No users in "User management"
tridy
Post by tridy »
Hi.
It seems that I can add new users but cannot manage them. They do not appear in the manage UI:
User_Management _No_Users.png (73.58 KiB) Viewed 34349 times
Firmware version
v2.3.7
UI version
1.8.0-RC-38
Is there a way to fix it?
Thanks!
Krooms
Re: No users in "User management"
Post by Krooms »
Same problem here with 3.1.1
Please provide us remote access to analyse the issue
jarek
Post by jarek »
in one of the previous version I had same issue - I checked configuration file and there were duplicated users saved (same name, same ID) - I removed duplicate and it started working.
tridy wrote:
19 May 2018 15:15
Hi.
Firmware version
v2.3.7
UI version
1.8.0-RC-38
Thanks!
Thanks, we will also check to make sure it is not possible to add user with the same login name
feuersee
Post by feuersee »
the same behavior here...
Software info
Firmware version v3.2.2
UI version v1.13.4
Built date 29-11-2021 15:34:48
Any idea? Thanks!
Stephan
Please halt Z-Way, open configjson-..... file in /opt/z-way-server/automation/storage and make sure to rename users that have the same login and id.
How have you managed to do it? Have you added users recently? We were unable to reproduce this. May be you remember what you did when this happened?
runaas
Post by runaas »
How can I "Please halt Z-Way, open configjson-..... file in /opt/z-way-server/automation/storage"
as I cannot see all users either.
Rune
sudo /etc/init.d/z-way-server stop
