Hi.
Happy user of razberry for a few years.
Wanted to replace a broken HeatIT thermostat with a another brand (Namron)
Interview is spotty, as it has been with all my thermostats, but - this one puts up yet another fight.
I cannot control the thermostat state, nor the temperature from the normal GUI.
All sensors show up properly, but - not the controls themselves.
However - if I Navigate to the Expert UI, and Controls -> Thermostats, I can control it just fine..
Any ideas on how to proceed.
Supplier was less than helpful..
Thermostat issues
Re: Thermostat issues
Hi
@crom_ Did you resolve this issue?
I have the same trouble with the same thermostat.
@PoltoS what log can I send to you for you to assist in this issue ?
Sorry I am a bit noob, and need some instructions.
br Ole
br Ole
@D-Fender z-way-server.log or just provide remote access via find.z-wave.me so our support team check it.
Thanks guys for the responses,
No - I haven't resolved this yet.
I can supply logs if needed. Anything you'd like me to do in the GUI, or grep-patterns, to get the right log entries @PoltoS?
I'd recon my log is full of garbage from several failed attempts adding this thermostat..
Edit: excluded device, and re-included device to make sure all relevant items is included in log. The device is now id18, Log available: https://pastebin.com/pZWwGg7E
Regards
Regards
Please let me know If you’d like the logs resupplied.
Hello, i have the same issue and woundering if someone solved this in some way?
I can controll the thermostat in expert mode, is there a way to use a Python script to at least turn it on/off, or use an Viritual Decice?
BR/
Marcus
BR/
Marcus
Sure, You can use a virtual device (using Code Device) to do anything via the ZWaveAPI layer
Why is this not working?
I have followed the steps from this guide:
https://help.z-wave.me/en/knowledge_bas ... 28/cat/57/
Code for action on:
zway.devices[31].instances[1].commandClasses[64].Set(1); controller.devices.get("DummyDevice_120").performCommand("on")
Code for action off:
zway.devices[31].instances[1].commandClasses[64].Set(0); controller.devices.get("DummyDevice_120").performCommand("off")
Code to get value:
(zway.devices[31].instances[1].commandClasses[64].data.mode.value == 0 && controller.devices.get("DummyDevice_120").get("metrics:level") == "on") ? 'on' : 'off'
BR/
Marcus
Code for action on:
Code to get value:
BR/
Marcus
- ZW1.jpg (343.83 KiB) Viewed 13931 times
Am I right that you are configuring device DummyDevice_120?
Do it that way:
Code for action on:
Code to get value:
zway.devices[31].instances[1].commandClasses[64].data.mode.value == 0 ? 'on' : 'off'
Do it that way:
Code for action on:
Code to get value:
