Introducing Z-Way package for Raspbian
Minux
Re: Introducing Z-Way package for Raspbian
Post by Minux »
aLiEnHeAd wrote: ↑
20 Jul 2019 01:17
@Minux: Try cleaning your browser cache.
OK it's working. good news
Thanks !
Ruyske
Post by Ruyske »
Trying to update , but have some package issue.
Failed to fetch https://repo.z-wave.me/z-way/raspbian/d ... /InRelease Unable to find expected entry 'contrib/binary-armhf/Packages' in Release file (Wrong sources.list entry or malformed file)
Tried to change sources , but result null.
Current sources.list is
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb-src http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
Can somebody help?
Those packages are for stretch. If you are on jessie, please update the OS first
Ruyske
Post by Ruyske »
Yep, Upgraded OS to stretch and now it updated corrctly.
Thanks!!
enbemokel
Post by enbemokel »
Hi, updated also from jessie to stretch, then had problems with
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 7E148E3C
Got the error, "no dirmngr found" or equal. I could install the 3.0.0 without the keys.
Z-Way is working so far, just one IFThen rule isnt working.
Will see the next days how stable it is.
Thanks for the good work
enbemokel
Post by enbemokel »
O.K. small update and maybe someone has a hint for me.
All of my IfThen rules aren´t working, also I have some SensorValuesLogging, that won´t report to thingspeak.com anymore since the update.
How can I start seeking?
enbemokel
Post by enbemokel »
Ahh, forgot to mention that the 24 Hours Device history isn´t working also. I can stop the app, then I see the
message in the log, "History removed for device"....but if I start, there is no "History addet to device"
Any ideas or updates for the problem?
Also, should I use the new Scenes, Rules, Schedules, Heating Control, ...... or still the expert menu with the app?
Both should work. When you start to use the new and convert old rules, they will stop in the expert apps (become inactive) and start in Automation/Rules. But if you don't convert, they will continue to work
enbemokel
Post by enbemokel »
O.K. so I can also delete them in the expert menu if they are converted?
And do you have some ideas about my ifthen rules?
enbemokel
Post by enbemokel »
I need some help, can´t add any ifthen, also not in the new menu.
I deleted all in the expert apps and in the new menu. Then build up new ones in the new menu. No way to get one working.
What can I check to get it work?
