I just received this morning ZWave dongle (usb) and i tried without success to used it/
I reinstalled my SD and plugged the dongle.
On the zway log, there is :
Opened device: /dev/ttyAMA0
[D] [zway] Worker thread successfully created
[D] [zway] Worker thread entry point
[zway] Adding job: Get controller info and supported function classes
[D] [zway] SENDING: ( 01 03 00 07 FB )
[zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[C] [zway] Get Serial API Capabilities returned zero.
[zway] Removing job: Get controller info and supported function classes
[D] [zway] Worker thread exit point
[D] [zway] Worker thread successfully finished
[E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
Part of messages log :
May 26 10:11:23 raspberrypi kernel: [ 110.129102] usb 1-1.2: new full-speed USB device number 10 using dwc_otg
May 26 10:11:23 raspberrypi kernel: [ 110.589103] usb 1-1.2: new full-speed USB device number 11 using dwc_otg
May 26 10:11:24 raspberrypi kernel: [ 111.049124] usb 1-1.2: new full-speed USB device number 12 using dwc_otg
May 26 10:11:24 raspberrypi kernel: [ 111.549099] usb 1-1.2: new full-speed USB device number 13 using dwc_otg
May 26 10:11:25 raspberrypi kernel: [ 112.209109] usb 1-1.2: new full-speed USB device number 14 using dwc_otg
May 26 10:11:25 raspberrypi kernel: [ 112.312434] usb 1-1.2: New USB device found, idVendor=0658, idProduct=0200
May 26 10:11:25 raspberrypi kernel: [ 112.312459] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
May 26 10:11:25 raspberrypi kernel: [ 112.313620] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
My knowledge in linux are verry basic, i think my usb dongle id detected by linux.
I already try to change the dongle on another usb port, with the same issue.
I don't know where is the problem.
Somebody could help me ?
Thanks in advance.
