How to upgrade RaZberry firmware?
Re: How to upgrade RaZberry firmware?
in fact, a simple chip reboot would be enough. Freq change does it too, so it worked for you
Where do you set the frequency?
I assume it is stored in some config file, but what is the name and location of the file?
How come "Start inclusion" wont work anymore efter upgrade? I can use "start exclusion" but only gets error when trying to add devices.
Errormessage follows: "Error handling data /Zwave.zway/Run/controller.AddNoteToNetwork(1)"
Same behaviour as before, when I didnt have a licensecode applied to my UZB1.
Log in first an then go to https://find.z-wave.me/expert/#/network/control.G400 wrote:Where do you set the frequency?
In the bottom left you can select your frequency.
Hi, have got the same problem, after upgrading. Have you find the solution? To confirm the EU freq do not seems to be the right solution.....in may case.gabrielb wrote:How come "Start inclusion" wont work anymore efter upgrade? I can use "start exclusion" but only gets error when trying to add devices.
TK
these 2 post are connected!!
read: https://forum.z-wave.me/viewtopic.php?f=3419&t=22296
I have a problem with upgrade the firmware (bootloader upgrade) at my new razberry (Update bootloader for 01.00 to 538d).
The installed software is v.2.2.1.
When I tried tu upgrade the firmware, it comes "Error handling data" and at the log:
[2016-03-07 21:29:26.490] [core] Failed to download bootloader: Not Found
[2016-03-07 21:29:28.590] [core] Failed to download bootloader: Not Found
Can I download and install the bootloader upgrad manually?
Bye
herbert
Bye
herbert
Yes, please? I really want to upgrade my firmware but I can not. I'm very frustrated as I always have to manually complete interview results.herbert-f wrote: Can I download and install the bootloader upgrad manually?
PoltoS... Why do you just ignore everyone with same problem, Bootloader/Firmware upgrade error "Error handling data"
Well I dont care anymore, I will look for another brand controller and move to Windows based installation.
Could be fun to end the Razberry suffering in the MWO.
Bye!
Bye!
If you have problems like this, go to the place where you bought it. In most legislations the shop where you bought it is the first responsible. It is their duty to deliver you a functional product. Many shops (especially webshops) are evading that responsibility. Just as most software vendors do. If something is broken in their software the advise is to buy the upgrade. Your garage doesn't get away with such an answer. Still the law is equally applicable to garages and software/computer vendors....
v2.1.1 raspi2
