Fibaro wallplug, Distance?
sonnyboy
Log
Post by sonnyboy »
Could somone please tell me how to turn on debug.
i have a lofile now but without debug on.
Where would i send the log file?
We have serius problems with classes that the wallplug dont have.
Z-way version: v1.4-rc1
You need to set 0 in config
You need to set 0 in config.xml in log-level tag.
sonnyboy
My config.xml look like this
Post by sonnyboy »
My config.xml look like this,
should i insert a log level tag?
"0"
/dev/ttyAMA0
8083
./htdocs
automation/main.js
sync
sync
sonnyboy
A picture of one of my wallplug i the rz ui
Post by sonnyboy »
I do notice that both
I do notice that both sonnyboy and Macke get warning Device xx Not placed in a zone
Did you place your devices in a zone? It should not matter, but what happens if you do place the device in a zone?
Pieter
sonnyboy
I have my devices in Zone
Post by sonnyboy »
I have my devices in zones now, but that dindt matter, i still got the strange values, i did a force interwie for a couple of hours ago and the values were correct for about 30 minutes, now ther is 3 lines with :0
I really feel sortry for you
I really feel sortry for you with this long struggle!
As I mentioned before my device is working fine. Just for the comparison, this is my configuration as I read it from the expert commands:
devices.12.instances.0.commandClasses.112.data: None (Saturday, 8 June 15:27)
1: None (Saturday, 8 June 15:27)
val: 1 (Saturday, 8 June 15:27)
size: 1 (Saturday, 8 June 15:27)
16: None (Saturday, 8 June 15:27)
34: None (Saturday, 8 June 15:28)
val: 63 (Saturday, 8 June 15:28)
size: 1 (Saturday, 8 June 15:28)
36: None (Saturday, 8 June 15:27)
val: None (Saturday, 8 June 15:27)
size: None (Saturday, 8 June 15:27)
39: None (Saturday, 8 June 15:28)
val: 600 (Saturday, 8 June 15:28)
size: 2 (Saturday, 8 June 15:28)
40: None (Saturday, 8 June 15:28)
val: 80 (Saturday, 8 June 15:28)
42: None (Saturday, 8 June 15:28)
val: 15 (Saturday, 8 June 15:28)
43: None (Saturday, 8 June 15:28)
val: 30 (Saturday, 8 June 15:28)
45: None (Saturday, 8 June 15:28)
val: 10 (Saturday, 8 June 15:28)
47: None (Saturday, 8 June 15:28)
val: 3600 (Saturday, 8 June 15:28)
49: None (Saturday, 8 June 15:28)
val: 0 (Saturday, 8 June 15:28)
50: None (Saturday, 8 June 15:28)
val: 300 (Saturday, 8 June 15:28)
51: None (Saturday, 8 June 15:28)
val: 500 (Saturday, 8 June 15:28)
52: None (Saturday, 8 June 15:28)
val: 6 (Saturday, 8 June 15:28)
60: None (Saturday, 8 June 15:28)
val: 25000 (Saturday, 8 June 15:28)
61: None (Saturday, 8 June 15:28)
val: 1 (Saturday, 8 June 15:28)
63: None (Saturday, 8 June 15:28)
70: None (Saturday, 8 June 15:28)
val: 65535 (Saturday, 8 June 15:28)
version: 1 (Saturday, 8 June 15:27)
security: false (Saturday, 8 June 15:27)
interviewDone: true (Saturday, 8 June 15:27)
interviewCounter: 9 (Saturday, 8 June 15:27)
I do not intend to give you false hope, but maybe this shot in the dark sheds some light?
Pieter
sonnyboy
Now i capture it devices.2. and 8 with debug
Post by sonnyboy »
devices.2. has a strange value :0
devices.9. has a strange value :66.9 line 28804 around time 10:52:18
You can get the file at http://gnoffe.se/share/z-way-server.log
This happend Between 10:30 and 11.00
Dear customers, we clearly
Dear customers, we clearly see some problem with SensorMultilevel and Meter. So far we were not able to reproduce the problem in debug mode, but we have seen it.
We hope to fix it this week. We are working hard on this topic!
sonnyboy
That sounds perfect.
Post by sonnyboy »
That would be nice, im tirerd to force re intewiew every night to get rid of the strange values.
