Good day,
After a year of almost excellent work I decided to update my Razberry and Danalock to last firmwares. Right now I have Z-way server 3.0.0 and Danalock v3 with 0.11.0 firmware. Each time when I try to connect my lock to razberry it fails (secure connection - fails on 38%, unsecure - 25%).
Hope, someone can help me)
Logs attached.
Danalock v3 failed to connect
- z-way-server.log.zip
- (100.44 KiB) Downloaded 1102 times
Re: Danalock v3 failed to connect
@giwwi seems to have pretty much the same issue that I have, with pretty much the same setup (Z-way-server 3.0.0, Danalock v3 with FW 0.11).
The difference is that I do not have HomeAssistant installed on my RaZberry Pi (only Raspbian Stretch). Several Danalocks worked with the previous version of z-way-server without an issue.
Could it be that the new z-way release 3.0.0 created some incompatibility with Danalock?
I also attach my z-way-server.log file to see the similarities.
Hope that someone can help us.
- (8 KiB) Downloaded 1118 times
Some problem here with Firmware 0.11.0. (Interview ends at 38%)
But with an older Version of the Firmware (sorry don't know the exact rev) the inclusion and interview was successful (with Z-Way 3.0.0). Therefore I think it is a problem with the Firmware.
I already contacted Danalock but i didn't get an answer so far. Please could you also contact Danalock and ask for a solution?
We can confirm that newer Danalock firmware do not answer on some commands. This is a Danalock issue and Danalock is working on it. We suggest to write them on support to force them solve it faster.
Thx for the info PoltoS!
Does anyone have a link to an older firmware of the danalaock?
FYI: Danalock has released a new firmware (0.11.9) which solves that problem.
Glad to know! Thanks for the info
I have a Danalock v3 and a inclusion problem with zway v3.0.0 and v3.0.2 and firmware 0.11.9 Raspbian Stretch:
The interview stop at 0% or 29%.
It is a fresh zway installation.
Regards.
[2019-12-11 14:43:20.049] [I] [zway] Adding job: Add/re-include node to network
[2019-12-11 14:43:20.050] [D] [zway] SENDING (cb 0x61): ( 01 05 00 4A C1 61 10 )
[2019-12-11 14:43:20.051] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:20.060] [D] [zway] RECEIVED: ( 01 07 00 4A 61 01 00 00 D2 )
[2019-12-11 14:43:20.060] [D] [zway] SENT ACK
[2019-12-11 14:43:20.060] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2019-12-11 14:43:20.060] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2019-12-11 14:43:20.061] [I] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2019-12-11 14:43:20.061] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
[2019-12-11 14:43:25.460] [D] [zway] Job 0x3b: deleted from queue
[2019-12-11 14:43:28.867] [D] [zway] RECEIVED: ( 01 10 00 4A 61 02 06 09 04 40 03 5E 98 9F 55 72 8A 7A )
[2019-12-11 14:43:28.867] [D] [zway] SENT ACK
[2019-12-11 14:43:28.867] [I] [zway] Job 0x4a (Add/re-include node to network): Node found: #6
[2019-12-11 14:43:28.868] [D] [zway] SETDATA controller.data.controllerState = 2 (0x00000002)
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.data = Empty
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.instances.0.data = Empty
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.instances.0.data.dynamic = Empty
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.instances.0.data.dynamic = False
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.instances.0.data.genericType = Empty
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.instances.0.data.genericType = 0 (0x00000000)
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.instances.0.data.specificType = Empty
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.instances.0.data.specificType = 0 (0x00000000)
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.instances.0.data.nodeInfoFrame = Empty
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.data.basicType = Empty
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.data.genericType = Empty
[2019-12-11 14:43:28.868] [D] [zway] SETDATA devices.6.data.specificType = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.infoProtocolSpecific = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.deviceTypeString = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.isVirtual = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.isListening = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.isRouting = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.isAwake = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.optional = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.isFailed = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.sensor250 = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.sensor1000 = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.neighbours = Empty
[2019-12-11 14:43:28.869] [D] [zway] SETDATA devices.6.data.manufacturerId = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.vendorString = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.manufacturerProductType = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.manufacturerProductId = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.ZWLib = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.ZWProtocolMajor = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.ZWProtocolMinor = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.SDK = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.applicationMajor = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.applicationMinor = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.nodeInfoFrame = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.fullNodeInfoFrame = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.ZDDXMLFile = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.lastSend = Empty
[2019-12-11 14:43:28.870] [D] [zway] SETDATA devices.6.data.lastSendInternal = Empty
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.lastNonceGet = Empty
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.lastReceived = Empty
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.failureCount = Empty
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.keepAwake = Empty
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.queueLength = Empty
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.givenName = Empty
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.interviewDone = Empty
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.basicType = 0 (0x00000000)
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.genericType = 0 (0x00000000)
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.specificType = 0 (0x00000000)
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.infoProtocolSpecific = 0 (0x00000000)
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.deviceTypeString = ""
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.isVirtual = False
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.isListening = True
[2019-12-11 14:43:28.871] [D] [zway] SETDATA devices.6.data.isRouting = False
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.isAwake = False
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.optional = False
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.isFailed = False
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.sensor250 = False
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.sensor1000 = False
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.neighbours = Empty
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.manufacturerId = 0 (0x00000000)
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.manufacturerProductType = 0 (0x00000000)
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.manufacturerProductId = 0 (0x00000000)
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.applicationMajor = 0 (0x00000000)
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.applicationMinor = 0 (0x00000000)
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.ZWProtocolMajor = 0 (0x00000000)
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.ZWProtocolMinor = 0 (0x00000000)
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.ZWLib = 0 (0x00000000)
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.SDK = ""
[2019-12-11 14:43:28.872] [D] [zway] SETDATA devices.6.data.vendorString = ""
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.nodeInfoFrame = Empty
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.fullNodeInfoFrame = **********
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.ZDDXMLFile = ""
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.keepAwake = False
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.queueLength = 0 (0x00000000)
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.lastSend = 0 (0x00000000)
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.lastSendInternal = **********
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.failureCount = 0 (0x00000000)
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.givenName = ""
[2019-12-11 14:43:28.873] [D] [zway] SETDATA devices.6.data.interviewDone = False
[2019-12-11 14:43:28.873] [I] [zway] Adding job: Get node protocol information
[2019-12-11 14:43:28.873] [I] [zway] Adding job: Check if node is failed
[2019-12-11 14:43:28.873] [I] [zway] Adding job: Get routing table line
[2019-12-11 14:43:28.874] [I] [zway] Adding job: Get routing table line
[2019-12-11 14:43:28.874] [D] [zway] SETDATA devices.6.data.basicType = 4 (0x00000004)
[2019-12-11 14:43:28.874] [D] [zway] SETDATA devices.6.data.genericType = 64 (0x00000040)
[2019-12-11 14:43:28.874] [D] [zway] SETDATA devices.6.instances.0.data.genericType = 64 (0x00000040)
[2019-12-11 14:43:28.874] [D] [zway] SETDATA devices.6.data.specificType = 3 (0x00000003)
[2019-12-11 14:43:28.874] [D] [zway] SETDATA devices.6.instances.0.data.specificType = 3 (0x00000003)
[2019-12-11 14:43:28.876] [D] [zway] SETDATA devices.6.data.deviceTypeString = "Secure Keypad"
[2019-12-11 14:43:28.876] [D] [zway] SETDATA devices.6.data.nodeInfoFrame = byte[6]
[2019-12-11 14:43:28.876] [D] [zway] ( 5E 98 9F 55 72 8A )
[2019-12-11 14:43:28.876] [D] [zway] SENDING: ( 01 04 00 62 06 9F )
[2019-12-11 14:43:28.880] [W] [zway] Received SOF, while awaiting ACK
[2019-12-11 14:43:28.881] [D] [zway] RECEIVED: ( 01 10 00 4A 61 03 06 09 04 40 03 5E 98 9F 55 72 8A 7B )
[2019-12-11 14:43:28.881] [D] [zway] SENT ACK
[2019-12-11 14:43:28.881] [I] [zway] Job 0x4a (Add/re-include node to network): Adding slave: #6
[2019-12-11 14:43:28.881] [D] [zway] SETDATA controller.data.controllerState = 3 (0x00000003)
[2019-12-11 14:43:28.881] [D] [zway] SETDATA controller.data.lastIncludedDevice = 6 (0x00000006)
[2019-12-11 14:43:28.881] [D] [zway] SETDATA devices.6.data.basicType = 4 (0x00000004)
[2019-12-11 14:43:28.881] [D] [zway] SETDATA devices.6.data.genericType = 64 (0x00000040)
[2019-12-11 14:43:28.881] [D] [zway] SETDATA devices.6.data.specificType = 3 (0x00000003)
[2019-12-11 14:43:28.883] [D] [zway] SETDATA devices.6.data.deviceTypeString = "Secure Keypad"
[2019-12-11 14:43:28.883] [D] [zway] SETDATA devices.6.data.nodeInfoFrame = byte[6]
[2019-12-11 14:43:28.883] [D] [zway] ( 5E 98 9F 55 72 8A )
[2019-12-11 14:43:28.890] [D] [zway] RECEIVED CAN
[2019-12-11 14:43:28.905] [D] [zway] SENDING: ( 01 04 00 62 06 9F )
[2019-12-11 14:43:28.908] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:28.908] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2019-12-11 14:43:28.908] [D] [zway] SENT ACK
[2019-12-11 14:43:28.908] [D] [zway] SETDATA devices.6.data.isFailed = False
[2019-12-11 14:43:28.908] [I] [zway] Job 0x62 (Check if node is failed): Node 6 is operating
[2019-12-11 14:43:28.908] [D] [zway] Job 0x62 (Check if node is failed): success
[2019-12-11 14:43:28.908] [I] [zway] Removing job: Check if node is failed
[2019-12-11 14:43:35.241] [I] [zway] Adding job: Get background noise level
[2019-12-11 14:43:36.590] [D] [zway] RECEIVED: ( 01 07 00 4A 61 05 06 00 D0 )
[2019-12-11 14:43:36.590] [D] [zway] SENT ACK
[2019-12-11 14:43:36.591] [D] [zway] SETDATA controller.data.controllerState = 4 (0x00000004)
[2019-12-11 14:43:36.591] [I] [zway] Job 0x4a (Add/re-include node to network): Protocol done
[2019-12-11 14:43:36.591] [D] [zway] SETDATA controller.data.lastIncludedDevice = 6 (0x00000006)
[2019-12-11 14:43:36.591] [I] [zway] Loading Command Classes for device 6
[2019-12-11 14:43:36.591] [I] [zway] Node 6:0 supports CC Basic
[2019-12-11 14:43:36.591] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data = Empty
[2019-12-11 14:43:36.591] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.supported = Empty
[2019-12-11 14:43:36.591] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.supported = True
[2019-12-11 14:43:36.591] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.version = Empty
[2019-12-11 14:43:36.591] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2019-12-11 14:43:36.591] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.security = Empty
[2019-12-11 14:43:36.591] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.security = False
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.interviewDone = Empty
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.interviewCounter = Empty
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.interviewDone = False
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.32.data.level = Empty
[2019-12-11 14:43:36.592] [I] [zway] Node 6:0 supports CC TransportService
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data = Empty
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.supported = Empty
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.supported = True
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.version = Empty
[2019-12-11 14:43:36.592] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.version = 1 (0x00000001)
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.security = Empty
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.security = False
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.interviewDone = Empty
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.interviewCounter = Empty
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.interviewDone = False
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.interviewCounter = 10 (0x0000000a)
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.datagram = Empty
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.offsets = Empty
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.sessionId = Empty
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.85.data.timerReason = Empty
[2019-12-11 14:43:36.593] [I] [zway] Node 6:0 supports CC ZWavePlusInfo
[2019-12-11 14:43:36.593] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data = Empty
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.supported = Empty
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.supported = True
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.version = Empty
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.version = 1 (0x00000001)
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.security = Empty
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.security = False
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.interviewDone = Empty
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.interviewCounter = Empty
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.interviewDone = False
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.interviewCounter = 10 (0x0000000a)
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.plusVersion = Empty
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.roleType = Empty
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.nodeType = Empty
[2019-12-11 14:43:36.594] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.installerIcon = Empty
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.userIcon = Empty
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.94.data.roleTypeString = Empty
[2019-12-11 14:43:36.595] [I] [zway] Node 6:0 supports CC ManufacturerSpecific
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data = Empty
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.supported = Empty
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.supported = True
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.version = Empty
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.security = Empty
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.security = False
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.interviewDone = Empty
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.interviewCounter = Empty
[2019-12-11 14:43:36.595] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.interviewDone = False
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.interviewCounter = 10 (0x0000000a)
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.vendorId = Empty
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.vendor = Empty
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.productId = Empty
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.productType = Empty
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.serialNumber = Empty
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.pseudoRandom = Empty
[2019-12-11 14:43:36.596] [I] [zway] Node 6:0 supports CC Time
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data = Empty
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.supported = Empty
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.supported = True
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.version = Empty
[2019-12-11 14:43:36.596] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.version = 1 (0x00000001)
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.security = Empty
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.security = False
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.interviewDone = Empty
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.interviewCounter = Empty
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.interviewDone = False
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.138.data.interviewCounter = 10 (0x0000000a)
[2019-12-11 14:43:36.597] [I] [zway] Node 6:0 supports CC Security
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data = Empty
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.supported = Empty
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.supported = True
[2019-12-11 14:43:36.597] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.version = Empty
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.version = 1 (0x00000001)
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.security = Empty
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.security = False
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.interviewDone = Empty
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.interviewCounter = Empty
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.interviewDone = False
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.interviewCounter = 10 (0x0000000a)
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.scheme = Empty
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.scheme = 0 (0x00000000)
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.data.secureChannelEstablished = Empty
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.data.secureChannelEstablished = False
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.secureNodeInfoFrame = Empty
[2019-12-11 14:43:36.598] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.secureNodeInfoFrame = byte[0]
[2019-12-11 14:43:36.598] [D] [zway] ( zero-length buffer )
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.securityRequested = Empty
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.securityAbandoned = Empty
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.securityAbandoned = False
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.rNonce = Empty
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.rNonceAckWait = Empty
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.canStream = Empty
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.canStream = False
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.firstPart = Empty
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.sequenceId = Empty
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.toFollow = Empty
[2019-12-11 14:43:36.599] [I] [zway] Node 6:0 supports CC SecurityS2
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data = Empty
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.supported = Empty
[2019-12-11 14:43:36.599] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.supported = True
[2019-12-11 14:43:36.600] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.version = Empty
[2019-12-11 14:43:36.600] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.version = 1 (0x00000001)
[2019-12-11 14:43:36.600] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.security = Empty
[2019-12-11 14:43:36.600] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.security = False
[2019-12-11 14:43:36.600] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.interviewDone = Empty
[2019-12-11 14:43:36.600] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.interviewCounter = Empty
[2019-12-11 14:43:36.600] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.interviewDone = False
[2019-12-11 14:43:36.600] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.interviewCounter = 10 (0x0000000a)
[2019-12-11 14:43:36.601] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.securityAbandoned = Empty
[2019-12-11 14:43:36.601] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.securityAbandoned = False
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.csa = Empty
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys = Empty
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys = False
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys.S0 = Empty
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys.S0 = False
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys.S2Unauthenticated = Empty
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys.S2Unauthenticated = False
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys.S2Authenticated = Empty
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys.S2Authenticated = False
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys.S2Access = Empty
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.requestedKeys.S2Access = False
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys = Empty
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys = False
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S0 = Empty
[2019-12-11 14:43:36.602] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S0 = False
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Unauthenticated = Empty
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Unauthenticated = False
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Authenticated = Empty
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Authenticated = False
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Access = Empty
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Access = False
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.guessKeys = Empty
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.guessKeys = False
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.data.securityS2ExchangedKeys = Empty
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.data.securityS2ExchangedKeys = 0 (0x00000000)
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.secureNodeInfoFrames = Empty
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.secureNodeInfoFrames.S2Unauthenticated = Empty
[2019-12-11 14:43:36.603] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.secureNodeInfoFrames.S2Unauthenticated = byte[0]
[2019-12-11 14:43:36.603] [D] [zway] ( zero-length buffer )
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.secureNodeInfoFrames.S2Authenticated = Empty
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.secureNodeInfoFrames.S2Authenticated = byte[0]
[2019-12-11 14:43:36.604] [D] [zway] ( zero-length buffer )
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.secureNodeInfoFrames.S2Access = Empty
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.secureNodeInfoFrames.S2Access = byte[0]
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.securityRequested = Empty
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.publicKey = Empty
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.publicKey = byte[0]
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.publicKeyVerified = Empty
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.publicKeyVerified = byte[0]
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.publicKeyAuthenticationRequired = Empty
[2019-12-11 14:43:36.604] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.publicKeyAuthenticationRequired = False
[2019-12-11 14:43:36.605] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.security = False
[2019-12-11 14:43:36.608] [D] [zway] S2 context allocated for device 6
[2019-12-11 14:43:36.608] [I] [zway] Loading remaining controlled Command Classes for device 6
[2019-12-11 14:43:36.608] [I] [zway] Node 6 controls CC Basic
[2019-12-11 14:43:36.608] [D] [zway] SETDATA devices.6.data.isAwake = True
[2019-12-11 14:43:36.608] [D] [zway] SETDATA devices.6.data.lastSendInternal = **********
[2019-12-11 14:43:36.608] [D] [zway] SETDATA devices.6.data.lastNonceGet = 137056 (0x00021760)
[2019-12-11 14:43:36.609] [I] [zway] Interview step 1 (S2)
[2019-12-11 14:43:36.609] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.interviewDone = False
[2019-12-11 14:43:36.609] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.interviewCounter = 9 (0x00000009)
[2019-12-11 14:43:36.609] [I] [zway] Node 6:0 CC SecurityS2 Interview started
[2019-12-11 14:43:36.609] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S0 = False
[2019-12-11 14:43:36.609] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Unauthenticated = False
[2019-12-11 14:43:36.609] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Authenticated = False
[2019-12-11 14:43:36.609] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Access = False
[2019-12-11 14:43:36.609] [D] [zway] SETDATA devices.1.data.privateKey = **********
[2019-12-11 14:43:36.807] [D] [zway] SETDATA devices.1.data.publicKey = byte[32]
[2019-12-11 14:43:36.808] [D] [zway] ( C7 DD 0A 46 F5 57 44 91 3D F8 05 32 2F 34 88 AE C6 9B 5D 59 DB 46 D8 FD 5A 50 52 30 CE D0 72 75 )
[2019-12-11 14:43:36.808] [I] [zway] Security S2 private/public key pair regenerated
[2019-12-11 14:43:36.808] [I] [zway] Adding job: Security S2 KEX Get
[2019-12-11 14:43:36.808] [D] [zway] Security S2 inclusion timer set to 10.000000
[2019-12-11 14:43:36.808] [D] [zway] Running wakeup handler for node 6
[2019-12-11 14:43:36.808] [D] [zway] SETDATA devices.6.data.lastSendInternal = **********
[2019-12-11 14:43:36.808] [I] [zway] Adding job: Add/re-include node to network
[2019-12-11 14:43:36.808] [D] [zway] SENDING (cb 0x61): ( 01 05 00 4A 05 61 D4 )
[2019-12-11 14:43:36.810] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:36.810] [I] [zway] Job 0x4a (Add/re-include node to network): Stop done
[2019-12-11 14:43:36.810] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2019-12-11 14:43:36.810] [I] [zway] Removing job: Add/re-include node to network
[2019-12-11 14:43:36.810] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2019-12-11 14:43:36.871] [D] [zway] RECEIVED: ( 01 07 00 4A 61 06 06 00 D3 )
[2019-12-11 14:43:36.871] [D] [zway] SENT ACK
[2019-12-11 14:43:36.872] [I] [zway] Job 0x4a (Add/re-include node to network): Done
[2019-12-11 14:43:36.872] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2019-12-11 14:43:36.872] [I] [zway] Removing job: Add/re-include node to network
[2019-12-11 14:43:36.872] [I] [zway] Adding job: Add/re-include node to network
[2019-12-11 14:43:36.872] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2019-12-11 14:43:36.872] [D] [zway] SENDING (cb 0x00): ( 01 05 00 4A 05 00 B5 )
[2019-12-11 14:43:36.881] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:36.881] [I] [zway] Job 0x4a (Add/re-include node to network): Stop done
[2019-12-11 14:43:36.881] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2019-12-11 14:43:36.881] [I] [zway] Removing job: Add/re-include node to network
[2019-12-11 14:43:36.881] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2019-12-11 14:43:36.891] [D] [zway] SENDING: ( 01 04 00 41 06 BC )
[2019-12-11 14:43:36.893] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:36.902] [D] [zway] RECEIVED: ( 01 09 01 41 53 DC 01 04 40 03 7F )
[2019-12-11 14:43:36.902] [D] [zway] SENT ACK
[2019-12-11 14:43:36.902] [D] [zway] SETDATA devices.6.data.basicType = 4 (0x00000004)
[2019-12-11 14:43:36.902] [D] [zway] SETDATA devices.6.data.genericType = 64 (0x00000040)
[2019-12-11 14:43:36.902] [D] [zway] SETDATA devices.6.data.specificType = 3 (0x00000003)
[2019-12-11 14:43:36.903] [D] [zway] SETDATA devices.6.data.deviceTypeString = "Secure Keypad"
[2019-12-11 14:43:36.903] [D] [zway] SETDATA devices.6.data.isRouting = True
[2019-12-11 14:43:36.903] [D] [zway] SETDATA devices.6.data.isListening = False
[2019-12-11 14:43:36.903] [D] [zway] SETDATA devices.6.data.optional = True
[2019-12-11 14:43:36.903] [D] [zway] SETDATA devices.6.data.sensor1000 = True
[2019-12-11 14:43:36.903] [D] [zway] SETDATA devices.6.data.sensor250 = False
[2019-12-11 14:43:36.903] [D] [zway] SETDATA devices.6.data.infoProtocolSpecific = 5495809 (0x0053dc01)
[2019-12-11 14:43:36.903] [D] [zway] Job 0x41 (Get node protocol information): success
[2019-12-11 14:43:36.903] [I] [zway] Removing job: Get node protocol information
[2019-12-11 14:43:36.903] [D] [zway] SENDING: ( 01 06 00 80 01 00 00 78 )
[2019-12-11 14:43:36.912] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:36.913] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2019-12-11 14:43:36.913] [D] [zway] SENT ACK
[2019-12-11 14:43:36.913] [D] [zway] SETDATA devices.1.data.neighbours = byte[0]
[2019-12-11 14:43:36.913] [D] [zway] ( zero-length buffer )
[2019-12-11 14:43:36.914] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 1: [ ]
[2019-12-11 14:43:36.914] [D] [zway] Job 0x80 (Get routing table line): success
[2019-12-11 14:43:36.914] [I] [zway] Removing job: Get routing table line
[2019-12-11 14:43:36.914] [D] [zway] SENDING: ( 01 06 00 80 05 00 00 7C )
[2019-12-11 14:43:36.922] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:36.922] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2019-12-11 14:43:36.922] [D] [zway] SENT ACK
[2019-12-11 14:43:36.922] [D] [zway] SETDATA devices.5.data.neighbours = byte[0]
[2019-12-11 14:43:36.922] [D] [zway] ( zero-length buffer )
[2019-12-11 14:43:36.923] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 5: [ ]
[2019-12-11 14:43:36.923] [D] [zway] Job 0x80 (Get routing table line): success
[2019-12-11 14:43:36.923] [I] [zway] Removing job: Get routing table line
[2019-12-11 14:43:36.923] [D] [zway] SENDING: ( 01 06 00 80 06 00 00 7F )
[2019-12-11 14:43:36.932] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:36.932] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2019-12-11 14:43:36.933] [D] [zway] SENT ACK
[2019-12-11 14:43:36.933] [D] [zway] SETDATA devices.6.data.neighbours = byte[0]
[2019-12-11 14:43:36.933] [D] [zway] ( zero-length buffer )
[2019-12-11 14:43:36.933] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 6: [ ]
[2019-12-11 14:43:36.933] [D] [zway] Job 0x80 (Get routing table line): success
[2019-12-11 14:43:36.933] [I] [zway] Removing job: Get routing table line
[2019-12-11 14:43:36.933] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2019-12-11 14:43:36.943] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:36.943] [D] [zway] RECEIVED: ( 01 05 01 3B B5 AE DB )
[2019-12-11 14:43:36.944] [D] [zway] SENT ACK
[2019-12-11 14:43:36.944] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 181 (0x000000b5)
[2019-12-11 14:43:36.944] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 174 (0x000000ae)
[2019-12-11 14:43:36.944] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 127 (0x0000007f)
[2019-12-11 14:43:36.944] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -82 dBm, Ch#2: -82 dBm, Ch#3: invalid
[2019-12-11 14:43:36.944] [D] [zway] Job 0x3b (Get background noise level): success
[2019-12-11 14:43:36.944] [I] [zway] Removing job: Get background noise level
[2019-12-11 14:43:37.656] [D] [zway] SENDING (cb 0x62): ( 01 09 00 13 06 02 9F 04 25 62 3D )
[2019-12-11 14:43:37.658] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:37.664] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-12-11 14:43:37.664] [D] [zway] SENT ACK
[2019-12-11 14:43:37.664] [D] [zway] Delivered to Z-Wave stack
[2019-12-11 14:43:41.143] [D] [zway] RECEIVED: ( 01 18 00 13 62 01 01 5C 00 7F 7F 7F 7F 7F 00 01 06 00 00 00 00 42 03 00 00 F3 )
[2019-12-11 14:43:41.143] [D] [zway] SENT ACK
[2019-12-11 14:43:41.143] [I] [zway] Job 0x13 (Security S2 KEX Get): Not delivered to recipient
[2019-12-11 14:43:41.144] [D] [zway] SENDING (cb 0x63): ( 01 09 00 13 06 02 9F 04 25 63 3C )
[2019-12-11 14:43:41.153] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:41.153] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-12-11 14:43:41.153] [D] [zway] SENT ACK
[2019-12-11 14:43:41.154] [D] [zway] Delivered to Z-Wave stack
[2019-12-11 14:43:44.600] [D] [zway] RECEIVED: ( 01 18 00 13 63 01 01 59 00 7F 7F 7F 7F 7F 00 01 06 00 00 00 00 42 03 00 00 F7 )
[2019-12-11 14:43:44.601] [D] [zway] SENT ACK
[2019-12-11 14:43:44.601] [I] [zway] Job 0x13 (Security S2 KEX Get): Not delivered to recipient
[2019-12-11 14:43:44.601] [D] [zway] SENDING (cb 0x64): ( 01 09 00 13 06 02 9F 04 25 64 3B )
[2019-12-11 14:43:44.610] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:44.610] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-12-11 14:43:44.610] [D] [zway] SENT ACK
[2019-12-11 14:43:44.610] [D] [zway] Delivered to Z-Wave stack
[2019-12-11 14:43:47.150] [D] [zway] Security S2 inclusion timeout event
[2019-12-11 14:43:47.153] [W] [zway] Node 6:0 CC SecurityS2: Security S2 key negociation with node 6 failed, KEX fail reason: Unknown Security S2 KEX failure reason (0)
[2019-12-11 14:43:47.153] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.securityAbandoned = True
[2019-12-11 14:43:47.154] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S0 = False
[2019-12-11 14:43:47.154] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Unauthenticated = False
[2019-12-11 14:43:47.154] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Authenticated = False
[2019-12-11 14:43:47.154] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys.S2Access = False
[2019-12-11 14:43:47.154] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.grantedKeys = False
[2019-12-11 14:43:47.154] [D] [zway] SETDATA devices.6.instances.0.commandClasses.159.data.interviewCounter = 0 (0x00000000)
[2019-12-11 14:43:47.154] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.securityAbandoned = True
[2019-12-11 14:43:47.154] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.interviewCounter = 0 (0x00000000)
[2019-12-11 14:43:47.154] [I] [zway] Saving configuration data to config/zddx/55555555-DevicesData.xml
[2019-12-11 14:43:47.319] [I] [zway] Interview step 2 skipped due to absence of Version CC
[2019-12-11 14:43:47.319] [D] [zway] SETDATA devices.6.data.SDK = "N/A"
[2019-12-11 14:43:47.319] [I] [zway] Interview step 3
[2019-12-11 14:43:47.319] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.interviewDone = False
[2019-12-11 14:43:47.319] [D] [zway] SETDATA devices.6.instances.0.commandClasses.114.data.interviewCounter = 9 (0x00000009)
[2019-12-11 14:43:47.319] [I] [zway] Node 6:0 CC ManufacturerSpecific Interview started
[2019-12-11 14:43:47.319] [I] [zway] Adding job: ManufacturerSpecific Get
[2019-12-11 14:43:47.319] [W] [zway] Security S0/S2 bootstrap failed
[2019-12-11 14:43:47.319] [D] [zway] Own inclusion - nothing to report to inclusion controller
[2019-12-11 14:43:48.011] [D] [zway] RECEIVED: ( 01 18 00 13 64 01 01 54 00 7F 7F 7F 7F 7F 00 01 06 00 00 00 00 42 03 00 00 FD )
[2019-12-11 14:43:48.012] [D] [zway] SENT ACK
[2019-12-11 14:43:48.012] [I] [zway] Job 0x13 (Security S2 KEX Get): Not delivered to recipient
[2019-12-11 14:43:48.012] [I] [zway] Job 0x13 (Security S2 KEX Get): Removing job due to too much retransmitions
[2019-12-11 14:43:48.012] [I] [zway] Adding job: Check if node is failed
[2019-12-11 14:43:48.012] [D] [zway] Job 0x13 (Security S2 KEX Get): fail
[2019-12-11 14:43:48.012] [I] [zway] Removing job: Security S2 KEX Get
[2019-12-11 14:43:48.012] [D] [zway] SENDING: ( 01 04 00 62 06 9F )
[2019-12-11 14:43:48.022] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:48.022] [D] [zway] RECEIVED: ( 01 04 01 62 01 99 )
[2019-12-11 14:43:48.022] [D] [zway] SENT ACK
[2019-12-11 14:43:48.022] [D] [zway] SETDATA devices.6.data.isFailed = True
[2019-12-11 14:43:48.023] [I] [zway] Job 0x62 (Check if node is failed): Node 6 is failed
[2019-12-11 14:43:48.023] [D] [zway] Job 0x62 (Check if node is failed): success
[2019-12-11 14:43:48.023] [D] [zway] SETDATA devices.6.data.failureCount = 1 (0x00000001)
[2019-12-11 14:43:48.023] [D] [zway] SETDATA devices.6.data.lastSendInternal = **********
[2019-12-11 14:43:48.023] [I] [zway] Removing job: Check if node is failed
[2019-12-11 14:43:49.449] [D] [zway] Job 0x62: deleted from queue
[2019-12-11 14:43:51.120] [D] [zway] SENDING (cb 0x65): ( 01 09 00 13 06 02 72 04 05 65 F7 )
[2019-12-11 14:43:51.122] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:51.128] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-12-11 14:43:51.128] [D] [zway] SENT ACK
[2019-12-11 14:43:51.128] [D] [zway] Delivered to Z-Wave stack
[2019-12-11 14:43:54.592] [D] [zway] RECEIVED: ( 01 18 00 13 65 01 01 5A 00 7F 7F 7F 7F 7F 00 01 06 00 00 00 00 42 03 00 00 F2 )
[2019-12-11 14:43:54.592] [D] [zway] SENT ACK
[2019-12-11 14:43:54.592] [I] [zway] Job 0x13 (ManufacturerSpecific Get): Not delivered to recipient
[2019-12-11 14:43:54.593] [D] [zway] SENDING (cb 0x66): ( 01 09 00 13 06 02 72 04 05 66 F4 )
[2019-12-11 14:43:54.606] [D] [zway] RECEIVED ACK
[2019-12-11 14:43:54.608] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-12-11 14:43:54.608] [D] [zway] SENT ACK
[2019-12-11 14:43:54.608] [D] [zway] Delivered to Z-Wave stack
[2019-12-11 14:43:57.373] [D] [zway] Job 0x4a: deleted from queue
[2019-12-11 14:43:57.424] [D] [zway] Job 0x4a: deleted from queue
[2019-12-11 14:43:57.434] [D] [zway] Job 0x41: deleted from queue
[2019-12-11 14:43:57.434] [D] [zway] Job 0x80: deleted from queue
[2019-12-11 14:43:57.445] [D] [zway] Job 0x3b: deleted from queue
Regards.
It is a know issue with Danalock. Please do a firmware upgrade via Bluetooth with the mobile app
Yes, I had updated to last firware 0.11.9 and issue continue
