background noise level
tin921
Post by tin921 »
how to disable or change the interval?
tin921
Re: background noise level
Post by tin921 »
any ideas anyone?
Does it harm you?
tin921
Post by tin921 »
that by itself doesn't. but i am trying to understand z-wave and zway as much as possible. i am reading the log file and trying to understand every print and data payload. but the log from noise reading is occupying too much. or what's the exact print i can ignore?
ibjr
Post by ibjr »
@PoltoS; I have the same question. On a RPi I want to limit the amount of data written to the memory card as much as possible, but I do need some of the log data for debugging purposes, so i can not switch off all the debugging. The background noise info does not provide much info (for debugging), so it would help if we could limit or switch off the noise data
Make sense, we will think about it.
Meanwhile you can go in automation/modules/ZWave/index.js and disable the timer. Search for background rssi
ibjr
Post by ibjr »
Thanks,
in the mean time I will disable the timer.
