Switch all on/off mode Settings for Fibaro FGS-211 Swithes and FGS-221 Switches are ignored by expert ui. I can Change the Settings to whatever I want. Expert UI does not show the little green Icon for this feature.
I am as well wondering why we have for instance Parameter 1 in FGS-221 which appears to be the same as the Parameter block with similar namings at the end of configuration.
Trying to compare the behaviour with blue ui I noticed following error message if I try to change configuration:
>> Command execution failed due to some error on the Server. Internal Server Error <<
I could not see anything Special in the z-way-Server log
V2.0.0. Editing Switch All on/off mode fails
Z-Way 2.0.0-final on Raspberry Pi
Re: V2.0.0. Editing Switch All on/off mode fails
nobody of zway team interested in this misbehaviour?
If my explanation is unclear, let me know.I am happy to provide more and better explanations.
Please capture network request details (in your browser developer tools) when you get "Command execution failed" message.
Also try to send on/off from url and see if it works: http://ip:8083/ZWaveAPI/Run/devices[x].SwitchAll.SetOn()
It is a bit unclear about parameter 1, so provide some details/screenshots please.
Unfortunately I do not know how to upload screen shots into this forum . I will send you a better explanation via Email.
