McoHome MH-S411 - Interview failure
topcatsss
Post by topcatsss »
Razberry Gen 2
Vendor: RaZberry by Z-Wave.Me
Vendors Product ID: 1024 / 2
Z-Wave Chip: ZW0500
SDK Version: 6.82.01
Serial API Version: 05.39
Firmware version v3.2.3
UI version v1.13.5
Device:
McoHome Technology Co., Ltd
MCO MH-S411
Application version 5.11
SDK version 6.61.01
I have tried repeated re-interview and it always stops at 92%
Fails on:
0 AssociationGroupInformation
1 AssociationGroupInformation
Any ideas?
Re: McoHome MH-S411 - Interview failure
Need logs, but this is one of the heaviest CCs. It uses too many commands... Or maybe it is a device bug. Logs will tell more
topcatsss
Post by topcatsss »
@PoltoS Okay may sound daft, which log file will tell more, as there are a number
/var/log/z-way-server.log
From the moment you included it till the end of the interview
topcatsss
Post by topcatsss »
Cleared down the item.
and re added.
Slightly different result, but still stuck at 96%
Screenshot 2022-11-07 123335.jpg (246.28 KiB) Viewed 12611 times
Screenshot 2022-11-07 123409.jpg (227.93 KiB) Viewed 12611 times
Screenshot 2022-11-07 123432.jpg (128.37 KiB) Viewed 12611 times
dev 46 add.zip
inclusion log file
(31.26 KiB) Downloaded 566 times
topcatsss
Post by topcatsss »
It has also associated with other devices, that i have not selected??
Screenshot 2022-11-07 123924.jpg (257.79 KiB) Viewed 12611 times
Looks like a missing reply from the device. Might be RF problem or the device is busy and forgets to answer. Anyway, this is not critical. Either Force interview of just mark it as done via the API.
