z-Way Server stops working
kandalf
Post by kandalf »
i have a new installation from sd image. Upgrade to version 2.2.1.
Now i have the problem the z-way server stopps running after a few hours.
The last entry from the log file are normal:
2016-06-08 08:00:50.537] [core] [ConditionSwitch-42] Calculating switch condition
[2016-06-08 08:00:50.544] [core] Notification: device-info (device-status): {"dev":"Solar altitude","l":"21.8 °"}
[2016-06-08 08:00:50.720] [core] Notification: device-info (device-status): {"dev":"Solar azimuth","l":"80.2 °"}
[2016-06-08 08:00:51.069] [core] [BaseModule-36] Set lastLevel to 21.81317497695942 for Astronomy_41_altitude (was 21.658466139998698)
[2016-06-08 08:00:51.140] [core] [BaseModule-36] Set lastLevel to 80.1880406008483 for Astronomy_41_azimuth (was 80.004337050274)
When i look at the process list there ist no running z-way-server :-(
/etc/init.d/z-way-server start starts the server but after some time he finished :-(
Anybody an idea?
Raspberry PI with Z-Wave.me Board
2 x Fibaro Double Relay-Switch FGS 222
2 x Fibaro Shutter FGR 222
Fibaro Multi Sensor
Z-Wave.me RemoteControl
kandalf
Re: z-Way Server stops working
Post by kandalf »
Hello together,
nobody any idea?
The problem is really crazy because when the z-way-server is not running i have no action from z-wave to my devices!
In the last 4 days i have this problem two times! Please help.
I use Debian Jessie with z-way 2.2.1.
I don't hink, that it is a problem from the astronimie modul but in the log files i can't see any hint why the server is crashing or stopping his work.
Fibaro Multi Sensor
kandalf
Post by kandalf »
So, yesterday i install a fresh sd card with the z-wave image.
Update version to 2.2.2 and recover the configuration.
All that changes ntohing to my problem. After some hours the z-way-server doens't run. If i look at the process list there is no z-way-server.
When i start it with z-way-server start he ist running for some hours.
What can i do? Is there is solution to restart the z-way-server automatically when he is stopping?
I need help because when the server is offline the complete z-wave functions are inactive :-(
Fibaro Multi Sensor
kandalf
Post by kandalf »
I have antoher information.
I can see with htop that "z-way-server" and "/etc/init.d/readKey start" use 100% CPU time.
I think this is not normal!?
Fibaro Multi Sensor
Hazard
Post by Hazard »
I've experienced this as well, but not as frequent as you have. It is more about 1x a month. I've noticed that the zway server stopped working after the router was shutdown / wireless connectivity has dropped. I've experienced this at least two times. Can you confirm that you can traceback your issue to connectivity matters?
After I restarted the PI everything works as expected.
kandalf
Post by kandalf »
my PI use not WLAN but ethernet direct at the router. In our house i have three Router, one main and 2 accesspoints.
On one accesspoint the pi is connect directly. WLAN swichted off in the night but the server is crashing on other times.
I have generate a script and cronjob which check the z-way-server and restart it when stopped.
Here are the logs how often the z-way-server was restarted:
[2016-06-20 13:30] z-way-server wurde neu gestartet
[2016-06-20 19:30] z-way-server wurde neu gestartet
[2016-06-21 06:35] z-way-server wurde neu gestartet
I don't know if it has someting to do with the router? But i test it on two places with connection to different routers and i have the same problem.
Fibaro Multi Sensor
kandalf
Post by kandalf »
So, last information.
I start with a complete new installation. SD Card with razberry image, update system and install version 2.2.2.
Than i reset and include all my devices. After this fresh installation all is running fine, no problems with the rules and noch crash from the z-way-server. So i don't know where is the difference between the installation before and now and i think its not easy to find it out. Hardware is the same as before.
Fibaro Multi Sensor
If you experience Z-Way crashes again, please collect logs and as much as you can (may be backtrace in gdb) and send us. This will help us to locate the bug.
We have fixed recently one problem that can lead to a crash, but from your description it is different from the one you experience.
fundy
Post by fundy »
Hi there I'm on 2.3.0 zway on RPI 3/razberry and the zway server constantly crashes in 1-2 max days. I don't see anything interesring or extraordinary in logs. RPI still works after zway crash and can be logged in via ssh. Do you have any ideas how to troubleshoot the problem. Where to start... It's so annoying that the platform is not really usable for any daily automation. And I don't think it's appropriate to check by cron periodically if zway server happend to crash and relaunch it if necessary. Any suggestions?
Many thanks
AlphaX2
Post by AlphaX2 »
Did it happen on a specific time? You may have seen my post, were it happens around 3 AM in the morning. But I'm using RaspberryPi 2 B+ version with RaZBerry V1 and Z-Way 2.3.0.
