I have several actors added to the razberry controller, which have not the correct UI trigger, switch, scale, and wrong position values.
Roller Shutter FGRM-222 -> Has a simple ON/OFF Switch like light Bulbs, but its a Blind Controller with Actions like:
UP/DOWN/Pause
FAKRO FAK_ZWS230 -> It is a Window Motor. The device Interview cannot be completed. Action switch with UP/DOWN is shown correct, but the Position value shown as brightness isn´t correct.
Is there a way to include these actors with better functionality?
May be modifying the command class of actors or something else?
Dave
Problem with wrong actor properties
Re: Problem with wrong actor properties
also, when FAKRO FAK_ZWS230 is included to raZberry, the HomeKit Gate module doesn´t work anymore?
