hi you
i'm beginner with z-way me
to day i installed z-wave me on raspberry pi 3
and i try to find Fibaro Double Switch 2 but it have error
I have configured /dev/ttyAMA0 for RaZberry Daughter Card and set fequency is EU but it can't find fibaro swich
so what is my problem and how to fix it?
thanks so much to any help
Fibaro and zway connect
- fibaro sw.png (507.99 KiB) Viewed 14733 times
- connect.png (124.96 KiB) Viewed 14733 times
- Untitled.png (629.45 KiB) Viewed 14733 times
Re: Fibaro and zway connect
that may log : https://drive.google.com/open?id=0BzyRU ... FZKMGtzSXc
im sory bacause I can not upload directly
and the img when i find device
thanks you for your reply
- Untitled4.png (670.25 KiB) Viewed 14717 times
Nothing strange in the log. RaZberry just don't see anything from your Fibaro Switch.
We have seen this with Fibaro FGS/FGD modules - try to do factory reset according to their manual. And then they should include flowlessly.
Hi Polto,
I tried again with razberry daughter card but it not suscess and i try with uzb
but when i inclusion device it have error "z-wave Expert UI error : unable to update data controller : addNote To netwwork [1]" and blue LED is not bright
when i exclusion device- LED is bright
i don't know my uzb work ?
and how to my zwave inclusion device
thanks for your help
- zwave uzb.png (676.21 KiB) Viewed 14644 times
- zwave err2.png (697.19 KiB) Viewed 14644 times
- zwave err.png (614.25 KiB) Viewed 14644 times
Your donlge looks to have no license loaded in it. Check controller info page and license button
hi Polto
sorry for my stupid question but i can't find license button and controller info page
and what is license on uzb1 ?
thanks for help
thanks for help
The license button is under controller info page
thanks you so much
I've found license button but I have not found license on uzb1 box
so do i must buy license and I can have it where and how ?
thanks so much
thanks so much
It can happen that you bought the UZB1 without license. It is cheaper than the one with. You can always buy the license separatelly.
