root@raspberrypi:/home/pi# root@raspberrypi:/home/pi# ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyAMA0
Z-WAVE Serial API Tool
Version:LWE0.9
by Z-WAVE>ME
Device ready in:1.08714699745 seconds
FULL INFO
Openning port .............................. OK
SERIAL INFO
VERSION: 07 1C VENDOR: 01 47
ZME_CAPABILITIES
UID: 82 CE 2D 6D 56 4C F7 65 8C 07 B2 61 13 A0 D6 00
VENDOR: 1D DD NODES: 83
FLAGS:
B6 0E 07 6B 54 17 E5 F1 43 88 4C 1E 7E 6F 44 1C 0E 07 D8 90 FB 1C EB 79 3A 03 73 F2 CF 6B FE 19
75 7C 4B B2 11 26 7E 3C CE C4 49 5C
FIRMWARE CRC
BOOT: FF FF FW: FF FF
MISC
FREQ: EU
NVR Content
Prog/erase lock : FF FF FF FF FF FF FF FF, Read back lock: FF
Rev FF, Cal FF, TXCal FF FF, SAW FF FF FF FF, Pin FF, CRC FF FF
NMV: CS FF, TYPE FF, SIZE FF FF, PSIZE FF FF (EEPROM Unknown)
USB: VID FF FF, PID FF FF, UUID FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FACTORY ID: WEEK 255, YEAR 255, CHIP FF FF, SER FF FF, WS 255, HWREV: FF FF, CRC8 FF
elapsed 1.40290999413 seconds
Controller Info
The inspect queue will open a second window to allow monitoring the commands sent out by this controller.
Role in Network
Node Id:
Home Id:
Primary Role: No
Primary Capability: No
SUC/SIS in network:
Hardware
Vendor:
Vendors Product ID: /
Z-Wave Chip:
Firmware
Library Type:
SDK Version:
Serial API Version:
Capabillities:
UUID:
Subvendor:
Nodes limit:
Controller Static API
Allow max RF power
Backup/Restore
Battery save on sleeping
Advanced network diagnostics
Z-Wave Long Range
Fast communications
Change vendor ID
Promiscuous mode (Zniffer)
Full Zniffer
RF jamming detection
Capabillities:
Software Information
Version number:
Compile-ID:
Compile-Date:
UI
UI version v1.5.9
Built date 02-04-2022 00:10:16
Functions:SmartHome UI - Notification
The following notification appeared in Your Z-Way System:
Cannot start Z-Wave binding: Error: Bad data - communication failed
Best Regards
Z-Wave.Me
