thank you very much, dolpheen!
for implementing your workaround in UI, I found these paths on my controller:
"/opt/z-way-server/htdocs/expert/app/core/controllers/" which contains "controllers.js"
and
"/opt/z-way-server/htdocs/expert/app/views/config/" which contains "assoc.html"
Do i have to rename some of your added files, to replace any existing files, cause I simply put them there, and can´t see new options within UI.
Problem with Associating devices!
Re: Problem with Associating devices!
You should replace existing files. Then in Association dialog(ex. for your wall controller) you should see WallPlug without instances just as id 8 while adding it.
mathias.nestler
Thanks a lot. This fixed my issue with associations too!
