I used the config interface on port 8084 to disable remote access.
However, when the system reboots this setting changes back to enabled.
Is there any way to make it permanently disabled?
Problem occurs on 2.0.1.
Thank you.
"Activate Remote Access" disabled not sticky across reboot
Re: "Activate Remote Access" disabled not sticky across rebo
I tested this recently on my own rig for someone else, and found it working correctly.
I do use v2.02-rc1
I do use v2.02-rc1
Happens to me also, see:
https://forum.z-wave.me/viewtopic.php?f=3419&t=21879
In my second post, there's a solution.
Cheers,
Patrick
Cheers,
Patrick
