Setting the password for Z-wave configuration interface
mickpc
Post by mickpc »
I am getting an error when trying to reset the password for the intial setup of the razberry.
I get the following error:
Err(1.18.3): main.c: 528: The spawned process 'bash:/etc/init.d/zbw_connect restart_with_delay 2' has exited with code 127 and says:
/etc/init.d/zbw_connect: line 2: START_OF_EMBEDDED_DATA: command not found
/etc/init.d/zbw_connect: line 3: -----BEGIN: command not found
/etc/init.d/zbw_connect: line 4: MIIEpQIBAAKCAQEA01GBq5PBX3Ioz02wydlQ71IXSbMc98aAIqUJGvDHl4cfXzql: command not found
/etc/init.d/zbw_connect: line 5: en+VK04aCmK1VwNttBPSjpQXyUL8ry7pZp6bjifsRTSc5M7ItRqYon0tVMFzxfzV: command not found
/etc/init.d/zbw_connect: line 6: RmfnyJjtLxHoTAp45L3jp2bcujOuUAXOCr1Cl7CpFsmoUxfBnmq51J7I97aEEidr: command not found
/etc/init.d/zbw_connect: line 7: i3y86H0d7vWpPb6S+voDdVrrSjaXbiViYayNgZX0icuC2NSI92R8Q38DGK672kq/: No such file or directory
/etc/init.d/zbw_connect: line 8: VMqMhs9JUREq1waPpbCnhiZLN/a+2Y8AgpFBn9FqSyk6W+XrdZW81ZGY7pJaXttf: No such file or directory
/etc/init.d/zbw_connect: line 9: 1hKnGiKPH8C1Lwo+IGPRisP/C165FegD1hzBSQIDAQABAoIBAEgx0nFB25C2OccJ: No such file or directory
/etc/init.d/zbw_connect: line 10: LdroCcSZcSdWsBDemiw74e54UFgua8NnD93X9KiE2FSwAHAn1bTuCMN5SN8TqaxY: command not found
/etc/init.d/zbw_connect: line 11: BJlwmohoj0ndfbSWCPAGlBr/VRtdtCXyCRMysHdR98ZbAdfoxACx9zLb65EZ0vW3: No such file or directory
/etc/init.d/zbw_connect: line 12: 5fq5SiT0z+/fGUi6FwX+RFqlnNczvseGmXua3kYUh244ILqethu8qqCGCY+YPCUU: No such file or directory
/etc/init.d/zbw_connect: line 13: TlHSW6LU9EeG7HgM9aKFDLf6I5T3LevenANM4nfylMx14S5eQvwNe5SS/OAB5DCB: No such file or directory
/etc/init.d/zbw_connect: line 14: uzKcQSok7sHHEy6aU9FUj0So0MMLDIUj8GDW2+NzY9cJTLZ6/cdx4l0dryKmEs8d: No such file or directory
/etc/init.d/zbw_connect: line 15: UMa+qDkCgYEA8TSXD7pgpaA2fJHMETzyEbSOsegPjEB2c8em7CXQ6qUwhirGlApO: command not found
/etc/init.d/zbw_connect: line 16: KH3kqmOF6K3Y/KfkLf+AwbQUQ8ayCLdpxELVOQka6qUFT6tsAc7uK4RB1hAJ/HjJ: No such file or directory
/etc/init.d/zbw_connect: line 17: SkorRnH9xjHYFynX259zwIdKV6iDCLpt6IlakIU3Te6sY/z1qddPjHcCgYEA4Eeh: No such file or directory
/etc/init.d/zbw_connect: line 18: OSXIlK0Q5cwesrQhilNOuu8XKgNN5Z58OkwKUIw3bqPb7oVsrXO6mP33GI1sryHK: command not found
/etc/init.d/zbw_connect: line 19: +saKPDCif9K9MNjj36SeSdqz3sR85mfyPr/PCjwlTdwn5cKTw39VsSrASLBKN64F: No such file or directory
/etc/init.d/zbw_connect: line 20: w1F/offP7IZMJsxhA3IKZki134GS09CR8ax8UD8CgYEA8DromQmPaGYA3mB3VlPU: No such file or directory
/etc/init.d/zbw_connect: line 21: 5D1oQVhW4+DwGLAoV9nyEUEk6vt/e8InxbxdGja1D+DV1A2C/S0UF9g6tqYWewfx: No such file or directory
/etc/init.d/zbw_connect: line 22: lz7ZDk07OafRel/I2qQ2IbE/wOuIhqPmFs93+lld3x+VkLxj+KD+sCoOqO90UiUb: No such file or directory
/etc/init.d/zbw_connect: line 23: ghYK1RVY1412tL8kDVwcJlECgYEAh7QPoypvcTY+cSzOrkY7vRynGIiuNWeGbJc2: command not found
/etc/init.d/zbw_connect: line 24: h3eXDiGpMLLI0ku89D5/+y4/ooV/63/A93fGEKFE0Z7LhpDVYG6UsA86omG1SRxA: No such file or directory
/etc/init.d/zbw_connect: line 25: ASPBvGmkELZTFbxj9/hF+0royZKRdZtANWxMk84D6xNfZGJpmNIZ5MW99hzKoIsk: No such file or directory
/etc/init.d/zbw_connect: line 26: o1xAY7UCgYEAq9DaeFzkpcs430r4i7nyQ+c0kW5k/CPvn40TXZ8uPdoWCRLt7wx1: No such file or directory
/etc/init.d/zbw_connect: line 27: vkB/LSd2jBp6xmF8QCfjL3QYgXZe6ycDRoLETwdIoSogVBB1KayvaXvXJlh4Wu5r: No such file or directory
/etc/init.d/zbw_connect: line 29: -----END: command not found
mickpc
Re: Setting the password for Z-wave configuration interface
Post by mickpc »
Can anyone tell me the default password? Please.
There is no default password. What do you want to do? Set password for find.z-wave.me?
mickpc
Post by mickpc »
Correct, however when I enter the password and click I get the error abouve.
This is ti change password for remote access, not for ssh.
Can you provide access to SSH exposing it to the internet? (but change password from default of Raspbian, please!!!). We will have a look what has gone wrong and fix it. (please send credentials via mail)
