Where to get the firmware
Skamkell
Post by Skamkell »
i set up my raspberry with z-way and would like to update my Razberry 7. But in the update window i have to provide a fimware file, i searched on the webpage of zwave.me but there is only a list of the firmware up to 7.28, but no way to download. Could somebody provide me a link to the firmware.
Thank you
Re: Where to get the firmware
Hello! Z-Way should show firmwares once we make them visible. 7.21 and 7.28 are currently under our internal tests. Please wait few more days
thaui
Post by thaui »
Any news on 7.28 FW?
It is available under token "all". It is safe to use it, but we are waiting for the next version to make the release as we found few minor issues to fix.
thaui
Post by thaui »
@PoltoS
Thanks for the reply. Let us know when it's published
lanbrown
Post by lanbrown »
I've been running the 7.28 firmware for the past few days. I started off on just one of the five systems I have and then did the other four yesterday. I really haven't found much wrong with it.
cesarvog
Post by cesarvog »
PoltoS wrote:
05 Aug 2022 03:27
I'm sorry if this is a stupid question, but I could not find the all token anywhere on the device firmware list page at https://z-wave.me/support/uzbrazberry-firmwares/.
So, my question is: Where **exactly** can I find a link to the "7.28 / 07.17.02.01 SDK 7.17.02" firmware, which is supposed to fix the network stability bug in SiLabs SDK, to be used in my Razberry 7 Pro?
Thanks in advance.
Cesar
lanbrown
Post by lanbrown »
The is because the "all" for a token is entered into the expert UI in Z-Way under the firmware update. It is not being entered into the z-wave.me site.
cesarvog
Post by cesarvog »
Thanks, @Ianbrown !
I would never figure this one out myself without your help...
God bless.
Cesar
cesarvog
Post by cesarvog »
I don't know what happened, but... It seems something may have gone wrong when trying to update to 7.26 SDK 7.17.01...
Let me explain what happened:
When I first filled the text box with "all" and pressed go, there was only one firmware available, which was 7.21. From this point, I was able to update to 7.21, without any problem. I waited until the page reloaded, went back to the Controller Info and was happy that it showed my board was now on 7.21.
I went back to the firmware update page, filled the token text box again with "all", and noticed there were still two firmwares available (7.21 to 7.26 SDK 7.17.01 and 7.26 to 7.28 SDK 7.17.02).
So I started the update to 7.26 SDK 7.17.01. It started as expected. I then left it running on a browser tab and moved on to another tab to write the above post.That's all I did, I did not close the browser window, or reloaded it in any way. I just changed the active browser tab.
I'm afraid moving into a different tab may have gotten me into trouble, and I now regret not having waited without doing so, as when I went back to the tab where the firmware was being updated, around 2 or 3 minutes later, it seemed that the firmware update was finished.
Then, I tried filling the token text box with "all" again, as I still wanted to go from 7.26 SDK 7.17.01 to 7.28 SDK 7.17.02, but the newer version doesn't show anymore, even after filling out the token text box and pressing the GO button... The image below shows what I get after I type all and press GO:
Screen Shot 2022-08-12 at 09.34.21.png (46.64 KiB) Viewed 13561 times
The controller info page now shows:
Screen Shot 2022-08-12 at 09.12.53.png (11.65 KiB) Viewed 13563 times
I have already tried waiting for around 10 minutes, then I tried rebooting the Pi, and when it came back online, nothing changed from the above.
My z-wave network still works, but I'm afraid I may have gotten my razberry 7 pro into an unpredicted state (7.26 SDK 7.17.00, instead of 7.17.01) and will need some help from support to put it back into an expected state.
Can someone with better knowledge help me in fixing this?
Thanks in advance.
Cesar
