hubert
Post by hubert »
z-way-4.1.1_armhf.deb seems to have fixed the queue problem for me, uptime 3 1/2 days and counting, thank you @PoltoS and team.
Stable with this Homebridge plugin for Apple Home integration https://github.com/jmichas/homebridge-zway-plugin
feuersee
Post by feuersee »
Hello again,
for me "Notifications by E-mail" caused high load (increasing over several days).
I'm still wondering about several not existing devices under expert view, analytics, signal strength. For example there are shown battery values of 60% every minute (see also case #806598).
Screenshot 2023-08-26 163745.gif (42.44 KiB) Viewed 116599 times
feuersee
Post by feuersee »
60% events caused by battery polling app - removed app.
johanneslarsson
Post by johanneslarsson »
Installed v4.1.2-wb1 through apt-get install, unsure what this release contain
hubert
Post by hubert »
johanneslarsson wrote: ↑
05 Sep 2023 19:04
The latest version in https://repo.z-wave.me/z-way/raspbian is still 4.1.1 and I don't see any announcement of 4.1.2, maybe this was pulled?
lanbrown
Post by lanbrown »
It is a release candidate, not a production release.
toeb
Post by toeb »
This is still happening on my setup. I did update to v4.1.2-wb1 yesterday, firmware was already on 7.38. This morning my job queue again contained > 650 Items and all my blinds stayed closed :(
Calling "Reset API" made stuff work again... but still, this is a nasty issue and needs to get resolved.
DesT
Post by DesT »
@PoltoS,
Any news about the queue problem? I'm with 4.1.3 and still having to reset almost everyday 'cause the queue is around 500-600
lanbrown
Post by lanbrown »
@DesT
What firmware version are you running on the Razberry? I have seen two manifestations of the queue issue but the cause was not the same. The first was running older firmware on the Razberry 7. The second was I never had an issue on one system until I went from 4.1.3 (standalone) to 4.1.0 (HA Docker add-on). So when the beta was released for the Docker I put it first on a Dev system and then a day later on the one system that had this issue. Four other systems running the 4.1.0 Docker have never had the queue bug.
My Razberry 7 Pro's are running this:
SDK Version:	7.20.00
Serial API Version:	07.40
DesT
Post by DesT »
@lanbrown
