Where to get the firmware
Re: Where to get the firmware
What is your current issue? The firmware looks ok
herbert-f
Post by herbert-f »
I can't access and no Nodes available ...
Role in Network
Node Id:
Home Id:
Primary Role:	No
Primary Capability:	No
SUC/SIS in network:
Hardware
Vendor:
Vendors Product ID:	/
Z-Wave Chip:
Firmware
Library Type:
SDK Version:
Serial API Version:
Capabillities:
UUID:
Subvendor:
Nodes limit:
Controller Static API
Allow max RF power
Backup/Restore
Battery save on sleeping
Advanced network diagnostics
Z-Wave Long Range
Fast communications
Change vendor ID
Promiscuous mode (Zniffer)
Full Zniffer
RF jamming detection
Capabillities:
Software Information
Version number:
Compile-ID:
Compile-Date:
UI
UI version	v1.5.9
Built date	02-04-2022 00:10:16
lanbrown
Post by lanbrown »
Z-Way doesn't see the Razberry 7 board; hence why the fields are blank. Have you tried shutting down the Raspberry Pi, unplugging it for 10 seconds and plugging it back in to perform a hard reset?
herbert-f
Post by herbert-f »
Yes. also more than 300 seconds
Please show the log. What have you done last? Were you able to check the firmware version after the last upgrade?
herbert-f
Post by herbert-f »
Hi Polto,
I bought yesterday a new Razberry 7 Pro - it works.
To repair my defect Razberry - I think - I must flash correct bin files for the bootloader and the firmware. The glb-File show this error:
Error 0 Hex file contains invalid record at line 1 while loading the bootloader
file:Razberry07.17.01.02.glb
Please send me bin-Files for the bootloader and the firmware - I try to flash with:
./ZMESerialUpdater serialapi_uzbupdate -b bootloader.bin -f firmware.bin -d /dev/ttyAMA0
Please don't do that, but use Z-Way UI to get updates instead.
Go in Expert UI > Network > Controller Info > Firmware Upgrade
herbert-f
Post by herbert-f »
This is not impossible - the board was not found !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
herbert-f
Post by herbert-f »
herbert-f wrote:
19 Aug 2022 15:31
Role in Network
Node Id:
Home Id:
Primary Role:	No
SUC/SIS in network:
Hardware
Vendor:
Z-Wave Chip:
Firmware
Library Type:
SDK Version:
Serial API Version:
Capabillities:
UUID:
Subvendor:
Nodes limit:
Allow max RF power
Backup/Restore
Z-Wave Long Range
Fast communications
Change vendor ID
Full Zniffer
Capabillities:
Version number:
Compile-ID:
Compile-Date:
UI
UI version	v1.5.9
So, ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyAMA0 does not see the board neither after the upgrade?
