Razberry 2 defective?
lacagoule91
Post by lacagoule91 »
Good afternoon !
Yesterday I received a Razberry 2 module. I plugged it on a Raspberry PI 2 B and installed Z-way and Domoticz. I noticed Domoticz was unable to include any z-wave device (for example a Fibaro Motion Sensor ZW5) and gave me some timeout errors.
I decided to check in Zway, and everytime I try to add a device I get the famous "Smarthome UI error". It seems like the razberry is not responding.
Here's a copy of the /etc/var/z-way-server.log. You'll notice it can't find any hardware info :
[2017-06-14 13:15:33.819] [C] [i/o] Failed to open device /dev/ttyACM0: No such file or directory
[2017-06-14 13:15:33.819] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2017-06-14 13:15:33.865] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Invalid port
[2017-06-14 13:15:33.869] [core] Loading module Cron from modules/Cron
[2017-06-14 13:15:33.873] [core] Executing script: /*** Cron ZAutomation module ************************************************** ...
[2017-06-14 13:15:33.883] [core] Instantiating module 2 from class Cron
[2017-06-14 13:15:33.886] [core] --- Starting module System Clock (CRON)
[2017-06-14 13:15:33.897] [core] Loading module ThermostatDevice from modules/ThermostatDevice
[2017-06-14 13:15:33.900] [core] Executing script: /*** ThermostatDevice Z-Way HA module ******************************************* ...
[2017-06-14 13:15:33.902] [core] Loading module LogicalRules from modules/LogicalRules
[2017-06-14 13:15:33.907] [core] Executing script: /*** LogicalRules Z-Way HA module ******************************************* ...
[2017-06-14 13:15:33.911] [core] Loading module InbandNotifications from modules/InbandNotifications
[2017-06-14 13:15:33.917] [I] [core] Executing script: /*** InbandNotifications Z-Way HA module ******************************************* ...
[2017-06-14 13:15:33.925] [I] [core] Instantiating module 3 from class InbandNotifications
[2017-06-14 13:15:33.929] [I] [core] --- Starting module Inband Notifier
[2017-06-14 13:15:33.942] [I] [core] Loading module InfoWidget from modules/InfoWidget
[2017-06-14 13:15:33.963] [I] [core] Executing script: /*** InfoWidget Z-Way HA module ******************************************* ...
[2017-06-14 13:15:33.978] [I] [core] Instantiating module 5 from class InfoWidget
[2017-06-14 13:15:33.980] [I] [core] --- Starting module Information Widget
[2017-06-14 13:15:33.993] [I] [core] Creating device text InfoWidget_5_Int
[2017-06-14 13:15:34.033] [I] [core] Loading module CustomUserCode from modules/CustomUserCode
[2017-06-14 13:15:34.036] [I] [core] Executing script: /*** CustomUserCode ZAutomation module **************************************** ...
[2017-06-14 13:15:34.038] [I] [core] Loading module SwitchControlGenerator from modules/SwitchControlGenerator
[2017-06-14 13:15:34.044] [I] [core] Executing script: /*** SwitchControlGenerator Z-Way HA module ******************************************* ...
[2017-06-14 13:15:34.052] [I] [core] Instantiating module 8 from class SwitchControlGenerator
[2017-06-14 13:15:34.057] [I] [core] --- Starting module Trap events from Remotes and Sensors
[2017-06-14 13:15:34.064] [I] [core] Loading module CustomUserCodeLoader from modules/CustomUserCodeLoader
[2017-06-14 13:15:34.071] [I] [core] Executing script: /*** CustomUserCodeLoader ZAutomation module **************************************** ...
[2017-06-14 13:15:34.073] [I] [core] Loading module FosCam9805 from modules/FosCam9805
[2017-06-14 13:15:34.077] [I] [core] Executing script: /*** FosCam9805 Z-Way HA module ************************************
Any help would be appreciated, as I'm not really a UNIX expert ;)
Thank you in advance !!!
Capture d’écran 2017-06-14 à 13.22.23.png (88.88 KiB) Viewed 6894 times
Re: Razberry 2 defective?
Why ttyACM0? With RaZberry it should be ttyAMA0
