Error handling data from server
yesterday I had a blackout and when the power came back the Razberry stopped to work.
Raspberry is still working (I have other codes running) but when I run http://192.168.1.22:8083/expert/#/ i see the following message Error handling data from server.
Of course all automations are not working any more.
How I could check if the problem is in the RaZberry or in some files corrupted?
Thanks for your support
Re: Error handling data from server
I have also replaced the Raspberry but still not working. At this point I strongly believe that is the RaZberry board that failed.
What version do you use?
1. You can make a backup of your z-way-server directoy and reinstall it (your user data should remain unchanged after re-installation).
2. You can change /etc/init.d/z-way-server
Remove in the 'start)' section and see what is logged on start z-way-server to console.
3. Also you can provide a /var/log/z-way-server.log for inspection
Remove
> /dev/null 2>&13. Also you can provide a /var/log/z-way-server.log for inspection
Razberry B+ 2.0.1-rc25 on ZW500 + 15 devices / Razberry B 2.0.1-rc25 on ZW300 for test
Hi dolpheen,
my RaZberry is an old version (3rd generation I believe).
Not sure what you mean at point 1 and 2.
below the last lines in the log files
[2015-03-07 13:19:32.154] [I] [core] Loading module Notification from modules/Notification
[2015-03-07 13:19:32.169] [I] [core] Executing script: /*** Notification Z-Way HA module ******************************************* ...
[2015-03-07 13:19:32.171] [I] [core] Loading module ImportRemoteHA from modules/ImportRemoteHA
[2015-03-07 13:19:32.186] [I] [core] Executing script: /*** ImportRemoteHA Z-Way HA module ******************************************* ...
[2015-03-07 13:19:32.199] [I] [core] Loading module TagOnOff from modules/TagOnOff
[2015-03-07 13:19:32.203] [I] [core] Executing script: /*** TagOnOff Z-Way HA module ******************************************* ...
[2015-03-07 13:19:32.206] [I] [core] Loading module CodeDevice from modules/CodeDevice
[2015-03-07 13:19:32.221] [I] [core] Executing script: /*** CodeDevice Z-Way HA module ******************************************* ...
[2015-03-07 13:19:32.224] [I] [core] Loading module LightScene from modules/LightScene
[2015-03-07 13:19:32.240] [I] [core] Executing script: /*** LightScene Z-Way HA module ******************************************* ...
[2015-03-07 13:19:32.242] [I] [core] Starting automation...
[2015-03-07 13:19:32.473] [I] [core] Starting storage...
[2015-03-07 13:19:32.485] [I] [core] ZWay Automation started
done but I don't remember how to stop start z-way from the consoledolpheen wrote: 2. You can change /etc/init.d/z-way-server
Removein the 'start)' section and see what is logged on start z-way-server to console.Code: Select all
> /dev/null 2>&1
I meant to install a razberry dist (with version you have before).Not sure what you mean at point 1 and 2.
Ex.
wget -q -O - razberry.z-wave.me/install/v2.0.0 | sudo bashdone but I don't remember how to stop start z-way from the console
sudo /etc/init.d/z-way-server stopCode: Select all
sudo /etc/init.d/z-way-server startWhat do you have on http://192.168.1.22:8083/?
What is console output for 'netstat -a' command while z-way-server is running?
This is what I can see when I start Z-way after editing the /etc/init.d/z-way-server
root@raspberrypi:/opt/z-way-server# sudo /etc/init.d/z-way-server stop
Stopping z-way-server: done.
root@raspberrypi:/opt/z-way-server# sudo /etc/init.d/z-way-server start
Starting z-way-server: done.
root@raspberrypi:/opt/z-way-server# Z-Way version v2.0.0 from 2014-12-08 19:54:26 +0300 (build a064f5408850947aed035bc9170e1fa04f0fd2ec)
Module modws.so loaded
Module modenocean.so loaded
Module modzwave.so loaded
Module moddhs.so loaded
Module modhomekit.so loaded
cURL 7.26.0 likely has DNS timeout bug. Please update cURL. Disabling sync DNS timeouts for now.
Module modhttp.so loaded
Looks like everything is OK. ('debug-port' error is not related to your problem)SolarFlor wrote:This is what I can see when I start Z-way after editing the /etc/init.d/z-way-server
Done but during the loading of the code the following meessage appeareddolpheen wrote: I meant to install a razberry dist (with version you have before).
Ex.Code: Select all
Err http://mirrordirector.raspbian.org wheezy Release.gpg
Could not connect to mirrordirector.raspbian.org:80 (5.153.225.207), connection timed out
- Presentazione1.jpg (21.5 KiB) Viewed 14893 times
I have repeated the download and everything were ok without error messages (maybe it was a problem with internet).
Anyway still the system is not working
"Error Handling data from server"
