I have one device that is unplugged, but it still shows up as active and its time get updated.
Node 66 has been unplugged atleast 12hrs
See attached image and logs at:
https://www.dropbox.com/s/90m3ibml76ftc ... 2Clog?dl=0
Unplugged device still reporting data
- Screenshot 2022-12-09 at 13-42-50 Z-Wave Expert UI.png (11.3 KiB) Viewed 1848 times
Re: Unplugged device still reporting data
hm.. The log tells that the last delivered command to the devices was at 2022-12-09 13:33:37.51. So, it is not unplugged!
Node 65, 66 and 71 are from same manufacturer and they had some issues initially to get included with S2. It took a few retries with include and exclusion before they got working.
They are sometimes losing contact and takes a few retries to toggle the switch.
Is there anything else you can find in the log?
Node 61 has often S2 messages getting not received.
My bad. Node 66 was indeed plugged in. It is the 65 node i have unplugged. But that device still haven't went to faulted.
