Where to get the firmware
Re: Where to get the firmware
What is your current issue? The firmware looks ok
I can't access and no Nodes available ...
Role in Network
Node Id:
Home Id:
Primary Role: No
Primary Capability: No
SUC/SIS in network:
Hardware
Vendor:
Vendors Product ID: /
Z-Wave Chip:
Firmware
Library Type:
SDK Version:
Serial API Version:
Capabillities:
UUID:
Subvendor:
Nodes limit:
Controller Static API
Allow max RF power
Backup/Restore
Battery save on sleeping
Advanced network diagnostics
Z-Wave Long Range
Fast communications
Change vendor ID
Promiscuous mode (Zniffer)
Full Zniffer
RF jamming detection
Capabillities:
Software Information
Version number:
Compile-ID:
Compile-Date:
UI
UI version v1.5.9
Built date 02-04-2022 00:10:16Re: Where to get the firmware
Z-Way doesn't see the Razberry 7 board; hence why the fields are blank. Have you tried shutting down the Raspberry Pi, unplugging it for 10 seconds and plugging it back in to perform a hard reset?
Yes. also more than 300 seconds
Please show the log. What have you done last? Were you able to check the firmware version after the last upgrade?
Hi Polto,
I bought yesterday a new Razberry 7 Pro - it works.
To repair my defect Razberry - I think - I must flash correct bin files for the bootloader and the firmware. The glb-File show this error:
Please send me bin-Files for the bootloader and the firmware - I try to flash with:Error 0 Hex file contains invalid record at line 1 while loading the bootloader
file:Razberry07.17.01.02.glb
./ZMESerialUpdater serialapi_uzbupdate -b bootloader.bin -f firmware.bin -d /dev/ttyAMA0Re: Where to get the firmware
Please don't do that, but use Z-Way UI to get updates instead.
Go in Expert UI > Network > Controller Info > Firmware Upgrade
This is not impossible - the board was not found !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
herbert-f wrote: ↑19 Aug 2022 15:31I can't access and no Nodes available ...
Role in Network Node Id: Home Id: Primary Role: No Primary Capability: No SUC/SIS in network: Hardware Vendor: Vendors Product ID: / Z-Wave Chip: Firmware Library Type: SDK Version: Serial API Version: Capabillities: UUID: Subvendor: Nodes limit: Controller Static API Allow max RF power Backup/Restore Battery save on sleeping Advanced network diagnostics Z-Wave Long Range Fast communications Change vendor ID Promiscuous mode (Zniffer) Full Zniffer RF jamming detection Capabillities: Software Information Version number: Compile-ID: Compile-Date: UI UI version v1.5.9 Built date 02-04-2022 00:10:16
So, ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyAMA0 does not see the board neither after the upgrade?
