/ZAutomation/api/v1/devices not reflecting true device state
mjm
Post by mjm »
I'm currently running v1.7.1 and I'm trying to use the REST API to set and read some Duwi switches. This works with commands like
http://razberry.local:8083/ZAutomation/api/v1/devices/ZWayVDev_2:0:37/command/on
I can query the status of the switches with:
. So far so good.
The problem is that when I use the manual on/off switches on the Duwi switches the old on/off status is reported, not the actual status.
How can I force an update?
TIA
Marcel
SolarFlor
Re: /ZAutomation/api/v1/devices not reflecting true device s
Post by SolarFlor »
mjm wrote: How can I force an update?
I had a similar problem with the switch AEON MES. The problem was that the device was not reporting the status to the controller. I have solved the issue (thanks to sdh) by setting the parameter 80 to 2.Maybe a similar setting is needed in your case as well
viewtopic.php?f=3422&t=20462
mjm
Post by mjm »
Thanks for the suggestion. Unfortunately where in the UI I would set the magical parameter 80 (which seems to be vendor specific?).
Is the blue UI supposed to auto update the switch state in the UI? In my case it doesn't; I have to press update. Weird, I seem to remember that updates were automatic in the past. I'm not sure.
Isn't there a software command to have the Razberry update it's values?
The UI (both) update the value once it get it. It get it only
1) if s/w sends a Get (once you press Update or Set button) or
2) if the device sends it unsolicited. Parameter 80 in Aeon changed it. It is manufacturer specific.
mjm
Post by mjm »
OK, thx. But what is the best way to do a 'get''?
Obviously commands like the following don't:
http://razberry.local:8083/ZAutomation/api/v1/devices/ZWayVDev_2:0:37/command/status
