V2.0.2-rc2-beta
Re: V2.0.2-rc2-beta
All v2.0.2 rc's have suddenly disappeared from the server. There are now two new v2.1.1 rc's, and a lot of older v2.0.1 rc's
Plainsane
Re: V2.0.2-rc2-beta
Post by Plainsane »
PoltoS wrote:in rc8 A/C temperature set is changed in SmartHome UI. Now it looks better. Please check
Ok 2 things, first, now things make sense with thermos. Second, the sensor is showing f but using a c to denote celsius.
Using 2.1.1rc2
It would be super cool if the upgrade process moved config/defaults.xml or upgrade it. I keep loosing the fahr settings in there and it takes me a while to figure out what happened and then re interview.
Re: V2.0.2-rc2-beta
Plainsane wrote:It would be super cool if the upgrade process moved config/defaults.xml or upgrade it. I keep loosing the fahr settings in there and it takes me a while to figure out what happened and then re interview.
Created issue 275 on github
Re: V2.0.2-rc2-beta
Indeed. We probably need to update this. But Defaults.xml gets updated from time to time by us, so probably it is important to port settings from old to new. We will think how to do it. Meanwhile please do manually
Plainsane
Re: V2.0.2-rc2-beta
Post by Plainsane »
Using 2.1.1rc2
Ok just kidding...I can only set the heat and Ac between 0-50. This presents a problem for me
Continued in new thread viewtopic.php?f=3422&t=22018&p=58036#p58036
Re: V2.0.2-rc2-beta
Plainsane wrote:Ok just kidding...I can only set the heat and Ac between 0-50. This presents a problem for me
Please do make a new topic for this heat and Ac issue
#Locked thread
New policy is to lock topics if the focus is drifting or problem has been resolved.
Locked
