raZberry and prosyst
stou
Post by stou »
I installed the raZberry on my raspberry pi. Everything works fine with the UI access http://IP_OFRASPBERRY:8083 .
I work with the prosyst SDK and my problem is when I would like to configure the z-wave driver bundle in the prosyst web admin console, I always have this error : "org.osgi.service.cm.ConfigurationException: port : Port /dev/ttyAMA0 does not exist"
Is the raZberry compatible with the prosyst environnement? Do you know what's the problem on /dev/ttyAMA0 ? I give access to the user pi on /dev/ttyAMA0 ...
Thank you
pofs
Re: raZberry and prosyst
Post by pofs »
We have never tested it, but it should be compatible.
Just don't forget to stop z-way-service before running another controller software on /dev/ttyAMA0
