.129] 0x03 SerialAPIApplicationNodeInformation
[2014-06-05 21:17:21.129] 0x04 ApplicationCommandHandler
[2014-06-05 21:17:21.129] 0x05 GetControllerCapabilities
[2014-06-05 21:17:21.160] ---------------------------
[2014-06-05 21:17:21.161] Job 0x07 (Get controller info and supported function classes): success
[2014-06-05 21:17:21.161] Adding job: Set Serial API timeouts
[2014-06-05 21:17:21.161] Adding job: WatchDog Start
[2014-06-05 21:17:21.161] Adding job: Get home id and controller node id
within 24 hours the system stops working and is again reporting the incompatible device message, the logging shows then:
[2014-06-05 21:51:28.282] SETDATA controller.data.APIVersion = "00.00"
[2014-06-05 21:51:28.282] SETDATA controller.data.manufacturerId = 0 (0x00000000)
[2014-06-05 21:51:28.282] SETDATA controller.data.manufacturerProductType = 0 (0x00000000)
[2014-06-05 21:51:28.282] SETDATA controller.data.manufacturerProductId = 0 (0x00000000)
[2014-06-05 21:51:28.288] SETDATA controller.data.vendor = "Sigma Designs"
[2014-06-05 21:51:28.288] Supported Function Classes:
[2014-06-05 21:51:28.288] ---------------------------
[2014-06-05 21:51:28.288] 0xd2 WatchDogStart
[2014-06-05 21:51:28.288] 0xf0 UNKNOWN
[2014-06-05 21:51:28.288] 0xf1 UNKNOWN
[2014-06-05 21:51:28.289] 0xf2 ZMEFreqChange
[2014-06-05 21:51:28.289] 0xf3 ZMERestore
[2014-06-05 21:51:28.289] SETDATA controller.data.capabilities = int[5]
[2014-06-05 21:51:28.289] [00] 210
[2014-06-05 21:51:28.289] [01] 240
[2014-06-05 21:51:28.289] [02] 241
[2014-06-05 21:51:28.289] [03] 242
[2014-06-05 21:51:28.290] [04] 243
[2014-06-05 21:51:28.290] ---------------------------
[2014-06-05 21:51:28.290] Initialization done
[2014-06-05 21:51:28.290] Job 0x07 (Get controller info and supported function classes): success
[2014-06-05 21:51:28.290] Device is not compatible. Terminating…
after some restarts/reboots and register clean with the echo command: echo -ne "x01x04x00x42x01xB8" > /dev/AMA0
it will run again for some hours. But after a while the whole story repeats.
Is this due to a defective board or is this something else?
I see in my logging many errors with a Meter get (v2) command:
2014-06-05 06:26:11.308] Executing script: OpenRemote("/MeterValue/4/0/2", { ...
[2014-06-05 06:26:11.318] Adding job: Meter get (v2)
[2014-06-05 06:26:11.321] Adding job: Meter get (v2)
[2014-06-05 06:26:11.322] SENDING (cb 0x49): [2014-06-05 06:26:11.326] Executing script: OpenRemote("/MeterValue/4/0/0",
( 01 0A 00 13 04 03 32 01 00 25 49 BE )
[2014-06-05 06:26:11.336] RECEIVED ACK
[2014-06-05 06:26:11.340] Adding job: Meter get (v2)
[2014-06-05 06:26:11.340] Job 0x13 (Meter get (v2)): removing duplicate
[2014-06-05 06:26:11.345] Executing script: OpenRemote("/SwitchBinaryStatus/17/1", { ...
[2014-06-05 06:26:11.353] RECEIVED: ( 01 04 01 13 00 E9 )
[2014-06-05 06:26:11.354] SENT ACK
[2014-06-05 06:26:11.356] Job 0x13 (Meter get (v2)): Could not be delivered to Z-Wave stack
[2014-06-05 06:26:11.362] Executing script: OpenRemote("/SwitchBinaryStatus/23/1", { ...
[2014-06-05 06:26:11.369] SENDING (cb 0x4a): ( 01 0A 00 13 04 03 32 01 00 25 4A BD )
[2014-06-05 06:26:11.393] RECEIVED ACK
[2014-06-05 06:26:11.393] Executing script: OpenRemote("/SwitchBinaryStatus/20/2", { ...
[2014-06-05 06:26:11.404] RECEIVED: ( 01 04 01 13 00 E9 )
[2014-06-05 06:26:11.404] SENT ACK
[2014-06-05 06:26:11.405] Job 0x13 (Meter get (v2)): Could not be delivered to Z-Wave stack
[2014-06-05 06:26:11.417] SENDING (cb 0x4b): ( 01 0A 00 13 04 03 32 01 00 25 4B BC )
[2014-06-05 06:26:11.427] RECEIVED ACK
[2014-06-05 06:26:11.438] RECEIVED: ( 01 04 01 13 00 E9 )
[2014-06-05 06:26:11.438] SENT ACK
[2014-06-05 06:26:11.439] Job 0x13 (Meter get (v2)): Could not be delivered to Z-Wave stack
[2014-06-05 06:26:11.439] Job 0x13 (Meter get (v2)): Removing job due to too much retransmitions
[2014-06-05 06:26:11.439] Job 0x13 (Meter get (v2)): fail
[2014-06-05 06:26:11.439] Removing job: Meter get (v2)
I'm not sure whether this is the cause of the z-way-server crash or a result of a failing z-way-server.
Your RaZberry seems to be dying... Maye be static discharge or something else killed it. sometimes it reports you wrong data:
This means device have not compatible functions to send packets and recieve them. This is a UART problem or chip problem. Try to clean your RaZberry with a 95% spirit. May be it will help. Or it was broken by ESD...
