Razberry/OpenRemote Commands
SubnetMask
Post by SubnetMask »
I've noticed in the Expert UI, there are options to allow you to manually send various supported commands to modules. In trying to set up OpenRemote, the main challenge I've faced is figuring out the commands to send. In the case of dimmers and Binary Switches, the commands weren't too difficult to get figured out. But the latest challenge is the Aeon Smart Smart Energy Switches that I have that can report wattage and kWh usage.
Would there be any way to make it possible to see the OR command that would be sent to the device to accomplish the desired function, such as in the case of this energy smart switch, the 'SensorMultilevel' get and 'Meter' get & reset?
pz1
Re: Razberry/OpenRemote Commands
Post by pz1 »
I assume you have read the instructions in the Recipe forum here, and from there on OpenRemote. If you want to know what goes behinde the scenes, look into automation/modules/OpenRemoteHelpers/index.js
